HIFI-FORUM » English » Stereo (Engl.) » VA1 and Avita in small room | |
VA1 and Avita in small room+A -A |
myriad
11:24
erstellt: 20. Nov 2006, |||
Yesterday being Sunday and nowhere to go i started tinkering with my setup. I pulled out my Cadence VA1 and instead hooked in Nad 214 power amp. As i have no seperate pre amp i had to connect the amp with HK Dolby Digital processor. To my surprise the sound changed dramatically. I could feel the bass. The drums sounded more immediate. The highs were good too. Though not as airy as VA1. All in all it sounded big and dynamic. It made me feel that is it my room which is too big for VA1? (My current room is 24'x17'x10.5'). I have a spare bedroom which is 13'x11'x10.5'. Will VA1 and Avita's sound good in small room? |
abhi.pani
11:34
Myriad, Definitely your room is toooooooooooooooooo big for VA-1. I have heard them in a similar sized room and instantaneously I felt the lack of power. In a small room it will definitely sound much better. But I still doubt if it can bring out the dynamics and big-ness of your solid states.. ![]() |
bhagwan69
13:01
What a lovely room - I would kill for a room of this size; Not to forget a room to spare !! Lucky you !!! Yes, the VA-1 is just not enough for a room of that size. 410 sq. ft. is double of what is needed. What you need is an ARCA + Canasya [speaker + amplifier] However, your chain is not up to that level, so I guess you will not spend that much more. The Cadence has a house sound, either one likes it or one hates it. |
abhi.pani
13:23
Seriously...he is lucky But the downside of such a big room is also evident...you need a much more powerful setup ![]()
I dont think "Hate" is the right word. At the max one may not like it as much....but it definitely doesnt have a sound that can be hated ![]() |
myriad
18:42
I have read in Audio Asylum people using SS for LF driver and Tubes for ESL panels. I want to know how they use two different amps for different drivers. Im sure these different amps must be having different impedance and gain. |
myriad
19:19
bhagwan, I cannot think of another upgradation right now. VA-1 sounds divine at low and moderate volumes. It's only when i try to crank a little loud the set up show it's limitation in big room. Whereas Nad couldn't sing at low volume whereas they came to life once i increased the volume. Again one cannot listen for long at high volumes.I know there are trade offs in every design. Maybe i should have ss and tubes for different moods and times ![]() |
bombaywalla
02:02
erstellt: 21. Nov 2006, |||
one has to be very careful doing this. Not only do different amps have diff impedance (which should not be an issue for a s.s. amp driving a woofer) & gain but also different tonality which will manifest itself as a separate-tweeter-separate-woofer sound. You might get the oomph from the bass driver but the overall sound will fragmented. If you are going to do this experimenting with diff s.s. amps to match your VA-1 will be the course of action on your part. Could get tedious! ![]() |
myriad
06:20
I tried two different amps in my previous set up and frankly it never worked. Hf & lf driver never integrated. I tried both ss as well as tube and ss combination. I think, it's better to swap from tube to ss and vice versa for different music and mood. Can you suggest some good, affordable (within 50-60 k) ss amps to go with Avitas? |
abhi.pani
07:25
How about a Sugden (should be available within 70k) ? Or even a Roksan ? [Beitrag von abhi.pani am 21. Nov 2006, 07:26 bearbeitet] |
Manek
07:27
wonder who sells sugden in India ? |
abhi.pani
07:30
Arj could throw some light on this. I suppose he should be able to suggest multiple ways of getting a Sugden.. ![]() |
Manek
07:37
myriad....do you have the 20watter or the 35 watter ? Manek. |
Amp_Nut
08:52
I concurr with both of you. I tried to bi-amp my Extremas with the Flying Moles (Solid State, Switching Amps ) feeding the Bass unit and Prima Luna Valve amp feeding the tweeter. Result - sound worse than if either amp was given full charge of the speakers... ![]() |
square_wave
09:20
Hi Abhi, Which roksan model are you comparing to the Sugden ? Power / integrated ? |
abhi.pani
09:32
I was talking of Roksan Kandy Integrated...but I am not comparing between Sugden and Roksan....I suppose they are two good choices for that kind of a budget. ![]() [Beitrag von abhi.pani am 21. Nov 2006, 09:34 bearbeitet] |
square_wave
09:52
Kandy is their budget series. The caspien M series poweer amp is available around the same price…….. ![]() Who sells roksan in India ? |
myriad
09:59
35 watter |
myriad
10:11
I have Audio Note Dac One 1.1x signature connected to VA-1. I read a post in Audio Asylum saying that AN Dac 1.1 needs at least 30k ohms input impedance to sound at it's full potential. The VA-1 has 10k ohms input impedance. I contacted Peter Qvotrup through e mail and he too echoed the same in his reply. Is this mismatch anyway limiting the dynamics? |
Manek
10:14
roksan if I remember right is distributed by marbin colah of innovative systems in bombay. I like the roksan amps. manek. |
bhagwan69
11:08
I am confused; Your DAC's output will go into the VA-1 so what is the mis match about ? If the AN DAC needs 30 K input impedence, then that will have to come from your Transport [what ever it is that you use]. How is it connected with the VA-1 ? Please do shed some light. Thanks. |
bhagwan69
11:10
The Sugden is far better than Roksan. Roksan is sold my Mr. Marbin vdH Colah. I wonder what stock he has. I would strongly suggest Sugden over Roksan. |
myriad
11:15
AN states that the preamp's input impedance should at least be 30k ohms whereas VA-1's input impedance is 10k ohms. My dvd player is connected to dac and dac to amplifier. |
square_wave
11:32
Bhagwan, How would the Roksan Caspian series or even the kandy power amp compare to a Nad c272 / Advance acoustics power amp ? Manek, Which Roksan amp did you listen to ? How would you describe their sound ? How are these priced in India ? [Beitrag von square_wave am 21. Nov 2006, 11:33 bearbeitet] |
bhagwan69
11:38
Nad - Advance - Roksan - Sudgen That is how I would place them. |
Amp_Nut
12:29
#25
Many, Many Moons ago, Sushil at PLAY ( then Nova Audio ) handled Roksan. He gave it up ... felt was too Expensive. If Im not mistaken, the mid level Roksan Caspian amp was Rs 90K.... |
Arj
13:48
#26
I had heard their caspin series amp some time back . donk know if they are really VFM on the basis of pricing. for the sound quality which is marginally better than the entry level (NAD/ROTEL/MARANTZ) the pricing used to be way off in singapore. I think they struggle in their bass reproduction with the not so easy speakers, something which is not expected at that price level. I found the CDP to be pretty nice and delicate though. they look good though ! |
Manek
13:49
#27
Bhagwan, the AN dac needs to see an input impedance of 30Kohms on the amplifier it connects to. The va 1.0 has 10Kohms input impedance on any line level input socket. The AN 1.1 dac has maybe 2500-3500 ohms output impedance(myriad whats the exact spec?), hence if you go by the general rule of output impedance(source)*10 should match input impedance of amplifier or any other input device.....then the AN would need an amplifier input impedance of approx 30K. myriad if you could furnish us with the output impedance of your AN dac...we could shed some more light. Manek. |
myriad
20:30
#28
![]() Go to Resources and then Dac 1.1x signature. |
Manek
07:03
#29
erstellt: 22. Nov 2006, |||
hi, I read the specs. output impedance is 2K. 20K of input impedance of the amp should suffice but one never knows. Myriad, since the VA has only a pot for volume(passive) which is of 10K why dont you ask cadence if they can incorporate a volume pot of 30K or 40K ? Wonder if their design would allow for it ? Manek. |
Manek
07:04
#30
or maybe you could try out a line stage buffer with a large input impedance and a low output impedance of 50-100ohms to see if it really makes a difference. Manek. |
Arj
10:49
#31
thats a good suggestion as some line stage buffers are just that , impedance matchers (or rather impedance transformers) |
bombaywalla
17:04
#32
That's right. I, too, read the specs on the AN(UK) website & it says < 2KOhms. I used 2KOhms like you did. So, if the source has a 2KOhms impedance & the VA-1 has 10KOhms, I calculated a voltage transfer ratio of 0.83. IF the VA-1 input impedance was 30K, then the voltage xfer ratio would have been 0.9375. So, I calculate a 1dB loss in signal (vs. the "ideal" case of inp imp of 30K). IMHO this is not much but it could still be hearable by Myriad. Loss of bass response & slightly wooly bass is what I'd expect. Somewhat rolled off highs as well. These aspects are probably not discernable unless a direct A/B comparison is made. Another suggestion (don't know how practical) is that Jensen (USA) makes impedance transformation transformers. They are very good sounding but expensive. I like Manek's suggestion the best - to change that 10K vol pot to a 100K volume pot. See if you can get Screamgigi or Viren to do this job for you. |
myriad
19:32
#33
First of all, i don't think Cadence will be ready to change the design for me. Secondly, it will cost me almost 8000/- rupees to send the amp from kolkata to Mumbai and back... top of that the cost of pot they will charge. I think it's better to dispose the dac and go for a standalone player or a dac which is compatible with VA-1. |
bombaywalla
21:40
#34
Ach, you are based in Calcutta! According to member Screamgigi there are a number of people in that city who have good soldering skills that will be able to do the mod for you. If I were you, I would get in touch with member Screamgigi or member Viren & see if you can get a 100K volume pot from them. They DIY build tube amps regularly & the should have this component. Also ask them for a reco for which outfit to take your amp to get the mod done. It should be a simple & quick one. Of course, check with Cadence that doing such a mod is OK/compatible with the VA-1. You could also dispose off the DAC & get another one that has 100 Ohms or less output impedance. You will have to audition a few to get a one which suits your tastes.
you presume too much! They are not changing the design! they are making a tweak to your particular unit. All other units in the field + those on the manuf line will be unaffected. |
Amp_Nut
06:31
#35
erstellt: 23. Nov 2006, |||
1. The topic of High input impedence is close to my heart and I have been 'researching' its deployment & effect at the Volume control stage... Bombaywalla's calculations are good, and provide a rational approach to the topic ... to a point. 2. There are second order effects that need to be considered, in an audiophile's perspective. 1. With a simple 1st Order filter that is created ( as in this case) there is not only loss of amplitude ( as correctly calculated by Bombaywalla) but also a phase shift (delay) at all frequencies that suffer some attenuation. The Phase delay reaches ( and thereafter stays at ) 90 degrees at the -3dB freq. Phase delay means that those frequencies are delayed... substantially delayed... upto a quater wavelength ! The late arrival will cause sound smearing and loss perceived resolution. Anyways, in this particular case, the loss is tiny, and IMHO negligible. I just wanted to point out the phase delay & its impact, which is almost always over looked. The same applies to the query a few days ago, as to the benift of a 45KHz capable tweeter. If its -3dB freq is Way beyond 20KHz, it will have negligible phase shift ( sound smearing ) at 20 KHz. The other comments on more openess and air also hold ... with our without that proverbial pinch of salt.... 3. Comming back to the Volume control.... My personal impression is that High Impedances ( atleast 47 K Ohms, preferably 100K ohms and above ) volume controls preserve a sence of air and ambience that low impedences ( below 10K ohms just cant deliver ). Almost All Valve pre-amps / amp deploy 100K Ohms or higher. Lower values ontribute to lower noise and better specmanship. Also solid state electronics prefer lower impedences. 4. The Volume contol type & brand also substantially contribute to the overall sound. Any resonably resolving stereo wil show the difference between an ALPS Pot and a Philips carbon pot... just the way Interconnects sound different. The Cadence amp does not use the el-cheapo Philips pot, I saw tghat last weekend.... Hence I suspect that Cadence may not be able to swap Pots for you, simply because they may not have stock of a higer ohmic value, in the purist brand that they use. Check with them, before you pay that huge shipment... ( which equals to the price of a Good DIY DAC ! ) P.S: Sorry for this long sermon / post.. [Beitrag von Amp_Nut am 23. Nov 2006, 11:17 bearbeitet] |
abhi.pani
08:43
#36
Sorry to butt in guys, but just couldnt resist asking this question. I am using a Plinius Integrated amp which has an input impedance of 47 kOhm. I suppose the output impedance of my source should be around 500 ohms but I am using a NAD C521 as CDP, which has an output impedance of 300 ohms...does that have any remarkable effect on the sound ? Do I have to look into this issue ? |
Manek
09:02
#37
nope |
Amp_Nut
09:58
#38
abhi.pani - you are in great shape, Sir. If your CDP has an output impedence of 300 Ohms, it will VERY Comfortably ( with practically ZERO performance penalty ) drive any Pre or Power amplifier with an Input impedence of 10 Times 300 Ohms or higher input impedance. Hence yr CDP will be THRILLED ![]() 47K Ohms is much higer, and therefore will draw even less current from the CDP, so its a Great match. ENJOY ! |
abhi.pani
10:35
#39
Without any knowledge of input-output impedance, even I felt that they match really really well...just was curious to know if there is something I was missing ![]() Thanks for the info...buddy. [Beitrag von abhi.pani am 23. Nov 2006, 10:36 bearbeitet] |
myriad
19:55
#40
I was going through archives on Audio Asylum and found this thread on An dac 1.1x. ![]() (In Reply to: Re: Preamp Input Impedance and Source's Ouput Impedance? posted by IkeH on April 15, 2004 at 06:00:14: Dear Ike, 27 kOhm should work OK, but I think you may find that it is possible to just change the load resistors on the CD input to increase the impedance. Or you could change the output capacitor from 0.47uF to 1uF or slightly higher in the DAC One.1x. Sincerely, Peter Qvortrup) I am not a technical guy so please help me out. Will changing the output capacitor solve the problem of mismatch and the dac working at it's full potential? |
bombaywalla
01:13
#41
erstellt: 24. Nov 2006, |||
Amp_Nut, thanks for the explanation of the 2nd-order effects. I had not considered this aspect. You make a good point of phase shift due to the 1st order filter. I shall keep this in mind the next time I encounter low impedance inputs to a power amp.
do you think that this is correct? ![]() Somehow I remember 45 degrees of phase shift at the -3dB corner & 90 degrees at 1 decade above the -3dB freq. A 1st order filter has only 1 reactive component (L or C) & hence only +/- 45 degrees should be possible. |
Manek
07:34
#42
changing the load resistor on the cd input of the amp would do it, i think. Scream, viren, siva, amp_nut....what do you guys say ? manek. |
Amp_Nut
10:10
#43
You are 100% Correct Bombaywalla. My knowledge was rusty. Thanks for the correction. |
Amp_Nut
10:20
#44
Manek said:
Yes, Manek. I think that integrated amp has a passive pre amp section ? I am not sure.. If it is a passive preamp, then the input goes directly to the Volume control pot, through the input selector switch. In such a case an 1 SERIES resistor at the Hot point of the CD input for each channel. Will not cost more than Rs 1 x 2. You will have to crank the volume control knob higher up, after the series resistor, but that should not be a problem, sonically. |
Manek
16:40
#45
BTW..i want to ask... is it always the load resistor on the amp inputs which determines as the input impedance of a power amp ? Would changing load resistor affect the sensitivity of the amp by any chance ? Can this mod be done to all amps SS and tube to get the desired impedance value ? Manek. |
Amp_Nut
07:13
#46
erstellt: 25. Nov 2006, |||
A few points : 1. The input (impedence) resistor is usually referred to as the resistor in parallel at the input of the amplifier. Parallel - ie between the signal terminal and ground. 2. The effectice input impedence of the amplifier ( that is what the source will see ) is the sum of the amplifier's input impednce + the external resistor. 3. For Valve or JFET inputs the amplifier's input impedence is usually Very high ( atleast a few Hundreds of K Ohms ) and so the external resistor practically determines the input impedence of the amp. 3. For SS ( BJT) amps the amplifiers input impedence itself is not too high ( often less than 100K ohms, so the external resistor + Amps intrinsic input impedance come into play. 4. Ther external resistor , particularly in SS amps can change ( usually degrade) : i. The amplifier noise ii. The Output Offset at the speaker terminals iii. SOMETIMES, the stability of the amplifier. Instability can result in more noise, and / or a harsher sound , and /or ![]() Hence dont take it for granted, and dont change the input resistor at will... Ofcourse, iii. above is me playing the devils's advocate... a worst case senario. |
Kamal
21:34
#47
erstellt: 27. Nov 2006, |||
Whooo, what mastery over the technical aspects of HiFi ! BTW, Amp, did you buy the SFE spkrs in India? Where & how much? Kamal |
Amp_Nut
05:44
#48
erstellt: 28. Nov 2006, |||
Hi Kamal. Thanks for the kind words... Yes, I did buy the SFEs in India ... Pre-Owned ( that is a nice way of saying 2nd Hand ! ![]() Bought them about 2 years ago, with stands for Rs 1,00,000 I am told a pair (Pre-owned ofcourse) is available with the SF dealer in Delhi, but the seller is asking for Rs 2 L. |
Manek
17:40
#49
thanks amp nut.....for the detailed explanation. manek. |
myriad
06:58
#50
erstellt: 29. Nov 2006, |||
I have a Nad 214 power amp. How about coonecting a tube pre with Nad? Has anyone tried the same combination? |
Manek
07:16
#51
myriad, I have currently connected by tube pre with my nad integrated. Its pretty cool. I dont expect the moon from it but it sounds pretty good for the price. But I dont think you will get the same refinement and tonal quality of a VA if you bundle a tube pre with the nad 214. You will have to go much higher. I have tried many SS power amps under and upto a lac with my tube pre. Nothing equaled the VA on refinement and tonality. Search is on but not desparate anymore. The right amp will come along when it comes along. Manek. |
Cadence Avita myriad am 30.03.2006 – Letzte Antwort am 03.04.2006 – 19 Beiträge |
Problem with Small Room mars_visa am 22.09.2008 – Letzte Antwort am 06.10.2008 – 26 Beiträge |
Which Amp with Cadence Avita myriad am 02.05.2006 – Letzte Antwort am 04.05.2006 – 12 Beiträge |
Room Treatment? myriad am 30.07.2007 – Letzte Antwort am 11.08.2007 – 13 Beiträge |
How to get better bass in a small untreated room? zhopudey am 24.10.2007 – Letzte Antwort am 25.10.2007 – 9 Beiträge |
planning on buying Cadence VA1-HP and Arista pair nautilus_d am 28.06.2009 – Letzte Antwort am 05.05.2011 – 71 Beiträge |
New living room project! _Ana_ am 29.11.2005 – Letzte Antwort am 30.11.2005 – 2 Beiträge |
Acoustic Room treatments sidvee am 30.06.2007 – Letzte Antwort am 02.07.2007 – 12 Beiträge |
Flooring for Stereo room benkenobi am 04.10.2005 – Letzte Antwort am 06.10.2005 – 13 Beiträge |
Small speaker suggestions? tomhifi am 04.10.2003 – Letzte Antwort am 07.10.2003 – 8 Beiträge |
Top 10 Threads in Stereo (Engl.) der letzten 7 Tage
- Good speakers for old system
- Jamo Concert E750 and E770
- Replacing Stock Jumpers on NAD/Marantz
- FYI: Cadence latest price list
- One speaker "louder" than the other?
- TNT triple T loudspeaker cable
- Vincent SV 231
- Planar speakers
- Best Amp for Quad 11L? Nad vs Rotel vs Marantz vs CA
- Is Jamo E-series worth it?
Top 10 Threads in Stereo (Engl.) der letzten 50 Tage
- Vincent SV 231
- Planar speakers
- Registrierte Mitglieder926.458 ( Heute: 1 )
- Neuestes MitgliedWagner89
- Gesamtzahl an Themen1.553.006
- Gesamtzahl an Beiträgen21.582.163
