Brummen beimToshi 37 WL68P
Lykkesholm
#1 erstellt: 28. Mrz 2007, 20:31
I'm writing this in english because my written german is not as good as my written english...
I have just received a Toshiba 37 WL68P from digitalo.de and have discovered that the tv makes a noise (brummen)when the backgroundlight is between 0 and 93...
Do any of you guys out there have any experiences with this? Is this problem on all 37" from Toshiba, or should I change it to a 37 C3030D?
Once again sorry for writing english in a german forum... I do read and speak german ok...
Taylor23
#2 erstellt: 29. Mrz 2007, 08:13
Hi Lykkesholm,
Sorry to hear about your problem. This (so-called) "hum" (Brummen) at a panel brightness below 90 is already known in this forum but should be rather a problem of the previous series such as the WL66 as far as I know.
I possess the same TV as you and mine is absolutely quiet on all brightness levels. "Normally" this hum should decrease below a panel brightness of 30 from what I've read in some posts but you wrote it's still noticeable till 0.
How would you describe the "noise-level". Do you hear this hum only at very low volume of your TV or even at normal? From what distance are you still able to hear it?
Since you've ordered your TV online and you are still within the 2 weeks time-frame to send it back to your seller without any problems, I would make use of it.
Regards
Lykkesholm
#3 erstellt: 29. Mrz 2007, 13:55
Hi Taylor23,
In this case the humming (brummen) is only something you hear at low volume levels, but then it's also noticable.
I sit ca. 3 meters away from the TV.
I'm thinking of buying a 37 C3000P in stead, do you know if it delivers a good picture?
37"WL68P vs. 42"C3000P
Deniso11 am 28.04.2007  –  Letzte Antwort am 29.04.2007  –  4 Beiträge
Toshiba 37 WL68P vs 37 C3000P
HARKAR am 16.03.2007  –  Letzte Antwort am 30.03.2007  –  7 Beiträge
Wandmontage bei Toshiba LCD (WL68P)
MalNeFrage am 01.05.2007  –  Letzte Antwort am 26.05.2007  –  7 Beiträge
C3000P vs. WL68P
focus-lm am 14.04.2007  –  Letzte Antwort am 06.05.2007  –  11 Beiträge
Kaufentscheidung 32c3000p/wl68p/Sony ?
schwoerdi am 13.05.2007  –  Letzte Antwort am 06.06.2007  –  16 Beiträge
Toshiba 37C3000p oder WL68P
thonor am 03.07.2007  –  Letzte Antwort am 04.07.2007  –  6 Beiträge
Toshiba 37 WL 58 Brummen
henry24 am 22.02.2006  –  Letzte Antwort am 22.02.2006  –  2 Beiträge
X3030D vs. WL67Z vs. WL68P ?
Amistar am 22.03.2007  –  Letzte Antwort am 23.03.2007  –  3 Beiträge
toshiba 37 WL 66 ZS brummen
phipps am 12.12.2006  –  Letzte Antwort am 20.01.2007  –  12 Beiträge
Toshiba 37 WL 66 ZS ohne brummen?
marcel343 am 09.01.2007  –  Letzte Antwort am 23.01.2007  –  19 Beiträge
2007
  • Registrierte Mitglieder930.578 ( Heute: 1 )
  • Neuestes MitgliedRedx90
  • Gesamtzahl an Themen1.563.228
  • Gesamtzahl an Beiträgen21.819.601
Top Hersteller in Toshiba Widget schließen
