Radical Audio need some help
josmuck
#1 erstellt: 05. Jul 2005, 16:07
http://www.acr.ch/sh...163.3&aid=519&cf=itc
Hi this is the RA that I bought plus 2 extra kicks. What I need to know is should I use a certin volum for the kicks? if so does anybody know how much. I plan on putting the kicks and a 2 way rearfill right behind the front seats mounted from the roof of my car. I know this is dangerous but I will make a frame out of steel and weld it to the frame of the car. Thanks for any help.
Brian
ls4
#2 erstellt: 05. Jul 2005, 16:14
i know what u mean. i would not put the kicks and a 2-way Rearfill into your selfbuild "rack". The Problem is not the safety but you want to have a nice sound i think. You dont really need a rearfill for good sound. I think it sounds better without a rearfill. The rearfill right behind the seats is too near at your ears so it will sound real bad. the problem with the kciks behind the seats is that you can here where the sound comes from. i think it would be better to build doorbaords for your doors where you can mount 2 speakers. if you really want a rearfill you should mount it behind the backseats or next to the backseats
Bye Ls4
bieritarier
#3 erstellt: 05. Jul 2005, 16:37
I fully aggree with what ls4 said. It isn't only dangerous to mount the speakers at the roof, the result will be blurry sound.
If I were you, I would mount the woofer in the doors, the 10 cm speakers at the instrument panel ant the tweeters at the A-pillar. It will take some testing to find out where the sound is best but it will extremely improve staging.
Regards,
Richie
josmuck
#4 erstellt: 05. Jul 2005, 16:50
How about the volums for the kicks any ideas?
later brian
bartleby005
#5 erstellt: 05. Jul 2005, 18:02
The Kicks can play in the door volume. Kicks have no real volume refrence. So there are spezial Pats that silence the doors. If you use them for the doors you can connect the doorboard volume to the door and it will work!
josmuck
#6 erstellt: 05. Jul 2005, 18:08
hi and thanks for the help. i realley dident want to build the doorboards becouse i am not shure how but i guess i will have to try. by the way you can write back in german i just hate writing it.
later brian
bartleby005
#7 erstellt: 05. Jul 2005, 18:30
OK, but it's kinda fun to write back in english. In case you think of the many mistakes we made, don't care i make the same mistakes in german
So if you are not willing to create them by yourself, there are some brands that offer cartype spezial dobos.
josmuck
#8 erstellt: 06. Jul 2005, 02:00
ya i have checked but they are realley freaking expensive . but what the hell i will try to make some before i spend that much money.
later brian
bieritarier
#9 erstellt: 06. Jul 2005, 09:08
I think it's much easier to build doorboards than to mount the kicks to the roof.
but I'd say it would be better to give the kicks a separate volume to play, and as you build doorboards that's not really more effort..
5-7 liters should be good.
Richie
josmuck
#10 erstellt: 12. Jul 2005, 11:11
hi just wanted to know if i could use a single soundstream 180 and bridg it for each kick.
thanks later brian
Nyromant
#11 erstellt: 12. Jul 2005, 12:36
Wenn die Endstufe nen Tieffpass bietet, der sich bei 250Hz oder höher einstellen lässt, kannst du das machen.
Ansonsten musst die Frequenzen per Headunit oder DSP trennen.
Bandpass heisst das Stichwort.
josmuck
#12 erstellt: 12. Jul 2005, 18:51
hi here is the manuel from soundstream
http://www.soundstream.com/sub/owner_manual/usa2ch.pdf
maybe if somebody can take a look at it and let me know if this will work.
rgds brian
ls4
#13 erstellt: 12. Jul 2005, 19:18
sorry i don't want to read the manual at the moment. you should look for a funtcion named bandpass. ist a combination of lowpass an highpass. if the soundstream amplifier does not support bandpass u need a headunit that has got active crossovers build in. then it will be very easy
Bye Ls4
bieritarier
#14 erstellt: 13. Jul 2005, 09:58
i can't see a subsonic on the USA amp and don't kno if it will work to acivate both, low pass and high pass.. just try..
Richie
Need Help!!!!
KielerJung85 am 09.11.2004  –  Letzte Antwort am 09.11.2004  –  10 Beiträge
Radical Audio
t4ndu am 16.09.2004  –  Letzte Antwort am 04.11.2004  –  8 Beiträge
Radical Audio
Armarillo2 am 31.01.2005  –  Letzte Antwort am 31.01.2005  –  11 Beiträge
radical audio
Drizzt am 13.04.2005  –  Letzte Antwort am 13.04.2005  –  3 Beiträge
RADICAL Audio?
tOyOtA96 am 01.06.2008  –  Letzte Antwort am 03.06.2008  –  12 Beiträge
Radical Audio Hochtöner
Greenslow am 28.05.2004  –  Letzte Antwort am 28.05.2004  –  3 Beiträge
Radical Audio RA16.2RF
TF2008 am 08.05.2005  –  Letzte Antwort am 01.09.2007  –  4 Beiträge
Radical Vs. Audio System
Killerbee am 22.06.2005  –  Letzte Antwort am 27.06.2005  –  10 Beiträge
radical audio ra160.2m
Erkan1967 am 22.04.2006  –  Letzte Antwort am 26.04.2006  –  9 Beiträge
Radical Audio RA28RF
mokombe am 14.08.2006  –  Letzte Antwort am 02.06.2011  –  12 Beiträge
2005
  • Registrierte Mitglieder930.976 ( Heute: 7 )
  • Neuestes MitgliedNoworob
  • Gesamtzahl an Themen1.564.342
  • Gesamtzahl an Beiträgen21.850.775
