HIFI-FORUM » Surround & Heimkino » Blu-ray Player & Ultra HD Blu-ray Player » OPPO BDP-103D DARBEE EDITION | |
OPPO BDP-103D DARBEE EDITION+A -A |
racethepace
11:04
#551
erstellt: 24. Apr 2014, |||
Hallo, habe gerade mal die Tasten VOL + - ausprobiert. Beim Drücken von VOL + steht die 100 im Display, ich kann den Wert aber durch Drücken auf VOL - nicht reduzieren !? Ist das bei euch auch so? Gruß racethepace |
Mickey_Mouse
11:14
#552
guck mal in den Einstellungen, da kann man das ändern (fixed/variable) |
racethepace
11:22
#553
Other Audio Processing Settings -> Output Volume: Variable/Fixed Danke für den Hinweis! Gruß racethepace |
djbeat
22:16
#554
erstellt: 07. Mai 2014, |||
neue Beta verfügbar: ![]() 1. Fixed a bug in calculating acoustic propagation delay from the "Speaker Distance" parameters of the "Speaker Configuration" setting. 2. Upgraded the Netflix application to the latest version certified for OPPO BDP-10x models. This version features a brand new user interface. It also contains improved adaptive streaming technology which will improve streaming quality for high-speed internet connections. The new Netflix application should help customers who have reported poor streaming quality during peak hours. (On a related note, recently customers reported that Netflix streaming on OPPO players and other streaming devices could become unstable with error message like "not connect to internet". In our experience this issue is not caused by the player or its firmware update. It could be either a server-side problem or an Internet traffic problem. Should this happen to your device, please report the outage to Netflix. Netflix recommends a troubleshooting method of de-activating the device and re-activating it. De-activation can be done from the OPPO player’s setup menu (Setup -> Device Setup -> Netflix -> De-activate). Re-activation canbe done by accessing the Netflix application from the Home Menu. In most cases, Netflix service can resume working after a few tries. The new Netflix application in this update contains additional network troubleshooting tool which can be used to test your connection to Netflix servers.) 3. Added the "Digital Concert Hall" application from Berliner Philharmoniker, which provides live and recorded classical music concerts in HD video from leading orchestras all over the world. Removed the "Film Fresh" application which is no longer functional due to the service provider stopping the service. 4. Improved Gapless Playback performance. Resolved issues such as the second track playing twice before moving to the third track, and resolved an issue where the Gracenote information could not be fetched when playing WAV files. 5. Resolved an issue where user settings (Size, Distance, Trim) inside the Speaker Configuration were incorrectly applied to the Headphone Out signal route. We revised the algorithm in this firmware and the Headphone Out signal is no longer affected by the Speaker Configuration changes. 6. Added a safety feature for BDP-103/103D: the "SACD Output" format is set to "PCM" by default. The reason is that the digital-to-analogue converter (DAC) used on these two models cannot adjust the volume for DSD signals, so the analog volume level could automatically switch back to 100 when a DSD stream is detected. This safety feature will force the DSD stream to be decoded as a PCM stream before sending it to the DAC, which can help control the volume when loading SACD disc(s). 7. Added support for the "4Kx2K@50/60Hz" resolution to the BDP-103D/105D (HDMI 1 only, and in YCbCr 4:2:0 format only). The "4Kx2K Output" setting for the BDP-103D/105D is set to "Auto 4K 50/60Hz 4:2:0" by default. 8. Resolved an issue of “Reset Factory Defaults” not erasing the user account for the Youtube Leanback application. 9. Resolved an "A/V Sync" related issue where the A/V Sync data was not be automatically applied to the Coaxial and Optical digital audio outputs after the player was powered on. 10. Improved the file sorting algorithm for the media center (the Music, Photo and Movie options on the Home Menu). The player can automatically detect numbers located at the beginning or end of the filenames and sort the files by the numeric value. Albums with numbered tracks will play in the proper order. 11. Extended support for the PCM audio format for up to 24-bit, 352.8 kHz / 384 kHz via the USB DAC IN port (BDP-105D only). 12. Added the timing adjustment for external subtitles. This can be accessed from the "Option" menu -> "Subtitle Adj." -> "Sync." when playing movies from a USB flash drive or external hard drive. 13. A new version of the Windows driver for the USB Audio DAC is available fordownload here (v2.22). It is compatible with BDP-105, 105D and the upcoming headphone amplifier HA-1. Please uninstall the previous version(s) of the OPPO USB DAC driver from your computer before installing this new one. |
BennyTurbo
06:21
#555
erstellt: 08. Mai 2014, |||
Hat sie schon jemand probiert? |
splatteralex
06:31
#556
In der neuen Video ist ein Test des 103D enthalten, wen es von Euch interessiert! Hat gewohnt gut abgeschnitten... |
Huberer
07:27
#557
Leider noch immer kein Wake-on-Lan in der neuen Firmware, obwohl ich sie diesbezüglich schon angeschrieben habe. Benutze den Oppo auch als Netzwerkplayer der auf meinen WHS zugreift. Leider kann der Oppo den ja nicht aufwecken wenn der WHS im Ruhezustand ist. Wäre super, wenn so etwas auch mal kommen könnte |
racethepace
08:26
#558
Hallo zusammen, ich habe mal den Film (Blu Ray) MERIDA mit makemkv gerippt, incl. der Dolby Plus Tonspur (7.1) Diese Tonspur spielt mein Oppo 103D aber nicht via Fileshare vom NAS. Die DD 5.1 Tonspur fkt. ohne Probleme. Ist das jemandem auch schonmal aufgefallen? Gruß racethepace |
cege
10:35
#559
Bei mir funktioniert jedes (HD)-Tonformat, ob von SMB-Freigabe oder NFS. Was hast Du für die Tonausgabe eingestellt... Bitstream? |
racethepace
10:43
#560
Kann ich heute Abend mal checken, aber von der Disc spielt der Oppo die DD Plus Spur ohne Probleme ab! |
dennis75
13:40
#561
Kann nur Einstellungssache sein, da er bei mir auch jede Tonart die es gibt von der NAS ohne Probleme per NFS oder Samba abspielt! |
racethepace
14:00
#562
Und die Files mit makeMKV erzeugt? |
cege
16:21
#563
Ich nutze auch nur makemkv für die Umwandlung von Blurays - alles ok bislang. Zugegebenermaßen ist DD Plus 7.1 ein wenig exotisch und ich muss mal sehen, ob ich einen solchen Film finde. |
dennis75
16:23
#564
Ja makemkv. In makemkv hast du auch die richtigen Tonspuren ausgewählt? |
racethepace
16:59
#565
So, Player steht auf Bitstream. Auch ich hatte bisher nie Probleme mit den HD-Tonformaten, bis jetzt bei Merida. Zu Merida muss man wissen, dass das der erste Film war, der in Dolby Atmos aufgenommen wurde! Im Anhang seht Ihr ein Foto der drei Tonspuren. Dabei liefert der Oppo keinen Ton bei der Dolby Digital Plus Tonspur, die anderen beiden fkt. ohne Probleme. Wie gesagt, bei Wiedergabe von Disc kein Problem, da funktioniert das als 7.1 Tonspur ohne Probleme. Also wer hat Merida um das mal zu testen ... ![]() |
Mickey_Mouse
17:19
#566
ich behaupte mal, dass da bei der "Konvertierung" (ich fange nicht wieder mit dem Thema an, warum/wie man das überhaupt macht) etwas schief gegangen ist. Die Dolby Plus 7.1 Trailer (ich habe den Namen der Trailer Seite wieder vergessen) werden hier (103EU) ohne Probleme vom NAS abgespielt, also prinzipiell geht das! |
racethepace
17:26
#567
Ich habe das Rippen mit makeMKV jetzt 3x gemacht, immer das selbe Ergebnis. Ich habe da auch makeMKV in Verdacht .... Denn viel kann man ja nicht falsch machen mit makeMKV ![]() |
dennis75
18:08
#568
Eben, viel falsch machen ist da nicht, Tonspur auswählen und fertig. Mhh komisch.. aktuellste Version haste installiert von MakeMkv? |
racethepace
18:55
#569
Jepp, mit V1.8.10 Und gerade nochmal ausprobiert, den Film über den USB-Stick direkt am Oppo abzuspielen -> gleiches Ergebnis, hatte auch nichts anderes erwartet. Ich habe da auch makeMKV unter Verdacht ... Mal sehen, werde mal mit FABilio probieren ![]() ![]() ![]() |
cege
21:11
#570
Google mal nach makemkv und dolby digital plus - scheint nicht unbekannt zu sein... das Thema! Gut, dass DD+ keine wirkliche Rolle spielt. Gefühlt 97% meiner HD-Filme haben DTS-HD und der Rest Dolby TrueHD. |
racethepace
05:49
#571
erstellt: 09. Mai 2014, |||
Da scheint makemkv definitiv einen Bug zu haben, siehe hier aus dem makemkv Forum: I have some problems ripping the german "Merida" (Pixar's "Brave") Blu-ray. Analyzing the m2ts files with MediaInfo, i found the following audio track: ![]() In makemkv erscheint der DD+ Track als 4.0. Das hatte mich sowieso schon gewundert. Allerdings überrascht mich auch, dass der Post aus dem November 2012 stammt, das sollte m.E. längst gefixed sein! Mal sehen, ob FABilio das besser macht ... [Beitrag von racethepace am 09. Mai 2014, 07:08 bearbeitet] |
Kinobi
16:57
#572
erstellt: 10. Mai 2014, |||
Kann der Oppo vobsub? |
racethepace
17:31
#573
Raal2k
18:36
#574
erstellt: 15. Mai 2014, |||
Die Kombi Oppo 103D und Sharp UQ70 ist ein Traum. Hab nun einen Panasonic Kabelreceiver gekauft und schleife das Bild durch den Oppo. Hat sich extrem gelohnt. Darbee ist einfach genial. |
racethepace
19:38
#575
erstellt: 21. Mai 2014, |||
Die neue Firmware ist da !! |
skratchy
04:31
#576
erstellt: 23. Mai 2014, |||
Hallo zusammen, Ich mache immer öfter die Erfahrung, dass es eigentlich einen festen Darbeewert im High Def Modus eigentlich nicht gibt. Mal gibt es Filme, wo man gut mit 65% gut gucken kann! gestern z.B. "Gangster Squad" definitiv to much.... Ansonsten macht der Player schon Spass ![]() |
Haitek
13:24
#577
Der OPPO macht mir viel Freude, auch im Audiobereich, besitze recht viele SACD und kaufe zunehmen BD Audio. Er hat allerdings zwischendurch mal "seine Tage", heißt grüßt mit freundlichem "hello" um dann erst einmal gar nichts zu machen, ggf muss der Stecker gezogen werden, kommt zwar selten vor, verwundert aber etwas. Jemand eine Idee? |
BennyTurbo
13:26
#578
Das hab ich noch nie gehabt? ![]() |
Mickey_Mouse
14:02
#579
ist bei mir (ohne "D") auch schon 2-3 Mal vorgekommen. Dabei lag dann aber immer eine Scheibe (ich bin mir nicht sicher ob immer eine SACD?) im Laufwerk. Auf der anderen Seite konnte ich das aber auch mit genau dieser Scheibe dann nicht ein zweites mal reproduzieren. Einmal hatte ich es, dass er so gehangen hat, ich aber eh noch Sat-TV gucken wollte und zu faul war aufzustehen. Und nach vielleicht 20 Minuten hat er dann auf einmal die Scheibe eingelesen und angefangen abzuspielen. |
Peter_J.
16:41
#580
erstellt: 24. Mai 2014, |||
Hallo, das passiert mir mit meinem Oppo auch manchmal, nur mit SADC´s; der Player stoppt nach 3 bis 4 Sekunden die Wiederabe und verweigert die Annahme aller FB-Befehle. Ausschalten, neu starten, die Scheibe entnehmen, neu einlegen, und dann hat es bis jetzt immer funktioniert. Seltsam! ![]() Grüße Peter J. |
Vv_ReZuS_vV
16:50
#581
Hallo, Wollte fragen ist einer von euch von einem pioneer bdp 450 auf den oppo gewechselt? Lohnt es sich? ![]() |
calle75
09:18
#582
erstellt: 25. Mai 2014, |||
Ja der Oppo findet auch meinen PC im Netzwerk, aber ich soll Benutzname und Passwort eingeben, habe aber sowas nicht vergeben, bzw. weiß auch nicht genau, welches er haben will. TV und Receiver benötigen sowas nicht, um auf den PC im LAN zuzugreifen. Deshalb bin ich etwas ratlos. |
cege
14:27
#583
Probiere mal gast oder guest und dann ohne Passwort... |
calle75
16:40
#584
Danke für den Tipp, funktioniert bei mir aber nicht. Auch nicht mit dem Namen meines Profiles. |
Haitek
11:43
#585
erstellt: 26. Mai 2014, |||
10XEU-75-0515 ? Grüße |
Jogitronic
15:54
#586
10XEU-75-0515 ist richtig |
Haitek
20:16
#587
Thx ![]() |
calle75
20:31
#588
OK, habe jetzt auch mal das Handbuch zu Rate gezogen, aber auch keine genauen Informationen dazu gefunden, wie ich das Streaming ermögliche. Letzten Endes bin ich jetzt auf folgende Einstellungen gestoßen: Systemsteuerung\Alle Systemsteuerungselemente\Netzwerk- und Freigabecenter\Medienstreamingoptionen Dort ist es dann möglich, den Oppo für Streaming zu aktivieren. Jetzt funktioniert es auch endlich. Gruß, CALLE |
Wutbürger
12:22
#589
erstellt: 09. Jun 2014, |||
Hallo haitekk, auch ich habe SACD's gesammelt. Die japanischen Neu Produktionen sind leider nicht in 5.1 abgemischt. ![]() Wo kaufst Du zunehmend BD Audio? Gruß Wutbürger |
t3
15:36
#590
erstellt: 11. Jun 2014, |||
Hallo Zusammen, Falls jemand Interesse hat: ![]() Verkaufe oder Tausche meinen Oppo BDP 103EU Darbee Edition !!!!!! Deswegen der Link am Anfang des Post. Meldet euch einfach per PM bei mir. Mit freundlichen Grüßen t3 [Beitrag von t3 am 12. Jun 2014, 13:21 bearbeitet] |
BennyTurbo
20:22
#591
erstellt: 12. Jun 2014, |||
Hallo, weiß jemand, wie man mp4v Dateien abspielen kann? Der Oppo erkennt sie noch nicht.... Sind 4K Ultra HD Videos ... der PC spielt sie auch auf Full HD ab, daher hatte ich gehofft ich kann das irgendwie auch dem Fernseher oder Beamer zuspielen. Danke. |
Seeker622
13:31
#592
erstellt: 13. Jun 2014, |||
Wie ist das mit dem verschieben der Untertitel, funktioniert das zuverlässig ? Bei einigen Filmen soll dies ja technisch nicht möglich sein(Java ?!), wie sieht das so prozentual aus, sind das viele ? |
TheWolf
08:23
#593
erstellt: 14. Jun 2014, |||
Bei mir hat das bisher immer einwandfrei geklappt. Man muss nur drauf achten, wo der Untertitel liegt. Mehr im unteren Bild-Teil: Verschieben nach unten klappt, nach oben nicht. Mehr im oberen Bild-Teil: Verschieben nach oben klappt, nach unten nicht.
Ist mir bisher weder bei DVD's noch bei BR's aufgefallen. Aber nicht vergessen: Es gibt auch feste Text-Einblendungen in Filmen, die keine Untertitel sind und die lassen sich dann natürlich nicht verschieben. |
Michi121
12:05
#594
Rrrrrrichtig! Die festen Einblendungen sind ja keine UT, die def Player erstellt, sondern Bestandteil des Films. Übrigens: Du kannst die UT nicht nur verschieben, sondern auch noch die Text- und Randfarbe einstellen. ![]() |
Seeker622
16:50
#595
Hm, also es geht mir nicht darum Filme im Original Ton, mit deutschen Untertiteln zu sehen. Zum Beispiel der Film "Malavita the Family" deutsche Tonspur, da wird wenn die Franzosen sprechen, die deutsche Übersetzung im schwarzen Balken angezeigt. Das ist auf einer 21:9 Leinwand natürlich ungünstig, so etwas meine ich. Generell müsste ich den UT vom unteren Rand nach oben schieben, wobei TheWolf schreibt das genau das nicht geht ? |
Mickey_Mouse
17:06
#596
das ist kein Untertitel der BD sondern gehört zum Film! |
Seeker622
20:34
#597
erstellt: 15. Jun 2014, |||
Oh, sind diese einblendenden, wenn kein UT ausgewählt wurde, also generell Bestandteil des Films ? |
TheWolf
08:05
#598
erstellt: 16. Jun 2014, |||
Von "ganz" unten nach "ganz" oben geht nicht aber das "zeigt" Dir der Oppo auch: Weiter hochschieben geht einfach nicht".
Auch das "zeigt" Dir der Oppo. Wenn keine Untertitel zum verschieben da sind, dann "verbietet" er das auch. Mal so nebenbei: Warum probierst Du's nicht einfach aus, dann siehst Du doch, was geht und was nicht. ![]() |
Seeker622
17:05
#599
Das würde ich ausprobieren, aber ich wollte mir eigentlich einen gebrauchten kaufen, wenn es dann nicht wie gedacht geht, stehe ich da. |
TheWolf
07:03
#600
erstellt: 17. Jun 2014, |||
Ah, jetzt, ja. ![]() Ist denn jetzt alles klar bei Dir oder haste noch Fragen dazu? |
Wutbürger
13:26
#601
erstellt: 27. Jun 2014, |||
und kaufe zunehmen BD Audio. Hallo haitekk, habe Dich schon einmal gebeten, mir zu sagen, wo Du die BD Audio kaufst? Wäre nett, wenn Du antworten würdest! ![]() Gruß Wutbürger |
Oppo BDP-103D (Darbee Edition) splatteralex am 12.11.2013 – Letzte Antwort am 12.11.2013 – 4 Beiträge |
Oppo BDP-103D und BDP-103EU SubSon am 18.08.2014 – Letzte Antwort am 18.08.2014 – 4 Beiträge |
Oppo BDP-83SE NuForce Edition derschröder am 01.07.2010 – Letzte Antwort am 07.01.2011 – 6 Beiträge |
Soundproblem Oppo BDP-105d DanielP83 am 09.12.2016 – Letzte Antwort am 27.12.2016 – 2 Beiträge |
Oppo BDP-103/103D autom. Umschaltung Modus Bildanpassung TheWolf am 20.02.2014 – Letzte Antwort am 15.03.2014 – 4 Beiträge |
Oppo 103d Konvertierung von 2D => 3D Tom2962 am 24.03.2014 – Letzte Antwort am 28.06.2014 – 7 Beiträge |
Oppo 103D und DVP 5000 gleich? Stephan.M. am 05.06.2014 – Letzte Antwort am 05.06.2014 – 3 Beiträge |
Oppo 103D: Upgrade auf 203 sinnvoll? peepshow am 30.03.2018 – Letzte Antwort am 02.04.2018 – 3 Beiträge |
Oppo BDP-80 Buschel am 23.01.2010 – Letzte Antwort am 20.09.2010 – 193 Beiträge |
Oppo BDP-93EU Netzstecker danny1581 am 05.04.2011 – Letzte Antwort am 05.04.2011 – 3 Beiträge |
Top 10 Threads in Blu-ray Player & Ultra HD Blu-ray Player der letzten 7 Tage
- PS5 nicht als UHD Bluray player geeignet?
- Lautes Laufwerksgeräusch bei DVD- und BluRay-Playern
- Sony UBP-X800M2 Ultra-HD Blu-ray Player
- Reavon UHD-Player 2021
- UHD-BR mit DVD-Region-free?
- UHD Blu Ray wird über PS5 nur in 1080p abgespielt
- Panasonic 9004 Nachfolger?
- Beim Abspielen von BluRay nur Ton, kein Bild
- Samsung BluRay Player öffnet nicht das CD-Fach
- Oppo UDP-203/205 Firmware Update Thread
Top 10 Threads in Blu-ray Player & Ultra HD Blu-ray Player der letzten 50 Tage
- Registrierte Mitglieder928.473 ( Heute: 14 )
- Neuestes MitgliedShawnglicK
- Gesamtzahl an Themen1.558.279
- Gesamtzahl an Beiträgen21.698.734
