| HIFI-FORUM » Fernseher & Beamer » LCD-Fernseher » Sharp » Sharp 'Special Edition' SE94U | |
Sharp 'Special Edition' SE94U+A -A |
Wiesenlooser
erstellt: 15. Apr 2008, 19:21
Komisch, dass es noch keinen Thread. Der Fernseher ist in den USA schon erhältlich und ich frage mich, warum wir das Teil nicht kriegen. Sharp LC-65SE94U LCD TV The “Special Edition” AQUOS SE94U Series, in 65, 52 and 46-inch screen size classes, sets a new standard for large-screen flat-panel LCD TVs. With Full HD 1080p resolution, dramatically enhanced black level and an elegant new “cornerstone” design, it produces a breathtaking picture quality that is second to none. Full HD 1080p (1920 x 1080) Resolution 27,000:1 Dynamic Contrast Ratio and 4ms response time 120Hz Frame Rate Conversion Cornerstone Design for elegent placement in any room Five 1080p Compatible Inputs including three HDMI inputs Manufacturer's Description "The SE94U Series utilizes the next generation of Sharp`s proprietary Advanced Super View/Black TFT Panel providing 27,000:1 Dynamic Contrast Ratio and 4ms response time. In addition, the SE94U models include a groundbreaking AQUOS Net Feature for custom Web content through an Ethernet jack, as well as 120Hz frame rate conversion for the ultimate in fast-motion image processing. All models are HDTVs with built-in ATSC / QAM / NTSC tuners and include 3 HDMI(TM) inputs, compatible with “deep color" 1080p signals, and 2 HD 1080p component video inputs as well as RS-232C for control. The SE94U Series features a unique leather-based cabinet, with detachable, recessed bottom-mounted speakers and the included table stand easily removes for wall mounting applications. Full HD 1080p (1920 x 1080) Resolution for the sharpest picture possible. Next-Generation 10-Bit ASV LCD Panel from Sharp`s Kameyama factory, producing 27,000:1 Dynamic Contrast Ratio and 4ms response time. AQUOS Net delivers customized Internet content and live customer support via Ethernet, viewable in full-screen, split-screen or “widget" format. 120Hz Frame Rate Conversion for the ultimate in fastmotion picture quality. Cornerstone Design for elegent placement in any room, featuring unique leather-based finish. Wide Viewing Angles (176 degrees H x 176 degrees W) Sharp's AQUOS LCD TVs viewing angles are so wide, you can view the TV clearly from practically anywhere in the room. Enhanced Black Level provides the deepest, most accurate black of any flat panel TV. Five-wavelength Backlight System enables the display of very deep greens and crimson reds, widening the available color spectrum. High Brightness (450 cd/m2) AQUOS LCD TVs are very bright. You can put them virtually anywhere – even near windows, doors or other light sources – and the picture is still vivid. Built-in ATSC / QAM / NTSC Tuners provide access to DTV and analog TV channels. Five 1080p Compatible Inputs including three HDMI inputs (v 1.3 with deep color) and two HD component. Youtube VideoDen will ich haben http://theyatesfamily.smugmug.com/photos/270411198_ME7sd-L.jpg
ANDYx1975
erstellt: 15. Apr 2008, 22:07
Also Sharp hat den bis jetzt nicht angekündigt. Lediglich den XJ1. |
berti50
erstellt: 15. Apr 2008, 22:15
Sharp braucht dringend ein paar neue Designer |
trojarno
erstellt: 15. Apr 2008, 22:22
Allerdings!!! Die sollten sich mal nach einigen Designern aus der Automobilindustrie umsehen, in der sich mMn in der letzten Zeit designtechnisch wirklich viel getan hat! [Beitrag von trojarno am 15. Apr 2008, 22:23 bearbeitet] |
Sharp Vs. Sharp Duke1900 am 26.12.2010 – Letzte Antwort am 29.12.2010 – 10 Beiträge |
Sharp LC60LE830 VS Sharp LC60LE925 hannes456 am 16.10.2011 – Letzte Antwort am 21.02.2012 – 13 Beiträge |
Sharp LCD 77Tommy am 10.07.2005 – Letzte Antwort am 11.07.2005 – 4 Beiträge |
LC26GA4E Sharp ???? q12 am 15.11.2004 – Letzte Antwort am 16.11.2004 – 10 Beiträge |
Sharp LC30HV4E FranzFreddie am 30.10.2004 – Letzte Antwort am 05.10.2008 – 4 Beiträge |
Sharp P55 DusterBuster am 01.02.2006 – Letzte Antwort am 09.02.2006 – 5 Beiträge |
Sharp 37GA9E LCD_SHARP am 29.10.2006 – Letzte Antwort am 29.10.2006 – 5 Beiträge |
Sharp kaufen Os!r!s am 31.12.2006 – Letzte Antwort am 31.12.2006 – 4 Beiträge |
Sharp - Reimport storell am 26.03.2007 – Letzte Antwort am 30.03.2007 – 19 Beiträge |
Sharp LC52XD1E Hunter1817 am 27.03.2007 – Letzte Antwort am 02.04.2007 – 8 Beiträge |
Top 10 Threads in Sharp der letzten 7 Tage
- LC 37GA8E schaltet ein und sofort wieder aus
- Aquos LC-TV: Neue Fernbedienung koppeln
- Sharp LC-60LE635E Bildeinstellungen
- Programmweiterschaltung spinnt auf einmal!
- Fehlercode im Display Sharp Aquos TV K LC-B43CF5242EB
- SHARP LC42 XL2E Kein Bild nach einschalten ->Lösung!
- Programmliste ändern ? SHARP LE705E
- Probleme mit Aquos Net+ (Kein Dienst Verfügbar)
- SharpTV: keine Digitalen Programme über Kabel
- Kein Vollbild auf meinem Sharp 42 XD1E bei 16:9 Material
Top 10 Threads in Sharp der letzten 50 Tage
- Registrierte Mitglieder930.528 ( Heute: 9 )
- Neuestes MitgliedScotchWh1sky
- Gesamtzahl an Themen1.563.105
- Gesamtzahl an Beiträgen21.816.585
