ARC AUDIO RS 6.0 vs Blam signature - which one is better
bladest
#1 erstellt: 09. Feb 2020, 01:23
Hi my current system p99rs , front morel virtus nano 602, tweeters morel piccolo,
rear speakers jl audio c5 650,
sub audison apbx 10as
amps mosconi pico 2 x , 3 1 for low 1 for high 1 for mid ,
i will replace soon with mosconi as 100.4
i am planning upgrading rear speakers
arc audio rs 6.0 or blam signature here are the specs can u tell me which one of these is better
Speaker Size 6.5"
Speaker Type Midrange -Raw Driver
Power Handling (Peak) 200 Watts
Power Handling (RMS) 80 Watts
Frequency Response 50Hz - 9.5kHz
Sensitivity 91.5dB
Impedance 4 ohms
Basket Material Cast Aluminum
Cone Material Composite Papyrus filled Paper
Surround Material Low Shore Rubber
Spider Material Synthetic Progressive Nomex
Motor Structure Multi-Step CNC Precision cut
Copper Shorting Ring Yes
Voice Coil CCAW
Mounting Depth 2.75"
Cutout Diameter 5.812"
Maximum Outer Diameter 6.654"
Mounting Flange Thickness .184"
Grills Included No
ars 6.0 specs.
here are blam signature specs
165.300 - keep in mind i dont need cross overs or other speakers, or tweeters which will be included in the set.
u can see their full specs here
https://www.blam-aud...019/07/S-165.300.pdf
Component Woofer
Max power 250 W
Nominal power 125 W
Impedance 2 Ω
Freq. Response 50 Hz - 5 KHz
Sensitivity (2,83V/1m) 93,2 dB
Magnet Ferrite
Magnet size Ø x h 100 x 20 mm 3,937 ‘’x 0,787 ‘’
Total driver displacement 0,3 l 0,011 cf
Weight of one component 1,81 kg 2,756 lb
Voice coil Ø 38 mm 1,496“
Voice coil height 17 mm 0,669“
Cone Carbon fiber
Joze1
Moderator
#2 erstellt: 09. Feb 2020, 08:20
Since you don't need rear speakers for a stereo system, you can just save your money. Stereo consits of two sound sources, not four.
If you necessarily want rear speakers (for whatever reason) buy the same as in the front to make sure to not have any phase issues. You can then either turn them down and only use them with passengers in the rear seat or you can use them with a corrected time alignment.
Neruassa
#3 erstellt: 09. Feb 2020, 09:41
Hallo Julian, spare dir deine Kraft.
Der TE stand mit mir in PM Kontakt und es hatte weder Hand noch Fuß.
Selbst nachdem ich ihm erklärt habe, dass sein P99 eingestellt werden muss, hat er nicht ansatzweise darauf reagiert und mich gefühlt jede Nachricht über irgendwelche neuen Lautsprecher gefragt, welche die besten sind... Vorhin auch wieder... Welche sind dir Weltbesten Hochtöner... Welche sind die besten TMTs... Dabei weiß er nicht mal, wie er die einbaut, geschweige denn Einstellt. Aber in der nächsten Nachricht, du wirst es wohl kaum glauben, fragt er nach dem nächsten Paar, ob die die besten sind...
Spar dir das Engagement, bzw wenn du PMs bekommst. Es verläuft im endlosen Kreis.
Ergebnis nach 15 PMs, siehst du hier. Er fragt nach den nächsten High End Hochtöner ob das die besten auf dem Planeten sind...
Er weiß nicht mal genau wie er das Zeug einbauen soll, selbst nachdem ich ihm Threads geschickt habe (KEINE REAKTION), und er hat auch niemanden, der einen DSP einstellt.
Der Sinn der ganzen PMs war jede Nachricht einen neuen Lautsprecher zu nennen um zu fragen, welcher der beste ist. Selbst nach meiner Antwort dazu, du kannst es dir wohl denken, kam in der nächsten PM der nächste LS...
[Beitrag von Neruassa am 09. Feb 2020, 09:44 bearbeitet]
Car-Hifi
#4 erstellt: 09. Feb 2020, 10:46
Mit mir auch.
Das selbe hier.
Ich habe es allerdings etwas früher geschafft, die Konversation zu beenden.
bladest
#5 erstellt: 09. Feb 2020, 16:31
The P99
IS Setted up and tuned professionally by car audio shop for $$$$.
i have not setted it by my self installation of everything is made,
Joze1
Moderator
#6 erstellt: 09. Feb 2020, 17:51
If it is set up and tuned already for the components you have right now, then it makes no sense to change the speakers. You would have to tune it again for $$$$.
Which amp?
KAMENi am 13.12.2004  –  Letzte Antwort am 15.12.2004  –  26 Beiträge
which sub?
josmuck am 24.05.2006  –  Letzte Antwort am 24.05.2006  –  8 Beiträge
P88 RS vs. P88 RS-II
michaelgeeser am 04.04.2008  –  Letzte Antwort am 04.04.2008  –  5 Beiträge
which head unit?
josmuck am 17.07.2006  –  Letzte Antwort am 18.07.2006  –  5 Beiträge
Audio System vs DLS
Elektronist am 16.01.2010  –  Letzte Antwort am 18.01.2010  –  24 Beiträge
Dynaudio vs. Audio Development
Elektronist am 19.01.2010  –  Letzte Antwort am 19.01.2010  –  5 Beiträge
Andrian A165 vs. ETON RS 161
flupie am 18.12.2008  –  Letzte Antwort am 29.12.2008  –  11 Beiträge
pionner vs. mac audio
fühler am 21.03.2010  –  Letzte Antwort am 22.03.2010  –  7 Beiträge
Axton vs. Lightning Audio
CPUfire am 24.03.2004  –  Letzte Antwort am 26.03.2004  –  13 Beiträge
Rockford vs. Audio System vs Ground Zero
Bassti000 am 15.08.2007  –  Letzte Antwort am 18.08.2007  –  13 Beiträge
2020
  • Registrierte Mitglieder930.676 ( Heute: 4 )
  • Neuestes MitgliedTim.R1
  • Gesamtzahl an Themen1.563.501
  • Gesamtzahl an Beiträgen21.827.182
