| HIFI-FORUM » PC, Netzwerk & Multimedia » Multimediaplayer » mkv wird nicht abgespielt | |
mkv wird nicht abgespielt+A -A |
macuser.95
erstellt: 10. Aug 2010, 06:59
Hey ich habe einen Film der nicht abgespielt wird: Format : Matroska File size : 10.4 GiB Duration : 1h 32mn Overall bit rate : 16.0 Mbps Encoded date : UTC 2010-08-07 17:46:26 Writing application : mkvmerge v4.2.0 ('No Talking') gebaut am Jul 28 2010 18:38:23 Writing library : libebml v1.0.0 + libmatroska v1.0.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 5 frames Muxing mode : Container profile=Unknown@4.1 Codec ID : V_MPEG4/ISO/AVC Duration : 1h 32mn Bit rate : 13.0 Mbps Width : 1 920 pixels Height : 820 pixels Display aspect ratio : 2.35:1 Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.344 Stream size : 8.20 GiB (79%) Writing library : x264 core 104 r1683 62997d6 Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=0.80:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=13000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60 Audio #1 ID : 2 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 32mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 1 001 MiB (9%) Language : German Audio #2 ID : 3 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 1h 32mn Bit rate mode : Constant Bit rate : 1 510 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz Bit depth : 24 bits Stream size : 1 001 MiB (9%) Der Bildschirm bleibt schwarz. Auf dem PC geht dieser Film mit VLC. Woran kann das liegen? |
OMFG_CU
erstellt: 10. Aug 2010, 07:42
@ mit der "suche" im Forum ... das hier zb. gefunden und noch mehr zum Thema MKV und MKVToolnix usw mfg |
dropback
erstellt: 10. Aug 2010, 08:52
Überhaupt wäre es sinnvoll anzugeben auf was für einem Player der Film überhaupt abgespielt werden soll! Meine Mikrowelle hat z.b auch seit jeher Probleme mit der mkv Wiedergabe, unabhängig von der verwendeten Toolnix Version. Komische Sache... |
macuser.95
erstellt: 10. Aug 2010, 20:42
Danke, aber das hat nichts gebracht. Soll auf dem WDTV laufen, die 1.03 Firmware ist drauf! Es laufen irgendwie gar keine mkv Datein mehr! |
curiosity13
erstellt: 11. Aug 2010, 09:10
Dann hilft vielleicht das hier: Matroska hat ein Reperaturkit zur Verfügung gestellt: mkclean tool.Einfach entpacken und die mkv-Datei auf die Datei mkWDclean.exe" werfen ![]() Es öffnet sich die Kommandozeile und der Fix startet. lg curi [Beitrag von curiosity13 am 11. Aug 2010, 09:10 bearbeitet] |
wfy
erstellt: 11. Aug 2010, 18:33
Ist das Medium, wo die mkv's gespeichert sind, vielleicht schreibgeschützt, bzw. die Option "Netzwerkbenutzer dürfen Dateien verändern" nicht gesetzt? |
skipp007
erstellt: 01. Okt 2010, 04:57
Habe noch eine Lösung für die WDT Live! Auf die Beta Prerelease Version 1.03.40 auf [urlhttp://download.wdc.com/wdtv/wdtvlive_1.03.40_V.zip[/url] upgraden! Kein Hänger bzw. Absturz mehr mit der zuvor Probleme verursachenden mkv-Datei! http://wdtvhd.com/index.php?showtopic=20286 |
MKV werden nicht mehr abgespielt Lammbock-83 am 16.07.2011 – Letzte Antwort am 17.07.2011 – 3 Beiträge |
werden alle .mkv standardmäßig abgespielt? Eugen2k am 24.06.2010 – Letzte Antwort am 24.06.2010 – 2 Beiträge |
mkv auslesen marcin1982 am 24.09.2012 – Letzte Antwort am 24.09.2012 – 6 Beiträge |
TVIX M6500 MKV abspielen + AC3-File dolf am 08.11.2009 – Letzte Antwort am 08.11.2009 – 2 Beiträge |
MKV-Ton? cryo75 am 19.05.2011 – Letzte Antwort am 19.05.2011 – 2 Beiträge |
WDTV live mit MKV und DTS orren am 05.03.2017 – Letzte Antwort am 28.03.2017 – 9 Beiträge |
MKV Multimedia fähig machen Flip86 am 10.04.2013 – Letzte Antwort am 10.04.2013 – 9 Beiträge |
Egreat A10 - 3D MKV Pegintron am 04.10.2021 – Letzte Antwort am 05.10.2021 – 12 Beiträge |
MKV nach Kapitelsprung Strasse? pitgo am 06.09.2011 – Letzte Antwort am 07.09.2011 – 4 Beiträge |
Media Player II / .mkv MaD_MaX_AT am 28.05.2009 – Letzte Antwort am 02.06.2009 – 4 Beiträge |
Top 10 Threads in Multimediaplayer der letzten 7 Tage
- Amazon Fire-Tv Stick und LG OLED55CX9LA
- HI RES Streaming über QOBUZ
- INNUOS ZENmini - ZEN - ZENith -Pulse Serie - Roon Erfahrungsaustausch
- Noxon iRadio 400 keine Internetsender mehr
- Lösung der DENON WLAN Probleme
- Pioneer N-70AE / N-50AE / N-30AE
- Bluesound VAULT 2i
- Kodi v20 KEINE MKV Dateien & erkennt Bibliothek nicht mehr auf Nvidia Shild
- Anleitung für DUMMIES: Audiophiler Raspberry Selbstbau Low Budget Musikplayer/-streamer
- Audio Netzwerkplayer was bringts?
Top 10 Threads in Multimediaplayer der letzten 50 Tage
- Registrierte Mitglieder930.688 ( Heute: 1 )
- Neuestes Mitgliedacidbembel
- Gesamtzahl an Beiträgen21.827.734
