Gehe zu Seite: |vorherige| Erste . 10 . 14 15 16 17 18 19 20 21 22 23 . 30 . 40 . 50 . 60 .. 100 .. Letzte |nächste|
Playstation4 Laberthread
mr.niceguy1979
#871 erstellt: 21. Aug 2013, 13:18
Naja, zum einen ist die Nutzung der Cloud auch noch nicht Praxis erprobt, zum anderen geht es um technisch nachvollziehbare Tatsachen, um Algorithmen, und um genau die Problemathik, die es bisher zu überwinden galt.
On a classical system you have a RAM pool and a VRAM pool that are physically speperated. Copying data from one pool to the other creates latency. The GPU is very good ad hiding latency. What it needs most is high bandwidth. The CPU on the other hand is extremely sensitive to latency. The CPU needs extremely low latency to work efficiently. Copying data from the RAM (CPU) to the VRAM (GPU) creates latency, but that's okay for the GPU. Copying data from RAM (CPU) to VRAM (GPU) and back to the RAM (CPU) creates even more latency. It's too much for the CPU. The copying alone takes longer than the computation wich makes this roundtrip highly ineffective.
Xbox360 and older APUs have a unified RAM. This means that the RAM is no longer physically seperated, but even though it's the same RAM chips, the system still distincts between memory partition for the differenct processors. You still need to copy the data between CPU partition and GPU partition, but this will be much more efficient than copying it between physically seperated pools. But it's still too much latency for a CPU, GPU, CPU roundtrip.
PS4 will have hUMA wich means that you no longer need a distinction between CPU partition and GPU partition. Both processors can use the same pieces of data at the same time. You don't need to copy stuff and this allows for completely new algorithms that utilize CPU and GPU at the same time. This is interesting since a GPU is very strong, but extremely dumb. A CPU is extremely smart, but very weak. Since you can utilize both processors at the same time for a single task you have a system that is extremely smart and extremely strong at the same time.
It will allow for an extreme boost for many, many algorithms and parts of algorithms. On top of that it will allow for completely new classes of algorithms. This is a game changer.
Hier eine Meinung (ja, nicht mehr) die aber logisch nachvollziehbar ist und die entspricht genau dem, was man so im Netz zu dem Thema findet.
Aber du hast Recht, noch kann man nur theoretisch darüber reden.
In 2-3 Jahren sind wir dann schlauer .
Ich denke nur, dass die Leute, die tief in der Materie stecken und dafür bezahlt werden (AMD, Sony und Programmierer), die werden schon Ahnung haben.
MfG
elchupacabre
#872 erstellt: 21. Aug 2013, 13:19
Und die bekommen ihr Geld auch durch die Verkäufe der Konsolen ua...
Für mich hat jede der Konsolen ihre Daseinsberechtigung, kaufen tu ich mir sowieso keine davon
mr.niceguy1979
#873 erstellt: 21. Aug 2013, 13:22
AMD steht aber unter Druck, Stichwort Konkurrenz.
Die denken sich so etwas nicht aus, nur weil sich das gut anhört.
Dann würde das kein gutes Ende nehmen.
Natürlich will man auch verkaufen .
Das hat keiner bestritten...
Naja, zumindest beschäftigst du dich mit der Konsole - warum auch immer .
MfG
[Beitrag von mr.niceguy1979 am 21. Aug 2013, 13:25 bearbeitet]
BennyTurbo
#874 erstellt: 21. Aug 2013, 13:23
Amazon hat gestern geschrieben, die Konsole kommt voraussichtlich am 29.11.
elchupacabre
#875 erstellt: 21. Aug 2013, 13:25
Mich interessiert einfach die Entwicklung des Ganzen, angefangen hat das bei mir schon vor langer, langer Zeit, mehr nicht
Zwuggel
#876 erstellt: 21. Aug 2013, 13:27
Ich freu mich auch schon auf die ersten Kommentare dann, was denn alles für "bescheiden" empfunden wird an den beiden neuen Konsolen
Papierkorb
#877 erstellt: 21. Aug 2013, 13:47
Ich hab mir die nacht noch driveclub dazugeordert für 20 taler. Denke dass ich zum release noch killzone nehm, oder BF4.
Übrigends finde ich es nicht schlimm das USA 2 wochen früher dran sind, so bekommt man schon erste erfahrungsberichte, positiv sowie negativ
snowman4
#878 erstellt: 21. Aug 2013, 15:35
BennyTurbo (Beitrag #874) schrieb:
Amazon hat gestern geschrieben, die Konsole kommt voraussichtlich am 29.11. :angel
Hat doch Sony an der Pressekonfrerenz gesagt und sollte nicht mehr voraussichtlich sein.
[Beitrag von snowman4 am 21. Aug 2013, 15:36 bearbeitet]
PowerhouseD2
#879 erstellt: 21. Aug 2013, 15:41
Mir wurde voraussichtlich Liefertermin am 29.11 angegeben.
Würde mich mal interessieren ob jemand der erst später vorbestellt hat einen anderen Liefertermin
Bekommen hat .
Anpera
#880 erstellt: 21. Aug 2013, 16:03
Und das gewaltig!
Intel ist im Gaming-Bereich (was PCs angeht) sehr mächtig - ja, fast schon konkurrenzlos!
AMD hat noch seine Grafikkarten, aber im Vergleich zu GeForce immer wieder Probleme mit den Treibern (dafür sind die nVidias teurer).
Wenn der Zuschlag bei den Konsolen an Intel gegangen wäre, hätte AMD mehr oder weniger dicht machen können...
Wird Zeit, dass AMD bei den CPUs wieder aufholt. Mir ist der Hersteller sympathischer als Intel (als GraKa wirds wohl immer nVidia bleiben ), aber aktuell würde ich keine AMD CPU kaufen...
bereft
#881 erstellt: 21. Aug 2013, 16:33
AMD hat ATI gekauft und seitdem ist die Radeon nur noch bedingt konkurrenzfähig? Früher war das ja mehr oder weniger ein regelmässiger Schlagabtausch je nachdem ob nvidia oder ati eine neue graka rausbringt.
Hab den pc sektor schon lange nicht mehr im blick.
[Beitrag von bereft am 21. Aug 2013, 19:31 bearbeitet]
Anpera
#882 erstellt: 21. Aug 2013, 19:04
Bei den CPUs hängt AMD enorm hinterher. Bei den GPUs gehts eigentlich, meist minimal langsamer, dafür etwas günstiger. Der Treiber allerdings ist in meinen Augen ne Krankheit und macht auch öfter Probleme ^^
Griller
#883 erstellt: 22. Aug 2013, 11:18
Hallo!
ich spiele mit dem Gedanken meinen Blu ray Player gegen die PS4 auszutauschen. Ist dies sinnvoll? Ich möchte aber auch keine Abstriche in Sachen Sound haben. Kann die Ps4 alle Soundformate abspielen? Weil die ps3 konnte ja irgendwelche Formate nicht. Gibt's Hinweise in Sachen Lautstärke des Laufwerks?
Noch was, das Blu Ray Laufwerk der PS4 kommt das herausgefahren oder muss man die Scheibe "reindrücken"?
Igelfrau
#884 erstellt: 22. Aug 2013, 12:21
Das werden wir alles wissen, wenn mal ein Gerät für die Allgemeinheit zur Verfügung steht. Dann darfst du gerne nochmal deine Fragen stellen oder dich einfach selber im Netz informieren.
Die PS3 kann übrigens alle Tonformate eines Silberlings abspielen (bis auf SACD, das ab der PS3 Slim nicht mehr ging)!
mr.niceguy1979
#885 erstellt: 22. Aug 2013, 12:27
Die PS4 wird mit Sicherheit alle gängigen, aktuellen Tonformate in bitstream und pcm einer BD ausgeben können. Die BD wird hineingesteckt, es fährt keine Klappe raus.
MfG
Igelfrau
#886 erstellt: 22. Aug 2013, 12:45
Da ich auf der IFA 2013 sicherlich auch den PS4 Stand besuchen werde, kann ich gerne dann ein paar Fotos bzw. Informationen liefern soweit gewünscht und vor Ort machbar.
mr.niceguy1979
#887 erstellt: 22. Aug 2013, 15:16
Immer her damit
MfG
z1x.*
#888 erstellt: 23. Aug 2013, 15:03
Servus Leuteee,
holt sich wer die PS4 bzw. hat sie schon vorbestellt?
Möchte sie mir auch holen aber ich denke ich fahr an dem Tag in den Laden.
Wo würdet ihr noch vorbestellen?
Welche Spiele gibt es zum Release und welche holt ihr euch? Peile BF4 an
Fony
#889 erstellt: 23. Aug 2013, 16:27
Ich ol mir die PS4.
Im Laden wirst du sie denn ersten Tag vllt. nicht bekommen sondern nur die Vorbesteller.. .
Mein 1. Spiel wird Watch Dogs werden .
Mohn34
#890 erstellt: 23. Aug 2013, 19:33
US: 15.11.2013
EU: 29.11.2013
Und das ist der Punkt was das soll mit den 14 Tage unterschied ob es nur auf die paar tage drauf angekommen wäre.
Bei mir sind es 4 Spiele zum launch.
Watch Dogs
Fifa 14
Killzone:Shadow Fall
Battlefield 4
Und denn noch vorbestellung:
Tom Clancy´s:The Division
The Order 1886
[Beitrag von Mohn34 am 23. Aug 2013, 19:39 bearbeitet]
qfactor
#891 erstellt: 25. Aug 2013, 08:21
Ich hab meine bei Amazon bestellt, liefert pümklich und der Kundenservice ist besser, als der der stationären Elektronik-Fachgeschäfte die ich kenne
Spiele (sofern verfügbar):
- Drive Club
- Oddworld: New 'n tasty
- Knacks oder wie das heißt
- am liebsten noch Motorstorm 4... aber die Hoffnung kann ich wohl begraben
Holy_Moly
#892 erstellt: 25. Aug 2013, 14:10
qfactor (Beitrag #891) schrieb:
- am liebsten noch Motorstorm 4... aber die Hoffnung kann ich wohl begraben :(
Drive Club ist ja ein halbes MotorStorm, auf jeden Fall von den gleichen Entwicklern
So schlecht kann es also nicht werden...
bereft
#893 erstellt: 25. Aug 2013, 14:16
die Skepsis gegenüber dem PS-Pad wächst, die altbewährten Sticks von der xbox und die neue Trigger-Rumble Funktion sind gute Argumente für die Xbox
der zweite große Punkt ist die Anzahl und Aufbau der Server bzw. des Netzwerks, die xbox scheint die bessere Konsole für das Online-Gaming zu sein.
da gibts auch noch das Gerücht dass die PS4 Version von BF4 keine 64 Spieler unterstützen soll, was wieder an PSN zweifeln lässt.
Motorstorm ist schon ein geniales Spieleprinzip und grafisch war der erste Teil "wow!", was mir am meisten gefallen hat waren die alternativen Routen, sieht fett aus und macht einfach mehr spass und dann noch diese Optik wenn die Strecke gute 100 Meter breit wird. Also Interesse wäre meinerseits vorhanden.
Fony
#894 erstellt: 25. Aug 2013, 14:59
War jemand auf der Gamescom und konnte die Playstation 4 testen?
Wenn ja, möchte wissen wie die Grafik ist, die lautstärke.. vllt kann man etwas zur wärmeentwicklung sagen, da sie ja die ganze zeit an war.
Und was mich auch brennend interessiert ist der Kontroller... kann mir jemand zu dem etwas sagen im Vergleich zum neuen Xbox Kontoller.
Einige PC-Magazine meinten ja der DS4 soll besser geworden sein als der neue Xbox Kontroller.
Wäre über antworten sehr erfreut.
Abdizur
#895 erstellt: 25. Aug 2013, 17:20
ich war auf der Gamescom.
Zu der Lautstärke und Wärmeentwicklung kann ich dir nichts sagen,
da es auf der Gamescom laut war und man somit nichts gehört hat, von der Konsole.
Das Gleiche gilt für die Wärmeentwicklung.
Zum Controller kann ich dir dass sagen, was jeder andere, der den Dualshock Controller halten konnte,
ebenfalls sagte:
The PlayStation 4 controller is just slightly better than the best thing ever
Game Informer: impressions on the DualShock 4, is one of the main reasons for taking a PS4
Battlefield 4 Lead Designer Explains Superiority of the DualShock 4 Over the DualShock 3 and the Xbox 360 Controller
Blacklight Retribution developer: "Holy crap, I think I've found my new favorite controller."
Man merkt am DualShock4 Controller, dass BUNGIE (DESTINY, Halo), Guerrilla Games (KILLZONE), Evolution Studios (Motorstorm, DRIVECLUB), Naughty Dog (Uncharted, The Last Of Us) und viele weitere Game Developer mitgeholfen haben, den Controller zu formen und zu entwicklen.
Mein Fazit:
Der Controller liegt absolut perfekt in der Hand.
Was ich zuerst sofort testen wollte ---> Die Sticks und die Shoulderbuttons. Wie bereits in den Artikeln beschrieben, fühlen sie sich einfach super und vorallem "natürlich" an. Das D-Pad ist sowieso schon immer das beste überhaupt gewesen, bei den PlayStations. Das Touch-Pad ist leicht zu erreichen und kann somit gut zum navigieren von Menüs, Browser, etc. verwendet werden.
Für mich und meine Freunde der beste Controller den wir je in den Händen halten konnten.
bereft (Beitrag #893) schrieb:
der zweite große Punkt ist die Anzahl und Aufbau der Server bzw. des Netzwerks, die xbox scheint die bessere Konsole für das Online-Gaming zu sein. da gibts auch noch das Gerücht dass die PS4 Version von BF4 keine 64 Spieler unterstützen soll, was wieder an PSN zweifeln lässt.
Absoluter Unsinn!
Das hat nichts mit PSN zu tun.
Wenn die PS4 irgendwas nicht haben sollte, in der finalen Version, dann hat es die XboxOne schon zwei Mal nicht. Dafür ist die PS4 hardware-mäßig der XBone zu sehr überlegen. Soviel dazu! Sowas liegt nicht an der Onlinestruktur, sondern an dem Game/der Software. Selbst die PS3 unterstützt Games mit bis zu 64 Onlinespielern gleichzeitig.
Ein weiteres Beispiel ist 1080p! Zur Zeit laufen die Konsolenversionen von Battlefield 4 in 720p mit 60FPS. Die Entwickler wollen bis zum Launch 1080p erreichen. Hat nichts mit der PS4/XBone zu tun, sondern mit den Entwicklern und der fehlenden Zeit.
[Beitrag von Abdizur am 25. Aug 2013, 17:24 bearbeitet]
bereft
#896 erstellt: 25. Aug 2013, 17:48
ich war ja auch skeptisch als ich davon gelesen habe, dachte zuerst daran dass MS EA geschmiert hat(mal wieder?)
ist ja klar dass 64 spieler, also einfach mehr als 16 zur NextGen dazugehört... gab wohl irgendwelche Gründe warum die Demo auf 16 Spieler beschränkt war. Also vergessen wir dieses "Gerücht" am besten gleich wieder.
das zweite ist aber das pad..ist da nicht zu wenig widerstand drauf? wenn die sich ganz lose bewegen lassen ist die Dosierung doch schwieriger? vllt. ist das nur eine Frage der Zeit bis man mehr "Fingerspitzengefühl" entwickelt. ich zweifle ja nicht daran dass es für mich als noch xboxler gut spielbar sein wird.
[Beitrag von bereft am 25. Aug 2013, 17:56 bearbeitet]
Papierkorb
#897 erstellt: 25. Aug 2013, 18:23
Schon erschreckend das es zum neuen controller nur positives zu hören gibt. Sehr oft hört man auch der beste controller seit langem.
Witzig dass das xbox lager das genau anders rum sieht. Scheinbar haben die alle verkrüppelte hände oder so.
Freu mich schon tierisch das mal selbst in den händen halten zu dürfen. Das einzige manko war bisher immer die größe, denn da war der 360 controller nicht verkehrt
bereft
#898 erstellt: 25. Aug 2013, 18:41
vielleicht reicht den PSlern die verbesserung um gleich der beste Controller aller Zeiten zu sein.
für mich ist da viel spielraum nach oben, hatte schon 1998 einen PS Controller in der Hand und habe genügend Erfahrungen sammeln können in all den Jahren und muss sagen dass ich lange die Analogsticks gemieden habe und beim xbox pad 2006 erst skeptisch war ob das so gut funktioniert,aber das hat wunderbar funktioniert, dann spielte ich mal Resistance auf der PS3 und es fiel mir gleich negativ auf,
70:30 dass mir die veränderungen am DS zusagen werden, ich glaube nicht dass es so eine große Sache sein wird und selbst wenn...im Laufe der Zeit wird es alternative Pads geben.
kenne viele die wegen CoD von PS auf die Xbox gewechselt sind da es mit dem Xbox Pad einfach besser zu spielen ist, das ist einfach aus 3 Gründen nunmal so: 1. spielraum und widerstand der Sticks, 2. Anordnung macht bei der xbox mehr Sinn und 3. die Größe bzw. die Position der Hände angenehmer bei der Xbox.
ich verstehe wenn jemand mit dem DS3 klar kommt, aber objektiv betrachtet(ergonomisch) ist das xbox pad einfach besser. Wenn das DS4 pad nur etwas schlechter ist, reicht mir das schon.
Papierkorb
#899 erstellt: 25. Aug 2013, 18:55
Der widerstand ist für mich beim DS3 besser, ich kann ganz leicht die kleinsten bewegungen machen.
Beim 360 ist der wiederstand um aus der 0 position rauszukommen zu hoch, ich brauch so viel "kraft", das ichs übers ziel hinaus geh, und wenn ichs wieder nach innen korrigier, dann ziehts schnell wieder in der 0 stellung, hab also deutlich probleme ein gewissen winkel zu halten.
Wie auch immer, sowohl der DS2, sixxaxis und auch DS3 hatten im vorfeld immer haufen kritik einstecken müssen.
Beim DS2 zb die analog tasten, die bei ridgeracer oider gran turismo für einen tauben daumen sorgten, da man immer feste die taste reindrücken musste.
Sixxaxix war zu leicht, kein rumble und beim DS3 waren immer noch die analog trigger die unlogisch geformt sind, absegehen von der oberfläche der sticks, wo viele leicht abrutschten.
Somit ist der DS4, der erste sony controller, der gelobt wird
bereft
#900 erstellt: 25. Aug 2013, 19:03
was für den einen zu empfindlich, ist dem anderen gerade recht!
es gibt nicht umsonst die "pro"-pads für FPS die einen Aufsatz haben damit der "Weg" größer ist und man dadurch noch besserer dosieren kann, entweder man macht es so oder man gibt den Sticks mehr Widerstand um "überhasteten" Bewegungen entgegen zu kommen, ein bisschen wie das "Spiel" des Lenkrads beim Auto, damit man im wahrsten Sinne des Wortes nicht "übersteuert".
dann muss man die Empfindlichkeit anpassen und je mehr Widerstand umso besser kann man es Dosieren-weil einfach mehr "Feedback" vorhanden ist, das selbe gilt für die Trigger und man braucht sich nur die Veränderungen anschauen, die Sticks weiter auseinander, mit einwölbungen und die Trigger mit besserem Halt da diese jetzt auch nach aussen abfallen, also alles in allem eine "schüchterne Annäherung" an das Xbox Pad.
keine Ahnung warum es damals keine nextgen fähige Veränderungen gegeben hat, das gehörte auch zur Arroganz von Sony dass man sich keine Sorgen darüber machen musste da sich die Community nicht groß darüber beschwert hat...aber wieviele FPS und Ego-perspektive Spiele wurden zur PS2 Zeit gespielt? wie gesagt konnte ich die Analogsticks bis 2006 gut ignorieren und spielte immer lieber mit dem Steuerkreuz, erst die xbox hat mir die Analogsticks näher gebracht.
[Beitrag von bereft am 25. Aug 2013, 19:05 bearbeitet]
Abdizur
#901 erstellt: 25. Aug 2013, 19:05
[Beitrag von Abdizur am 25. Aug 2013, 19:05 bearbeitet]
bereft
#902 erstellt: 25. Aug 2013, 19:40
naja, Shooter müssen schon mehr bieten als die Jagd auf Killstreaks und das schauen auf die K/D, CoD für mich gestorben, BF mein neuer Standard Shooter und sonst? eher weniger Shooter, Killzone für mich nur eine Randerscheinung.
dieses Spiel interessiert mich schon eher:
http://www.pcgames.d...-im-Februar-1084987/
wow, an meinem Panasonic Plasma wird das bestimmt bombastisch aussehen!
und das Pad macht mich zuversichtlich, da kriegt man gleich mal einen guten Einblick wozu das Touchpad alles gut sein kann.
http://www.cnet.de/8...konsolen-verfuegbar/
DriveClub, Battlefield und Watch Dogs für mich... hinsichtlich Fifa etwas unsicher, warte mal ab.
[Beitrag von bereft am 25. Aug 2013, 19:54 bearbeitet]
mroemer1
#903 erstellt: 25. Aug 2013, 21:19
:prost
Ich glaube kaum das dieses Game viel mit Motorstorm zu tun hat, außerdem haben die Entwickler davor auch ein paar vernünftige Rally Spiele (WRC), programmiert.
Auf jeden Fall ist es bei meiner PS3 auch mit dabei, genau wie Madden 25, später dann wohl noch Wolfenstein.
[Beitrag von mroemer1 am 25. Aug 2013, 21:22 bearbeitet]
bereft
#904 erstellt: 25. Aug 2013, 21:24
Driveclub sieht gut aus, habe ein gutes Auge fürs Handling und sehe auch die Beschleunigung, das ist schon ordentlich, ich denke mal irgendwo im bereich von PGR und Forza Horizon( Das sind die "guten" Arcade-Racer die einen guten Mix aus Physics und Spielspass/Geschwindigkeitsrausch bieten, DriveClub scheint langsamer zu sein als Forza Horizon, was mir gut gefallen würde, selbst PGR war mir noch tendenziell zu schnell, vor allem etwas längere Bremswege habe ich mir gewünscht, die Autos haben ja fast alle F1 Bremsen ), verstehe aber nicht warum vor allem auf Youtube man immer mit den Forza und GT vergleichen kommen muss, das muss man getrennt betrachten und für mich sieht das Handling echt gut aus, keine übertrieben hohen Kurvengeschwindigkeiten und keine verrückten Drifts..
GRID 2 ist für mich der größte Murks überhaupt, gut dass Gamestop die 9,99er Aktion hat und ich das Spiel für GTA V eintauschen kann, zusammen mit Forza Horizon oder Black Ops2(warscheinlicher)
daher ist DriveClub für mich eine sichere Nummer...mir gefällt einfach auch die Ausrichtung, es hebt sich ab vom stumpfen 1 Rennen nach dem anderen Abspulen, mit vielen Disziplinen wie bereiche für Drifts oder Blitzer, das ist genau die Art Rennspiel die auf DAUER spass machen... The Crew sieht dagegen hinsichtlich des Handlings schwächer aus, da muss der Spielspass sehr hoch sein um das zu kompensieren, the Crew ist dann doch weiter an Sachen wie NFS angelehnt und ein reines Arcade-Fun Rennspiel.
[Beitrag von bereft am 25. Aug 2013, 21:33 bearbeitet]
Abdizur
#905 erstellt: 25. Aug 2013, 22:18
und das Pad macht mich zuversichtlich, da kriegt man gleich mal einen guten Einblick wozu das Touchpad alles gut sein kann. :prost
1. http://i.minus.com/itcRpqL6rnGc7.gif
2. http://i.minus.com/iTerzT4GbI1IU.gif
3. http://www.brotastik.com/gifs/infamous.gif
4. http://i.minus.com/iLiEg2pwPd5Jx.gif
5. http://i.minus.com/ibgWtyWb75QExs.gif
Igelfrau
#906 erstellt: 26. Aug 2013, 10:43
Hübsche Schnipsel! Danke dafür.
Star_Soldier
#907 erstellt: 26. Aug 2013, 15:54
Ist es eigentlich nicht egal welche Pads dabei sind ? Es gibt doch so viele Drittanbieter das für jeden das passende pad irgendwo ist.
Bei den alten PS musste ich auch die Pads austauschen weil die Hörner viel zu kurz waren um sie richtig zu greifen.
bereft
#908 erstellt: 26. Aug 2013, 16:42
nur wie lange dauert das bis es alternative Pads gibt? jetzt nur mal aus neugier gefragt.
ParrotHH
#909 erstellt: 26. Aug 2013, 17:24
Hallo!
Wenn ich was spiele, dann sinds meist Rennsimulationen. Weiss zufällig jemand, ob ich mir dann schon wieder ein neues Lenkrad kaufen muss, oder ob mein "altes" Driving Force GT noch unterstützt wird...
Parrot
JoFasT
#910 erstellt: 26. Aug 2013, 18:37
im prinzip hast du ja irgendwo recht.
aber eigentlich hast du dir antwort mit diesem satz eig schon selbst gegeben! du mußtest dir, warst also quasi "gezwungen" dir neue
zu kaufen, weil die anderen, sagen wir mal, nicht optimal waren.
das hättest du dir sparen können, wären die "alten" PS3 pads einfach besser gewesen!
pads von drittanbietern müssen ja auch erstmal besser als die originalen sein.
außerdem kosten sie zusätzlich geld. daher sollte wohl derzeit kein PS4 vorbesteller wirklich daran interessiert sein, die pads
ersetzen zu müssen.
ne andere geschichte, wenn man erstmal zufrieden ist, aber irgendwann einfach später neue, supergeile hammerpads auf den
markt kommen und man dann einfach bock auf was neues hat
aber die pads sind im prinzip das, was mich an der PS3 am meisten gestört hatte, was ich einfach bei xbox deutlich besser finde (fand)!
scheinbar werden die neuen aber wohl besser! bin selbst gespannt.
Jo
edit: korrigiert falscher smiley! blöde wurstfinger
[Beitrag von JoFasT am 26. Aug 2013, 19:22 bearbeitet]
snowman4
#911 erstellt: 26. Aug 2013, 19:17
Pads - Ja, das ist so eine Sache. Ich komme mit den PS3 Pads besser zurecht als die von der Xbox360, die sind mir einfach etwas zu schwer.
bereft
#912 erstellt: 26. Aug 2013, 19:27
so ist das eben, solange die Unterschiede nicht total gravierend sind, findet sich immer ein Mensch dem das eine pad einfach besser in die Hände passt, von Kindern brauchen wir gar nicht erst zu sprechen....oder Frauen-Hände
bei mir ist es wie bei JoFast, wir werden es halt mit besten Absichten probieren, ansonsten gibts halt ein anderes Pad und wenn es ein teures wird, dafür ist das Pad einfach zu wichtig....
waren die aktuellen Pads damals aber auch so Teuer? das sind schon Hammerpreise... wenn man dazu den aktuellen Preis eines Wireless Pads der xbox vergleicht, dass nur 29 Euro kostet.... ja, ich glaube mich erinnern zu können dass das DS3 bzw. Sixaxxis damals ca. 69 Euro gekostet hat.
[Beitrag von bereft am 26. Aug 2013, 19:28 bearbeitet]
Papierkorb
#913 erstellt: 26. Aug 2013, 20:31
Also ich konnte mich bisher mit allen controller anfreuden, bis auf 2.
Das ist einmal der original xbox controller.... total unhandlig, und zum anderen vom jaguar, auch nicht angenehm.
Ansonsten fand ich die original controller mit abstand immer am besten, wo natürlich jeder auch seine nachteile hatte.
Die besten hatten meiner meinung nach immer nintendo, SNES, N64 (angesehen vom ausgeleierten stick) und gamecube.
Die preise find ich teilweise auch heftig, besonders von der xbox 180, da kostet ein komplett set glaub um die 90€ (mit akku + ladegedöns).
Da seh ich sony leicht vorn, was den preis angeht
Abdizur
#914 erstellt: 27. Aug 2013, 22:09
[Beitrag von Abdizur am 27. Aug 2013, 22:17 bearbeitet]
Igelfrau
#915 erstellt: 27. Aug 2013, 22:18
Beeindruckende Grafiken! Die Szene mit dem Dino ist schon wirklich toll umgesetzt.
qfactor
#916 erstellt: 28. Aug 2013, 06:04
Resogun - gekauft
DonPaddo
#917 erstellt: 28. Aug 2013, 11:31
Der Xbox - Controller wird mir schon fehlen nach meinem Wechsel zur PS4, jedoch der Mensch ist ein Gewohnheitstier. Als ich damals mit der richtigen Xbox 1 das erste Mal einen Shooter gespielt habe ( Halo 1 ), dachte ich mir auch, dass ich niemals so alle Spiele spielen könnte.... nun, rund 10 Jahre später, habe ich Probleme mit der Maus und (nicht-) Strategiespiele.
Ich denke ich werde mich nach ein paar Partien Fifa, BF4 und Driveclub an den PS- Controller gewöhnen. Es werden mir vielleicht nach einigen Stunden spielen die Daumenmuskel wehtun, aber das hat ja schon fast Retrocharakter ( Damals das erste Mal SNES Controller )
Zu den Gifs: Bin mal echt gespannt wo die Reise hingeht. Wenn man sich die Launchtitel der PS3/Xbox360 anschaut und diese mit den jetztigen Current-Gen- Spielen vergleicht, dann sind da Welten zwischen. Letztens F.e.a.r. 2 in die Konsole eingelegt.Subjektiv würde ich sagen, das Teil kommt aus dem Jahr 98-99 ;-)
bereft
#918 erstellt: 28. Aug 2013, 15:33
jepp, zu hause vor meinem Panasonic STW50 wird das schon bombastisch, das darf man aus der "ferne" nicht unterschätzen, jedoch auch NOCH nicht zu viel verlangen, aber es wird sich schon einiges tun! und ich bin die aktuelle Grafik leid, möchte ich nicht mehr, das langweilt mich nur noch.
bereft
#919 erstellt: 01. Sep 2013, 15:07
Habe mir noch einige Videos zu DriveClub angeschaut...die Beschleunigung sieht nach Sim aus-die Autos brauchen ziemlich lange bis 250 und mehr. Auf jedenfall etwas langsamer als bei forza horizon, das handling ist ein bisschen drifty, ich hoffe das feedback ist gut genug sodass man es gut steuern kann..wie gesagt sieht das tempo in den kurven gut aus...die bremsen sind auch zu stark um sim zu sein aber immerhin muss man bremsen.
Wenn es um die Version geht bin ich mir unsicher...ps+ hole ich mir auf jeden fall aber ob mir die abgespeckte version ausreichen wird? Denn rennspielemäßig sieht es dank gt6 nur für die ps3 mager aus.
[Beitrag von bereft am 01. Sep 2013, 15:08 bearbeitet]
Papierkorb
#920 erstellt: 01. Sep 2013, 19:21
Ich hab driveclub für 20 eier bestellt, da störts nicht wenns nicht so gut ist, wie manche vermuten.
Die PSN+ version ist nett gemeint, aber meine leitung ist immer noch nicht schnell genug, will zocken und nicht laden
Abdizur
#921 erstellt: 02. Sep 2013, 00:51
Falls es dir nicht ausreichen sollte, kannst du dann ja im PSN das Pack kaufen (Preis liegt dann maybe bei ca. 19,99€) um dann auf die komplette/100%ige Version upzugraden.
Bist ja somit nicht auf die leicht abgespeckte Version PS+ Version gefangen
Playstation4
Stefan_79 am 21.08.2016  –  Letzte Antwort am 06.09.2016  –  2 Beiträge
PS3 Preis Europa
RiTaNoL am 05.04.2006  –  Letzte Antwort am 15.05.2006  –  135 Beiträge
Wie PS4 verstecken?
adtika am 01.02.2014  –  Letzte Antwort am 03.02.2014  –  2 Beiträge
Wird GTA4 in Deutschland indiziert? was glaubt ihr?
XoX321 am 26.04.2008  –  Letzte Antwort am 29.04.2008  –  12 Beiträge
Wer kauft die PS3 um 600? ?
Jon_Lord am 25.08.2006  –  Letzte Antwort am 06.02.2007  –  205 Beiträge
UNCHARTED - Drake's Fortune - THREAD
rabbaz am 25.11.2007  –  Letzte Antwort am 05.01.2008  –  114 Beiträge
Uncharted 3 - Drake's Deception
-Thommes- am 10.12.2010  –  Letzte Antwort am 14.12.2011  –  94 Beiträge
Uncharted 2 Demo Super
-=Hellraiser=- am 16.09.2009  –  Letzte Antwort am 16.10.2009  –  77 Beiträge
Call of Duty 4 Modern Warfare VERDAMMT GEHT DAS LANGE WENN MAN ONLINE SPIELEN WILL !
paberotti am 28.11.2007  –  Letzte Antwort am 04.12.2007  –  15 Beiträge
Uncharted 1 Tonproblem
Neos2c am 29.11.2009  –  Letzte Antwort am 02.12.2009  –  7 Beiträge
  • Registrierte Mitglieder928.183 ( Heute: 2 )
  • Neuestes MitgliedSchallarbeiter
  • Gesamtzahl an Themen1.557.630
  • Gesamtzahl an Beiträgen21.683.474
