| HIFI-FORUM » Fernseher & Beamer » Plasma-Fernseher » Panasonic » DER Panasonic ST60/STW60 PlasmaThread | |
Gehe zu Seite: |vorherige| Erste . 10 . 12 13 14 15 16 17 18 19 20 21 . 30 . 40 . 50 . 60 .. 100 .. Letzte |nächste|
DER Panasonic ST60/STW60 PlasmaThread+A -A |
phoenix0870
#755
erstellt: 06. Jun 2013, 20:46
StefMug
#756
erstellt: 06. Jun 2013, 20:49
hab ich schon ein paar Mal gelesen, technische Erklärung kann ich leider keine liefern. Es wird auch in einem hdtvtest.co.uk erwähnt: In terms of motion, Panasonic’s plasma range gets nearly everything right in 3D. 24hz, 50hz and 60hz input are all reproduced without stutter (setup permitting). The only motion artefact of note relates to the 3D subfield drive. As it happens, Panasonic’s plasma displays in 3D mode are arguably not “Full HD” because not all of the panel light emission stages are completed at full resolution. That means that the TX-P65VT50 does not resolve full vertical resolution with 3D content throughout the entire dynamic range. While the plasma panel can output two rows of vertically adjacent single-pixel black and lines at full resolution without difficulty, it can’t render more subtle shade variations (for example, dark grey and light grey) with full precision, instead blurring them into a single grey tone. We imagine that the thinking of Panasonic’s marketing division is that, since some of the panel’s light emitting stages are full resolution, and that the panel still has higher resolution than a passive 3D LCD TV, the “Full HD 3D” claim is justifiable from a marketing standpoint, seeing as the technical specifics of plasma panel subfield driving are not commonly understood among consumers (again, this is our assumption, Panasonic has never commented on the subject). hier der link dazu |
Duncan_Idaho
#757
erstellt: 07. Jun 2013, 09:12
Hab mir den Bericht mal durchgelesen und denke dass ich als professioneller Sprachenmittler den schon sehr gut verstanden habe. Zum einen, ist es nach deren Aussage eine Technologie, die standardmäßig eingesetzt wird und sich auf die Helligkeitsschritte bezieht, wir reden hier also nicht vom eigentlichen Bild, sondern nur von den Helligkeitsveränderungen. Weiterhin erklären sie wie das funktioniert und fragen sich zu Anfang, ob es Panasonic gelungen ist die Zwischenschritte in 1080 zu realisieren. Wobei sie keinerlei Wertung vornehmen, es ist für sie weder gut noch schlecht dass die Zwischenschritte in halber Auflösung erfolgen. Teilweise geben sie sogar zu, dass sie es nicht ganz verstehen, indem sie sagen, dass Panasonic schon seinen Grund dafür hat sowas zu machen, statt eine fachliche Begründung zu liefern. Nebenbei fehlen mir Infos über die Taktgeschwindigkeit der Abläufe, ob so nicht auf alternative Weise die Farbmischung erfolgt und eine genaue Differenzierung zwischen Helligkeitswechseln und kompletten Bildwechseln. [Beitrag von Duncan_Idaho am 07. Jun 2013, 09:16 bearbeitet] |
Alex_Quien_85
#758
erstellt: 07. Jun 2013, 11:18
THX Duncan [Beitrag von Alex_Quien_85 am 07. Jun 2013, 11:18 bearbeitet] |
StefMug
#759
erstellt: 07. Jun 2013, 11:38
super Duncan |
Alex_Quien_85
#760
erstellt: 07. Jun 2013, 13:30
Ist der STW 60 im ausgeschalteten zustand eigtl. schwarz oder so grün grau? |
Bruce2019
#761
erstellt: 07. Jun 2013, 16:43
Das hängt vom Sonneinfall ab. Bei hellem Lichteinfall Schwarz/grau, wenn die Sonne direkt draufknallt vermutlich grün, aber dann kannst du mit einem Plasma sowieso nicht fernschauen. Aber in normal hellem Raum, bei mir sind die Sonnenfenster z.b. auf der linken Seite wirkt der TV für einen Plasma ziemlich schwarz und wirkt daher sehr edel. |
Muppi
#762
erstellt: 07. Jun 2013, 17:05
Gratulation, sieht sehr schick aus. |
kfterntz
#763
erstellt: 07. Jun 2013, 17:10
Wie stark spiegelt der ST60? Sieht man noch Spiegelungen Abends, wenn man ein bisschen Licht an hat, bei viel Schwarzanteil im Bild. Hat jemand eventuell einen Vergleich zum VT50? |
Alex_Quien_85
#764
erstellt: 07. Jun 2013, 17:23
Klasse Bruce...schaut echt geil aus |
miscarriage
#765
erstellt: 08. Jun 2013, 00:39
Auch von mir ein kleiner Einwurf zum Thema Spiegelung: Ich wurde positive überrascht, denn bei direktem Sonneneinstrahl wirkt das Panel bei mir dunkelgrau / schwarz (wenn der TV komplett aus ist). Und wenn er an ist und die Sonne ins Zimmer strahlt, dann sieht das so aus... ![]() Ist ein 65STW60 und ich liebe das Teil seit der ersten Minute! G00dN8 und angenehmes Wochenende gewünscht |
Massi76
#766
erstellt: 08. Jun 2013, 12:00
Hallo wird durch die grösse des Panels heller und der Schwarzwert besser oder schlechter? Bin am überlegen ob ich 55 oder 65 nehmen soll, platz hätte ich genug. |
Nui
#767
erstellt: 08. Jun 2013, 12:09
Das panel wird mit der größer dunkler, der schwarzwert bleibt aber gleich. |
Warrior668
#768
erstellt: 08. Jun 2013, 12:36
Was ich bisher gesehen habe sind die 55er und die 65er in etwa gleich hell. Der 50er ist heller. Meine Meinung: Wenn der Platz reicht und des Sitzabstand passt, dann nimm den 65er. Meistens bereut man els nicht den größeren genommen zu haben. |
Nui
#769
erstellt: 08. Jun 2013, 12:43
Laut avforums scheint das zumindest beim VT65 echt der Fall zu sein. Also bleibe ich dabei, die Unterschiede zwischen den Größen sind arbriträrer nonsense ![]() Und schau dir das Bild vom 65er da oben doch an. Willst du ein noch kleineres Bild? [Beitrag von Nui am 08. Jun 2013, 12:43 bearbeitet] |
Ralf_1
#770
erstellt: 08. Jun 2013, 14:51
Hallo zusammen, folgendes, ich habe seit Anfang 2007 einen TH42PV71F, der immer noch top seinen Dienst tut, aber technisch einfach total überholt ist. Kein HD-Tuner, kein Full HD, kein 3D, hoher Stromverbrauch (nicht sooo schlimm). War damals Testsieger und hatte zu den damaligen LCDs ein super Bild, gerade am analogen Kabelanschluss. Seit Monaten(!) schau ich in den Märkten und im Internet. Zuerst Pana Plasma, dann Pana LCD, die letzten Wochen Samsung F6500 und nun wieder Pana Plasma. Das Einzige was mich abschreckt ist die Sache mit dem Einfahren (hatte ich beim jetzigen PV71F nur kurz gemacht und bis heute keine Probleme gehabt) und dem Einbrennen. Hat sich das was getan bei der 60er Serie? Die 50er soll da ja extrem anfällig sein. Und in den Märkten stehen 50er mit ausgefallen Plasmazellen/Pixelfehler (leuchten dann gelblich). Was ist da los? Kann man einen 55STW60 kaufen? Taugt der was? Möchte wieder so 5-6 Jahre dann Ruhe haben. Hauptsache HD Receiver und Full DH Bildauflösung. Und eben ein tolles Bild (habe nur mal einen 42" STW60 gesehen und das war super). @miscarriage: Der Pana hängt doch viel zu hoch.? Ach so ja, und dann möchte ich noch eine Soundbar dazu! Also mit extra Subwoofer. Gibts hier was passendes von Pana das was taugt? [Beitrag von Ralf_1 am 08. Jun 2013, 15:04 bearbeitet] |
Bruce2019
#771
erstellt: 08. Jun 2013, 17:43
Du musst nur Berücksichtigen, das die HD Ready Geräte bei SD Sendern besser sind. Dies als generelle Info! Ich glaube der PV71F spiegelt auch ziemlich, da wirst du mit dem STW60 eine grosse Freude haben. Auch in Sachen Schwarzwert und den anderen von dir genannten Punkten. Ich achte die ersten Tage das ich keine Kinobalken verwende und 4:3, aber danach fahre ich den TV nicht ein. Ich hab den STW60 jetzt seit 3 Wochen und schaue Eurosport, zocke Playstation. Alles kein Problem. Warte noch bis nach dem Sommer und hol dir einen STW60 in 42 Zoll, dann bekommst du auch einen guten Preis. |
Ralf_1
#772
erstellt: 08. Jun 2013, 17:51
Hallo und vielen Dank für Deine Antwort! Nein, unter 55" kaufe ich keinen TV mehr. Ich kann noch bis Anfang Juli warten wegen Umzug. Wie ist denn der Klang so? Wollte eine 2.1 Anlage dazu oder eine Soundbar (Sonos, Pana). Auch hier keine Ahnung. Je mehr man recherchiert, desto schwieriger wirds. Hatte gerade ein Bose 2.1 System (Cinemate GS 2.1), aber das kann nicht mal DTS.Und wo kann man heute guten Gewissens eine TV bestellen? Denke der STW60 in 55" kostet überall gleich mit 1699. Bei Cosse scheint es Rabatt zu geben, kenne diesen Shop aber nicht. [Beitrag von Ralf_1 am 08. Jun 2013, 17:52 bearbeitet] |
MarcWessels
#773
erstellt: 08. Jun 2013, 21:57
Massi76
#774
erstellt: 09. Jun 2013, 09:44
Hallo war gestern bei MM hatten leider keinen STW60 aber dafür VTW und ZT. Der ZT ist ein Traumjavascript:insert('%20:hail%20','') vom Bild wirklich top es lief Blu Ray material die farben,bewegungsschärfe,Schwarzwert etc wollte garnicht mehr weg aber 4.499. Habe nochmal den Sitzabstand gemessen und der betrug so ca. 3,50m zurzeit habe ich ein alten 42PV60 denke das ich mit den 65STW60 besser bedient bin. Denke nicht das Bild um viel schlechter ist als ein vtw oder zt was meint ihr? |
Nui
#775
erstellt: 09. Jun 2013, 10:02
Ich glaube richtig deutlich besser ist der ZT nur im Lichtfilter, in allem anderen dürfte er relative ähnlich sein. [Beitrag von Nui am 09. Jun 2013, 10:03 bearbeitet] |
Duncan_Idaho
#776
erstellt: 09. Jun 2013, 11:56
@Einbrennen Ist schon seit einiger Zeit kein Problem mehr, nur sollte man HUD in den ersten hundert Stunden eher meiden. Solange man gut gemischtes Programm fährt, sollte es da keine Probleme geben. Wer die ersten hundert Stunden nur Konsole mit HUD spielt sieht natürlich Einbrenner, aber selbst die bekommt man flott wieder raus. Ideal ist in der Anfangszeit viel 16:9 pur anzusehen. Ob 50er oder 60er ist da eigentlich egal. @SD-Sender Hängt vom Sender ab, wenn ein Sender ein gutes Signal liefert und der Bildschirm einen guten Scaler hat sieht auch das gut aus... leider wird von vielen Sendern auf einen Kanal vier Kanäle gelegt was natürlich eine entsprechende Kompression zur Folge hat. Bis auf ÖR lohnt es sich fast eh nicht mehr TV zu sehen, von daher eher ein untergeordnetes Problem. @Kaufen Würde dies wenn möglich vor Ort bei Fachhandel kaufen. Den Transportunternehmen trau ich bei Plasmas nicht sonderlich, was man ja auch oft an roten Lagesensoren sieht... @Diagonale bei 3,5 m ist 55" gut, 65" auch, achte nur drauf, dass sich die Entfernung durch Halterung verringern kann. Je nach Aufstellungsort lohnen sich schwenkbare Halterungen, da haben sich vor allem die von NEG bei Amazaon bewährt. @Spiegelung Bei Panasonic Plasma eher gering. @Sound Finger weg von Bose, das ist überteuerter Billigschrott. Soundbar ist eine Lösung wenn du wenig Platz hast, ansonst würde ich Verstärker und LS vorziehen. Die im Display eingebauten LS sind immer nur eine Notlösung. @Modell Wenn du das letzte ruasholen willst, dann ZT, ansonst reicht der ST völlig, der Unterschied zum VT ist nur direkt nebeneinander und dann auch nicht sonderlich ausgeprägt zu sehen. @Hochhängen Ist kein Problem wenn man eine schwenkbare Halterung hat. @defekte Plasmas Kommt eher selten vor, aber teilweise gehen die Leute mit den Modellen in der Ausstellung nicht sonderlich gut um. Weiterhin stellt man lieber einen Rückläufer als eine brandneues Gerät in die Ausstellung.... |
Ralf_1
#777
erstellt: 09. Jun 2013, 14:33
Wow, danke für Deine ausfühliche Rückmeldung! Soundbar habe ich eine tolle gefunden. Ist die Yamaha YSP-2200. Soll top sein das Teil. Ansonsten weiß nicht ob so ein "billiges" Pana 2.1 einen Wert hat. Irgendwie gibts von Pana auf diesem Sektor nicht so viel. Die Sonos Playbar wäre vielleicht auch noch was, aber eben total teuer und ohne Subwoofer. Ich habe SAT Schüssel und kauf mir dann die HD Karte dazu. |
Wodde
#778
erstellt: 09. Jun 2013, 21:33
Eine Frag an die STW60 Besitzer: Ist der True Cinema Mode auch ohne Kalibrierung brauchbar, vor allem was die Farbtreue betrifft? Kann man den True Cinema Mode des STW mit der Out of the Box Qualität des THX Modus der höherklassigen Geräte vergleichen? Oder muss man sich da einen Profi ins Haus holen? I [Beitrag von Wodde am 09. Jun 2013, 21:39 bearbeitet] |
Duncan_Idaho
#779
erstellt: 10. Jun 2013, 00:44
Also wenn du den Platz hast würde ich einen brauchbaren Verstärker und LS empfehlen... Volumen ist bei LS durch nichts anderes zu ersetzen. Muss ja nicht gleich Marantz und B&W sein, ein günstiger Onkyo/Denon und Canton, etc. tun es auch. |
RennMann
#780
erstellt: 10. Jun 2013, 08:16
Ist der Input Lag von 47ms spürbar beim PS zocken? Stört das? Wie weit fallen die Preise nach dem Sommer für einen 55STW60? Danke für Antworten & Gruß RennMann |
Nui
#781
erstellt: 10. Jun 2013, 10:14
Manche stört es, manche nicht. |
Duncan_Idaho
#782
erstellt: 10. Jun 2013, 11:10
Ralf, du hast PM! @Preise Wenn es wie die vorigen Jahre läuft, dann fallen die Preise nach einem Jahr auf etwa die Hälfte, wobei sie etwa die ersten 6 Monate noch recht nah beim Einführungspreis bleiben um dann langsam zu sinken und gegen Ende stark zu fallen. |
Wodde
#783
erstellt: 10. Jun 2013, 14:30
Kann ein STW60 Besitzer mal was zum 3D sagen? Manche Reviews im Netz bekritteln starkes Ghosting, was man aber mit dem umstellen auf 48HZ beseitigen kann, diese Einstellung finde ich aber in der deutschen Bedienungsanleitung nicht? Ich werde von einem 55VT30 auf den 65STW60 umsteigen, möchte mich aber nicht verschlechtern. Deshalb frag ich lieber mal hier nach [Beitrag von Wodde am 10. Jun 2013, 14:34 bearbeitet] |
bowieh
#784
erstellt: 10. Jun 2013, 16:05
Tests und Tipps zum US Gerät kannst du nicht auf das EU Gerät umlegen. Bist du dir sicher, dass du das Ghosting im Zusammenhang mit einem 60er Gerät gelesen hast ? Die EU Modelle hatten noch nie und US Modelle haben heuer keinen 48 Hz Mode mehr. |
Wodde
#785
erstellt: 10. Jun 2013, 17:05
Das Ghosting wird im AVS Forum von mehreren Usern erwähnt, also wohl US Modell. Hast aber recht, sie meinten den 96Hz Modus. Allerdings wird auch in einem französischen Review stärkeres Ghosting erwähnt, und das 3D nur mit 3 von 6 Punkten bewertet. Ich würde nur gerne wissen ob es da Rückschritte im vergleich zum VT30 gegeben hat, denn was nutzt mir die höhere Helligkeit im 3D Modus wenn es dafür mehr ghostet? ![]() Zumindest sind sich alle einig das das 2D Bild mit dem VT30 den Boden aufwischt [Beitrag von Wodde am 10. Jun 2013, 17:07 bearbeitet] |
Hardrock82
#786
erstellt: 10. Jun 2013, 21:23
@ Duncan_Idaho Bei 100 Betriebsstunden wirst du wohl kaum Nachleuchtungen sehen, dies geht meist so ab 200-300 Stunden los, einfahren sollte man wies Norbert S in seinen guten Einfahrthread hier bei HF beschreibt, am besten die ersten 500 Betriebsstunden. Und richtige Einbrenner kriegt man nicht mehr weg, was du eher als Einbrenner bezeichnest sind negative starke Abbilder von HUDs die man mit der Bildlaufleiste (leider) nicht mehr wegbekommt, da müsste man schon HD Programm Material samt Zoom 3 im Dynamic Mode einige Stunden (schlimmstenfalls Tage) laufen lassen, damit die sch** vielleicht doch mal weggeht. Und wenn die Bose klanglich nicht gut findest, dann sollteste lieber keine Onkyo AVRs entpfehlen den die sind auch der letzte Dreck, den sie zicken (wie auch Pioneers) bei Handschecks mit Konsolen/BD Playern rum und das schlimmst da sind meist voll die billigen Kathoden verbaut, mein SR 606 zeigt nach nur 2 Jahren jetzt kein Bild mehr über HDMI an (egal welchen Port) nur der Ton ist noch zu hören und wie man hier so liesst, sollen auch die teureren Modell damit Problemchen haben. Mein nächster AVR wird daher mit höchster warscheinlichkeit ein Yamaha V773 werden. (Denons sollen ja bei Surround leider nicht so gut sein.) @ Ralf 1 Hatte zwar erst nach 300 Betriebsstunden mit den zocken auf meinen VT50 angefangen, aber bisher nie Problemchen mit starken Nachleuchtungen bei Quellmaterial wechsel gehabt. Schlimmer sehe ich da die HD Sender Logos, selbst die Digitalen leuchten bei mir manchmal schon leicht nach. Vom uncoolen Galileo Logo bei P7 will ich erst garnicht reden. ![]() @ RennMann Bestell dir einfach den STW60 per Amazon, dann findest du ganz schnell heraus, ob dich der Inputlagwert (auf LCD Niveau) nervt. ![]() Ich bezweifle es aber ganz stark, da selbst meine 43ms (50" VT50) mich im Vergleich zu meinen alten Samsung (jetzt bei meinen Bruder) nicht negativ bei schnelle Tasteneingaben/Kombos behindert. Liegt ebend auch an der Technologie bzw. der TV Reaktionszeit und da können LCDs einfach nicht mithalten. 0,001ms vs. 5ms 16/24ms vs. 30-40ms (Sony/Samsung) LG Plasmas sogar 100ms [alte Kamera Messmethode] 16ms früher, betragen heute so um die 30ms mit dem präziseren Leo Bodnar Messverfahren. Der STW60 hat 74,5ms (neue Messmethode) was ergo über 40ms alte Messung wäre, das sind 3 Frames Pufferung, mit einer guten Internetleitung (samt guter Pingzeit) vielleicht noch kompensierbar, mit laggy Netz (wie bei mir derzeit, LTE) und einem LCD einfach kaum auszugleichen, es sei den man müsste sich schon bei Shootern in den Levels und mit den Waffen auskennen, aber man will ja mesit eher "relext" zocken, da wäre dann ein Plasma schon besser, vorallen weil man die sch** Schlieren im Game Mode dann nicht ertragen muss. Adios und gute Nacht |
Nui
#787
erstellt: 10. Jun 2013, 21:26
Also der aktuelle Sony hat nen inputlag von 9 ms |
Hardrock82
#788
erstellt: 10. Jun 2013, 22:21
Ja gut die Modelle W805/905 fallen da mit ca. 6/8ms (alte Messmethode) aus dem Rahmen, aber man muss nicht nur auf den besseren Schwarzwert (Samsungs) verzichten, sondern muss dank LG IPS Panels (Panasonic/LG und einzelne Sony/Phillips von 2013) mit höherer DSE Anfälligkeit, als bei den 2012 Panasonic IPS Panels leben. |
Nui
#789
erstellt: 10. Jun 2013, 22:23
Ich wollte nicht behaupten dass sonst wie die besser Wahl ist. |
Hardrock82
#790
erstellt: 10. Jun 2013, 22:35
Nene versteh dich schon. Auch wenns schon sehr spät ist und ik gleich pennen gehe. ![]() Mit 30-40ms ..SONY meinte ich auch eher die 2012 Modelle das krasse ja, wenn man den HDMI Port bei Samsung nicht in PC umbenennt dann hat man sogar einen höheren Lagwert und gerade diese Umbenennung musste man früher bei Phillips od. LG tätigen! Aber die Samsungs laufen ja mit S-PVA Panels da frage ich mich jetzt ja, was haben die an der Bildelektronik verändert damit so'ne verkackte Sch*** passiert! Und warum schafft es SONY urplötzlich fast einen Lagwert auf Z4500 Niveau (0-10ms) zu bringen wo sie doch erst ab 2010 wieder die Kurve mit einen Gamer freundlichen Geräte bekommen hatten. Warum hat man dies den nicht mit den VA Panels geschafft, an der guten Bildelektronik (eines HX825/855 zbsp.) kanns ja wohl kaum gelegen haben, oder bin ich da jetzt aufm Holzweg? Nacht |
Tzwän
#791
erstellt: 11. Jun 2013, 07:56
Hallo liebe Gemeinde. Ich habe jetzt vor mir den STW60 in 55" zu holen. Ich habe einfach einen langen Leidensweg mit Edge-LED (insgesamt 5 "Flaggschiffe" von den Topherstellern) und kann einfach nicht mit den Problemen die diese Technik mit sich bringt leben. Ich habe noch einen uralten 42" LG und der hat diese ganzen Probleme (Banding/DSE/Clouding/Flashlights) einfach nicht. Ich war richtig erschrocken als ich das Bild der heutigen Technik und den "Fortschritt" sah. Ich habe jetzt den Thread verfolgt und bin erst einmal von dem was ich gelesen habe begeistert. Jedoch frage ich mich ob der STW bzw die Plasma der heutigen Zeit Probleme mit dem Helligkeitspumpen bzw.- korrektur haben?! [Beitrag von Tzwän am 11. Jun 2013, 07:58 bearbeitet] |
RennMann
#792
erstellt: 11. Jun 2013, 08:25
@Hardrock Danke für die Einschätzung. Ich bin mittlerweile der auch der Ansicht, dass ich mir einen STW60 bestelle und einfach ausprobiere. Wenn mich der IL wirklich nervt dann geht das Ding halt zurück. Wobei ich nicht online zogge - für ein bissel Forza4 und Crysis2 wird die Kiste schnell genug sein hoffe ich. Gruß RennMann |
Duncan_Idaho
#793
erstellt: 11. Jun 2013, 10:25
Du hast noch nie wirklich Bose von Innen gesehen, oder? Die Einstiegsgeräte bei den anderen mögen jetzt nicht so der Brüller sein, aber gegen Bose sind selbst die noch Luxusprodukte. Generell würde ich in einen Amp eher 500+ und in LS 1000+ investieren, aber nicht jeder kann das. Und wer bei günstigen Amps die Bilder über das Gerät laufen lässt statt direkt zu gehen, nur um sich einen Knopfdruck zu sparen, dem ist auch nicht zu helfen. Nebenbei hoffe ich, dass du mit Kathode nicht ne Röhre meinst, die haben die Geräte nämlich gar nicht eingebaut. |
Hardrock82
#794
erstellt: 11. Jun 2013, 20:10
Nein habe ich noch nicht nach einigen negativen Dingen die ich im Netz mal gelesen hatte war die Firma nie für mich relevant. Da gibts bessere von Canton/Klipsche od. Nubert.
Hatte diesen Namen im Onkyo AVR Bereich aufgeschnappt, das was du meinst sind Kathodenröhren (hatte u.a mein alter Sony EX4). fakt ist dieser HDMI Board Fehler ist auch bei den teureren Modellen (bsp. 1009) und daher kommt Onkyo für mich nicht mehr in frage. [Beitrag von Hardrock82 am 11. Jun 2013, 20:10 bearbeitet] |
miscarriage
#795
erstellt: 11. Jun 2013, 21:38
Mein vorheriger 55" hing definitiv zu hoch, aber dieser hängt absolut goldrichtig. Ich denke, dass ist die Perspektive, die das ganze Erscheinungsbild etwas verfälscht |
Manjion
#796
erstellt: 12. Jun 2013, 20:57
Hallo, erstmal danke für die vielen nützlichen Infos hier! Kurze Frage kann der Pana Web-Browser Flash Inhalte darstellen? lg |
D.Smith
#797
erstellt: 13. Jun 2013, 14:03
Wo gibt es die 55 bzw 65 Zoll Variante gerade günstiger als UVP? |
Ralf_1
#798
erstellt: 13. Jun 2013, 17:35
Ganz spontan bei einem kleineren Elektro-/TV-Geschäft nachgefragt: 1649 inkl. Anlieferung, Aufstellen, Einrichten etc. Bevor ich es einem Großen in den Rachen werfe und nicht weiß wie die Spedition den Karton handhabt (Thema Plasma stehend transportieren etc.), kaufe ich dort. Unter 1699 gibts ihn offiziell kaum bis gar nicht. Denke Pana hat da ein Auge drauf und da wird sich die nächste Zeit auch nichts oder nicht viel am Preis tun. |
nt2008
#799
erstellt: 13. Jun 2013, 17:49
Schau mal hier rein, vielleicht ist das etwas für Dich Klick |
Ralf_1
#800
erstellt: 13. Jun 2013, 17:59
Äh, der TX-P55STW60E hat aber keine(n) Lüfter, oder? |
Duncan_Idaho
#801
erstellt: 13. Jun 2013, 18:40
Nö, ist ohne Lüfter. |
Deanaze
#802
erstellt: 14. Jun 2013, 11:19
Hallo Zusammen, da ein neuer TV ansteht und mich irgendwie diese bad News der LED HIghEndModelle F8090 oder W905 abschreckt soviel Geld in die Hand zu nehmen ist der TX-P55STW60 in den Fokus gerückt. Da ich überwiegend am Abend schaue, gern auch Sport denke ich mittlerweile das ich mit nem Plasma besser fahre. Eine Sache stört mich allerdings noch, diese 50HzBug Geschichte. Ist der beim TX-P55STW60 sehr stark ausgeprägt und kann man den ausschalten durch Zusatzfunktionen? Danke und Gruss, Chriss |
D.Smith
#803
erstellt: 14. Jun 2013, 17:46
Hi Leute War gerade im Satuxx und hab mir mal Plasmas und LCD angeschaut(Bin dem einen oder anderen nicht abgeneigt,wenn sie mich überzeugen können). Dort stand der 65Vt50(neben Pana 50etw60) und der 50VT60(neben55DTW60) direkt neben LCDs. Das Licht ist hier im Markt echt gut.Keine Neonlampen.Sehr gedämpftes Licht.Dunkler als wenn man jetzt zuhause sitzt. Das die Plasmas dunkler sein würden war mir klar,aber so krass hätte ich nicht gedacht. Hab bei beiden den THX Brightroom Modus aktiviert. Und die Farben kamen beim LCD besser rüber als bei beiden Plasmas(kein Dynamikmodus beim LCD). Das Bild wirkte bei den Plasmas zu LCD wie Modelle 2007 gegen 2013. Hab jetzt keinen anderen Vergleich, wie ich es sagen könnte.Ich habe auch Null unterschiede zwischen VT50 und VT60 sehen können.Ob Helligkeit oder Farbintensität. Leider hatten sie keinen STW60 da,wofür ich mich eigentlich Interessiert habe. Der müsste aber deutlich heller sein als die VT Kandidaten,sonst ist der raus. Ich erwarte kein Netzhautablösendes Weiss wie bei den LCD`s,aber das bei den VT/VTW war nur graues etwas. Das Bild hat mich überhaupt nicht überzeugt. Selbst bei der Pana Demo hatten die LCDs die besseren,satteren und Intensivieren Farben. Ich bin kein Plasmahasser oder Verteufler,sondern ich kauf was mir gefällt.Bitte das nicht Falsch verstehen. Ich muss mal bei Mediamarkt vorbeischeuen,ob die einen STW dort haben.Dort wird man leider von Neonröhren geröstet. Hier ein Paar Fotos vom Satuxx in Essen mit der Handycam aufgenommen. ETW60 ZU VT50 ![]() ETW60 ZU VT50 ![]() VTW60 zu DTW60 ![]() VTW60 zu DTW60 ![]() Einstellunge VTW60 ![]() EInstellungen VT50 ![]() Lichtverhältnisse ![]() Lichtverhältnisse |
Wodde
#804
erstellt: 14. Jun 2013, 18:09
Wenn die Lichtverhältnisse auf den Fotos tatsächlich dunkler als bei dir zuhause sind solltest du dir einen LCD zulegen. Ich persönlich würde bei solchen Lichtverhältnissen im WZ die Krätze bekommen |
D.Smith
#805
erstellt: 14. Jun 2013, 18:25
Ich wollte damit sagen.Sie waren zum verfassten Zeitpunkt dunkler als bei mir zuhause. Und zumindestens war das Licht nicht wie bei mir im Keller mit Kaltweiss Neonlampe. Unabhängig davon war das Bild mau,egal ob Licht gedämpft oder aus. [Beitrag von D.Smith am 14. Jun 2013, 18:26 bearbeitet] |
Unterschied ST60 und STW60 hampelmann21 am 30.06.2013 – Letzte Antwort am 16.02.2014 – 13 Beiträge |
Sitzabstand für Panasonic STW60 MrCornJulio am 16.10.2013 – Letzte Antwort am 29.11.2013 – 23 Beiträge |
DER Panasonic VT60/VTW60 3-D PlasmaThread spartain am 19.03.2013 – Letzte Antwort am 28.11.2024 – 21392 Beiträge |
Der Panasonic STW60 Settings Thread thomas036 am 01.06.2013 – Letzte Antwort am 30.10.2020 – 652 Beiträge |
Panasonic STW60 65 Zoll Probleme Reno_Raines am 24.08.2013 – Letzte Antwort am 05.09.2013 – 36 Beiträge |
VT50, VT60, STW60 - Fragen tiki22 am 10.07.2013 – Letzte Antwort am 13.07.2013 – 7 Beiträge |
Panasonic STW60 Homescreen abschalten und weitere Fragen? DonDigger am 09.07.2013 – Letzte Antwort am 03.12.2013 – 11 Beiträge |
VT50 oder STW60? obtFusi am 12.07.2013 – Letzte Antwort am 31.01.2014 – 6 Beiträge |
Unterschied zwischen STW60 vs GTW60 ?? schnippl am 11.09.2013 – Letzte Antwort am 30.12.2013 – 10 Beiträge |
STW60 GT60 VT50 telex am 03.06.2013 – Letzte Antwort am 25.11.2013 – 14 Beiträge |
- Teletext Problem
- Teletext Problem
- Registrierte Mitglieder930.523 ( Heute: 2 )
- Neuestes MitgliedVoWo
- Gesamtzahl an Themen1.563.064
- Gesamtzahl an Beiträgen21.815.907
