What is a Good Speaker?
SDhawan
#1 erstellt: 04. Okt 2004, 18:27
Hi Everyone!
We keep debating X speaker is better than Y for reasons abc. This sounds flat and this really deep and that is too bright, etc. etc.
Why don't we first define what makes a good speaker? What frequency range? What sensitivity? What are the characteristics that make a good speaker? Is just the scientific parameters or the subjective assessment?
Why don't we all give our views? And may be at the end one of the moderators could compile it into one single article or writeup and post it back at the forum.
Lets hear
Sanjay
[Beitrag von SDhawan am 04. Okt 2004, 18:30 bearbeitet]
Arj
#2 erstellt: 05. Okt 2004, 03:33
Hmm..Debatable question this Doc !
The speaker does have the most impact on the sound but still its qualities should not be taken in isolation as it is its interaction with the Amp , the source as well as the room which determines its qualities
But some well agreed highlights of a good speaker would be
1. Clean midrange ie voice not sounding "Boxy"
2. Cleanest reproduction of sound, for each instrument
3. No Boomy bass (Like the 1200PMPO stuff !!)
4. Clean high frequecies..no shrill sounds..Asha Bhonsle should not make you cover your ears
5. Good soundstaging ie once the toe in is correct, you should be able to image the singer in the middle and each instrument in the music around the singer and aslo be able to identify each instrument
6. A guitar should sound just like one and not like a sitar or a Banjo.
Well..
Manek
#3 erstellt: 06. Okt 2004, 05:18
to put it in a nutshell :
1) good speakers should sound as natural as possible. (All the points that ARJ mentioned hold true here)
2) compare the sound of your speakers to what you would hear if the music were played in frot of you live.
3) Should reproduce the timbre of the instruments correctly
4) Full or extended range speakers are not always the best. Some speakers go down to only 45hz but they play most of the music 45hz and above very accurately.
5) Flat response speakers are generally termed to be good but may not be the case if they dont measure up as far as transient response is concerned.
5) Over and above all of this, a good speaker is what sounds good to you !
What makes a good speaker stand?
zhopudey am 19.07.2007  –  Letzte Antwort am 15.08.2007  –  41 Beiträge
What is a good CD Changer
Max3 am 12.11.2003  –  Letzte Antwort am 25.11.2003  –  10 Beiträge
what is Speaker Break-In
juggy_25 am 17.07.2006  –  Letzte Antwort am 24.07.2006  –  6 Beiträge
good speaker cables
onion am 03.10.2003  –  Letzte Antwort am 27.01.2004  –  3 Beiträge
what is a graphic equaliser
filmguy am 05.04.2005  –  Letzte Antwort am 06.04.2005  –  2 Beiträge
denon----- what a margin
ojoi am 17.06.2005  –  Letzte Antwort am 21.06.2005  –  3 Beiträge
A good solid state amp
G_S_Madhav am 08.10.2008  –  Letzte Antwort am 13.10.2008  –  65 Beiträge
a good stereo system
kishore am 31.07.2004  –  Letzte Antwort am 12.08.2004  –  6 Beiträge
what makes a speaker timing go awry?
stevieboy am 22.11.2005  –  Letzte Antwort am 28.11.2005  –  36 Beiträge
What is antiskating and what is it's function?
jani am 15.10.2010  –  Letzte Antwort am 16.10.2010  –  4 Beiträge
2004
  • Registrierte Mitglieder930.845 ( Heute: 6 )
  • Neuestes MitgliedGrayam_Delaney
  • Gesamtzahl an Themen1.563.944
  • Gesamtzahl an Beiträgen21.839.746
