| HIFI-FORUM » Stereo » Mobiles Hifi / iPod / MP3 Player / Bluetooth-Lautsprecher » m3u-Playlist sichtbar aber nicht spielbar | |
m3u-Playlist sichtbar aber nicht spielbar+A -A |
Dreadlock65
erstellt: 23. Apr 2015, 08:54
Hallo Leute, leider funktionieren die über JRiverMedia Center erstellen m3u-PLaylisten nicht. Hat jemand Tipps? Ich habe das Problem an den Support von iBasso geschickt, aber noch keine Antwort. Details anbei: Viele Grüße Email an ibasso: Problems with m3u-playlists Dear Guys, I bought a DX50 (firmware 1.92)an like it very much. Esspecially the brilliant sound. But yesterday after hours trying to use m3u-playlists generated by JRiver Media Center (www.jriver.com) and other tools, I wanted to return the DX50 to AMAZON and intended to inform other clients of AMAZON about this fault. BUT I DIT NOT, because of the briliant sound :-) and beause I see, that you clear faults and beacuase you are publishing new firmware quite often. I see the in the JRiver-Software (or other) generatetd on the computer (Windows m3u-playlists in the computer and on the device. But it isn't possible to play them. BUT: If I add title to these playlists WITHIN THE DX 50 (!) it is possible to play THESE titles on the device!I helped myself by organizing may music with folders - as in the 90s... But I want You to do the following: 1. Please inform me in detail, what I have to do, that the playlists which I generate on the computer are working. Which kind of m3u-File, is storing it on the micro-sd-card possible or necessary, to put it in the internal memory of the DX 50? OR simply debug this fault in the firmware. PLAYING PLAYLISTS IS A VERY IMPORTANT FEATURE! 2. The second 'fault' is, that when I want to play genres (I use it as a workaround for the not working playlists), the device shows folders with the musicians. It is not possible to play music at random of ALL musicians of this genre. Only each musician (-folder) can by played. 3.It's the same with other real folders on the device. It should be possible to play folders with sub-Folders. I hope you can help me soon. Otherwise I have to return the player and comment it within AMAZON. Best Regards |
AG1M
erstellt: 23. Apr 2015, 12:55
Hallo, schau mal hier: http://www.head-fi.o.../16155#post_11239184 hilft vielleicht.Btw. wäre Rockbox eine Alternative Firmware fü dich? Läuft auf meinem DX50 wunderbar und hat einen guten Playlist Support. |
Dreadlock65
erstellt: 23. Apr 2015, 20:39
Hallo AG1m, vielen Dank für den schnellen Tipp. Ich bin aus der Anleitung "Then go to the directory where you saved (usually iBasso sd) and edit the directories for Android. For example: E: \ Music \ The La La.mp3 by: /mnt/ external _sd / Music / La La La.mp3" nicht ganz schlau geworden. Ein Verzeichnis umbenennen ist banal, aber daraus einen anderen einen Pfad machen...? Rockbox hatte ich vor x Jahren. Lief gut. Habe aber gelesen dass das auf dem DX50 noch nicht stabil laufen soll. Wird denn durch die andere firmware der Klang beeinflusst? Hast Du einen empfehlenswerten Link oder einfach auf die Rockbox-Seite...? |
AG1M
erstellt: 23. Apr 2015, 20:52
Also, du musst nur den absoluten Pfad anpassen, indem du deine Playlist Datein mit einem Texteditor anpasst (steht alles in dem Link), also aus "X:\dein pfad auf dem pc\deine Musik" wird "/mnt/external_sd\deine Musik". Deine Ordner selbst können so bleiben nur die Pfadangabe/Schreibweise sollte angepasst werden. Da die iBasso Firmware Linux basierend ist, ist der Einhängepunkt oder auf Englisch Mount point kurz "mnt" für die microSD Karte "external_sd" dieser Pfad. Unter Rockbox ist es im übrigen der gleiche Pfad usw. Hier gibts Rockbox für den DX50: http://www.head-fi.o...-with-stock-firmware Bei mir ist der DX50 noch nicht einmal mit Rockbox eingeforen oder hat Probleme gemacht. Der Klang ist immer gleich (gut) egal ob iBasso Mango oder Rockbox. |
Dreadlock65
erstellt: 23. Apr 2015, 21:18
Aah, jetzt dämmert's. Editieren der Playlist selbst. Danke! Eine letzte Frage: Muss ich den Pfad immer wieder anpassen, wenn mal eine neue Datei zur Musiksammlung hinzu kommt und JRiver Media Center mit dem Player synchronisiert? Mit anderen Worten, wird dann jedesmal die Playlist und darin der händisch geänderte Pfad überschrieben? Das wäre dann ja nervig und gelinde gesagt wenig komfortabel. |
AG1M
erstellt: 24. Apr 2015, 09:31
Hallo, du musst immer mit einem Texteditor anpassen, das geht aber einfach via "Suchen&Ersetzen" in wenigen Sekunden. Persönlich verwende ich aber weder Playlisten noch die Datenbankfunktion, bevorzuge schon immer reine Ordnernavigation. Wenn das für dich also sehr wichtig ist, wirst du nicht um das anpassen herum kommen, soviel ich weiß. |
playlist auf Cowon M2 erstellen waldhörer am 21.01.2016 – Letzte Antwort am 03.04.2016 – 2 Beiträge |
News Cowon D2 & Rockbox & Sound & .m3u Pinin am 20.06.2008 – Letzte Antwort am 20.06.2008 – 2 Beiträge |
Cowon I9 Playlist cmoss am 01.03.2012 – Letzte Antwort am 01.03.2012 – 3 Beiträge |
Playlist für FiiO X1 wird im Auto nicht gelesen RunWithOne am 19.09.2016 – Letzte Antwort am 01.11.2016 – 16 Beiträge |
Cowon S9 Playlist übertragen Rotten67 am 15.04.2011 – Letzte Antwort am 23.04.2011 – 10 Beiträge |
Fiio M9 Playlist importieren SteveHH1965 am 13.09.2024 – Letzte Antwort am 14.09.2024 – 3 Beiträge |
Cowon D2 Playlist problem drcarbo am 17.06.2007 – Letzte Antwort am 18.06.2007 – 4 Beiträge |
iAudio X5L - HD, Playlist Gertschi15 am 03.03.2006 – Letzte Antwort am 10.03.2006 – 4 Beiträge |
D2 und Dynamic Playlist mike99 am 29.10.2008 – Letzte Antwort am 31.10.2008 – 3 Beiträge |
Fiio - Playlist am PC erstellen deefly am 02.03.2017 – Letzte Antwort am 03.03.2017 – 5 Beiträge |
2015
Top 10 Threads in Mobiles Hifi / iPod / MP3 Player / Bluetooth-Lautsprecher der letzten 7 Tage
- TEUFEL "Rockster Go": Problem bei fortlaufender Wiedergabe
- JBL Partybox (OTG) externe powerbank
- Soundboks 3. Gen am Strom betreiben
- JBL Xtreme (keine Verbindung mit JBL Portable App)
- JBL Xtreme 3 mit Powerbank laden
- Teufel Rockster Air läd nicht/Sicherung defekt
- Gibt es noch mini Lautsprecher ohne Bluetooth?
- Zwei JBL PartyBox 1000 mit Cinch verbinden.
- Aktuelle Smartphones mit DAC überhaupt vorhanden?
- "Bester" Walkman (Kassette) ?
Top 10 Threads in Mobiles Hifi / iPod / MP3 Player / Bluetooth-Lautsprecher der letzten 50 Tage
- Registrierte Mitglieder930.970 ( Heute: )
- Neuestes Mitgliedpchubshop
- Gesamtzahl an Themen1.564.310
- Gesamtzahl an Beiträgen21.850.229
