BlackBerry PlayBook VS iPad, enjoy DVD/Video with a tablet PC and mobile phone.
wzhang48
#1 erstellt: 01. Apr 2011, 05:38
Now that RIM has finally unveiled their iPad rival, the BlackBerry PlayBook, we thought some of you would appreciate a summary of how the PlayBook excels when directly compared to Apple’s iPad.
Let’s start with physical design, the PlayBook is just 10mm thick, whereas the iPad is 13.4mm thick, also the PlayBook weighs less at just 0.9lbs, whereas the lightest iPad weighs 1.5lbs. To be honest the weight difference isn’t surprising as the iPad’s 9.7 inch display is larger than the PlayBook’s 7 inch display.
The clarity of the displays should be pretty similar, this is because the PlayBook’s 7 inch display supports a resolution of 1024 x 600, whilst the iPad’s 9.7 inch display outputs at 1024 x 768.
The PlayBook should offer a great web experience as it features full Adobe Flash 10.1 and HTML 5 support, at the moment a high percentage of websites use Flash, however in the future it is thought that HTML 5 will take over, therefore the PlayBook should be compatible with pretty much every website you tried to view.
One thing I dislike about the iPad is the need for accessories such as the iPad Camera Connection Kit and the iPad Dock Connector to VGA Adapter, the PlayBook features a built-in microUSB connector and micro HDMI, these standardized connectors should allow you to easily connect your PlayBook to a wide-range of devices with a wide-range of cables.
The micro HDMI output allows your to connect your PlayBook to an external HD display, according to RIM’s website you will be able to stream video at 1080p, which is far superior to the iPad’s 576p output (via the Apple Component AV Cable).
When the iPad was revealed I was surprised that there was no built-in camera, the PlayBook features two camera, a 5 megapixel rear-facing camera and a 3 megapixel front-facing camera for video conferencing, these additions increase the PlayBook’s appeal, however no-doubt also increase its price.
Finally we will talk about performance, so far we haven’t seen a proper hands-on demo, however we do know that the PlayBook is capable of true multi-tasking, this is thanks to the combination of a 1 GHz dual-core processor, 1GB of RAM and BlackBerry Tablet OS, it will be interesting to see how this compares to the iPad’s 1GHz single core processor, 256MB of RAM and iOS.
The iPad’s build quality and software interactivity are in my opinion its best qualities, therefore I am sure RIM will do their utmost to match this, if the build quality of BlackBerry smartphones is anything to go by the PlayBook should be OK, however I do feel that RIM have a long way to come with touch screen intuitivity, what do you think?
Now I will introduce you an all in one solution. Only one program will help you solve all your questions, that is Nidesoft DVD Ripper Suite. This program consists of two wonderful software: Nidesoft DVD Ripper and Nidesoft Video Converter. Nidesoft DVD Ripper is an excellent software with powerful functions that can convert DVD files to almost all popular video and audio formats including MP4, MP3, AVI,WMV, 3GP, AVC, AAC,etc. Nidesoft Video Converter can convert between almost all popular video and audio formats so that you can get movies and music from any format files. The quality is high and the speed is super fast. Also it is easy to use, only a few clicks were needed.
You can free download the Nidesoft DVD Ripper and Video Converter from this link:
http://www.nidesoft.com/dvd-ripper.html
Then I will introduce you how to get movies and music from DVD and other video files with this powerful program.
How to get movies and music from DVD?
Step 1: you may open the Nidesoft DVD Ripper and load DVD movies first.
a.Open the Nidesoft DVD Ripper Suite you have just downloaded, click “DVD Ripper”, then you may get the software Nidesoft DVD Ripper.
b.Insert the DVD disc into the DVD Drive
c.Click the Open DVD button, browse your computer, find the DVD folder of the movie and open it.
After add your movie, you can click any title or chapter to preview it in the preview window on the right. Then you can choose any titles or chapters you want to convert by click the check boxes before them. In this way, you can choose to convert DVD with the entire movie or just convert one or several chapters.
Step 2: Nidesoft DVD Ripper has powerful functions that enable you edit your video during conversion. You may use the functions below to make your perfect video.
Merge: A regular DVD movie has several chapters, you can convert several chapters into one by click the blank box before merge into one file. Click the check box before any chapter you want and merge them into one file.
Crop: you can cut off the black edges of the DVD movie to watch in full screen by click the crop button. A window will be opened and you can customize the size of screen by your will.
Effect: Click the Effect button you can set special effect including gray effect and negative effect.
You can also set the brightness, contrast, saturation and volume.
Trim: as you have selected the clips to convert, you can trim any segment of the clips by clicking the trim button. You can move the slide below the screen or set the start
time and end time to trim any segment.
Step 3: you may customize the output video with its full functions.
Audio Track: Select an audio track from the available audio tracks of your DVD movie.
Subtitle: Common DVD movies have several subtitles such as English, Chinese, French, etc. You can choose one language you prefer or select “None” to delete subtitle.
Profile: Click the button and show the list of profiles, you can select the profiles you want. For example, if you want to convert your DVD movies to your iPod video player, click the “iPod video MPEG-4 (*.mp4)”.
Note: If you don’t know which format to convert, you may choose the profile according to your portable player. For example, if your portable player is PSP, choose the profile “PSP Video MPEG-4 (*mp4)”
Step 4: now you can start your conversion.
After the settings finished, you can just click the convert button to start the conversion. You can view the conversion speed at the bottom. The conversion will be completed in few minutes.
How to convert video or audio files to some formats which your player supports?
You can free download the Nidesoft Video Converter from this link:
http://www.nidesoft.com/video-converter.html
For example, you have downloaded a file from YouTube is in “flv” format and you may follow the way below to convert the flv files or other video files in your computer into your portable player.
Step 1: open the Nidesoft Video Converter and load files.
a.Open the Nidesoft DVD Ripper Suite you have just downloaded, click “Video Converter”, you may get the software Nidesoft Video Converter.
b.click "add Files" button and import the videos from your computer. Nidesoft video converter supports batch conversion so you can import multiple files at one time.
c.EDIT the video with the function button:
Crop, Effect, Trim, Options
(1)Crop: Remove the undesired area or just convert part of the video area from your video file by dragging the frame around the video or setting the crop values: Top, Button, Left and Right.
(2)Effect: You can select gray effect or Negative effect from Special Effect or tune the Brightness, Contrast, Saturation and Volume to get special effect movie.
(3)Trim: To get your favorite segment by setting the “Start Time” and “End Time” or dragging the Start Time slider to set the start time and dragging the End Time slider to set the finish time.
(4)Options:
Set video Resolution, video Bitrate, Audio Channels, and Audio Bitrate to customize the output video's quality.
Note: You could click the white box besides "Merge into one file" to merge your selected titles into one video before starting the conversion.
d.Select the out file format
Click the “format” drop-down list to select the output format. If you don’t know what formats your device supports, you can just select the format according to the device name.
e.Click the "Convert" button and start the conversion. Please wait a few minutes before the conversion succeeds!
Ok, now you have got music from videos and next what you need to do is enjoying it. At last, we strongly recommend to to try Nidesoft Blu Ray Ripper, which could convert Blu-Ray disc to many video and audio formats. And, if you have any questions, please visit Nidesoft Studio homepage to get more details information of the products.
JVC DR-M10 and reading disc with pc
TheOner am 11.01.2006  –  Letzte Antwort am 09.02.2006  –  2 Beiträge
set top box and dvd recorder with rf input
hilfehilfehilfe am 24.04.2018  –  Letzte Antwort am 26.04.2018  –  12 Beiträge
DVD-Recorder und Video/Foto
langmoni am 02.01.2005  –  Letzte Antwort am 15.01.2005  –  3 Beiträge
DVD statt Video Recorder?
petrawi am 06.04.2004  –  Letzte Antwort am 06.04.2004  –  8 Beiträge
Was ist DVD-Video?
songokubvb am 20.04.2005  –  Letzte Antwort am 20.04.2005  –  2 Beiträge
Video auf DVD
Horus am 07.03.2013  –  Letzte Antwort am 08.03.2013  –  5 Beiträge
Thomson 8550E Formatierung ab harddisk
Tvdegn am 25.04.2006  –  Letzte Antwort am 13.02.2007  –  2 Beiträge
dvd recorder vs. dvd player
Butty am 04.03.2007  –  Letzte Antwort am 04.03.2007  –  2 Beiträge
DVD-/HDD-Recorder vs. HTPC
Hansanaut am 19.06.2008  –  Letzte Antwort am 13.10.2008  –  9 Beiträge
LG RH188B * gebrannte Video-DVD erkennt der PC nicht.
thommythomm am 23.03.2007  –  Letzte Antwort am 26.03.2007  –  9 Beiträge
2011
  • Registrierte Mitglieder929.754 ( Heute: 1 )
  • Neuestes MitgliedCoreyKer
  • Gesamtzahl an Themen1.561.116
  • Gesamtzahl an Beiträgen21.767.497
