| HIFI-FORUM » Car-Hifi » Car-Hifi: Lautsprecher » Frontlautsprecher für Ford Escort MK4 | |
Frontlautsprecher für Ford Escort MK4+A -A |
azar
erstellt: 24. Jul 2004, 22:54
Hi everybody!! Sorry for writing this in English, but my German is quite poor and as I'm about to order some stuff from Germany(I'm from Denmark) and this is one of the best and biggest german forums I've found, I thought I should try to ask you people! I have a Escort from 1989 and want to buy a new HU and some new front speakers. So far my choice of HU has fallen on a Pioneer DEH-P5630MP for 185 Euro. My problems are regarding the front speakers. The original ones are 13 cm and are mounted at the foot end on either side. I want to just mount the new speakers in the same place as the original and want to ask if anybody with knowledge about escorts knows how deep the speakers are allowed to be. I've looked at these canton RS 13 cx: http://www.hirschill...224&products_id=1046The "einbautiefe" is 56 mm. Do you know if they will fit. Otherwise you are welcome to comment on the Pioneer HU and the cantons. As the speakers are only driven by the HU, is this a good choice then?? Otherwise what can you recommend? Thanks in advance. You're welcome to answer in German as I understand it pretty well. |
matzesstyle
erstellt: 25. Jul 2004, 08:16
Hallo, Du könntest doch ganz einfach dein Fenster runterkurbeln, die Frontlautsprecher rausschrauben und nachmessen! Dann hast du in etwa die Einbautiefe! Eine gute Wahl ist es nicht unbedingt, die Lautsprecher an Radio anzuschließen, besser an einen seperaten Verstärker! Ich denke an den Komponenten gibt es ansonsten nicht viel zu mängeln! Die sind schon in Ordnung! mfg Matze (If you understand just the half I wrote, I would try in english too) |
azar
erstellt: 25. Jul 2004, 12:16
Thanks. I understand you perfectly. Yes, I know that a amplifier would be the best, but I've decided not to put too much money on the system as it's a quite an old car. Also I know component speakers would be a better solution, but will it make much difference when you're not using an amplifier? Also I'm not sure where and how to install the tweeter. And I suppose I also have to buy speaker cable then and run them from the HU to crossover to speakers. As I'm no handyman even simple things like that looks like a tough job to do.. |
matzesstyle
erstellt: 25. Jul 2004, 12:59
Ja, KomponentenSysme sind in der Regel besser! Da der Tweeter höher ober verbaut werden kann, somit ist die Bühne auch weiter oben, was halt besser klingt! Auch der Unterschied MIT Verstärker ist deutlich hörbar! Ein mal der Pegel, die ganze Dynamik, die Musik scheint freier zu spielen. Denk auch mal daran, dass du eine Hifi-Anlage auch immer größtenteils übernehmen kannst! Daher macht ein Verstärker auch Sinn! Kannst später in dein nächsts Auto übernehmen! Wo und wie das entscheidest du! Da wo er am besten klingt für dich! Und beim WIE, kannste dich dann kreativ auslassen! Mit den Kabeln hast du richtig erkannt, ist schon eine Mehrarbeit, lohnt sich aber meines Erachtens! |
azar
erstellt: 25. Jul 2004, 13:44
Thanks very much for the quick answers. I will consider buying a component set then, maybe these canton RS 2.13: http://www.hirschill...1_22&products_id=977They are the same price as the coaxials. Then later if necessary I can then upgrade the system with an amplifier. |
matzesstyle
erstellt: 25. Jul 2004, 13:57
Kein Problem! Das halte ich für sinnvoll, später nochmal eine Endstufe zu kaufen, um das Canton da anzuschließen! Würd dir beim Canton aber dringend raten, dir das vorher anzuhören! Canton ist gewöhnlich recht schrill im Hochtonbereich, aber sonst ein sehr gutes System! Und ich würd wirklich das Compo nehmen anstatt dem Koax! Bringt dir wirklich mehr Klang ins Auto! [Beitrag von matzesstyle am 25. Jul 2004, 13:57 bearbeitet] |
Subwoofer für Ford Escort DomF am 31.10.2008 – Letzte Antwort am 31.10.2008 – 7 Beiträge |
Frontlautsprecher für Escort gesucht mr2sup am 16.09.2015 – Letzte Antwort am 17.09.2015 – 5 Beiträge |
Rainbow slx 265 + ford escort DiCraft am 22.08.2004 – Letzte Antwort am 23.08.2004 – 2 Beiträge |
Lautsprecher Ford Escort petromax_no1 am 25.12.2004 – Letzte Antwort am 26.12.2004 – 5 Beiträge |
Ford Escort Kombi Lautsprechereinbau benji1402 am 13.05.2007 – Letzte Antwort am 05.04.2010 – 8 Beiträge |
Fensterkurbel Ford Escort Demontage Fescort am 26.06.2008 – Letzte Antwort am 27.06.2008 – 2 Beiträge |
Ford Escort Cabrio Boxen qlimax1990 am 25.12.2009 – Letzte Antwort am 27.12.2009 – 3 Beiträge |
Boxen für Ford Escort Champ? -=Audio_Man=- am 28.06.2004 – Letzte Antwort am 28.06.2004 – 2 Beiträge |
Fs für Ford Escort Cabrio Bedboy am 27.04.2005 – Letzte Antwort am 29.04.2005 – 4 Beiträge |
FORD Escort (Kombi) gute LS !? Haki-28 am 03.02.2006 – Letzte Antwort am 03.02.2006 – 3 Beiträge |
2004
Top 10 Threads in Car-Hifi: Lautsprecher der letzten 7 Tage
- Option Lautsprecher = Eton Lautsprecher
- 3 Ohm Lautsprecher an 4 Ohm Endstufe
- Plus und Minus am Lautsprecher???
- Linker Lautsprecher ohne Funktion
- Lautsprecher Rauschen bei 0 Lautstärke
- Wie HPF und LPF für Lautsprecher einstellen?
- Lautsprecher brummt bei hohen Bässen
- Lautsprecher Caddy hinten
- Unterschied Tieftöner und Mitteltöner
- Boxen pfeifen beim gas geben mit . warum !
Top 10 Threads in Car-Hifi: Lautsprecher der letzten 50 Tage
- Registrierte Mitglieder930.940 ( Heute: 6 )
- Neuestes MitgliedBifob
- Gesamtzahl an Themen1.564.219
- Gesamtzahl an Beiträgen21.847.201
