| HIFI-FORUM » Surround & Heimkino » A/V-Receiver/-Verstärker » Denon » Denon AVR 4806! Neues Highlight? | |
Denon AVR 4806! Neues Highlight?+A -A |
Audio
erstellt: 17. Jul 2005, 12:31
Hallo Forum! Hatte vor kurzem Kontakt mit Denon und erkundigte mich nach einem bezahlbaren AVR zwischen 3805 und AVC 11! Denon meint, da kommt was, aber wollte nicht mit der Sprache rausrücken ! Habe das hier im Ausland ganz aktuell gefunden! Ein neues Modell oder der Nachfolger des 3805? Soll etwas über 3000 ,- US$ kosten! Denon AVR-4806 7.1 A/V Reference Receiver with THX Ultra2 Certified THX Surround EX/DTS ES 6.1 Discrete/Dolby Digital EX Pro Logic IIx/dts Surround • THX Ultra2 Certified • THX Surround EX; dts Extended Surround Discrete 6.1; dts ES Matrix 6.1; dts Neo:6 Cinema & Music Matrix Decoding; Dolby Digital EX; Dolby Pro Logic IIx; Dolby Headphone; dts • Ultra2 7.1 Cinema and Music modes • Lucasfilm Home THX Cinema 4.0, 5.1 and 6.1ES post-processing • Audyssey MultEq Auto Setup System, microphone included • DVD-Audio/SACD decoding with Adjustable Digital Bass Management, Delay, Channel Levels and Tone Controls, through DENON Link and/or IEEE-1394 • All new DDSC-Digital featuring 3 Texas Instruments 32-bit floating point DSP processors • XM Satellite Radio Ready, with optional 'Connect and Play' antenna system • 7 Channels equal power amplifier section • 140 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) • 165 watts per channel (6 ohms, 20 Hz-20 kHz, <.05%THD) • 24 bit, 192 kHz A/D conversion (Burr-Brown PCM-1804) on all analog inputs • 16 Custom designed, Burr-Brown PCM-1791 24-bit, 192-kHz highest resolution DACs, with DSD compatibility - each audio channel operating in differential mode • Pure Audio mode, features 4 DACs per audio channel in dual-differential mode • Exclusive AL24 Processing Plus on all channels • 3 HDMI/1 DVD-D Video Inputs, 1 HDMI Output • HDMI 1.1 Repeater Inputs allow for DVD-Audio decoding • Analog to HDMI Video Conversion with on-screen display • 3 sets component video inputs, compatible with wideband (480p, 720p, 1080i) response for progressive DVD, DTV (100 MHz), dual component outputs • 8 sets composite and "S" video inputs • Video Conversion of Composite to S-Video and/or to Component • Video Time Based Correction for Video Conversion Circuit • 7.1 external wide bandwidth (100 kHz) inputs for multi-channel formats • 8(3 Coax, 5 Opt.) assignable digital inputs • Denon Link 3rd and dual IEEE-1394 inputs, both inputs DVD-Audio and SACD compatible • 13 analog inputs including built-in AM/FM tuner • Multi-Zone 1 stereo pre-amp outputs with video output • Multi-Zone 2 outputs, pre-amp outputs or speaker outputs • Ethernet and RS-232C port for external controllers, and possible upgrades • 3 Source/3 Zone Audio and Video(Composite, S-Video each zone) • Configurable Power Amplifiers for Multi-Zone or Bi-amping • Remote In/Out Ports • Assignable +12V/250mA triggers (x3) • Variable high/low pass Crossover 40/60/80/100/120/150/200/250 • Front, center, surround and surround back bass and treble control • Subwoofer bass control • Audio Delay adjustment to match audio signals with video signals(0-200ms) • Digitally regulated volume control with .5dB increment adjustments • Delay time adjustment increased to 20 feet per speaker in .1 foot increments • Auto Surround Mode stores modes by signal type(analog or digital) in memory • On-Screen Display • Download the Owner's Manual in PDF format - Click on the Owner's Manual Icon (note 11MB file) • Download the addtional XM operational guide in PDF format - Click on the Review Icon • Dimensions: 17.1"w x 7.0"h x 19.7"d • Weight: 52.5 lbs. Ist das ein abgespeckter AVC 11? Mmmmmmh! Gruß audio
Leon-x
erstellt: 17. Jul 2005, 12:38
Hallo Der 4806er ist die US-Version des europäischen AVC-A11. Die Daten lesen sich auch genau so. Leon [Beitrag von Leon-x am 17. Jul 2005, 12:38 bearbeitet] |
derandre
erstellt: 17. Jul 2005, 18:23
Sollte es auch schon hierzulande zu kaufen geben: Schau mal bei Denon auf der Homepage nach dem AVC-A11XV. Gibt ja auch schon einen Test in der neuen "Video" oder bei AreaDVD. Wann hast Du denn mit Denon gesprochen? [Beitrag von derandre am 17. Jul 2005, 18:26 bearbeitet] |
Passat
erstellt: 17. Jul 2005, 19:46
Der AVR-4806 ist die Receiver-Variante des hier erhältlichen AVC-A 11 XV. Genauso verhält es sich mit dem AVR-5805, das ist die Receiver-Variante des AVC-A 1 XV. Hier sind nur die AVC lieferbar, dagegen gibt es in den USA nur die AVR. In den USA gibt es fast nur AV-Receiver und kaum AV-Verstärker. Bei Yamaha ist es z.B. genauso. Den DSP-Z 9 gibt es in den USA nur als Receiver RX-Z 9. Grüsse Roman |
Yoshi
erstellt: 17. Jul 2005, 20:09
Es soll dennoch ein Modell zwischen AVR 3805 und A11 XV rauskommen. Nur wie das Ding heissen wird, was es kosten soll und welche Ausstattungsmerkmale es bekommen wird, kann man so noch nicht sagen. Da heisst es einfach abwarten. |
TheSoundAuthority
erstellt: 17. Jul 2005, 20:12
Begründung für die unterschiedlichen Artikelbezeichnungen ist dass sich in USA und JAPAN produkte mit nur Nummern besser verkaufen als die mit Buchstaben (kein Witz) |
Passat
erstellt: 17. Jul 2005, 20:13
In Analogie zum AVR-2805 und AVR-2105 würde ich, da AVR-4806 ja schon vergeben ist, auf AVR-4106 tippen...... Grüsse Roman |
Audio
erstellt: 18. Jul 2005, 04:23
Hi! Hab mir schon gedacht, dass das der AVC 11 ist! Allerdings hat mich der Preis etwas irritiert! Habe zwar nicht den Umrechnungskurs nicht im Kopf, dass sind doch aber locker unter 3000 ,- €?! Auch wenn 3000 ,- US$ der von mir gelesene Straßenpreis waren, dann liegt auch dieser weit unter dem derzeitgen Straßenpreis in Europa! Glückliche Amis! Gruß audio |
Audio
erstellt: 18. Jul 2005, 08:15
Hi! 2490 ,- €! Yoh! Zu dem Preis nehme ich auch einen! audio Mann ist das heiß! 10.15 Uhr und 30 grad im Büro! |
TheSoundAuthority
erstellt: 18. Jul 2005, 08:45
Ich auch =)) |
Audio
erstellt: 18. Jul 2005, 09:59
Hallo! Mein Bruder muß im Herbst beruflich in die Staaten! Man wäre nicht die Sache mit der Garantie und dem Netzteil! 1000 ,- € oder mehr gespart und nen halbes Jahr eher an "meinem Schatz"! audio |
Leon-x
erstellt: 18. Jul 2005, 10:01
Hallo Audio Hast du den A11 überhaupt schonmal an deinen LS Zuhause gehört ? Leon |
Audio
erstellt: 18. Jul 2005, 12:18
Hi! Nein noch nicht! Zur Zeit träume ich nur von ihm! Hatte ihn nur in Erwägung gezogen, da er von den Klangeigenschaften (schnell pp. - siehe areadvd-Test) als guter Ersatz für meinen AVR 3802 (und natürlich Verbesserung) herhalten und zu den Dynis passen könnte! Vor einem eventl. Kauf werde ich ihn aber bestimmt in meiner Kette probehören! Der Preis tut zwar weh, aber zur IFA soll laut Denon ein AVR im Bereich 2000 ,- bis 2500 ,- € kommen! Incl. HDMI, audessy pp.! Ich nehme an, dass wird der Nachfolger für den 3805 (höher positioniert, da ihm der 2805 sprich 2806 immer näher rückt) werden! Daher mein Anfragethread! Sollte dass so sein, kommt er in meine engere Wahl! Da die klanglichen Abstände in diesen Regionen aber eh dünner werden und einige "kleine Vorteile" ruck zuck 1000 ,- € mehr kosten - naja, warten wirs ab! Anfang September weiß ich mehr! Gruß audio [Beitrag von Audio am 18. Jul 2005, 12:20 bearbeitet] |
Yoshi
erstellt: 18. Jul 2005, 12:29
Nein, es kommt etwa zur IFA ein Nachfolger des 3805 namens 3806. Zusätzlich soll über dem 3806 und unter dem A11 XV, noch ein weiteres Modell (Receiver), positioniert werden. So sind zumindest meine aktuellen Infos. |
Audio
erstellt: 18. Jul 2005, 12:52
Hi! Hast du näheres oder nen Link? Gruß audio Man ist das heiß! |
BladeDivX
erstellt: 18. Jul 2005, 15:32
Leider habe ich eben auch nix gefunden aber ich schaue auch jeden tag nach neuen INFOS zu dem neuen Denon .. ich denke auch das ein neuer Denon für den 3805 kommen wird da sie ja auch für den 2805 den 2806 gebracht haben. ob der neue dann 3806 oder 3106 heissen wird kann zur zeit wohl noch keiner sagen. bei denon selber ist nun auch schon zu wollte eben anrufen aber die haben schon feierabend ... ich würde das auch gerne wissen ob da nun noch einer kommt weil das würde mir die entscheidung zwichen den "wenn er kommen würde neuer Denon XXX" und dem Yamaha RX-V4600 sehr erleichtern. Aber wie immer denke ich das Denon was macht und erst auf der IFA damit rausrückt. Den die anderen schlafen ja nicht den Sony,Yamaha, und Pioneer kommen ja nun auch mit HDMI. siehe dazu anderen beitrag hier. also warten wirs ab... wenn einer mehr wes kann er es bitte schreiben .. ich höre gerne zu. |
TheSoundAuthority
erstellt: 18. Jul 2005, 15:37
Ich denke auch dass es ein Nachfolger vom 3805 wird und nicht ein komplett neuer - realistisch wäre, dass dieser auch HDMi unterstützt - sonst kann der 3805 ja ziemlich "alles" |
BladeDivX
erstellt: 18. Jul 2005, 17:16
Zitat Audio :
Würdest du denn auch nicht für € 2.899,00 kaufen ?? da wüste ich wo man den bekommt zu dem preis :o) [Beitrag von BladeDivX am 18. Jul 2005, 17:18 bearbeitet] |
TheSoundAuthority
erstellt: 18. Jul 2005, 17:23
WO ?!?!?!?!? |
BladeDivX
erstellt: 18. Jul 2005, 17:41
na dann schau mal hier aber mir ist das persönlich auch noch zu viel aber der wird noch günstiger. http://www.mediachec...016?pid=psm&langnr=1 |
TheSoundAuthority
erstellt: 18. Jul 2005, 17:46
Hmm der Laden ist mir sehr suspekt - ist das wohl ein EU-Gerät? NEIN DANKE |
BladeDivX
erstellt: 18. Jul 2005, 17:53
ja sicher ist das ein EU wieso nein danke ??? |
TheSoundAuthority
erstellt: 18. Jul 2005, 17:55
Hatte mit EU Importen bisher nur stress...sei es Fernseher oder Beamer...seitdem lass ich die Finger von sowas |
BladeDivX
erstellt: 18. Jul 2005, 18:07
wie kommst du aus den USA oder Japan oder was meinst du ?? das ist ein German gerät !! wenn du eines aus den USA kaufen willst dann bekommst du es noch Billiger. :o) |
TheSoundAuthority
#25
erstellt: 18. Jul 2005, 18:10
USA und JAPAN gehören ja auch zu der EU...*g* mein Fernseher war zB aus Frankreich...defekt...deutsches Umtauschrecht - FEHLANZEIGE... desshalb bin ich mit solchen sachen vorsichtiger und informiere mich erst SCHRIFTLICH wie das mit der Garantie aussieht...zweitens haben US und JAPAN geräte a) andere Anschlüsse b) andere V Zahlen... |
BladeDivX
#26
erstellt: 18. Jul 2005, 18:13
Lösche das ganz schnell man Politik nicht 6 sondern 8 ? oder was ? USA und Japan EU !? sag mal kommst du von einen anderen stern ?? lösche das schnell ... nein also das ist ein gerät sicher aus German und nicht aus France oder UK .. das sind zwar EU länder aber du kannst ja mal anrufen . kostet ja nur 12 Cent |
TheSoundAuthority
#27
erstellt: 18. Jul 2005, 18:18
Schlag mal im Duden Ironie nach - ich glaube du wirst fündig |
BladeDivX
#28
erstellt: 18. Jul 2005, 18:23
Ne das brauche ich nicht den Amerika und Japan sind nicht in der EU. USA <-- United ... wie das den heisst weist du ja und das Japan Asien ist auch oder ! Denke das solltest du auch wissen oder !? Ich glaube nicht das Japan und die USA in der EU sind LACH!! Oder denkst du im ernst das ist Europa ? Ironie ich wess was das heisst aber denke mal darüber nach sowas schreibt man doch nicht LACH Und noch mal dazu wenn du eines da kaufen solltest bekommst du ja auch ein Deutsche rechnung. Also wenn du probleme hast schickst du das gerät da hin (kaufs Ort) oder nach Denon. Das ist ja auch ein Deutsche der das gerät verkauft. [Beitrag von BladeDivX am 18. Jul 2005, 19:39 bearbeitet] |
TheSoundAuthority
#29
erstellt: 18. Jul 2005, 18:40
Du sagst was über meine schreibweiße und bekommst nichtmal nen richtigen deutschen satz hin ?_? Erst überlegen, dann schreiben...beides zusammen können nur Frauen und das bekanntermasen auch nicht perfekt... Wenn du meinen Satz mal richtig durchlesen würdest, verstehst du auch den Sinn... und denn schreibt man mit 2n... und nein Amerika und Japan sind nicht USA... ich drüber nachdenken, dass man Ironie nicht schreiben soll - kann ich was dazu wenn du des Deutschen nicht fähig bist und Ironie nicht erkennst?... Pisa bewahrheitet sich! |
BladeDivX
#30
erstellt: 18. Jul 2005, 18:52
Komm dir zu liebe mache ich das noch mal Ordentlich ^^ also noch was dazu wenn man schnell schreibt und nicht noch mal liest kann das schon mal vorkommen das man das eine oder andere vergisst oder sich verschreibt .. aber egal .. darum geht es hier nicht .. ich wollte dir nur einen gefallen tun . und du bist damit ja nicht zufreiden anscheint .. wer geräte aus anderen ländern kauft ist eben DUMMMMMM und ich war es auch mal habe mal ein Autoradio aus den USA gekauft nur das hatte nix mit der Garantie am Hut sondern das die eben kein FM un AM haben wenn doch eben in anderen Frequenzen. also ruf einfach mal da an wenn du es haben willst. Peace ok *ggg* [Beitrag von BladeDivX am 18. Jul 2005, 18:52 bearbeitet] |
TheSoundAuthority
#31
erstellt: 18. Jul 2005, 18:56
Du verstehst es immer noch nicht - aber lassen wir es dabei |
Melzman
#32
erstellt: 19. Jul 2005, 09:57
Hab ich das richtig gesehen bei AreaDVD ?? Der getestete A11XV ist dort in der Farbe Gold abgebildet. Also gibt es das Gerät auch in Gold oder was ? |
TheSoundAuthority
#33
erstellt: 19. Jul 2005, 10:08
Ich glaub das ist dieses Premium Silber...geht mehr ins Champanier rein! |
BladeDivX
#34
erstellt: 19. Jul 2005, 10:55
Jo so ist es in silber bekommst du ihn nicht und in Schwarz erst ab September ... farbe ist ins Goldene wie beim AVC-A1XV der ja 6000,- € Kostet. Sicher haben sie das gemacht das man sich dazu dann auch den DVDPlayer DVD-A1XV Kauft der hat auch die farbe. Edit : // In silber denke ich wirst du ihn garnicht bekommen. In planung waren nur die beiden Champagner und Schwarz. [Beitrag von BladeDivX am 19. Jul 2005, 11:00 bearbeitet] |
TheSoundAuthority
#35
erstellt: 19. Jul 2005, 11:29
Na sicher bekommst du ihn im normalen silber ![]() Hab ihn doch schon probegehört in silber...es gibt bisher dieses Champagnier und Silber - Schwarz wie gesagt ab September 05 ! |
BladeDivX
#36
erstellt: 19. Jul 2005, 12:11
dann hast du ja andere Infos als ich sorry das kann sein das du ihn in silber gehört hast .. na ja man kann sich ja auch irren aber in silber war er nicht geplannt .. na ja ich kaufe mir den eh nicht da der nachfolger des 3805 sicher auch HDMI haben wird und nur das ist mir wichtig der 3805 ist so auch ein Absolutes TOP gerät.. Edit 2 :// Hier laut Denon ist nur das zu sehen habe ich aus der beschriebung ganz unten... da steht das auch .. kann ja sein das das nicht mehr aktu. ist. lieferbare Ausführungen Premium Silber, Schwarz (Schwarz ab Spätsommer 2005) [Beitrag von BladeDivX am 19. Jul 2005, 12:14 bearbeitet] |
TheSoundAuthority
#37
erstellt: 19. Jul 2005, 12:15
Frage inwiefern du 4 HDMI kanäle steuern musst - ich komm mit meinem 1 gut hin, da es nur mein DVD Player / Beamer unterstützt Sobald HDTV und BlueRay auf dem Markt kommen sieht es natürlich anders aus |
Audio
#38
erstellt: 19. Jul 2005, 12:37
Hi AoD-UnknowN! Probegehört! Gibt mal deinen ersten Eindruck zum Besten! Schnell, flink und präzise (wie in area beschrieben) oder eher breit, satt und voluminös? Gruß audio |
TheSoundAuthority
#39
erstellt: 19. Jul 2005, 12:47
öhm...ALLES ZUSAMMEN! Hab ihn ein Wochenende an den B&W 800ern getestet...einfach genial! |
Audio
#40
erstellt: 20. Jul 2005, 06:26
Hi AoD-UnknowN! Minimalisten würden sagen "kurz und präzise"! Ich frage: Klangspezifika? Klang SACD u. DVD-A über i-Link? Funktionsweise des Einmesssystems "audysse" i.O.? Wenn du Zeit hast, schick mir bitte mal ne PM! Kann nicht mehr bis zur IFA warten! Gruß audio |
TheSoundAuthority
#41
erstellt: 20. Jul 2005, 07:25
Ich konnte weder den iLink noch den DLink testen...das ding war am DVD-A1XV angeschlossen (via Koax) und das wars dann auch |
Audio
#42
erstellt: 20. Jul 2005, 08:53
Schade! Dann bis zur IFA und zum Test daheim! Quasi demnächst in ihrem (meinem) Kino! Danke audio |
Neues Update für AVR X2200W benjamin1* am 23.03.2017 – Letzte Antwort am 23.03.2017 – 2 Beiträge |
Neues Denon Lineup 2016 AVR-X1300W AVR-X2300W AVR-X3300W AVR-X4300H AVR-X6300H Sonophil am 02.05.2016 – Letzte Antwort am 14.07.2024 – 4325 Beiträge |
Reset Denon AVR 3311 maverick_zi am 22.03.2011 – Letzte Antwort am 22.03.2011 – 2 Beiträge |
Neues Firmwareupdate für AVR 4311 ? Krawallus am 17.02.2013 – Letzte Antwort am 30.04.2013 – 5 Beiträge |
Denon AVR-1603 MONO Aquaristiker am 03.11.2014 – Letzte Antwort am 05.11.2014 – 11 Beiträge |
Denon AVR-X7200W Aylon am 01.02.2015 – Letzte Antwort am 26.05.2015 – 19 Beiträge |
Updatefehlschlag mit Denon AVR SchlaueFragenSteller am 15.01.2016 – Letzte Antwort am 17.01.2016 – 4 Beiträge |
Hilfe, Denon AVR 4100 Hackepeter83 am 24.01.2016 – Letzte Antwort am 24.01.2016 – 2 Beiträge |
Denon AVR-X2400H: Firmware AMVX am 01.06.2018 – Letzte Antwort am 06.03.2019 – 26 Beiträge |
Denon AVR-X1000 zukunftsicher? Boondock11 am 08.12.2018 – Letzte Antwort am 09.12.2018 – 5 Beiträge |
2005
- Registrierte Mitglieder930.657 ( Heute: 8 )
- Neuestes Mitgliedhansano715
- Gesamtzahl an Themen1.563.438
- Gesamtzahl an Beiträgen21.825.390
