| HIFI-FORUM » English » Stereo (Engl.) » Help! | |
Help!+A -A |
mmx_2
erstellt: 27. Dez 2004, 01:31
I have a pair of old Infinity Renassaince 90 speakers that I'm very fond of, the only trouble is that they are a very difficult load (0,9ohm minimum) and my current amp, a Classe Ca-301 doesn't quite seem to do the job. I've been looking for a new amplifier for a while and have stopped at two alternatives, the first is a Pass Labs X-350 amplifier and the second ML:s awesome 33H monoblocks. Yes, I know they are quite different in price but how big is the different in reality? What other options are there? |
Manek
erstellt: 27. Dez 2004, 05:46
Do remember that you are bound to face this problem as long as you have those speakers....your costs on amps/upgrades will skyrocket. If I were you I would change the speakers( I know its difficult) and make sure that you have a wider option of amps to drive them with in the future. Secondly this way you could get away with amps which are cheaper and yet probably sound as good. regards manek |
mmx_2
erstellt: 27. Dez 2004, 09:57
Yes, I know, but both me and my girlfriend are very fond of them, and I have tried quite a lot others (Martin Logan Prodigy, B&W Nautilus etc) but every other speaker seem to lack something that the Ren 90 are better at. |
Manek
erstellt: 27. Dez 2004, 13:35
yeah I know what you mean ! Breaks the heart to sell speakers that suits one ears. I'm really surprised that a speaker manufacturer like infinity would let impedance drop to 0.9 ohms. How old would you say these speakers are ? Nowadays most speaker manufacturers make take care as to not let the speakers go below 2ohms. 0.9 ohms is a killer ! What about the Jeff rowlands 201 and 501 monoblock amps ? I heard the 201's with the B&W's in a high end HT setup and they sounded very good indeed. Dont know about their 0.9 ohm capability. Would they be in your price range ? manek. |
mmx_2
erstellt: 27. Dez 2004, 13:57
They are from the mid 90:s. The problem is the dual coil Watkins woofer with one 2 ohm side and one 4ohm side. Price range is up to 10000$ I guess but cheaper is of course always better! I have considered buying a pair of 33h and they would definitly do the job, but what ohter options are there? I have looked at a Pass Labs X350 and they would probably do a better job but still not quite it. I guess tube amps are out of the question. [Beitrag von mmx_2 am 27. Dez 2004, 13:58 bearbeitet] |
Manek
erstellt: 28. Dez 2004, 05:32
tubes are a no no ! you could also try the plinius range too. I hear they are pretty beefy and can handle all kinds of tough loads. ofcourse the jeff rowland monos which I mentioned earlier. |
mmx_2
erstellt: 28. Dez 2004, 11:28
Sounds interesting! I have looked at plinius and they are definitly worth looking at. No experince from Jeff Rowland, but I guess they are very, very good as well. I have also been thinking of a FPB 600C amp, that most likely would do the job and more over! They only problem is that I have to change fuses to get it working properly! |
Jeeves
erstellt: 29. Dez 2004, 04:48
Hi there, May I suggest a much less expensive alternative? Try the Aragon range. If you can get an older range (pre Klipsh) like Aragon 8008BB/Aragon 8008ST, they are I believe better than the new ones.But you might like to check out the new ones too, the specs are the same, really have power to drive most loads. Jeeves |
Arj
erstellt: 29. Dez 2004, 05:08
MMX_2, from what I know of Infinity (At least the new ranges) they are not very difficult to drive. this .9 Ohms that you speak of might occur only at very high freq..were you able to check out its specs sheet ? But Driving 1 ohm loads is not an easy task ! If you can get hold of YBA, MBL, Jeff Rowlands, Krell, Pass labs etc do try them as well.they are all able to run Martin Logans Vvry well and elecrrostats do have sub 1 ohm impedance Even the Electrocompaniet monoblocks which originate from the Nordic regions should be good. In fact I do know of one audiophile who used to Run Infinity Kappa 8 with Electrocompaniet monoblocs AW 180...he upgraded to Thiels driven by a classe but then went back to his old setup after 2 months |
Manek
erstellt: 29. Dez 2004, 09:08
mmx2....if possible try before you buy ! manek. |
mmx_2
erstellt: 29. Dez 2004, 19:50
Thanks for all tip! Great response. I have tried quite a lot including some electrocompaniet and the are good, but this speaker is a bit tricky as said. Have also heard them with a Krell FPB 200C but I was not very impressed. It looks like its gonna be a Pass Labs X-350, a friend of mine has got this one and he is very satisfied. |
Manek
erstellt: 29. Dez 2004, 20:49
all the best...hope your speakers treat the pass labs well |
Think i found a find! puchoo am 11.06.2007 – Letzte Antwort am 11.06.2007 – 4 Beiträge |
Of Speakers and Roaches soulforged am 21.04.2006 – Letzte Antwort am 05.05.2006 – 41 Beiträge |
Marantz 1072 amplifier with a weird noise jeroentje am 30.01.2005 – Letzte Antwort am 31.01.2005 – 4 Beiträge |
Budget amp and speakers. Help!! Psycholic am 30.06.2005 – Letzte Antwort am 30.06.2005 – 8 Beiträge |
What is the difference between Pre Amp & Amplifier? philipmorris am 19.07.2006 – Letzte Antwort am 19.07.2006 – 6 Beiträge |
Stereo and Computer Speakers Alexb123 am 12.01.2004 – Letzte Antwort am 12.01.2004 – 6 Beiträge |
Help on Info needed : Stereo amplifier fuse Ronnie22 am 17.09.2006 – Letzte Antwort am 18.09.2006 – 11 Beiträge |
Help with speakers connections pranab31 am 27.02.2006 – Letzte Antwort am 28.02.2006 – 5 Beiträge |
Cables and Interconnects for My A/V Receiver ASR am 04.10.2005 – Letzte Antwort am 14.10.2005 – 9 Beiträge |
Pro-ject and other turntables soulforged am 30.06.2006 – Letzte Antwort am 19.07.2006 – 15 Beiträge |
2004
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder930.726 ( Heute: 6 )
- Neuestes Mitglieddj-milan
- Gesamtzahl an Themen1.563.637
- Gesamtzahl an Beiträgen21.831.221
