HIFI-FORUM » Fernseher & Beamer » Scaler, Linedoubler & Videoprocessing » ChromaPure 2.2 Autocal | |
ChromaPure 2.2 Autocal+A -A |
durandal
#1 erstellt: 04. Jun 2011, 20:20 | |
zur Info - habe soeben den Newsletter von Chromapure bekommen - Auto-Calibrate ist für den DVDO Duo und den Lumagen eingebaut. Sobald Tom mir die neue Lizenz gesendet hat, teste ich es mit dem DVDO Duo und poste das Ergebnis. Bin auf jeden Fall gespannt -- What is ChromaPure Auto-Calibrate? This product allows anyone with little or no training in video technology to fully calibrate their display with almost no user input. Just setup a few simple options, click Auto-Calibrate, and then just go have a cup of coffee while the process completes, usually in 5-10 minutes. This feature is an optional add-on to ChromaPure Standard, and it works in conjunction with a DVDO Duo or Lumagen Radiance external video processor. The processor acts as both a test pattern signal generator and calibration device. The Auto-Calibrate software controls the processor and the color analyzer to get the most out of your display. It will even generate a before and after calibration report for you. The display's performance with respect to each of these parameters is presented in colourful charts and precise numerical values, both of which can update in real time as calibration adjustments are made. ChromaPure is based on a before/after model. When the calibration is finished, the user can generate a printable report that depicts the performance of the display before and after calibration. Auto-Calibrate will adjust the display's grayscale, gamma response, and color gamut to within industry standards. Auto-Calibrate is available to ChromaPure Standard users at a $139 CurtPalme.com discounted price. It is free for ChromaPure Professional users. ChromaPure Professional users should contact us to enable this option. What do I need to use ChromaPure Auto-Calibrate? A PC or laptop running ChromaPure 2.2 or higher with the ChromaPure Auto-Calibrate add-on A DVDO Duo or Lumagen Radiance external video processor connected to the PC via serial connection |
Fudoh
#2 erstellt: 04. Jun 2011, 22:44 | |
Würdest Du nach deinem ersten "Auto-Run" mal vergleichsweise deinen manuellen Kalibrierungsreport und dann zum Vergleich den automatischen posten ? Das Update kostet übrigens $139 für die Standard User. Die reguläre 2.2 (ohne Autokalibrierung) gibt's ebenfalls seit gestern zum Download. Grüße Tobias [Beitrag von Fudoh am 04. Jun 2011, 22:45 bearbeitet] |
durandal
#3 erstellt: 04. Jun 2011, 22:59 | |
Hallo Tobias, alles klar. Die neue Lizenz habe ich von Tom vor ein paar Minuten bekommen (hatte damals das Glück die alte 1er für 99US$ auf Pro 2 upgraden zu können). Aber heute teste ich es nicht mehr, sonst kriege ich Ärger mit der "Chefin" |
*speckbert*
#4 erstellt: 05. Jun 2011, 20:31 | |
Mit meinem Lumagen Radiance funktioniert die Auto-Calibrate Funktion nicht wirklich. Die Testbilder die am Fernseher angezeigt werden, stimmen mit der Anzeige in ChromaPure nicht überein. als Beispiel: lt. ChromaPure sollte eine 10% Grayscale Messung stattfinden - Testbild am TV ist aber Weiss |
Fudoh
#5 erstellt: 05. Jun 2011, 21:59 | |
Das Release ist ja erst einen Tag alt, da werden schon noch ein paar Bugs vorhanden sein. Ist Deine Radiance Firmware aktuell ? Da würde ich Tom einfach mal ne Email schicken - der Support ist ja erstklassig. Grüße Tobias |
*speckbert*
#6 erstellt: 06. Jun 2011, 07:14 | |
Hallo, ja ich hatte die aktuellste Radiance Firmware drauf. Ich werde es aber noch auf einem anderen Laptop testen bevor ich Tom kontaktiere. Mal sehen was "durandal" zu berichten hat. MfG |
durandal
#7 erstellt: 13. Jun 2011, 21:44 | |
Ich hatte leider erst heute Zeit es zu testen und bin beim Setup gescheitert. Sobald ich den Duo als Signal Generator wähle und die Comport Settings ändern möchte passiert folgendes: .net Framework meldet, dass der StopBit Wert außerhalb des gültigen Bereiches liegt. Update: Tom hat geantwortet - probiere es die tage noch mal aus. @speckbert: hattest Du zwischenzeitlich mehr Erfolg? [Beitrag von durandal am 13. Jun 2011, 23:26 bearbeitet] |
durandal
#8 erstellt: 14. Jun 2011, 23:52 | |
Autocal hat "funktioniert". Zunöchst zur Ausgangssituation: Epson EH-TW5500 (normale Edition - Lampe ca. 150h) im natürlich Modus + i1Pro 1. Durchgang im Eco Modus: - Dauerte ca. 1,25h - deutlich zu hoher Grünanteil (obwohl schon runtergedreht) im Ausgangszustand. - Fazit: Im Eco Modus kann ich den Beamer nicht auf eine vernünftige Grundbasis bringen. 2. Durchgang im Normal Modus (pre Cal): - RGB Histogramm ist relativ linear in den Grundeinstellungen - Greyscale reist unterhalb 20% und oberhalb 80% aus. - Chromaticity: Verringert bei Blau, Rot, Magenta - Erhöht bei Grün - Gamma <30 und >70 bis unter 1,74 2.1 Autocal im Normal Modus (post Cal): - RGB Histogramm war bereits recht linear >90% ist besser geworden, <20% schlechter (wobei der i1pro bei mit mit <30% ohnehin nicht mehr sauber mist - nur 1 Durchgang eingestellt) - Greyscale ist bei >90% besser geworden - Chromaticity: Nahezu identisch zum pre cal - Gamma: Ist deutlich linearer geworden - Dauer: ca. 20 Minuten Fazit: Gamma wurde sehr gut korrigiert - Rest war bereits recht linear, bzw. hatte durch die Korrektur keine maßgeblichen Auswirkungen. Persönlich finde ich es recht angenehm. |
*speckbert*
#9 erstellt: 15. Jun 2011, 07:28 | |
Hi, bei mir funktioniert leider nur die Gamut Messung. Bei der Gamma u. Grayscale Messung werden die Test Pattern <IRE60 zu hell dargestellt. Sobald ich "Start Auto-Calibration" drücke wird im Radiance Menü der "Luma-Wert" viel zu stark erhöht. IRE 50 bekommt einen Luma-Wert von 75.5 IRE 40 = Luma 65.5 IRE 30 = Luma 55.5 IRE 20 = Luma 40 IRE 10 = Luma 20 Tom vermutet einen Bug in meinem Radiance Mini. MfG [Beitrag von *speckbert* am 15. Jun 2011, 08:00 bearbeitet] |
DVDO iscan DUO / ZL1G Kalibrierung timmey1983 am 17.05.2012 – Letzte Antwort am 19.05.2012 – 3 Beiträge |
DVDO DUO Sporty2 am 16.12.2010 – Letzte Antwort am 27.01.2011 – 26 Beiträge |
DVDO Duo heute noch sinnvoll ? arik am 15.01.2012 – Letzte Antwort am 08.04.2012 – 11 Beiträge |
Lumagen oder DVDO? Smarti_X am 19.09.2007 – Letzte Antwort am 20.09.2007 – 3 Beiträge |
ABT / DVDO iScan Duo (mt Dual Video-HDMI Out) Fudoh am 16.09.2009 – Letzte Antwort am 26.01.2013 – 72 Beiträge |
DVDO IScan HD+ Sporty2 am 03.10.2010 – Letzte Antwort am 04.10.2010 – 3 Beiträge |
DVDO bloß welcher ? tb_filedealer am 08.01.2011 – Letzte Antwort am 07.04.2011 – 14 Beiträge |
Dvdo Edge oder DVDO iScan VP30 minu am 22.05.2009 – Letzte Antwort am 23.05.2009 – 3 Beiträge |
PAL Signale nach NTSC umrechnen lassen vom DVDO Duo tb_filedealer am 08.03.2011 – Letzte Antwort am 11.03.2011 – 12 Beiträge |
Schon Nachfolger für DVDO mit HDMI 1.4? tb_filedealer am 29.04.2011 – Letzte Antwort am 29.07.2013 – 30 Beiträge |
2011
Top 10 Threads in Scaler, Linedoubler & Videoprocessing der letzten 7 Tage
- Frage zu den Dateiformaten einer Blu-Ray Disc
- 720p auf 1080p skalieren lassen?
- PowerDVD: HD-DVD-Untertitel lassen sich nicht aus oder umschalten
- Womit Bildsignal horizontal spiegeln? (rechts <-> links)
- Videoprozessor für alte Videospiele ? ( PlayStation 1 usw )
- Ist die Kalibrierung eines TV-Gerätes sinnvoll?
- Lumagen Radiance Pro Videoprozessor 4xxx, 5xxx, 4K, DTM, Scaler, Darbee, 3D LUT
- Schwaiger Scart auf HDMI-Konverter
- Darbee 4K in 2021
- HD Fury Vertex 2
Top 10 Threads in Scaler, Linedoubler & Videoprocessing der letzten 50 Tage
- Darbee 4K in 2021
- HD Fury Vertex 2
- Registrierte Mitglieder927.268 ( Heute: 10 )
- Neuestes Mitgliedcaptn.kirk
- Gesamtzahl an Themen1.555.188
- Gesamtzahl an Beiträgen21.631.359
