HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Sharp » Sharp LC-32RA1E flickering? | |
Sharp LC-32RA1E flickering?+A -A |
RaphV
13:12
erstellt: 02. Mrz 2007, |
Hello, Firstly i'm sorry to write in english. I can understand german but It's more difficult for me to write it. I've just bought a Sharp LC-32RA1E and I'm happy of the image quality. However I've a problem which disturbs me. I sometimes can see the image flicker. There is like waves on my image coming from the bottom of the screen. I'm receiving TV through ANALOG technology and the TV is connected with a 10meters long cable. What can be the origin of these "waves" (I thought LCDs normally don't flicker)?? |
olaf70
16:14
what is about flickering with dvd? and if you freeze the picture, is it still flickering? |
RaphV
17:00
I've to try that tonight and I'll give you the result. My first impression (because I've tried the freezing function) is that the waves continue when frozen. But I'll try again to be sure. |
RaphV
19:24
I've tried to freeze the TV image and also tried a DVD (connected through SCART) and to pause the DVD. The flickering is always there!!! ![]() I don't know if it's only an idea but i've the impression it's not on the whole image but only in the unicolor, not moving areas. For example, is someone is speaking on a blue background, the background flickers but the speaker doesn't. |
Hillox
12:46
erstellt: 05. Mrz 2007, |
I have an RA1E too and I don't know anybody who has the flickering you mentioned .. I think you should ask the support |
RaphV
22:33
I've tried to deactivate simultaneously the Analog TV and the DVD. I even tried to deactivate all my wifi connections and my Hifi (I thought at interferences), but the flickering doesn't want to go away. My latest chance is with Sharp Support I think, I've sent an email to my reseller to see how I have to do. I hope they'll help me ![]() How is the Sharp Support? |
RaphV
21:33
erstellt: 06. Mrz 2007, |
Before bringing the TV back to SHARP, I've tried the following: I've played the DVD Lord of the rings and pushed PAUSE. I saw the image flickering and when looking nearly at the image, I could see that the pixels in the "flickering area" always move, the image is not still (not ALL the pixels change tone of colour (become light blue and then dark blue again and so on), only some of them)! Is that normal on a LCD?? |
Hillox
21:41
i tried it just a moment ago and i am not able to see something like that ... so i dont think that it's normal... |
RaphV
22:52
Ok thanks for your test, I'll send the TV back to sharp ![]() |
olaf70
09:24
erstellt: 07. Mrz 2007, |
hi raph, ja, jetzt ist alles gut bei mir. ich habe in dem shop ein neues gerät erhalten. ich bin kein techniker, ich denke aber, dass eine art dimmer in dem gerät eingebaut ist. dieser scheint das flickern zu verursachen. never mind, wird schon alles gut gehen... gruß olaf |
RaphV
18:58
erstellt: 20. Mrz 2007, |
For those who have the same problem as I described. I've sent my TV back to Sharp and they repaired it. They told me it was a problem coming from a "platine". I have no idea what it is but the TV is now working. |
Hillox
22:30
great ... sharp support works , huh ? ![]() |
RaphV
23:05
erstellt: 22. Mrz 2007, |
Huh... I spoke a little bit to early! The problem didn't disappear!!! What happened is that sharp support did change a component (platine??) in the TV and then tested it with factory settings. The backlight was set to it's highest value and in this case the problem doesn't appear... I had to call back sharp and now I've to send them the TV a second time. I hope they'll test it right this time! So I'm not so happy of the efficiency of sharp support, but at least they're nice when you contact them. |
Hillox
23:25
eventually you should try other settings ... here is one setting working fine in germany ![]() hintergrundbel. 0 kontrast +30 helligkeit +6 farbe +10 farbtönung 0 schärfe +2 farbtemp. normal schwarzwert aus! schwarz weiss aus filmmodus an! trud ein I/P modus zeilensprung wenn über Scart 576i! Rauschunterdrückung gering Schnellbild ein OPC aus sorry that this is in germany .. |
RaphV
19:20
erstellt: 23. Mrz 2007, |
Thanks, but I do have almost the same settings as yours. The problem comes frome backlight (hintergrundbeleuchtung) when it's value is set lower than the maximum. It means that with the "hintergrundbeleuchtung" value set to 0 I have the flickering effect. I've tried many settings and finally concluded it comes from the backlight. The only problem is that sharp did try the TV only with backlight set to it's maximum value... In this case everything is ok! Note to Hillox: I can understand german but I'm bad at writing it! French would be even better than english ![]() |
Hillox
12:41
erstellt: 24. Mrz 2007, |
never learned french , so lets talk english ![]() well you should ask the support again .. flickering is not normal ! |
RaphV
14:46
Yep I've sent my tv back to sharp this morning. I'll keep you informed on the next episode ![]() This time I've wroten that they have to call me before sending the tv back to me, so I can know what they've repaired or changed... I don't want to be in the same situation again! |
RaphV
08:03
erstellt: 30. Mrz 2007, |
![]() ![]() Sharp called me yesterday. They told me they saw the problem with the parameters I gave them (the same in the precedent Hillox message). They also tested these parameters on another new LC-32RA1E and a 32GA9E. Both of them had also the problem, so he concluded that it's a problem present in all sharp tvs... It's really hard to believe!! I don't know what to do now! [Beitrag von RaphV am 30. Mrz 2007, 08:04 bearbeitet] |
Hillox
14:45
lol I don'T think that its a problem of all tv's , mine is working fine I think ... and why didn't they seen it before ? |
audio passthrue merlin1201 am 28.12.2012 – Letzte Antwort am 29.12.2012 – 3 Beiträge |
Sky Optionskanäle auf LC60LE652E alien43 am 17.09.2014 – Letzte Antwort am 20.10.2014 – 3 Beiträge |
Neue Sharp-Displays Anfang 2007: D92U / HD1E Braindead2k am 18.12.2006 – Letzte Antwort am 05.01.2008 – 1054 Beiträge |
Sharp shows off 65-inch LCD HDTV daniel_H am 07.10.2004 – Letzte Antwort am 08.10.2004 – 2 Beiträge |
PROBLEM MIT sharp lc-32ra1e defaultuser am 16.02.2007 – Letzte Antwort am 17.02.2007 – 2 Beiträge |
Sharp Modelle 2011 Honda_Steffen am 08.03.2011 – Letzte Antwort am 19.05.2012 – 105 Beiträge |
Sharp LC-32RA1E Einschaltprobleme TVJunkie555 am 01.01.2008 – Letzte Antwort am 04.01.2008 – 2 Beiträge |
Sharp 'Special Edition' SE94U Wiesenlooser am 15.04.2008 – Letzte Antwort am 16.04.2008 – 4 Beiträge |
Sharp X Serie 2008 ANDYx1975 am 09.04.2008 – Letzte Antwort am 16.07.2008 – 41 Beiträge |
Sharp LC-37 GA8E HDMI von PC DVI-I nutzen funky_b am 22.11.2006 – Letzte Antwort am 21.04.2007 – 14 Beiträge |
2007
Top Produkte in Sharp
Top 10 Threads in Sharp der letzten 7 Tage
- LC 37GA8E schaltet ein und sofort wieder aus
- Aquos LC-TV: Neue Fernbedienung koppeln
- Sharp LC-60LE635E Bildeinstellungen
- Programmweiterschaltung spinnt auf einmal!
- Fehlercode im Display Sharp Aquos TV K LC-B43CF5242EB
- SHARP LC42 XL2E Kein Bild nach einschalten ->Lösung!
- Programmliste ändern ? SHARP LE705E
- Probleme mit Aquos Net+ (Kein Dienst Verfügbar)
- SharpTV: keine Digitalen Programme über Kabel
- Kein Vollbild auf meinem Sharp 42 XD1E bei 16:9 Material
Top 10 Threads in Sharp der letzten 50 Tage
- Registrierte Mitglieder929.027 ( Heute: 14 )
- Neuestes Mitgliedevian1893
- Gesamtzahl an Themen1.559.508
- Gesamtzahl an Beiträgen21.728.199
