| HIFI-FORUM » Car-Hifi » Car-Hifi: Allgemeines » Elektronik » pollin.de | |
pollin.de+A -A |
josmuck
erstellt: 06. Feb 2005, 00:30
hi in pollin are smaller 12v batts with - 12 V/7 Ah - Anschluss 4,8 mm - Maße (LxBxH) 150x64x95 mm. could you use something like this as a cap?? thanks brian |
-Hoschi-
erstellt: 06. Feb 2005, 00:33
Not really...they are too slow.. |
josmuck
erstellt: 06. Feb 2005, 00:36
k thanks i was kinda hoping to get a chep cap do you think i need a cap when i put the 3 hawkers right before the amps?? later brian |
-Hoschi-
erstellt: 06. Feb 2005, 00:40
Hmm I dunno what kind you got there. But imho a cap is always usefull... |
josmuck
erstellt: 06. Feb 2005, 00:48
the hawker 40 that are in pollin right now |
-Hoschi-
erstellt: 06. Feb 2005, 00:52
I meant your Amp....Sorry forget to wrote it down |
josmuck
erstellt: 06. Feb 2005, 00:57
3 AS f2-500 and gawd i cant wait to start getting it put into my car |
-Hoschi-
erstellt: 06. Feb 2005, 01:02
Wow..hmmm 3 Hawkers and a few caps would be better I think.. |
josmuck
erstellt: 06. Feb 2005, 01:06
shit that is what i thought. there goes a nother 150euros laterz and thanks for the info.. brian |
-Hoschi-
erstellt: 06. Feb 2005, 01:11
No problem....would try it with no Caps....maybe it's enough...but it would be better if you have a few caps... |
muni-mula
erstellt: 06. Feb 2005, 10:16
a normal cap in combination with a powerful hifi system like yours wouldn't make any sense. So, take 3 of the sbs40's, parallel connected. I think that's enough power. if it isn't enough, you can add a bat cap later, these are better than ordinary caps. |
josmuck
erstellt: 06. Feb 2005, 12:12
ok thanks for the info i will try it first with the hawkers and if that is not enough i will see about the batcap. thanks and laterz brian |
JPSpecial
erstellt: 06. Feb 2005, 20:10
I would try without the caps too, if the cable´s length between the Hawkers and the amps isn´t that long, there should be no problems with the power supply. [Beitrag von JPSpecial am 06. Feb 2005, 20:11 bearbeitet] |
12v 65ah gel bat josmuck am 26.01.2005 – Letzte Antwort am 27.01.2005 – 6 Beiträge |
CAP josmuck am 19.07.2005 – Letzte Antwort am 19.07.2005 – 5 Beiträge |
Audio System PM/4 josmuck am 12.07.2005 – Letzte Antwort am 12.07.2005 – 4 Beiträge |
3 subs 2 amps you can write back in german no problem josmuck am 22.01.2005 – Letzte Antwort am 29.01.2005 – 21 Beiträge |
italian, seeking info on amp Bender79 am 18.09.2004 – Letzte Antwort am 20.09.2004 – 5 Beiträge |
Anschluss CAP dtgr am 29.08.2004 – Letzte Antwort am 29.08.2004 – 7 Beiträge |
Cap/Zusatzbatterie für AS 160.4 ? Andi989 am 09.05.2011 – Letzte Antwort am 20.05.2011 – 5 Beiträge |
Steg Qmos 105.4 help KAMENi am 26.06.2005 – Letzte Antwort am 28.06.2005 – 9 Beiträge |
Frage zu AS F4/380 lUp am 30.01.2005 – Letzte Antwort am 04.02.2005 – 12 Beiträge |
wieviel mm² korbelo am 04.06.2005 – Letzte Antwort am 05.06.2005 – 8 Beiträge |
2005
- Autoradio anschließen
- Unterschied 2 Ohm / 4 Ohm?
- Kein ILL und ACC
- Kein ILL und ACC
- Gesamtzahl an Beiträgen21.838.798
