| HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » VSA 1000 | |
VSA 1000+A -A |
David_Ramirez
erstellt: 21. Sep 2021, 20:50
hello everyone, may you help me with the amplification plan of a visonic VSA 1000 PRE / MAIN AMPLIFIER equipment have a fault in the amplifier and it has been impossible for me to repair greetings from Chile |
Rabia_sorda
erstellt: 22. Sep 2021, 11:24
Hello It will not be easy to find a circuit diagram for such a rare device. Here someone also had problems with the device. Maybe it will help you a little. Eng. translate Orig. germanGreetings |
Poetry2me
erstellt: 22. Sep 2021, 17:14
To make it easier for you, here is the full schematic of the integrated amplifier Visonic VSA 1000: ![]() I found the service manual at hifiengine.com, which requires just an easy email address based login. - Johannes [Beitrag von Poetry2me am 22. Sep 2021, 17:15 bearbeitet] |
Poetry2me
erstellt: 22. Sep 2021, 17:34
General advice: -- check if main amp channels both have <=100mV of DC voltage ("offset"), otherwise there is a main amp damage. Measure offset before the protection relais, e.g. at emitter resistors. -- check permanent heat sources like the voltage regulator transistors, including Zener diodes. -- check the "fusible resistors" as they are always suspicious at that age. These will show (seemingly random up or down) resistance changes, sometimes fail completely. Can be replaced with regular resistors. - Johannes [Beitrag von Poetry2me am 22. Sep 2021, 17:36 bearbeitet] |
sdoom
erstellt: 22. Sep 2021, 17:42
Hi , a good way to start is what is the amp doing and whaqt is not working, so for example the amp stays in protect , check the output transistors for shorts...a.s.o. so could you explain in more detail what´s the issue? |
Yamaha A-S301 help kartalkafadar am 13.07.2024 – Letzte Antwort am 22.07.2024 – 15 Beiträge |
HIFI amplifier: diagnosing power amplifier stage hyuna am 05.01.2017 – Letzte Antwort am 13.01.2017 – 2 Beiträge |
Tuner problem with my STR-GX315 szabi am 29.11.2005 – Letzte Antwort am 05.03.2011 – 2 Beiträge |
replacement for khl 7000 a fuse frans_callebaut am 01.04.2019 – Letzte Antwort am 02.04.2019 – 2 Beiträge |
Kenwood KA-4040R stereo amp. L Channel week Almantas am 25.06.2024 – Letzte Antwort am 25.06.2024 – 2 Beiträge |
Monster Clarity HD ONE Not Working. sharpiedog am 18.12.2017 – Letzte Antwort am 18.12.2017 – 5 Beiträge |
Dual MN-8010 battery? kabuco87 am 04.02.2005 – Letzte Antwort am 10.08.2011 – 3 Beiträge |
JVC Subwoofer Amplifier ME-EX90 standalone betreiben powerbee am 21.07.2022 – Letzte Antwort am 22.07.2022 – 3 Beiträge |
Pioneer VSA AX 10 Probleme UV-B am 11.05.2017 – Letzte Antwort am 11.05.2017 – 3 Beiträge |
Pioneer vsa 303 Umbau DanielMarkus am 15.01.2017 – Letzte Antwort am 20.01.2017 – 4 Beiträge |
2021
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder930.955 ( Heute: 2 )
- Neuestes MitgliedVETOS
- Gesamtzahl an Themen1.564.254
- Gesamtzahl an Beiträgen21.848.409
