| HIFI-FORUM » Stereo » Mobiles Hifi / iPod / MP3 Player / Bluetooth-Lautsprecher » Neuer iBasso D14 "Bushmaster" DAC/KHV | |
Neuer iBasso D14 "Bushmaster" DAC/KHV+A -A |
AG1M
erstellt: 14. Mai 2015, 19:59
Eben bei der iBasso Facebook Seite gesehen: https://www.facebook.com/iBassoAudioDie mMn wichtigsten Punkte habe ich mal Fett markiert. Klingt nach einem neuen sehr guten portablen DAC/KHV von iBasso. ![]() The iBasso D14. As a dac used with your computer, combined with a great internal amplifier many of your musical needs are met! There is no lag time if you listen to movies and with the OTG function, it works with any phone that has a proper functioning OTG output. iBasso D14 The D14 is our new generation AMP and DAC combo that combines the advantages of and advances on our design of the D12 and D62. It utilizes the Sabre32 ES9018K2M DAC chip and with the XMOS USB receiver and the D14 is able to take up to a 32bit/384kHz PCM signal and native DSD up to 256x from computers. It also can work as a DAC for Android smart phones via a USB OTG. Other than the USB input, the D14 can take up to 24bit/192kHz optical input, coaxial input and analogue line in. On the Amplification section, we have an OPAMP based high output headphone amplifier, which can output up to 400mW into a 32ohm load. The sound quality from this little all-in-one AMP+DAC is better than any of our previous AMP+DAC products and achieves this from a combination of advanced technologies and superior implementation of components. D14 Specifications: Power Source: Built-in 4.2V Li-polymer Batteries or external power supply. Frequency Response: 17Hz~20 KHz +/-1dB (DAC) 17Hz~100 KHz +/-0.2dB (AMP). Signal to Noise Ratio:115dB (DAC), 116dB (Amp). Crosstalk: 106dB (DAC). Total Harmonic Distortion: 0.0018%@1kHz/-10dBF (DAC) 0.0012%@1kHz/max volume (AMP). Output power: Up to 400mW+400mW into 32ohm. Gain: +3dB and +9dB (AMP). Battery Life: 13 hours AMP+DAC or 25 hours if amp only. Battery Charge Time: 5 hours. External Power supply: 5V DC. Recommended Headphone Impedance: 8~300. Output impedance: 0.1ohm. Retail Price: $229.00 release date the beginning of June, 2015. ![]() ![]()
AG1M
erstellt: 18. Jun 2015, 17:08
Es wird langsam ernst, bald wird der D14 zu haben sein laut iBasso nur noch ein wenig „Feintuning“. Hab hier schon einmal einen Shop gefunden: http://www.son-video...-D14-Bushmaster.html wenn das wirklich bei 230 Euro liegen wird, wäre das imho absolut Konkurrenzlos in allen Gesichtspunkten was der portable DAC/KHV bietet. Ich werde ganz sicher schwach werden Die Maße würden mich noch interessieren und hoffentlich packt iBasso ein ganz kurzes micro USB auf micro USB OTG Kabel dazu, sonst hat man wieder den Adapter Alptraum, wenn man sein Android Smartphone dran stecken möchte. Beim Iphones ist ja eh ein CCC / Lightning Kabel nötig, aber so ein micro USB könnte iBasso schon mit dazu legen, gab es ja auch bei älteren DACs wenn ich mich richtig erinnere auch dazu. |
housemeister1970
erstellt: 18. Okt 2015, 11:44
Hi Hast Du Dich dem feinen Gerätchen eigentlich weiter gewidmet? Bin am überlegen mir das Teil primär als Desktop-Lösung in Verbindung mit meinem Grado RS2e zuzulegen. Ein Händler in Deutschland konnte ich jedoch bisher nicht ausmachen. Nur der von Dir genannte Händler aus Frankreich hat das Teil auf Lager. Gruss Ralph [Beitrag von housemeister1970 am 18. Okt 2015, 11:57 bearbeitet] |
AG1M
erstellt: 18. Okt 2015, 12:22
Hi, nein habe da nicht weiter recherchiert. Aktuell direkt von iBasso.com zu bekommen, oder hier falls noch vorhanden: http://www.hifi-foru...m_id=265&thread=3813Aber wenn es rein als Desktop Lösung dienen soll, lieber einen LH Labs Geek Out 450 bzw. 1000 nehmen, hatte ich selbst beide schon hier, die Audioqualität wie beim iFi Audio mircro iDSD (Geek Out 1000) sehr hoch, hatte da auch u.a. mit meinem RS2i verglichen. |
housemeister1970
erstellt: 18. Okt 2015, 12:51
Ja, über die LH Geek Out KHV/DAC Lösung bin auch am überlegen. Hier im Biete Bereich findet man sogar den Geek Out V2 für round about 300 Euronen. Das einzigste was mich an dem Teil stören könnte ist dessen Plastik-Gehäuse und daß das Teil eben direkt in den USB-Port des Rechners gesteckt werden muss. Nutze bisher den Audioquest Dragonfly und bei dem ist das ja das selbe. Bisschen frimelige Angelegenheit meines erachtens. Aber klanglich sicherlich feine Teile, da Class A Verstärker und DSD Unterstützung. Zumindest beim V2. Hmm, da grübel ich nun schon ein paar Tage rum. |
AG1M
erstellt: 18. Okt 2015, 13:00
Ich nutze da immer das USB Kabel zwischen solchen USB DAC/KHV Modellen, aber sonst ist der D14 in meinen Augen von all den Möglichkeiten/Leistung in dem Preisbereich sehr interessant keine Frage.Btw. DSD und Co. können die Geek Out V1 auch alle, nur u.a. symmetrischer Ausgang ist beim V2 möglich. [Beitrag von AG1M am 18. Okt 2015, 13:02 bearbeitet] |
david_della_rocco
erstellt: 19. Okt 2015, 06:31
Ich hab den D14 seit gut 4 Wochen. Analog an den DX50 angeschlossen höre ich zum RSA Predator keinen unterschied, außer minimal mehr Rauschen (wobei der Predator absolut still ist). Allerdings coaxial angeschlossen (optisch noch nicht versucht) Offenbart der D14 einen Wahnsinns Sound ohne Rausch. OTG USB-Kabel ist mit dabei. Auf jeden Fall ist es ein klanglicher zugewinn zum DX50. Power hat der AMP ohne ende. Kleines minus für den Poti, nichts für extrem-leise-hörer. Ist relativ laut bis er im gleichlauf ist. Verarbeitung ist grandios, größe perfekt zum stacken mit DX50-DX90. Für das Geld ein super Gerät. Hören tu ich mit Fischer Amp FA-3E XB und Beyerdynamic T90. |
iBasso P5 "Falcon" - portabler KHV mit wechselbaren Buffer und OpAmp AG1M am 25.05.2015 – Letzte Antwort am 05.08.2015 – 2 Beiträge |
neuer DAP oder Smartphone mit USB/DAC-KHV housemeister1970 am 10.04.2016 – Letzte Antwort am 12.04.2016 – 15 Beiträge |
KHV DAC für ipod DJMDG am 24.09.2011 – Letzte Antwort am 26.09.2011 – 8 Beiträge |
DX170-Neuer iBasso im Anflug? Roadfox am 09.07.2022 – Letzte Antwort am 17.08.2022 – 51 Beiträge |
Smartphone + KHV/DAC vs. DAP sarah.10.03 am 24.12.2015 – Letzte Antwort am 27.12.2015 – 15 Beiträge |
FiiO E10K + Ibasso DX90 -Life- am 29.11.2018 – Letzte Antwort am 01.12.2018 – 8 Beiträge |
FiiO E12A - neuer portabler KHV AG1M am 10.10.2014 – Letzte Antwort am 29.05.2015 – 31 Beiträge |
Ibasso DX90 robodoc am 02.02.2014 – Letzte Antwort am 02.09.2016 – 496 Beiträge |
KHV/DAC - Ifi hip-dac oder Beyerdynamic Impacto Universal? thebuddha am 13.04.2020 – Letzte Antwort am 13.04.2020 – 4 Beiträge |
Mp3-Player an mobilen KHV/DAC anschleißen? infinity650 am 22.09.2011 – Letzte Antwort am 25.09.2011 – 5 Beiträge |
Top 10 Threads in Mobiles Hifi / iPod / MP3 Player / Bluetooth-Lautsprecher der letzten 7 Tage
- TEUFEL "Rockster Go": Problem bei fortlaufender Wiedergabe
- JBL Partybox (OTG) externe powerbank
- Soundboks 3. Gen am Strom betreiben
- JBL Xtreme (keine Verbindung mit JBL Portable App)
- JBL Xtreme 3 mit Powerbank laden
- Teufel Rockster Air läd nicht/Sicherung defekt
- Gibt es noch mini Lautsprecher ohne Bluetooth?
- Zwei JBL PartyBox 1000 mit Cinch verbinden.
- Aktuelle Smartphones mit DAC überhaupt vorhanden?
- "Bester" Walkman (Kassette) ?
Top 10 Threads in Mobiles Hifi / iPod / MP3 Player / Bluetooth-Lautsprecher der letzten 50 Tage
- Registrierte Mitglieder930.643 ( Heute: 7 )
- Neuestes MitgliedHolger72!
- Gesamtzahl an Themen1.563.397
- Gesamtzahl an Beiträgen21.824.299
