Canton Plus A
Rockerfeller86
#1 erstellt: 11. Sep 2019, 19:55
Hello everybody!
I have a extremely rare subwoofer, Plus A, does anybody have one?
Cheers, skål!
/ Freddie from Sweden
Passat
#2 erstellt: 12. Sep 2019, 07:57
Yes, i have a Plus A.
Here pictures of my Plus A:
Inside the amp:
Cheers
Roman
[Beitrag von Passat am 12. Sep 2019, 07:58 bearbeitet]
Rockerfeller86
#3 erstellt: 12. Sep 2019, 08:13
Cool! I have a problem, the sound faded away and now its no sound from non of the three amps, do you have a servicescheme? 🙂
Passat
#4 erstellt: 12. Sep 2019, 08:57
I do not have a servicescheme.
Even Canton have no servicescheme.
All such dokuments for the Plus A are lost at Canton.
The Plus A has a heat problem on the sockets for the three boards on the right.
the brown color on the middle socket is from the heat.
The capacitors on the three boards must then be replaced.
On the picture the 2 capacitors at the left end of the boards.
The boards are different!
2 boards are for the satellites, 1 board is for the bass.
[Beitrag von Passat am 12. Sep 2019, 09:07 bearbeitet]
Rockerfeller86
#5 erstellt: 12. Sep 2019, 15:09
Thank you so much! I wonder how many of these is still alive and is it some value in them?
Have a great evening!
Freddie
Rockerfeller86
#6 erstellt: 12. Sep 2019, 15:41
Screenshot_20190912_173825_com.android.chrome
Passat
#7 erstellt: 12. Sep 2019, 19:52
The Plus A was very expensive, so not many were sold.
I have searched many years for my Plus A.
Since 2000 i have seen only 4 Plus A at Ebay or other internet sources and you are the second owner of a Plus A other than myself, of whom I know.
In standard black it costs 3.600,- DM, in wood 4.000,- DM in 1984.
That were 10.500 - 11.600 SEK.
[Beitrag von Passat am 12. Sep 2019, 19:56 bearbeitet]
Trinnitus
#8 erstellt: 12. Sep 2019, 21:08
Hey Freddie,
Canton Plus A
Canton Plus A 1b
Reparatur-Thread
Canton Plus A
Beispiel ↓
P6010128b
Gruß Matthias
[Beitrag von Trinnitus am 12. Sep 2019, 22:25 bearbeitet]
Hifi-Hilde
#9 erstellt: 16. Jun 2024, 07:58
Hallo zusammen,
ich konnte kürzlich einen Plus A bei Kleinanzeigen.de ergattern, er läuft zwar, hat aber auch das Hitzeproblem bei den Steckplatinen.
Außerdem scheint die Einschaltautomatik defekt zu sein (grüne und rote LED leuchten immer beide).
Hat jemand vielleicht noch das PDF mit der Bedienungsanleitung parat ?
Das wäre ganz großartig
Viele Grüße aus Hamburg
Stefan
Hüb'
Moderator
#10 erstellt: 26. Jun 2024, 09:36
Vermutlich kann Canton dir da weiterhelfen.
Hifi-Hilde
#11 erstellt: 26. Jun 2024, 10:48
Leider nicht, meine Anfrage bei canton gab nur die Rückmeldung, das sei schon zu lange her und man habe nichts (mehr).
Ich hatte mehr auf die beiden anderen Plus A Besitzer (Roman und Matthias) gehofft.
Vielleicht verirrt sich einer von Ihnen ja nochmal in diesen Thread...
Hüb'
Moderator
#12 erstellt: 26. Jun 2024, 11:04
Ah, schade. Oftmals können die Cantöner selbst bei sehr alten Produkten noch helfen.
Trinnitus
#13 erstellt: 24. Jan 2025, 22:25
Guten Abend Stefan,
ein .pdf gibt es dazu nicht mehr. Der Herr der die damals gebaut und repariert hat ist nicht mehr und
er hat alles dazu in die ewigen Jagdgründe befördert.
Hier hilft dann nur noch, Bauteile prüfen und ggf. erneuern, Verlötungen nachlöten, ausgeglühte Kabel
gibt es auch und die müssen natürlich auch neu.
Wenn das Teil dann wieder funktioniert, ist es vorteilhaft wenn man Sicherheitsglas in den Fenstern hat.
Gruß Matthias
Lux SQ 1220 - Is there anybody out there...?
fbaihofer am 15.12.2004  –  Letzte Antwort am 22.10.2009  –  19 Beiträge
Canton Plus C / Plus S
nullnyx am 30.12.2021  –  Letzte Antwort am 12.01.2022  –  18 Beiträge
Kenwood KT-3300SD tuner - does it exist?/
Nick_G am 21.10.2010  –  Letzte Antwort am 21.10.2010  –  3 Beiträge
Onkyo vs. Canton vs. T+A
SimonSy am 13.07.2021  –  Letzte Antwort am 13.07.2021  –  11 Beiträge
Exotic German/Japanese Power Amp Continental GA-COMPO A
matijaudio am 18.01.2015  –  Letzte Antwort am 21.01.2015  –  3 Beiträge
Canton Plus C als Woofer für Dynaudio Audience 42?
slugg11 am 13.09.2012  –  Letzte Antwort am 14.09.2012  –  6 Beiträge
Sanyo JCX 2100LE?
colamange am 25.02.2006  –  Letzte Antwort am 26.02.2006  –  2 Beiträge
Luxman M-02 Dual-FET
Chavagnac am 03.03.2012  –  Letzte Antwort am 04.03.2012  –  7 Beiträge
Telefunken Boxen TL-80
peters8 am 05.06.2014  –  Letzte Antwort am 10.06.2014  –  6 Beiträge
Canton GLE 100 + Yamaha a-700
sheep am 10.09.2004  –  Letzte Antwort am 13.09.2004  –  2 Beiträge
  • Gesamtzahl an Themen1.563.926
  • Gesamtzahl an Beiträgen21.839.259
