JBL Boxen EON 1500
Vohwinkeler
#1 erstellt: 05. Okt 2008, 16:05
Kann mir jemand Sagen welche Werte die "Sofitten" in der Box haben?
Eminenz
#2 erstellt: 05. Okt 2008, 16:06
JBL EON1500 Specifications
Description15" 2-way Multi-purpose
ApplicationMain speaker for music playback and live sound, stage monitor
Frequency Range55-16 kHz
Sensitivity (1w/1m)98 dB
Nominal Coverage60°x 90°
Power Handling Avg 225 W Peak 900 W
Max SPL129 dB
Nominal Impedance8 ohms
Dimension (HxWxD)686 x 430 x 444 mm 27 x 17 x 17.5 in
Weight17.24 kg 38 lbs
Key Features and Attributes
15" 2-way speaker system.
55 Hz to 16 kHz frequency response.
98 dB sensitivity (1 watt @ 1 meter)
8 ohms impedance
225 watts continuous pink noise power handling, 900 watts peak.
Now with Parallel 1/4" and NL4 input connectors (previous version only had
dual 1/4" connectors).
Liquid cooled titanium-diaphragm compression driver.
Molded one-piece baffle with integral 60° x 90° constant directivity horn.
SonicGuard™ circuitry unobtrusively protects the compression driver
from overpowering.
Multi-angle enclosure for flexibility - use EON1500 as a main PA speaker or
floor monitor.
Handsome, all black enclosure is unobtrusive and professional in appearance.
Enclosure and baffle are molded of tough, durable co-polymer material. EON 1500
will stand up to impact that would cause the joints on a conventional enclosure to separate.
A heavy-duty, perforated metal grill protects the woofer.
Ergonomically designed and balanced handle and lightweight enclosure for easy and
comfortable carrying
Net weight: a mere 38 lbs. (17.2 kg.).
Attachment points for wall or ceiling-mounting brackets (brackets available separately).
Integral 35 mm pole mount receptacle with securing thumb screw
Vohwinkeler
#3 erstellt: 07. Okt 2008, 20:44
Die Maße, Gewichte etc. habe ich schon.
Es geht darum die defekten Sofitten zu erneuern.
Leider ist weder auf der Platine, noch an den alten sofitten etwas lesbares.
Wäre schön jemanden zu finden der so was schon mal repariert hat.
Wer kennt JBL MX 1500 ?
Fact am 21.04.2004  –  Letzte Antwort am 21.04.2004  –  3 Beiträge
kennt jemand JBL CS 1500?
redroomboy99 am 16.12.2007  –  Letzte Antwort am 18.12.2007  –  8 Beiträge
jbl boxen
bugsbunchy am 02.08.2003  –  Letzte Antwort am 05.08.2003  –  3 Beiträge
Frage zu JBL Boxen
Momba am 15.08.2003  –  Letzte Antwort am 11.09.2003  –  6 Beiträge
Magnat oder JBL Boxen
Punami am 25.02.2005  –  Letzte Antwort am 27.02.2005  –  3 Beiträge
Boxen Montage JBL SCS Serien
am 07.04.2004  –  Letzte Antwort am 20.04.2004  –  2 Beiträge
Boxen für ca 1500 für Denon 3805!
GHOSTMAN am 26.12.2005  –  Letzte Antwort am 26.12.2005  –  2 Beiträge
welche boxen zu yamaha rxv 650 bzw. 1500
lublu am 18.03.2005  –  Letzte Antwort am 18.04.2005  –  3 Beiträge
Jbl
RMS_power am 02.12.2004  –  Letzte Antwort am 03.12.2004  –  3 Beiträge
Teufel, Canton, JBL? ich brauch HILFE !
hartmensch am 15.09.2006  –  Letzte Antwort am 15.09.2006  –  4 Beiträge
  • Registrierte Mitglieder930.464 ( Heute: 1 )
  • Neuestes MitgliedJackpotcon
  • Gesamtzahl an Themen1.562.906
  • Gesamtzahl an Beiträgen21.812.010
