Super Klang durch wlan!
collec
#1 erstellt: 18. Aug 2006, 09:25
Ich suche eine gut Soundcard,aber habe Squeezebox 3 gefunden.
Audio Outputs Audio outputs (general)
Digital and analog outputs
All RCA connectors are gold-plated
Volume control is provided for all outputs
Multiple outputs may be used at the same time
Analog RCA outputs
High fidelity Burr-Brown™ 24-bit DAC
Two dedicated linear power regulators for DAC and line-out stages
Full 6.0Vpp line-level signals
Signal-to-noise ratio: over 100dB
Total harmonic distortion: less than -93.5dB (0.002%)
Digital S/PDIF outputs
Optical and coax digital connections
Dedicated high-precision crystal oscillators (no PLL, no resampling)
Standard IEC-958 (S/PDIF) encoding
Optical connector: TOSLINK 660nm
Coax connector: RCA, 500mVpp into 75 ohms
Sample rates: 44.1Khz, 48Khz
Audio format: linear PCM, 16 or 24 bits per sample
Intrinsic jitter: less than 50ps (standard deviation)
Headphone output
Standard 1/8" jack also functions as an IR blaster
Minimum headphone impedance: 16 ohms
Total harmonic distortion: less than 0.03%
Left/right crosstalk attenuation: 92dB
Audio Formats Audio formats
Lossless Formats (Apple Lossless, FLAC, WMA Lossless)
"Bit-perfect" CD audio streaming, with reduced storage and bandwidth usage.
Approximately 2:1 compression ratio
Uncompressed formats (AIFF, WAV, PCM)
Supports raw pass-through of uncompressed PCM audio formats
Digital passthrough to S/PDIF for DTS
Compressed formats (MP3, AAC, Ogg Vorbis, MP2, MusePack, WMA)
MPEG decoding uses MAD software, widely regarded as the most accurate, most compatible MP3 decoder.
High accuracy 24-bit synthesis
Supports all MP3 data rates and sample rates, including VBR
May be streamed in PCM (raw), MP3 (transcoded), or FLAC (transcoded) formats
Sound Check and Replay Gain support for automatic volume control.
Some formats may require additional software installation (e.g. Quicktime), depending on platform.
Internet Radio
"Always-on" Internet Radio, powered by SqueezeNetwork, lets you tune in to Internet Radio streams even when the home PC is switched off.
Quick selection from hundreds of Internet Radio streams offered by Slim Devices' partners.
Internet Radio favorites can be saved in a playlist for easy access.
Displays song title information during playback
Support for MP3, Ogg Vorbis, and WMA formatted Internet Radio streams
Tech Notes Firmware
Flash upgradeable firmware
Network settings are stored in non-volatile memory
Auto-configuration for most networks
Easy setup for wireless networks
Architecture
250 MHz 8-way multithreaded RISC processor
"Pure software" SlimDSP™ architecture
Field-upgradeable Xilinx CPLD
64Mb high-speed RAM
16Mb program flash
Low-power design, all solid-state, fanless
Viele leute sagen,es kann mit LOSSLESS musicformat eine 500Euro Cdplayer gegen.Natruelich kann man ausser DAC benutzen,um Qualitaet zu erhoehen.
[Beitrag von collec am 18. Aug 2006, 10:21 bearbeitet]
kani
#2 erstellt: 18. Aug 2006, 12:39
Was willst du jetzt von uns wissen, oder uns sagen?
Nur Werbetext hinzuklatschen is nicht sonderlich hilfreich
Ich gehe mal davon aus, dass du wissen willst, ob das Ding taugt.
Dafür musst du nicht ne ganze Latte an technischen Daten in deinen post knallen. Derjenige, der dir was zu dem Teil sagen kann, weil er es kennt, wird dir auch technische Daten einen Bericht abgeben können.
Für denjenigen, der es nicht kennt, sind die technischen Daten unnötiger Ballast, der ihm auch nicht weiterhilft, dir etwas über das Teil sagen zu können, weil er ausschließlich mit den technischen Daten, dir NIX zu den Qualitäten des Produkts sagen können wird.
Soundaussetzer durch Wlan
Volteran am 23.10.2006  –  Letzte Antwort am 24.10.2006  –  4 Beiträge
Audikabel PC-Receiver ersetzen durch WLAN
fragensteller4711 am 07.10.2012  –  Letzte Antwort am 09.10.2012  –  4 Beiträge
Besseren Klang durch externe Soundkarte?
dieglo am 18.03.2008  –  Letzte Antwort am 19.03.2008  –  10 Beiträge
WLAN-Router
Fehr am 17.01.2006  –  Letzte Antwort am 18.01.2006  –  3 Beiträge
WLAN einrichten
Boardfreak am 27.07.2008  –  Letzte Antwort am 29.07.2008  –  4 Beiträge
Problem WLAN
padddy am 06.01.2009  –  Letzte Antwort am 07.01.2009  –  10 Beiträge
WLan - Repeater
Leo93 am 25.12.2009  –  Letzte Antwort am 28.12.2009  –  8 Beiträge
Arcam rdac WLAN Dongle Stört WLAN
Amice am 28.02.2013  –  Letzte Antwort am 28.02.2013  –  2 Beiträge
Schlechter Klang durch Digita-Ausgang der Soundkarte
Link2 am 29.08.2014  –  Letzte Antwort am 04.09.2014  –  7 Beiträge
dumpfer Klang
grendel32 am 01.10.2015  –  Letzte Antwort am 02.10.2015  –  3 Beiträge
2006
  • Registrierte Mitglieder930.950 ( Heute: 3 )
  • Neuestes Mitgliedmarillo
  • Gesamtzahl an Themen1.564.242
  • Gesamtzahl an Beiträgen21.847.993
