HIFI-FORUM » Car-Hifi » Car-Hifi: Allgemeines » SPL » 16v | |
16v+A -A |
josmuck
22:32
erstellt: 16. Feb 2006, |
Hi, i would like raise the voltage up to 16v. i spoke today with sombody that sells the cyclone from hawker and he was not sure what would happen if i put a 2v bat together with a 12v bat. does anybody out there have any idea what i should do or how i can get to 16v? laterz brian |
Son_of_Thor
00:41
erstellt: 17. Feb 2006, |
Hello, you can do this with 2 oder 4 Volt Cells, no Problem. Fiam, Ground Zero, Hawker... some Batterie Manufactors Produce this Cells. But you should ONLY use them for dB-Drag, for the Burp!!!! Don`t use this for music and be sure your amps can do this Voltage. With a normal Batterie an a 4 Volt Cell you get so 17 Volt. Mfg Dirk |
Smartmatze
17:54
erstellt: 18. Feb 2006, |
If you wire a 2V cell in series to a normal battery, you'll get 14 V. Of course, real voltage will be at about 15 V, but we speak about NOMINAL voltage, when a normaler car battery has 12V. IF you want a 16 V setup, you have to use 2 V cells in series or 1 4V cell wired to the 12V. This will result in a 17,0 - 18,0 V real voltage depending on the cells you use. IF your ampflifiers are able to work at this volage you will get about 20-40% more power - but remember this results in probably 0.5 - 1.0 dB. In my opinion, this amount of higher pressure is easier to get if you work on you box... Üüüühh!!! Matze |
reso for a polo 6n josmuck am 07.07.2005 – Letzte Antwort am 13.07.2005 – 14 Beiträge |
148,4 josmuck am 16.08.2005 – Letzte Antwort am 21.08.2005 – 3 Beiträge |
bat. macneil am 02.10.2006 – Letzte Antwort am 04.10.2006 – 7 Beiträge |
16V im Auto, mit 14v + 2v AGM Batterien! dbdrag2016 am 06.03.2018 – Letzte Antwort am 07.03.2018 – 23 Beiträge |
welche Reso im 35 i passat Limo gsxfblau am 14.01.2005 – Letzte Antwort am 04.02.2005 – 11 Beiträge |
Bat.-größe = andere Klasse? Algi am 08.10.2006 – Letzte Antwort am 09.10.2006 – 5 Beiträge |
bat/leistung/verhalten macneil am 23.05.2007 – Letzte Antwort am 28.05.2007 – 11 Beiträge |
zusatz bat, frage macneil am 14.12.2007 – Letzte Antwort am 20.12.2007 – 11 Beiträge |
B2 Audio CC15 oder GZPW12SPL Darklegendhero123 am 03.10.2014 – Letzte Antwort am 03.10.2014 – 4 Beiträge |
Extra SPL Kiste Speaker, Volumen, more i need some Tipps siggixxl am 01.10.2015 – Letzte Antwort am 24.04.2016 – 31 Beiträge |
2006
Top Produkte in SPL
Top 10 Threads in SPL der letzten 7 Tage
Top 10 Threads in SPL der letzten 50 Tage
- Registrierte Mitglieder929.176 ( Heute: 5 )
- Neuestes MitgliedLetty25
- Gesamtzahl an Themen1.559.869
- Gesamtzahl an Beiträgen21.737.104
