Trimaster HX 31" BVM-HX310
Ralf65
#1 erstellt: 15. Sep 2018, 08:05
Sony stellt auf der IBC den neuen Master Monitor BVM-HX310 vor, dieser ist mit einem so benannten α-Si TFT Active Matrix LCD Panel ausgestattet und soll im HDR Modus im Vollbild 1000Nits erreichen, bei einem Kontrastverhälltnis 1.000.000:1
weitere Infos auch auf AVWatch
Unbenannt
Panel: α-Si TFT Active Matrix LCD
Picture size (diagonal): 789.1 mm (31.1 inches)
Effective Picture size (H x V): 698.0 x 368.1 mm (27 1/2 x 14 1/2 inches)
Resolution (H x V): 4096 x 2160 pixels
Aspect: 17 : 9 (1.89 : 1)
Pixel efficiency: 99,99%
Panel drive: 10-bit
Panel frame rate: 48 Hz / 50 Hz / 60 Hz (48 Hz and 60 Hz are also compatible with 1/1.001 frame rates)
Viewing angle (panel specification): 89°/89°/89°/89° (up/down/left/right contrast > 10:1)
Colour temperature: D55, D61, D65, D93, DCI*1, and user 1-5 (5,000 K to 10,000 K adjustable), DCI XYZ
Luminance (panel specification) (typical): 1000 cd/m2
Colour space (Colour gamut): ITU-R BT.2020*2, ITU-R BT.709, EBU, SMPTE-C, DCI-P3*2, Native*3, S-GAMUT3*2, S-GAMUT3.cine*2
Transmission Matrix: ITU-R BT.2020 (Non-constant luminance is supported), ITU-R BT.709
EOTF: 2.2, 2.4, 2.6, CRT, 2.4 (HDR), S-Log3 (HDR), S-Log3 (Live HDR), S-Log2 (HDR), SMPTE ST 2084(HDR), ITU-BT.2100(HLG)
SDI 1 input: (3G/HD) BNC type (x4) Input impedance: 75 Ω unbalanced
SDI 2 input: (12G/6G/3G/HD) BNC type (x2) , (3G/HD) BNC type (x2), Input impedance: 75 Ω unbalanced
HDMI: HDMI (HDCP2.3/1.4) (x1)
Serial remote (LAN): Ethernet (10BASE-T/100BASE-TX), RJ-45 (x1)
SDI 1 MONITOR output: (3G/HD) BNC type (x4) , Output impedance: 75 Ω unbalanced
SDI 2 output: (12G/6G/3G/HD) BNC type (x2) , (3G/HD) BNC type (x2) , Output impedance: 75 Ω unbalanced
Audio monitor: Stereo mini jack (x1)
Headphones: Stereo mini jack (x1)
Power requirement: AC 100 V to 240 V, 5.1 A to 2.1 A, 50/60 Hz
Power consumption: Approx. 450W (max.)
Dimensions (W x H x D): 778 x 519.5 x 230 mm (30 3/4 x 20 1/2 x 9 1/8 inches)
Mass Approx.: 30kg (66 lb 2 oz)
[Beitrag von Ralf65 am 15. Sep 2018, 08:51 bearbeitet]
Sony BVM-HX 310 Dual Layer LCD Master Monitor
Ralf65 am 03.08.2019  –  Letzte Antwort am 10.08.2019  –  7 Beiträge
Sony hx 705 usb
Silvermen am 04.07.2010  –  Letzte Antwort am 05.07.2010  –  2 Beiträge
Sony 46 HX 705
laulo am 22.08.2010  –  Letzte Antwort am 23.08.2010  –  5 Beiträge
HX 800 / 805 Einstellungsthread
Remergil1974 am 23.10.2010  –  Letzte Antwort am 10.12.2013  –  203 Beiträge
NX oder HX
zippen am 13.12.2010  –  Letzte Antwort am 13.12.2010  –  7 Beiträge
Neues Update HX 725
lemmie am 13.05.2012  –  Letzte Antwort am 16.05.2012  –  3 Beiträge
Festplatte für HX 755
Punto2Sporting am 05.07.2012  –  Letzte Antwort am 06.07.2012  –  6 Beiträge
KDL-52 HX 90DTI
alterjager am 07.08.2013  –  Letzte Antwort am 08.08.2013  –  7 Beiträge
65 HX 925 wandlung
B4byf4ce am 04.07.2013  –  Letzte Antwort am 29.07.2013  –  6 Beiträge
KDL 925 HX
wishbone_ash am 11.11.2015  –  Letzte Antwort am 12.11.2015  –  5 Beiträge
2018
  • Registrierte Mitglieder930.980 ( Heute: 5 )
  • Neuestes Mitgliedpetermayerhofer
  • Gesamtzahl an Themen1.564.348
  • Gesamtzahl an Beiträgen21.851.064
