philips wechselkoffer fwv994
inecik
#1 erstellt: 27. Feb 2023, 11:34
Hi friends,I have a plattenspieler with amplifier, model no philips wechselkoffer fwv994. the record player is 22GC036 but the amplifier have no type no.I think that; The sound is low, for yo why is it?there is 15VDC after rectifier and two electrolitic capacitor on amplifier board, can They cause?
inecik
#2 erstellt: 27. Feb 2023, 11:39
fwv994fwv994
inecik
#3 erstellt: 27. Feb 2023, 11:41
fwv994
Ingor
#4 erstellt: 27. Feb 2023, 15:18
What means low? No sound? Low clear sound? Low distorted sound? Low in comparison to what?
On the amplifier boards are 3 electrolytic capacitors. Two that stand up and on is lying near the the two transistors. The amplifier has 4 transistors, the AC 188 and 187 are complementary Germanium transistors. Be carefull this transistors are relatively expensive.
Did you make a measurment on the amplifiere board already?
inecik
#5 erstellt: 27. Feb 2023, 16:13
there is low clear sound and two electrolitik capacitor, 2500uf-15v and 100uf-10v.how will I make a measurement on the board.
inecik
#6 erstellt: 27. Feb 2023, 16:14
sorry 1000uf-10volt.
Ingor
#7 erstellt: 27. Feb 2023, 17:27
Electrolytic condensors
3 eletrolytics
inecik
#8 erstellt: 27. Feb 2023, 19:22
Hi Ingor you are right sorry, just now I looked careful and there are two electrolitic cap. ( same value 100 uf-15v) and 1000uf-10 v
Ingor
#9 erstellt: 27. Feb 2023, 21:56
You could change these three capacitors, but this is only try and error. Do you have knowledge of electronics?
inecik
#10 erstellt: 28. Feb 2023, 15:51
yes I can replace thats capasitors.
Ingor
#11 erstellt: 28. Feb 2023, 16:29
Before you change anything. Connect an external audio signal to the amplifier. The old audio catridges tends to degrade. So the amplifier is fine, but the signal from the "needle" ist to small.
inecik
#12 erstellt: 01. Mrz 2023, 09:04
O.K I will try your recommendation.
What is it?
didyman am 21.08.2008  –  Letzte Antwort am 23.08.2008  –  4 Beiträge
Lux SQ 1220 - Is there anybody out there...?
fbaihofer am 15.12.2004  –  Letzte Antwort am 22.10.2009  –  19 Beiträge
Dual CL 138
kikala5 am 18.04.2018  –  Letzte Antwort am 20.04.2018  –  5 Beiträge
Sanyo JCX 2100LE?
colamange am 25.02.2006  –  Letzte Antwort am 26.02.2006  –  2 Beiträge
Marantz 2500 fan voltage?
anderslober am 04.07.2011  –  Letzte Antwort am 04.07.2011  –  5 Beiträge
Old amplifier & impedance diffrences.
muhmaku am 04.09.2006  –  Letzte Antwort am 04.09.2006  –  2 Beiträge
Telefunken Boxen TL-80
peters8 am 05.06.2014  –  Letzte Antwort am 10.06.2014  –  6 Beiträge
Revox B-150
d.genchev am 17.05.2022  –  Letzte Antwort am 01.02.2023  –  9 Beiträge
Exotic German/Japanese Power Amp Continental GA-COMPO A
matijaudio am 18.01.2015  –  Letzte Antwort am 21.01.2015  –  3 Beiträge
Kenwood KT-3300SD tuner - does it exist?/
Nick_G am 21.10.2010  –  Letzte Antwort am 21.10.2010  –  3 Beiträge
  • Registrierte Mitglieder928.914 ( Heute: 2 )
  • Neuestes MitgliedVanypedia
  • Gesamtzahl an Themen1.559.272
  • Gesamtzahl an Beiträgen21.722.021
