Verkauft: Matrix Mini-i
j!more
#1 erstellt: 19. Dez 2012, 07:31
Preis (Pflichtangabe!): 189 Euro inkl. Versand
Standort: München
Zustand: Sehr guter gebrauchter Zustand
Artikelbeschreibung: KHV und Monitor-Controller Matrix Mini-i, 3 Jahre alt. Ideale Audio-Zentrale für den PC. Genug Power für alle Kopfhörer durch TI-Ausgangsstufen, beste Wandler,
Dual AD1955 D/A chip, digital volume control,digital LCD display, balanced and unbalanced outputs, independent system clock, S/PDIF, AES/EBU, and USB inputs, as well as a built-in headphone amplifier.
Features
· Balanced structure with dual AD1955 24bit / 192kHz D/A converter units
· Professional digital receiver chip of ultra-low jitter and an independent system clock
· USB, AES/EBU, optical, coaxial digital inputs and a coaxial output
· Up to 24bit / 192kHz digital input via coaxial and optical
· Professional stereo OP-Amps OP275/OPA2134, offering the best signal playback quality
· Digital step volume controller that covers -90 to 0 dB (1 dB each step)
· Both balanced and unbalanced output, which makes it possible to connect two sets of analog devices with different interfaces at the same time
· Multi-stage stabilized voltage power supply
· Internal headphone amp unit can easily drive any headphones of 300 ohms and below
· Large screen LCD panel displays user friendly information on current playback status and unit setting
· Pre-amp mode and DAC mode selectable
· While starting up or switching input channels, the volume will fade in to prevent shock and hearing damage caused by excessive volume
· Displays track information when working with D-Sub code compatible CD players
Digitale Eingänge:
OPTICAL: Shielded/enclosed optical input Sampling Rate: 44.1kHz ~192kHz
BNC : Standard BNC 75 ohm Sampling Rate: 44.1kHz ~192kHz
USB : Standard USB-B connector Sampling Rate: 44.1kHz ~48kHz
AES/EBU: Standard XLR interface Sampling Rate: 44.1kHz ~192kHz
Digitaler Ausgang:
Coaxial Output: standard RCA jack Supports AC-3, DTS data output
Sampling Rate: 44.1kHz ~192kHz Output Level: 1Vp-p (75 ohm)
Analog-Sektion:
RCA Output Level: 0V~ 2.0V adjustable
Balanced Output Level: 0V~ 4.0V adjustable (XLR : 1=GND, 2=HOT, 3=COLD)
Frequency response: 20Hz~20KHz
SNR: 105 dB
Dynamic Range: 108 dB
Distortion : <0.0002%(1KHz)
[Beitrag von j!more am 19. Dez 2012, 07:42 bearbeitet]
Matrix Mini-i DAC/Kopfhörerverstärker 'Verkauft'
perfect_pitch am 25.05.2013  –  Letzte Antwort am 29.07.2013  –  6 Beiträge
Matrix mini-i DAC/KHV
tf32h am 26.01.2014  –  Letzte Antwort am 08.07.2014  –  8 Beiträge
Matrix Audio Mini-i Pro
P_S_Nelke am 02.06.2017  –  Letzte Antwort am 05.06.2017  –  2 Beiträge
Matrix Audio Mini-i Pro 3 (verkauft)
maky100 am 14.03.2022  –  Letzte Antwort am 06.04.2022  –  3 Beiträge
Matrix Mini i DAC/ Kopfhörerverstärker 'Verkauft'
perfect_pitch am 12.08.2012  –  Letzte Antwort am 28.08.2012  –  4 Beiträge
Audio-GD NFB6 Balanced Headphone Amplifier
Anarion am 06.05.2012  –  Letzte Antwort am 21.05.2012  –  2 Beiträge
KHV Matrix M-Stage
Quince am 28.01.2012  –  Letzte Antwort am 06.02.2012  –  3 Beiträge
Topping DX7s DSD DAC/KHV bei München
Ongii am 28.12.2020  –  Letzte Antwort am 11.01.2021  –  2 Beiträge
DAC Matrix Wandler / Kopfhörerverstärker
sebnest am 19.10.2011  –  Letzte Antwort am 18.11.2011  –  4 Beiträge
VERKAUFT Transistorkopfhörerverstärker SPL Phonotor mini - Top-Zustand
MacGerry am 15.07.2018  –  Letzte Antwort am 26.07.2018  –  2 Beiträge
2012
  • Registrierte Mitglieder927.564 ( Heute: 5 )
  • Neuestes Mitgliedkowalski_51
  • Gesamtzahl an Themen1.555.951
  • Gesamtzahl an Beiträgen21.648.998
