| HIFI-FORUM » Stereo » Elektronik » Analogtechnik/Plattenspieler » Suche Kenwood Stroboskoplampe | |
Suche Kenwood Stroboskoplampe+A -A |
yawara
erstellt: 02. Jul 2007, 07:40
Hallo! Ich habe einen Kenwood KD 5033AF Dreher, bei dem das Stroboskop nicht mehr richtig läuft. Also mal geht es, dann wieder nicht....wenn ich den Pitcher etwas drehe, geht die Lampe dann wieder an....dann fängt der Dreher aber etwas an zu leiern. Möglicherweise zieht dann der hohe Stromberbrauch die Motorleistung kurzzeitig etwas gerunter. Ist die Lampe hin? Oder deutet das "Hin-und-Wieder geht sie" auf einen Defekt im Netzteil oder sonst irgendwo hin? Gruß Janko |
tri-comp
erstellt: 02. Jul 2007, 08:42
Hi, This is just a guess, because I don't know the KD-5033: Older turntables have a NEON lamp as stroboscope light. When the lamp get's old it will start to flicker much like the ordinary neon-lamps you know for lighting of the house. You then have two options: 1) Replace the lamp (NE-2 is most likely what is used here) Take a look at: http://en.wikipedia.org/wiki/Neon_lamp2) Lower the series resistor. In most cases a resistor between 470K-Ohm and 1M-Ohm is used. It should be safe to lower it to 100K-Ohm which forces more current through the lamp stabilizing the glow (But also accellerating the wear) ....of course your turntable may NOT use a NEON-lamp in which case all the above should be disregarded entirely Kind regards, /tri-comp |
yawara
erstellt: 03. Jul 2007, 12:08
Hi Tri-comp! Thank You for support! I*ll have a look inside my turntable at the weekend....maybe it is a NEON-Lamp....but the Lamp needs about 100V!?! Bye J |
tri-comp
erstellt: 03. Jul 2007, 15:46
Yes, it needs from 90-110V. That's why it has a series-resistor to limit current. 220V AC directly will kill it instantly! Actually it functions like a kind of Zener-diode. When you apply voltage slowly from zero and up, the lamp will fire (turn-on) at around 100V. If you apply more voltage (through a current limiting resistor, of course) the lamp will conduct more current to keep the voltage across it stable @ 100V. This ability is used in old Tube-amplifiers where the power-supply can be stabilized. Here the Neon-lamp is used as a zener, or in case higher current is needed, some specialized tubes like the OA-2 / OB-2 were used. They work much like the simple neon-lamp. When you connect a NEON-lamp to AC, both electrodes light up. When it's connected to DC, only one is lit. Flickering light & black coating of inside indicates end-of-life Kind regards, /tri-comp |
Kenwood KD-492F - Verbessern Bongo_Bong am 27.07.2016 – Letzte Antwort am 28.07.2016 – 3 Beiträge |
Kenwood KD-990 Plattenspieler maha798 am 22.05.2006 – Letzte Antwort am 16.01.2009 – 17 Beiträge |
Kenwood KD 850, Plattengrößenerkennung defekt turntable_wanted am 28.03.2019 – Letzte Antwort am 24.06.2019 – 14 Beiträge |
Restauration Kenwood KD 990 Exilzebra am 06.01.2013 – Letzte Antwort am 07.01.2013 – 2 Beiträge |
Kenwood KD-1500 vampula am 01.12.2011 – Letzte Antwort am 02.12.2011 – 3 Beiträge |
Kenwood KD 3070 HoLee_Krap am 29.12.2016 – Letzte Antwort am 01.01.2017 – 13 Beiträge |
Plattenspieler fängt immer wieder an eggerph am 20.10.2014 – Letzte Antwort am 21.10.2014 – 11 Beiträge |
Revox B795 springt hin und wieder woolfinator am 30.07.2013 – Letzte Antwort am 31.07.2013 – 6 Beiträge |
Aufsetzpunkt Kenwood KD 4020 cazor am 03.08.2018 – Letzte Antwort am 03.08.2018 – 10 Beiträge |
Kenwood KD 990 Lift defekt Alu18mm am 18.07.2017 – Letzte Antwort am 04.08.2017 – 11 Beiträge |
2007
- Plattengewicht Ja oder Nein
- elliptisch, sphärisch, hä?
- Hilfe: Plattenteller eiert
- Registrierte Mitglieder930.662 ( Heute: 2 )
- Neuestes MitgliedIL7
- Gesamtzahl an Beiträgen21.825.845
