Three odes to Apollo, God of music
aa22
#1 erstellt: 20. Feb 2010, 02:26
Ode # 1:
R120 triode (RT, la radiotechnique; securite, professionel, date unknown, made in France) triode. A single ended mono triode amplifier based on this great triode.
Driver stage: PTT200 (equiv. WE310a, but with different socket, LMT, date unknown, made in France)
Ode # 2:
Condensators: (NOS) Siemens flashlight condensors 400 microFarad, 330 Volt. Simply the best 4 high-end & "low-end" tube and transistor (be warned for transistors) amplifiers . Better than all esoteric-capasitors I know (My ultimate Geheimtip ;-)) Photocopier/Stroboscope-lightning-condensators. Lightning fast! Long live Siemens Germany!!
Ode # 3:
Previous, great sounding, driver stage: pcc88 in a kind of srpp mode(series regulated push-pull). Signal taken from Anode of the lower triode instead of from Kathode of upper triode. (Small change, but great improvement on SRPP, when we talk about making music.)
The previous driverstage DID make music, but Jean Hiraga (son roman s"appelle: "Initation aux amplis a tubes", hors serie Led audio, editions frequences) recommends penthode-penthode-triode. So I decided to give this a chance. With ancient! PTT200 penthodes.
Voici.
World best amplifiers are build today!
odes to Apollo, Greek God of music,
(diesmahl in meistens Englischer Sprache)\
Ihr weisst schon weshalb ;-)
aa22
#2 erstellt: 20. Feb 2010, 03:39
rorenoren
#3 erstellt: 20. Feb 2010, 03:43
Hi AA,
are you writing about DIY amps or are they factory made?
If DIY and not commercial, please post schematics.
Me and lots of people here are interested in new stuff.
I use flash capacitors (Rubicon, Hitachi) for years, but can not tell a difference to normal good capacitors.
(Philips)
Depending on the used voltage, the 330V may be a bit low.
These capacitors are made to be able to deliver very high current in short time.
(and are quite small for their capacity/voltage)
At least they are cheap, usually.
Greets, Jens
Edit, nice pic, but please give us schematics and more information on the design.
(tubes look similar to german AD1)
[Beitrag von rorenoren am 20. Feb 2010, 03:45 bearbeitet]
aa22
#4 erstellt: 20. Feb 2010, 05:15
1. DIY
2. R120 uses standard 2A3 schematic. R120 is better than 2A3 (according Jean Hiraga) and has different socket.
3. flash capacitors by Siemens beat all in my opinion. Every amp I know (including 'high-end'-transistor-based) is improved by Siemens. Es ist wirklich ein Geheimtip.
Ich werde mahl die schemas publicieren.
Mein Verstaerker waehrend die Umbau ist ein Philips AG9016 mono-penthode, 2 x 2 Watt! gespeist und teilweise entkoppled(??) von Siemens Elco's. Ist auch nicht slecht zum anhoeren;-). High-End ueber 2000Euro schaetze Ich.
Ich werde mehr informationen schicken. Die Platte worauf meine Verstaerker gebaut ist (chassis) ist reines Kupfer. Zwei C-cores vom Vacuumschmelze als Ausgangsuebertreiber habe Ich selbst gewikkelt. Die Platte hat die moeglichkeit zwei PTT200's extra zu erfaschen.
(Meine driver mit den doppeltriode PCC88 war extern.)
Ich brauche jetzt nur ein Transformator fuer 2 x 10 Volt, 0,4 A als gluhspeisung fuer die PTT200's , Ich werde Mahl in die Stadt gehen.
Die R120 liefert 3,5 Watt pro Kanal. Und das reicht fuer ein 60 kubicmeter Wohnzimmer volkommen.
Rorenoren: Schade dass Sie bis jetzt nicht die flash Kondensatoren von SIEMENS probiert hasst, Sie werden sich staunen...
Es wird sicher kein factory-made Verstaerker von mir geben.
Heutzutage:
Als Endroehre kommt eigentlich nur die WE300B im Frage. Die Koeniging der Trioden.
Die wird wieder neu fabrisiert.
Hat mehr Leistung als die R120.
Und als Driver, Vorstufe, hat Mann die Wahl zwischen PCC88 und ECC88 in verbesserte SRPP-schaltung oder eben ein classischer Penthode-schaltung.
[Beitrag von aa22 am 21. Feb 2010, 01:47 bearbeitet]
aa22
#5 erstellt: 20. Feb 2010, 05:19
PS:
I am sorry, Philips really make/made the worst capacitors I've ever heard.
aa22
#6 erstellt: 20. Feb 2010, 05:58
Triode Driver-stage Verbessert:
anode2
gitter2
kathode2--------------->Standard SRPP Schaltung--->next stage
katode widerstand2
anode1----------------->Verbesserte Schaltung------>next stage
gitter1
kathode1
kathodewiderstand1
Erde1
Kosten: Nihil,ausser ein wenig Arbeit.
Baten: Um eintausend Euro verbessertes verstaerker.
[Beitrag von aa22 am 21. Feb 2010, 01:49 bearbeitet]
aa22
#7 erstellt: 20. Feb 2010, 06:09
Wenn Mann sehr gut hinschaut, wird Mann es schon verstehen
[Beitrag von aa22 am 21. Feb 2010, 01:50 bearbeitet]
aa22
#8 erstellt: 20. Feb 2010, 06:27
Und ez40 doppelt-dioden fuer die gleichspannung.
Sogar hinter 2 x 8H Drosselspuelen lohnt es sich Roehrengleichrichter zu benutzen.
Und fuer die Gluh-drahte Wechselspannung benutzen, fuer ein langes Leben der Roehre und bessere Audio-resultaten.
Bis bald,
AA
GorgTech
#9 erstellt: 20. Feb 2010, 13:06
ein Röhrengleichrichter wird meistens aus anderen Gründen eingebaut ( Optik, einfache Einschaltverzögerung der Anodenspannung ohne NE555 Schaltung, Nostalgie etc.).
Am eigentlichen Klang verändert ein Röhrengleichrichter nichts, technisch betrachtet ist dieser sogar schlimmer als die Verwendung von Si-Dioden -> es wird unnötig Energie verheizt, der Innenwiderstand und resultierende Spannungsabfall des Gleichrichters ist sehr groß, der Wirkungsgrad eher bescheiden...
Ich verwende auch gerne hin und wieder Gleichrichterröhren in Selbstbauprojekte ( hauptsächlich wegen der Optik um ein stimmiges Gesamtbild zu erhalten ).
Gruß,
Georg
E130L
#10 erstellt: 20. Feb 2010, 19:53
...und 400µF Siebelkos vertragen sich mit einer EZ40 auch nicht sehr gut evtl. Drosseln davor machen das auch nicht besser!
MfG Volker
aa22
#11 erstellt: 20. Feb 2010, 20:25
Bei Monotriodeverstaerker kann mann den Unterschied zwischen heisses Vacuum und verschmutztes kaltes Silicium fuer die Gleichrichter sehr gut hoeren. Silicium verschmutzt die Klaenge wesentich.
Die Triode AD1 wird von Jean Hiraga auch sehr empholen, vor Allem die von Loewe Opta.
AD1 liefert 4,2 Watt, R120 liefert 3,5 Watt.
Geheimtip:
Last Man Standing
Original Motion Picture Soundtrack
Beste Platte (Klangtechnisch) von Ry Cooder.
[Beitrag von aa22 am 21. Feb 2010, 01:53 bearbeitet]
aa22
#12 erstellt: 20. Feb 2010, 20:44
noch ein Bild. Mit die PTT 200 und selber gebastelte Roerenfusse.
aa22
#13 erstellt: 20. Feb 2010, 20:45
aa22
#14 erstellt: 20. Feb 2010, 22:04
Re : ..und 400µF Siebelkos vertragen sich mit einer EZ40 auch nicht sehr gut evtl. Drosseln davor machen das auch nicht besser!
Die Drosseln haben ein Innenwiderstand von 60 Ohm.
Und die zweimahl pro Kanal. Zusammen mit ein ohmser widerstand von 121 Ohm macht das 241 Ohm.
Die 400 microFarad Siebelco's sind schon geladen bevor die AZ40's voll funktionieren. Seit ueber 10 Jahre geht dass schon gut, brauchte niemahls Roeren zu wechseln.
[Beitrag von aa22 am 20. Feb 2010, 23:03 bearbeitet]
DB
#15 erstellt: 21. Feb 2010, 10:41
ein Schaltplan wäre schon mal interessant.
Zum Philips AG9016: hatte ich auch mal. 1990 für 15,-DM gekauft. Rausgeschmissenes Geld, schade drum.
Jedes DDR-Röhrenradio der 60er Jahre hatte bessere Ausgangsübertrager.
MfG
DB
aa22
#16 erstellt: 22. Feb 2010, 01:56
Ich und viele Anderen werden Heutzutage ohne Problem das zehnfache zahlen fuer ein gut spielender Philips AG9016.
Ich kenne die alte DDR Sachen nicht, Schade, damahls wurde nur wenig aus dem DDR ins Westen exportiert.
Aber Ich bin interessiert in DDR-Trioden mit mindestens 15 Watt Anodenleistung.
DB
#17 erstellt: 22. Feb 2010, 08:10
Da gibt es nur eine einzige, die EC360 und die ist nicht besonders für NF-Verstärkung geeignet, da um die 40% Durchgriff und sehr klinganfällig.
MfG
DB
aa22
#18 erstellt: 23. Feb 2010, 02:56
einige Bilder
aa22
#19 erstellt: 23. Feb 2010, 03:01
1
aa22
#20 erstellt: 23. Feb 2010, 03:02
aa22
#21 erstellt: 23. Feb 2010, 03:06
2
aa22
#22 erstellt: 23. Feb 2010, 03:21
aa22
#23 erstellt: 23. Feb 2010, 03:23
aa22
#24 erstellt: 23. Feb 2010, 03:30
ist mir zu Aufwendig, hier Bilder zu uploaden.
Chao, also.
aa22
#25 erstellt: 23. Feb 2010, 04:02
http://s12b.directupload.net/file/d/2079/b9bcd625_jpg.htm
Also vielleicht hat man Recht, die Gleichrichterroehre ist vielleicht ueberlastet in mein Design. Werde das nogmahls ueberpruefen, wie das wirklich aussieht.
[Beitrag von aa22 am 23. Feb 2010, 04:19 bearbeitet]
aa22
#26 erstellt: 23. Feb 2010, 04:27
es ist nicht so schlim wie es ausseht:
http://s11b.directupload.net/file/d/2079/ibyl6p9j_gif.htm
[Beitrag von aa22 am 23. Feb 2010, 04:29 bearbeitet]
DB
#27 erstellt: 23. Feb 2010, 07:03
interessanter als Röhrendatenblätter wäre die Schaltung.
MfG
DB
Erfahrungen PrimaLuna Prologue Three / Four
terry69 am 14.05.2007  –  Letzte Antwort am 14.05.2007  –  3 Beiträge
Music Angel - Music Curve
Edison am 16.06.2005  –  Letzte Antwort am 28.06.2005  –  11 Beiträge
Music Angel
Syntropus am 31.01.2008  –  Letzte Antwort am 03.02.2008  –  7 Beiträge
Music Angel
PeHaJoPe am 25.03.2008  –  Letzte Antwort am 14.04.2008  –  24 Beiträge
Music Angel
safena am 16.11.2011  –  Letzte Antwort am 18.11.2011  –  3 Beiträge
Music Angel 300B
I.Q am 10.04.2006  –  Letzte Antwort am 19.04.2006  –  5 Beiträge
Music angel EL34
mark1810 am 10.11.2007  –  Letzte Antwort am 14.11.2007  –  7 Beiträge
Music Angel 845 Chinaröhrenverstärker
kraftroehre am 16.11.2007  –  Letzte Antwort am 18.09.2009  –  22 Beiträge
Music Curve 2020 / KT88
schirmgitter am 05.09.2012  –  Letzte Antwort am 11.09.2012  –  6 Beiträge
Cayin A88T clear to land
prontosystems am 11.01.2014  –  Letzte Antwort am 27.02.2014  –  12 Beiträge
  • Registrierte Mitglieder930.523 ( Heute: )
  • Neuestes Mitglied
  • Gesamtzahl an Themen1.563.060
  • Gesamtzahl an Beiträgen21.815.794
