Yamaha A-S301 help
kartalkafadar
#1 erstellt: 13. Jul 2024, 12:51
Hello. I have a Yamaha A-S301 amplifier that I use at home. 1 week ago, while listening to music, after 1 hour, the sound distortion occurred on the left output. There is no problem on the right output. I opened the cover of the device and there is no burnt part visible to the eye. I tested solid speakers and cables, but the problem is in the output. I will try to add a video. Do you think the fault may be caused by the left output transistor? There is sound in the speaker, but it is not clear, distorted and crackly.
https://uploadnow.io/f/zdmX3x1
CarlM.
#2 erstellt: 13. Jul 2024, 13:32
Did you try different sources - especially optical vs. analog (OPTICAL vs. CD, TUNER)?
What about the sound using headphones?
Press PURE DIRECT ... any changes?
Are you experienced in repairing equipment like this? Multimeter, soldering station?
kartalkafadar
#3 erstellt: 13. Jul 2024, 13:49
Yes, I tried, but the sound at the left output also produces a distorted tone. I tried tuner, phone, optic etc. all of them, while the right side gives good sound, the left side gives a crackling sound. Yes, I have a soldering station. I work in the technical department at Apple service, but I wanted to consult you because I have not repaired an amplifier before. Could one of the output transistors be faulty? Could it cause sound distortion?
CarlM.
#4 erstellt: 13. Jul 2024, 14:02
"Could one of the output transistors be faulty? Could it cause sound distortion? "
In most cases the protection would be active. Therefore I don't believe so.
The service manual is available for download here:
https://www.manualsl....html?page=18#manual
Page 18 describes the way to use the self diagnostic function.
If it detects no problems, it will be necessary to make some measurements (we'll see later).
kartalkafadar
#5 erstellt: 15. Jul 2024, 06:04
Thank you, I will try this tonight.
Poetry2me
#6 erstellt: 15. Jul 2024, 08:57
I would recommend to check the block diagram first to help you identify where the problem could be and which parts to exclude.
Note that many preamp functions of these amps are implemented within one big "Volume IC" (IC402). Yamaha is re-using their AV Receiver IC which originally supports many more channels than just stereo. So here they are using it to support functions like symmetrical input (CD), tone control, loudness, etc.
Yamaha A-S501 A-S301 block diagram volume IC marked
To support further troubleshooting in case of power amp damage, please find here the left power amp schematic with colorized stages.
Yamaha A-S501 A-S301 schematic detail left power amp stages marked
- Johannes
kartalkafadar
#7 erstellt: 16. Jul 2024, 06:10
Hello again. Last night, I made the troubleshooting combinations recommended by Yamaha. The sound was distorted on the left side. After this combination yesterday, there is no sound coming out from the left side, there is only sound on the right output.
Thank you for the schematic. Which transistor should I look at before Q123A - Q123C transistors?
My device's problem was the same as in the video.
https://www.youtube.com/watch?v=qBceQLDwjvE&list=LL&index=1
[Beitrag von kartalkafadar am 16. Jul 2024, 14:32 bearbeitet]
Poetry2me
#8 erstellt: 17. Jul 2024, 07:50
As I read this, all your checks so far point in the direction of a damage in the left power amp section.
The firmware self test you started did NOT give you an indication but may have completed the damage to a part in the power amp.
But we already know a lot now.
Since protection does not recognize the damage (does not trigger the relay to cut off loudspeaker terminals from the amp),
---> the damage is not likely to be in the last two current amplifying stages 4 "Driver" and 5 "Final".
And generally, the amp works, it amplifies. Only just distorting somewhat, like an overdriven or limited signal. This means that
---> the damage is not likely to be in stage 1 "Differential input stage", the signal can be recognized as such.
This leaves you with stages 2 and 3 which both belong to the VAS (Voltage Amplifying Stages).
Interestingly, with Yamaha receivers and amps, we recently had multiple cases where single parts (resistors, diodes) in these stages failed due to overload of parts too weak by design.
I would check the two SMD diodes D103 and D104 whether one of them has a fault, like a disconnect. SMD parts are usually placed on solder side of the PCB.
Next I would check the resistor R124 which is in line with them. R124 is implemented as an oldschool through-hole resistor.
Hope this helps.
- Johannes
[Beitrag von Poetry2me am 17. Jul 2024, 11:00 bearbeitet]
kartalkafadar
#9 erstellt: 17. Jul 2024, 08:58
Thank you for your answer. I will check the D103 and D104 diodes you mentioned and then check the R124 resistance. I will leave you feedback again. I want it to be useful to people who have the same problem.
kartalkafadar
#10 erstellt: 19. Jul 2024, 06:24
Hope this helps.
- Johannes
Hello Brother. I made the diode and resistor measurements you mentioned and found that the 100k resistor values ​​were low and I replaced it with an upper case and a 100k resistor. My problem was solved. Thank you for your help. The resistor had also lost its value since there was no burn or blackening. Yamaha may have used the 100k resistor cover at this input in a small way. I think it would last longer if a top cover was placed, so I did that.
[Beitrag von kartalkafadar am 19. Jul 2024, 13:44 bearbeitet]
Valenzband
#11 erstellt: 19. Jul 2024, 09:18
Better delete your email reference! You may receive a lot of SPAM otherwise as this forum is public.
Use tab "private communication" ("Private Nachrichten" ) instead.
kartalkafadar
#12 erstellt: 19. Jul 2024, 13:49
I will correct it, thank you for the information.
Poetry2me
#13 erstellt: 19. Jul 2024, 23:17
____CONGRATULATIONS____ for you successful repair
Glad it worked out well. One more device saved for the planet's sake.
And yes, I think that Yamaha does have an issue with dimensioning their parts.
Maybe the impulse load of the components mentioned may be greater than expected. The components used should be able to handle impuls load better.
- Johannes
[Beitrag von Poetry2me am 19. Jul 2024, 23:18 bearbeitet]
Poetry2me
#14 erstellt: 19. Jul 2024, 23:31
Yamaha A-S501 A-S301 schematic detail left power amp stages marked faulty resistor
Yamaha A-S301 PCB MAIN(1) side A component side faulti resistor marked
kartalkafadar
#15 erstellt: 22. Jul 2024, 06:26
- Johannes
Yes . This is my opinion too. The cases he uses are small, the resistors may have lost their values ​​in the heat. If we add both the temperature of the environment used and the operating time of the amplifier under load, these problems may arise. Apple made the same tantalum capacitor case mistake in the 2011 Macbook Pro model, and when the graphics card started to heat up, the device crashed. We solved this problem by enlarging the case. Fortunately, the problem was solved, thank you for the information, my friend. I would appreciate it if you could send me your e-mail address via private message.
Teufel decoderstation 3 rear left output problem
MarkBLN am 07.09.2021  –  Letzte Antwort am 08.09.2021  –  9 Beiträge
HIFI amplifier: diagnosing power amplifier stage
hyuna am 05.01.2017  –  Letzte Antwort am 13.01.2017  –  2 Beiträge
Tuner problem with my STR-GX315
szabi am 29.11.2005  –  Letzte Antwort am 05.03.2011  –  2 Beiträge
Sony dtc 1000es Audio Design PRODAT 1
David.Box am 08.07.2019  –  Letzte Antwort am 08.07.2019  –  3 Beiträge
replacement for khl 7000 a fuse
frans_callebaut am 01.04.2019  –  Letzte Antwort am 02.04.2019  –  2 Beiträge
SONY DTC-77 "funy" fehler
Lajos_hu am 24.04.2016  –  Letzte Antwort am 25.04.2016  –  6 Beiträge
Kenwood KA-4040R stereo amp. L Channel week
Almantas am 25.06.2024  –  Letzte Antwort am 25.06.2024  –  2 Beiträge
Dual MN-8010 battery?
kabuco87 am 04.02.2005  –  Letzte Antwort am 10.08.2011  –  3 Beiträge
VSA 1000
David_Ramirez am 21.09.2021  –  Letzte Antwort am 22.09.2021  –  5 Beiträge
The amp e800 probleme
megashooter am 17.12.2015  –  Letzte Antwort am 18.12.2015  –  2 Beiträge
2024
  • Registrierte Mitglieder930.676 ( Heute: 2 )
  • Neuestes MitgliedRain_Ed
  • Gesamtzahl an Themen1.563.496
  • Gesamtzahl an Beiträgen21.827.112
