Yamaha rx-v771 ONLY video out through hdmi
psr1978
#1 erstellt: 09. Jan 2013, 22:34
Halo all,
I brought new v771 reciever and I have a Plasma TV which has only stereo out. I have connected my TV via HDMI which means both Audio and Video are going to TV (from reciever) and I should get Audio back from TV to reciever.
Since my TV has only stereo out, I will not get 5.1 surround sound.
My question is, Can I send only video through HDMI? If it is possible how?
Or do have any other possibility to get 5.1 surround sound from TV?
Thank you in advance and obviously you can reply in German, I can understand.
Regards,
Sreedhar
steelydan1
#2 erstellt: 10. Jan 2013, 00:07
Hello
If you disable ARC (=Audio Return Channel) in your TV (build in receiver) there will be no audio signal send through HDMI to the 771.
If your TV have a digital SPDIFoutput (Toslink or Coax) you can connect it this way with the 771.It should be possible sending a 5.1 signal to the 771 this way. Maybe you need to configure the SPDIFoutput in the TV menu first for multichannel output.
I hope this is of use to you.
Regards
[Beitrag von steelydan1 am 10. Jan 2013, 00:15 bearbeitet]
psr1978
#3 erstellt: 10. Jan 2013, 13:05
Thank you Steelydan1,
As you mentioned disabling ARC in reciever might help. Does such thing exist in recievers (YAMAHA RX-V771)?
It seems you have mis-understood. I am sending Audio and Video signal through HDMI from my reciever to TV. So, if such an option exists in reciever, my problem is solved. Thank you in advance,
Regards,
Sreedhar
Gonzo_2
#4 erstellt: 10. Jan 2013, 13:58
In Grundeinstellung sollte nur Video über HDMI zum TV gehen - (Siehe S.95 der Bedienungsanleitung):
Ist im Setup-Menü einstellbar Setup>HDMI>Audio-Ausgang>HDMIout1,HDMIout2:
S95
RX-V771 - HDMI Schaltungsproblem
Helios61 am 14.06.2015  –  Letzte Antwort am 14.06.2015  –  4 Beiträge
Yamaha RX-V465 - HDMI Through + HDMI Wiedergabe
Niggo89 am 12.05.2010  –  Letzte Antwort am 13.05.2010  –  4 Beiträge
Yamaha RX-V771 kaufen?
HellSpawn666 am 10.02.2016  –  Letzte Antwort am 12.02.2016  –  8 Beiträge
S-Video - Audio Zuordnung RX-V771
digicorder-fan am 08.01.2012  –  Letzte Antwort am 11.01.2012  –  11 Beiträge
rx v771 und OSD
Lebeog am 18.01.2012  –  Letzte Antwort am 18.01.2012  –  3 Beiträge
HDMI ARC bei RX-V771
pkp am 21.02.2014  –  Letzte Antwort am 23.02.2014  –  3 Beiträge
Yamaha RX V771 Internetradio
*olaf*_ am 26.02.2012  –  Letzte Antwort am 17.06.2012  –  14 Beiträge
Yamaha RX-V771 defekt
Bruno1987 am 24.05.2013  –  Letzte Antwort am 28.05.2013  –  5 Beiträge
Yamaha RX-V771 - Anzeigefehler
Schluntz am 27.04.2014  –  Letzte Antwort am 28.04.2014  –  4 Beiträge
RX-V771 Bitte um Anschlusshilfe
antsje am 03.02.2013  –  Letzte Antwort am 03.02.2013  –  3 Beiträge
2013
  • Registrierte Mitglieder930.676 ( Heute: 5 )
  • Neuestes MitgliedPeterMal
  • Gesamtzahl an Themen1.563.502
  • Gesamtzahl an Beiträgen21.827.265
