Teufel decoderstation 3 rear left output problem
MarkBLN
#1 erstellt: 07. Sep 2021, 19:18
Hi guys.
Hope it's OK to post in English.
The issue im having is that I have a decoderstation 3 and the rear left output sporadically stops working. Sometimes giving a few taps to the side of the case fixes it. Anyone familiar with this unit know if this can be fixed? Maybe a loose wire inside attached to this connector? I tried to open it to look and removed the back screws, but couldn't figure out how to open the casing.
Any tips would be welcomed.
Thanks,
Mark.
Rabia_sorda
#2 erstellt: 07. Sep 2021, 19:43
There is a hint here to open the case:
Instructions: Open Teufel Decoderstation 3
If a mechanical effect leads to an improvement, this indicates loose contacts. These can be loose connectors but also cold solder joints. In the worst case, there may also be cracks in the circuit board.
MarkBLN
#3 erstellt: 07. Sep 2021, 20:37
Thanks very much. I'll have a look and see if I can see a problem with the connection so.
Rabia_sorda
#4 erstellt: 07. Sep 2021, 21:13
Good luck!
MarkBLN
#5 erstellt: 07. Sep 2021, 21:22
I opened it up. There doesn't seem to be any visible damage to the board and all the solder looks ok. When I put it back together the rear left was not working again. A few more taps to the side of the case got it running again though. So I don't know. You think I should resolder the joints for the output pins, or maybe it's something else?
Rabia_sorda
#6 erstellt: 07. Sep 2021, 21:39
It is still a loose contact.
Have you ever renewed the RCA cables - not that they are defective.
Otherwise, the soldered joints of the RCA plugs tend to break.
Furthermore, a remote diagnosis is very difficult with a loose contact and you have to search for it yourself and also measure it.
MarkBLN
#7 erstellt: 07. Sep 2021, 21:56
The cables are new, and I swapped 3 sets and all the same. So I guess it's the solder on the rca connectors. I'll resolder and see how that goes. Thanks mate
Rabia_sorda
#8 erstellt: 07. Sep 2021, 22:03
Instead of a loose contact, it can also be a ground contact (short circuit) in a signal line. Possibly also to the housing / GND.
MarkBLN
#9 erstellt: 07. Sep 2021, 22:05
Ok, thank you. I'll look
Teufel Decoderstation 5 defekt
HiFi-Fetikind am 20.03.2013  –  Letzte Antwort am 09.04.2013  –  3 Beiträge
Onkyo TX-SR502 - Anschluss Rear left defekt?
crack_the_sky am 19.04.2009  –  Letzte Antwort am 19.04.2009  –  3 Beiträge
Teufel concept E300 defekt?
Jan9n1 am 21.11.2015  –  Letzte Antwort am 23.11.2015  –  8 Beiträge
Yamaha A-S301 help
kartalkafadar am 13.07.2024  –  Letzte Antwort am 22.07.2024  –  15 Beiträge
DCX2496 Störgeräusche über Output 1
ElsaEcomo am 11.09.2017  –  Letzte Antwort am 10.10.2019  –  4 Beiträge
Audio output (Laptop) wechseln
BBlumenthal am 19.06.2013  –  Letzte Antwort am 22.06.2013  –  4 Beiträge
Teufel Concept S SW+R 5.1 zuerst Tonaussetzer mal rechts mal rear-r
airsun78 am 11.03.2013  –  Letzte Antwort am 18.04.2013  –  7 Beiträge
Problem: Teufel Concept E 300
Fuzzle91 am 09.04.2015  –  Letzte Antwort am 10.04.2015  –  4 Beiträge
JVC AX-22 Input ja Output nein Problem Defekt?
jonaspunck am 12.01.2010  –  Letzte Antwort am 14.01.2010  –  3 Beiträge
Technics SU-7700K Amp ein Output Defekt
DesmondTMB am 01.01.2018  –  Letzte Antwort am 01.01.2018  –  5 Beiträge
2021
  • Registrierte Mitglieder930.959 ( Heute: 5 )
  • Neuestes MitgliedJürgen47
  • Gesamtzahl an Themen1.564.259
  • Gesamtzahl an Beiträgen21.848.623
