| HIFI-FORUM » Surround & Heimkino » Blu-ray Player & Ultra HD Blu-ray Player » Übersicht: DolbyVision kompatibler UHD-BD Player | |
Übersicht: DolbyVision kompatibler UHD-BD Player+A -A |
Ralf65
erstellt: 24. Dez 2017, 07:14
Da vielleicht für einige interessant, starte ich mal einen Thread mit einer reinen Auflistung der derzeit verfügbaren DolbyVision komptabilen UHD Blu-ray Disc Player am Markt Oppo UDP-203 ![]() Disc Types* 4K UHD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile BD-ROM Version 3.1 Profile 6 (also compatible with BD-ROM Version 2.5 Profile 5) Output Analog Audio: 7.1ch, 5.1ch, stereo. Coaxial/Optical Audio: up to 2ch/192kHz PCM, Dolby Digital, DTS. HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, Bitstream. HDMI Video: UHD/1080p24/1080p/1080i/720p/576p/576i/480p/480i, 3D frame-packing 720p/1080p24. Input HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, Bitstream. HDMI Video: UHD/1080p24/1080p/1080i/720p/576p/576i/480p/480i, 3D frame-packing 720p/1080p24. Audio Characteristics** Frequency: 20Hz - 48kHz (±0.2dB), 20Hz - 96kHz (-4dB ˜ +0.05dB) Signal-to-Noise Ratio: >112dB (A-weighted, Unmute) THD+N: < 0.001% (1kHz at 0dBFS, 20kHz LPF) Crosstalk: < -103dB (A-weighted) General Specification Power Supply: 100V - 240V˜, 50/60Hz AC Power Consumption: 40W (Standby: 0.5W in Energy Efficient Mode) Dimensions: 16.9 x 12.2 x 3.1 inches (430mm x 311mm x 79mm) Mass: 9.5lbs (4.3kg) Oppo UDP-205 ![]() Disc Types* 4K UHD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile BD-ROM Version 3.1 Profile 6 (also compatible with BD-ROM Version 2.5 Profile 5) Output Analog Audio: 7.1ch, 5.1ch, stereo. Dedicated Stereo Analog Audio: XLR balanced, RCA single-ended. Coaxial/Optical Audio: up to 2ch/192kHz PCM, Dolby Digital, DTS. HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, Bitstream. HDMI Video: UHD/1080p24/1080p/1080i/720p/576p/576i/480p/480i, 3D frame-packing 720p/1080p24. Input HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, Bitstream. HDMI Video: UHD/1080p24/1080p/1080i/720p/576p/576i/480p/480i, 3D frame-packing 720p/1080p24. USB Audio: up to 2ch/768kHz PCM, up to 2ch/2.8224MHz/5.6448MHz/11.2896MHz/22.5792 MHz (native mode only) DSD. Coaxial/Optical Audio: up to 2ch/192kHz PCM, Dolby Digital, DTS, AAC. Audio Characteristics** (Stereo Audio Output) Frequency Response: 20Hz – 160kHz (-3dB ˜ +0.05dB) Signal-to-Noise Ratio: > 120dBr THD+N: < 0.00018% Output Level: (RCA) 2.1±0.2Vrms. (XLR) 4.2±0.4Vrms Dynamic Range: > 120dB Crosstalk: > 118dB Analogue Audio Characteristics** (Multi-channel Audio Output) Frequency Response: 20Hz – 160kHz (-3dB ˜ +0.05dB) Signal-to-Noise Ratio: > 120dBr THD+N: < 0.00031% Output Level: 2.1±0.2Vrms Dynamic Range: > 120dB Crosstalk: > 118dB Headphone Audio Characteristics** Frequency Response: 20Hz – 80kHz (-2dB ˜ +0.05dB) into 32ohm Signal-to-Noise Ratio: > 105dBr into 32ohm THD+N: < 0.01% into 32ohm and 50mW Maximum Output Power: 590mW into 32ohm Dynamic Range: > 115dB into 32ohm Output Impedance: < 0.1ohm General Specification Power Supply: 110V – 120V ˜ / 220V – 240V ˜, 50/60Hz Power Consumption: 65W (Standby: 0.5W in Energy Efficient Mode) Dimensions: 16.8 x 12.2 x 4.8 inches (430mm x 311mm x 123mm) Mass: 22lbs (10kg) Cambrige CXUHD (basiert auf dem Oppo UDP-203) ![]() Disc-Typen: UHD Blu-ray, Blu-ray, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD-PROFIL BD-ROM Version 3.1 Profil 6 (ebenfalls kompatibel mit BD-ROM Version 2.5 Profil 5) Architektur-Decoder: Mediatek MTK8591 Externer Speicher: 2 x USB 3.0 Video-Frameraten: 24 Hz / 50 Hz / 60 Hz Unterstützte Videodateiformate: MPEG2, MPEG 2 HD, MPEG4, MPEG4 HD, AVC, VC-1, XVID, AVI, AVC, MKV (4.1), DAT, VOB, WMV, MOV, MP4, MPEG-PS, FLV, MTS, M2TS, M2T, M4V, QuickTime Unterstützte Audiodateiformate: AAC, WMA, MP3, APE, Ogg Vorbis, FLAC, WAV Unterstützte Bilddateiformate: JPG, BMP, GIF, PNG HDMI 1 (Eingang und Ausgang) Video: UHD/1080p 24/1080p/1080i/720p/576p/576i/4 80p/480i, 3D Frame-Packing 720p/1080p24 Audio: bis zu 7.1-Kanal / 192 kHz PCM, bis zu 5.1-Kanal DSD, Bitstream HDMI 2 (Nur Audioausgang) bis zu 7.1-Kanal / 192 kHz PCM, bis zu 5.1-Kanal DSD, Bitstream ETHERNET: 1000 BASE-T WI-FI: 802.11B, G, N (2.4GHz), 802.11A, N, AC (5GHz) PSU Universal-Wechselmodus 100 – 240 V AC, IEC-Buchse MAX. STROMVERBRAUCH 35W StandBy-Verbrauch (Quick-START-Modus Ausgeschaltet) < 0.5 W Abmessungen (B X H X T) (Mit Füßen) 82 x 430 x 312 mm Gewicht (Unverpackt) 5,0 kg LG UP970 (untersützt nach einem FW Update derzeit kein DolbyVision mehr, eine Korrektur erfolgt angeblich zur CES im Jan.) ![]() Version 6.0 BD-Live Ja Bonus View Ja Internetfähig Ja Lokaler Festspeicher Ja Formate Blu-ray UBD-Rom, UBD-R, UBD-RE, 3D BD-ROM, BD-ROM, BD-R, BD-RE DVD DVD (NTSC), DVD (PAL), DVD-R(W), DVD+R(W) CD CD-DA, DTS-CD, CD-R, CD-RW Video-Komprimierungsformate WMV, MKV, M4V, MP4, MOV, VOB, FLV, 3GP, AVCHD, AVC Rec, TS, DAT, MPEG1, MPEG2, MPEG4 AVC (H.264), SMPTE VC1 (VC-9) Audio-Komprimierungsformate LPCM, Dolby Digital, Dolby Digital Plus, Dolby TrueHD, DTS, DTS-HD Master Audio, MPEG 1/2 L2, MP3, WMA, AAC, FLAC Bildformate JPEG, GIF, Animierte GIF, PNG Netzwerkfunktionen WLAN Ja Komfort Funktionen SIMPLINK Ja Erinnerung an letztgesehene Szene Ja (auch nach dem Ausschalten) Wiedergabe von externen Festplatten Ja Kindersicherung Ja Bildschirmschoner Ja Videoverarbeitung 1080p Upscaling Ja UltraHD (4k) Upscaling Ja Konvertierung zwischen PAL und NTSC Ja HDR10 Ja Dolby Vision Ja* Audioverarbeitung Änderung des Dynamikumfangs Ja BitStream Ja Downmixing und Downsampling Dolby Digital 2ch Downmix Anschlüsse HDMI out (HDCP 2.2) 1 HDMI out (HDCP 1.4) 1 (nur für Audio Übertragung) RJ45-Ethernet (LAN) 1 USB 2.0 1 Besondere Wiedergabefunktionen Zufallswiedergabe Ja A-B Wiederholung Ja Zeitlupe Ja Energieeffizienz Netzspannung in Volt 200-240 Netzfrequenz in Hz 50/60 Maße Haupteinheit 430 x 45,5 x 205 mm Verpackung 480 x 282 x 106 mm Gewicht Haupteinheit in kg 1,63 kg Gesamt 2,59 kg [Beitrag von Ralf65 am 24. Dez 2017, 07:19 bearbeitet] |
Ralf65
erstellt: 07. Jan 2018, 18:39
Panasonic DP-UB820 >>> unterstützt auch HDR10+ <<< ![]() DP-UB820 als Modell UB824 angeblich auch in silbernen Design erhältlich High Quality Picture Ultra HD Blu-ray Playback (4K/HDR) HCX (Hollywood Cinema Experience) Processor for Ultra HD Blu-ray Player Supports HDR10+/ Dolby Vision dynamic metadata technology 4K High-Precision Chroma Processing 4K Direct Chroma Up-scaling 4K 60p/50p/4:4:4 Output HDR Optimizer FULL HD 3D Blu-ray Disc Playback High Quality Sound 7.1ch Analogue Audio Output TWIN HDMI PURE AV (Twin Isolated Output) High Clarity Sound Premium HDMI Low Clock Jitter Process Digital Tube Sound with Up-sampling High-resolution Audio Playback (DSD (11.2MHz/2.8MHz/5.6MHz), ALAC, FLAC, WAV, AIFF) 192kHz/96kHz Surround Re-master Smart Features Works with Voice Assistant (Naming Tentative) 4K VOD Supported (NETFLIX/ YouTube/ Amazon*2) 4K Networking (4K Video/ 4K Jpeg Playback) Internet Apps*1 DLNA (Client/Renderer) Network Drive Access External HDD Playback Mirroring with Smartphone / Tablet Web Browser*1 Wireless LAN Built-in Stylish GUI Quick Start Home Screen Wallpaper Control by HDMI Connection [Beitrag von Ralf65 am 07. Jan 2018, 18:39 bearbeitet] |
Ralf65
erstellt: 09. Jan 2018, 05:49
Sony UB-X700 (DolbyVision Support mit FW Update angekündigt für Sommer 2018) ![]() Playback Capability Disc BD-RE, BD-RE Dual Layer, BD-ROM, CD (CD-DA), CD-R/-RW, DVD+R, DVD+R Double Layer, DVD+RW, DVD-R, DVD-R Dual Layer, DVD-RW, DVD-Video, SA-CD (SA-CD / CD) Playback, Stereoscopic 3D (profile 5), Ultra HD Blu-ray™ Video format AVCHD Disc Format, HEVC, Motion JPEG (.mov, .avi), MPEG-1 Video/PS (.mpg, .MPEG, .mkv).VOB, .VRO, MPEG-2 Video/PS, TS (.mpg, .MPEG, .m2ts, .mts, .mkv).VOB, .VRO, MPEG-4/AVC (.mov, 3gp, .3g2, .3gpp, .3gpp2, .flv), MPEG-4 AVC (.mkv, .mp4, .m4v, .m2ts, .mts), VC1 (.m2ts, .mts, .mkv), VP6, VP8, VP9, WMV9 (.wmv, .asf, .mkv), Xvid (.avi, .mkv) Audio Format AAC (.AAC, .mka), AIFF (.aiff, .aif), ALAC (.m4a), Dolby® Digital (.ac3, .mka), DSD - DSDIFF/DSD (.dff, .dsf), FLAC (.flac, .fla), HEAAC v.1/v.2/level2, LPCM (.mka), Mokey’s Audio, Vorbis, WMA10 Pro, WMA9 Standard (.WMA) Photo format BMP (.bmp), GIF (.gif), JPEG (.jpg, .jpeg), MPO MPF 3D (.mpo), PNG (.png), WEBP (.webp) Picture and Audio Features Picture Feature 24p True Cinema™, 4K Upscale (60p), Deep color (12 bit) Certified Hi-Res Audio No Dolby Dolby Atmos® (bitstream out)/Dolby® True HD decoding (7.1ch) DTS® DTS:X™ (bitstream out)/DTS decoding (7.1ch) DSEE HX No Bluetooth® No Network Wi-Fi® Built in Yes Wi-Fi® MIMO Yes Features Screen mirroring (Wi-Fi® Miracast) Streaming 3D Streaming, 4K streaming, Live streaming Convenience Features Functions Auto Power Off (Auto Stand-by), BRAVIA Sync, Child Lock, Parental Control, Super Quick Start Mode Applications Video & TV SideView Terminals Input and Output Coaxial Audio Output(s): 1 (Rear), Ethernet Connection(s): 1 (Rear), HDMI Output(s): 2 (Rear), USB Input(s): 1 (Front) Size & Weight Dimensions (W x H x D) 320 mm x 45 mm x 217 mm Weight 1.4 kg [Beitrag von Ralf65 am 09. Jan 2018, 09:30 bearbeitet] |
Ralf65
erstellt: 14. Feb 2018, 07:39
Panasonic DMP-UB9000 >>> unterstützt auch HDR10+ <<< ![]() High Quality Picture Ultra HD Blu-ray Playback (4K/HDR) HCX (Hollywood Cinema Experience) Processor for Ultra HD Blu-ray Supports HDR10+/ Dolby Vision dynamic metadata technology 4K High-Precision Chroma Processing 4K Direct Chroma Up-scaling 4K 60p/50p/4:4:4 Output HDR Optimiser FULL HD 3D Blu-ray Disc Playback THX Certified (Coming Soon) High Quality Sound 7.1ch Analogue Audio Output 2ch Analog Audio Output (XLR/RCA) High-quality Audio Parts TWIN HDMI PURE AV (Twin Isolated Output) High Clarity Sound Premium HDMI Low Clock Jitter Process Digital Tube Sound with Up-sampling High-resolution Audio Playback (DSD (11.2MHz/5.6MHz/2.8MHz), ALAC, FLAC, WAV, AIFF) 192kHz/96kHz Surround Re-master High Rigid Chassis with Exclusive Design Smart Features Viewing Experience Controlled via Voice 4K VOD (You-Tube, Netflix, Amazon) 4K Networking (4K Video/ 4K Jpeg Playback) Internet Apps Network Contents Playback Network Drive Access External HDD Playback Mirroring with Smartphone / Tablet Wireless LAN Built-in Home Screen Wallpaper Control by HDMI Connection [Beitrag von Ralf65 am 14. Feb 2018, 07:41 bearbeitet] |
Ralf65
erstellt: 23. Mrz 2018, 17:45
LG UBK 90 offizieller Nachfolger des UP970 Homepage Datenblatt![]() Hauptfeatures 1080p Upscaling nur HDMI 4K Upscaling Dolby Vision, HDR Audio Features DD 2ch Down Mix Re-Encoder (DTS Only) LPCM Conversion (DTS HD, Dolby, TrueHD) Down Sampling Audio Formate LPCM Bitstream/Decoding Dolby Digital Bitstream/Decoding Dolby Atmos Bitstream Dolby Digital Plus Bitstream/Decoding Dolby TrueHD Bitstream/Decoding mp3, WMA, AAC, Flac Decoding Anschlüsse 2 x HDMI Output (HDMI 2.0a, HDCP 2.2) Optical Audio Output USB Ethernet Maße 430 x 45,5 x 205 mm [Beitrag von Ralf65 am 23. Mrz 2018, 17:56 bearbeitet] |
Scoty
erstellt: 30. Mrz 2018, 08:49
Schöne Übersicht. Kann man bei einen der Player auch Kodi installieren und über das Netzwerk auf seine Medien am PC zugreifen? |
Unchianed
erstellt: 30. Mrz 2018, 10:18
Zumindestens der Sony UDP-X700 beherrscht DLNA. Damit ist Zugriff aufs Netzwerk möglich; bei mir wäre das dann Zugriff auf Plex. |
Alex_Quien_85
erstellt: 31. Mrz 2018, 12:57
schöne Übersicht. Ich bin mal auf den UB820 gespannt |
blackpet
erstellt: 11. Mai 2018, 18:55
der neue LG UBK90 kann schon mal wieder kein DLNA.Wieder kastriert, geht morgen zurück und auch kein Bildvorteil zum UP 90.genau identisch. >Spielt sogar bei den selben Filmen wie der vorgänger die Atmosspuren nicht ab.Per Festplatte meine ich. [Beitrag von blackpet am 11. Mai 2018, 18:56 bearbeitet] |
Supermax2004
erstellt: 13. Mai 2018, 09:25
Das is schlecht. Aber erkennt der vielleicht zugemüllte 100gb Rohlinge, im Gegensatz zum 970? |
Ralf65
erstellt: 13. Mai 2018, 16:08
diskutiert das Bitte im entsprechenden Modell Thread des jeweiligen Herstellers, dies hier soll einer reiner Informationsthread zur Auflistung der Modelle sein und der Übersicht dienen Danke |
Ralf65
erstellt: 12. Jul 2018, 07:41
XBox One-S / XBox One-X >>eingeschränkte<< DolbyVision Unterstützung (Streaming) ![]() mit dem Systemupdate 1810 erhällt auch die XBox One-X bzw. XBox One-S eine eingeschrängte DolbyVision Unterstützung, dabei wird Dolby Vision (vorerst ?) jedoch ausschließlich für die Streaming Funktion auf NetfFlix Prime realisiert Bitte Hier keine Kommentare posten. dieser Thread soll als reiner Informationsthread zur Übersicht dienen und daher so übersichtlich wie möglich gehalten werden [Beitrag von Ralf65 am 12. Jul 2018, 08:04 bearbeitet] |
Ralf65
erstellt: 05. Sep 2018, 16:26
Pioneer UDP-LX500 unterstützt auch das DolbyVision "Low Latency" Profil (Sony kompatibel) ![]() Audio Highly Precise D/A Conversion Direct Function for Pure Analogue Audio Output PQLS Jitter-less Sound Transmission via HDMI (with compatible AV Receiver) Three-Block Internal Layout (Power Supply, Drive/Digital Processing, Analogue Audio) Ultra-Rigid Construction without Radiation Holes Double-Layered Chassis Reinforced with 3 mm Steel Plate for Rigidity and Low Centre of Gravity 6-Layered Main Circuit Board for High S/N Ratio Rigid & Quiet UHD BD Drive Honeycomb Mechanism Drive Cover Acoustic Damper Tray Float-Mounting Structure Video Ultra HD Blu-ray Playback SDR/HDR Preset Mode for Optimal Performance for the Display Video Adjust HDR10 Dolby Vision (Low Latency Compatible) 36-bit Deep Colour/”x.v.Colour” Highly Precise D/A Conversion Dual HDMI Output Three-Block Internal Layout (Power Supply, Drive/Digital Processing, Analogue Audio) Ultra-Rigid Construction without Radiation Holes Double-Layered Chassis Reinforced with 3 mm Steel Plate for Rigidity and Low Centre of Gravity 6-Layered Main Circuit Board for High S/N Ratio Rigid & Quiet UHD BD Drive Honeycomb Mechanism Drive Cover Acoustic Damper Tray Float-Mounting Structure Playback Media BD-ROM (UHDBD/3D BD/BD)/BD-R (DL)/BD-R LTH/BD-RE (DL) DVD-ROM (DVD-Video/DVD-Audio)/DVD-R (DL)/DVD-RW/DVD+R (DL)/DVD+RW Audio CD (CD-DA/SACD)/CD-ROM/CD-R/CD-RW USB Memory/HDD Anschlüsse HDMI 2 Out (1 Main for Audio/Video, 1 Sub for Audio) Digital Coaxial Out Digital Optical Out USB 2 In (1 Front, 1 Rear) Ethernet RS-232C Analogue Audio Out (Unbalanced) Zero Signal Terminal (for Audio/Video Quality Tuning) Abmessungen/Gewicht Dimensions (W X H x D): 435 x 118 x 337 mm Weight: 10.3 kg Bitte Hier keine Kommentare posten. dieser Thread soll als reiner Informationsthread zur Übersicht dienen und daher so übersichtlich wie möglich gehalten werden [Beitrag von Ralf65 am 05. Sep 2018, 16:26 bearbeitet] |
silvasurfa1
erstellt: 12. Jan 2020, 10:43
Wurden auf der CES 2020 neue Geräte vorgestellt, bzw kommen dieses Jahr noch neue Geräte? [Beitrag von silvasurfa1 am 12. Jan 2020, 21:42 bearbeitet] |
silvasurfa1
erstellt: 15. Jan 2020, 13:52
Tascam BD-MP4K UHD-BD Player DolbyVision Ralf65 am 15.11.2020 – Letzte Antwort am 12.11.2021 – 19 Beiträge |
Sony 2018 UHD-BD UBP-X700 DolbyVision Ralf65 am 09.01.2018 – Letzte Antwort am 13.01.2018 – 17 Beiträge |
Oppo UDP-203 / 205 UHD-BD Player mit DolbyVision Ralf65 am 07.05.2016 – Letzte Antwort am 06.08.2024 – 10939 Beiträge |
LG UHD BD Player incl. DolbyVision CES 2017 Ralf65 am 14.12.2016 – Letzte Antwort am 31.05.2018 – 921 Beiträge |
Cambridge Audio UHD-BD "CXUHD" Ralf65 am 10.08.2017 – Letzte Antwort am 29.08.2024 – 389 Beiträge |
Magnetar UDP800 / 900 UHD-BD SACD Player Ralf65 am 13.09.2022 – Letzte Antwort am 11.11.2024 – 97 Beiträge |
Panasonic UB820 - Probleme mit DolbyVision berlinois1 am 14.05.2021 – Letzte Antwort am 14.05.2021 – 3 Beiträge |
Cambridge UHD-BD Player UHD4K Ralf65 am 16.03.2017 – Letzte Antwort am 21.08.2017 – 21 Beiträge |
Panasonic 2018 DMP-UB824 mit DolbyVision, HDR10+ Ralf65 am 07.01.2018 – Letzte Antwort am 13.07.2024 – 3389 Beiträge |
BD Player Uhd Player verschiedene wiedergabe Qualitäten? Oehamdi am 11.09.2017 – Letzte Antwort am 11.09.2017 – 11 Beiträge |
Top 10 Threads in Blu-ray Player & Ultra HD Blu-ray Player der letzten 7 Tage
- PS5 nicht als UHD Bluray player geeignet?
- Lautes Laufwerksgeräusch bei DVD- und BluRay-Playern
- Sony UBP-X800M2 Ultra-HD Blu-ray Player
- Reavon UHD-Player 2021
- UHD-BR mit DVD-Region-free?
- UHD Blu Ray wird über PS5 nur in 1080p abgespielt
- Panasonic 9004 Nachfolger?
- Beim Abspielen von BluRay nur Ton, kein Bild
- Samsung BluRay Player öffnet nicht das CD-Fach
- Oppo UDP-203/205 Firmware Update Thread
Top 10 Threads in Blu-ray Player & Ultra HD Blu-ray Player der letzten 50 Tage
- Registrierte Mitglieder930.678 ( Heute: 1 )
- Neuestes Mitgliedsoyay
- Gesamtzahl an Beiträgen21.827.020
