| HIFI-FORUM » Stereo » Kaufberatung Stereo » High quality stereo amplifier with network player | |
High quality stereo amplifier with network player+A -A |
mihai0711
erstellt: 07. Dez 2018, 10:23
Here's a puzzle for you, Hi-Fi gear experts. I would like an integrated amplifier or a power amplifier + network player combo that.. has the following: - is a 2-channel Class AB amplifier - delivers at least 100W into 8 ohms at THD+N < 0.05% - preferably delivers at least 200W into 8 ohms at THD+N < 0.01% - can dive down to 2 ohms for musical transients (my Canton Reference 5K speakers go down to 3 ohms) - can play 192k FLAC files from a DLNA server or USB Hard Drive (DSD and MQA playback are a plus) - can be controlled via a remote and a mobile app - MSRP is below $5000 (the less, the better - I am also open to buy used) - no need to mention I am looking for the best sound quality I can get doesn't necessarly need to have the following: - tone controls - Spotify, TIDAL, Deezer, Napster, etc. - FM Radio - internet radio - a ton of digital and analogue inputs and outputs - subwoofer out - Headphones amplifier - multiroom - Bluetooth - other extra features besides the ones listed above Here are some candidates I already identified in the marketplace - with their downsides: - The combo Cambridge Audio Azur 851N+851W: no real downsides, but I am convinced I can get better amp performance in this price range :) - Yamaha R-N803D: has a lot of extra features I don't need and only delivers 100W at 0.019% THD; but is quite cheap @ $800 - Hegel H360: not very clear if the DLNA functionality works only with a network storage - seems that it needs an uPnP-capable media player. Price is quite high (around $6000 new; however on the used market dives down to $3000) - Rotel RT-1570 + RB-1582 MKII: streamer is entry-level, amp doesn't have very good reviews - NAD M32 + BluOS v2: is a class D amplifier - Musical Fidelity M6 Encore 225: has a lot of extra features I don't need (CD Player, ripper) Notes: - I use Canton Reference 5K speakers (https://www.canton.de/en/reference-k/reference-5-k) and I mostly listen to Jazz and Classical music with a dash of Pop from time to time. - I would, of course, preffer a one-box solution to my puzzle :) If you have other recommendations, please enlighten me! Thank you very much in advance! [Beitrag von mihai0711 am 07. Dez 2018, 10:24 bearbeitet] |
Erik030474
erstellt: 07. Dez 2018, 11:25
What for? You won't hear the difference to Class-D!
You copied this from where?
If your speakers are that critical, I would recommend a GLOCKENKLANG BUGATTI 400.
Have a look at LINN, HIFIAKADEMIE and a lot of others! |
mihai0711
erstellt: 08. Mai 2019, 07:49
Just as a follow-up, for anyone interested: My answer to the puzzle is Hegel H590 (ex-demo a bit above the 5000 price-point) + Canton Reference 3K speakers. |
mihai0711
erstellt: 18. Jun 2019, 09:48
To whom landed here from Google searches and might have a simmilar dillema - some explanations below. First, my rationale: I wanted clear, articluate, punchy bass. Therefore, I went for a floor-stander that goes down to 20Hz. Or at least to 25Hz. And I don't mean the 25Hz written in the spec sheet (-10dB/1m), but the one in tests, with room response at -6dB/2.5m. Further on, I looked for an amp that can sustain and control that bass. That is - at least 200W into 8 ohms which must double into 4 ohms. Also, for crystal-clear vocals and sparklinkg instruments (piano, violin, guitar), one must go for the best mid-range there is (usually only found in the reference series of speakers). Therefore, for top-notch sound in the bass and mid-range, you'd want a "flagship", "higher-end", "signature", "reference", "top of the line" amplifier and speakers, plus cabling, room treatment and good speaker positioning. Here are the finalists - partially extracted from StereoPlay's latest rank (June 2019) combined with my personal research. https://www.connect....ereoplay-2019-06.pdf Reference class A/B amps with DAC and at least 200W/8 ohm which doubles into 4 ohms (approximate MSRP prices): - Gryphon Diablo 300 (18k with DAC) - Mark Levinson Nº 585 (14k) - McIntosh MA9000 (13k) - Hegel H590 (10k) - Maranz PM10 (Class D, 10k) - Audionet DNA (10k) - Perreaux 255i (8k) - Krell Digital Vanguard (7.8k) - Anthem STR (6k) - Hegel H390 (6k) Reference Speakers that in-room go below 30Hz at -6dB/2.5m (approximate MSRP prices): - KEF Blade Two (25k) - Bowers & Wilkins 802 D3 (22k) - Canton Reference 1K (20k) - Monitor Audio Platinum PL500 II (20k) - Focal Sopra No. 3 (20k) - Audio Physic Avantera III (20k) - Dynaudio Confidence 30 (20k) - KEF Reference 5 (19k) - Sonus Faber Amati Tradition (18k) - Bowers & Wilkins 803 D3 (17k) - Wilson Audio Sabrina (16k) - Focal Sopra No. 2 (14k) - Focal Kanta No. 3 (13k) - Canton Reference 3K (10k) - Dynaudio Contour 60 (10k) - Nubert nuVero 170 (9k) - Bowers & Wilkins 804 D3 (9k) I got (May 2019) a Hegel H590 + Canton Reference 3K combo for ~9k euro (MSRP 20k) and they sound heavenly The Canton Reference 3K in-room goes just a bit below 30Hz - but for lower bass I had to spend more - much more ![]() The Hegel H590 best matched what I was searching for because of its detailed, neutral, crystal-clear DAC/amp and bass control. Also the lack of phono amp, headphone amp, tone controls, fancy/gloomy aesthetics and other features that I don't use/need - instead, the H590 focuses only on the things that matter to me the most: detailed sound, musicality, bass control, dynamics (it can deliver up to 2.2kW per channel into 1 ohm!), noise floor, quality DAC, basic streamer, minimal design etc. Note that I listen mostly to acoustic music - jazz, ambient, chill-out, piano, instrumental and classical in a 25 square meter room. Cheers! |
S.M.S.L. DP3 Hi-Res-LAN-Network Player skyranger73G am 10.06.2018 – Letzte Antwort am 05.10.2018 – 4 Beiträge |
High Quality Musik Downloden ? Aber wo ? Tr0ni am 14.01.2010 – Letzte Antwort am 14.01.2010 – 2 Beiträge |
Amplifier und CD-Player fuer den Einstieg Zutai am 09.12.2003 – Letzte Antwort am 23.12.2003 – 10 Beiträge |
HIGH END CD-Player gesucht ovosskamp am 08.01.2005 – Letzte Antwort am 08.01.2005 – 2 Beiträge |
high fidelity high end music hifi stereo anlage LottoKingKarl am 22.07.2014 – Letzte Antwort am 22.07.2014 – 6 Beiträge |
Portablen High Res. Player elias am 12.08.2019 – Letzte Antwort am 13.08.2019 – 3 Beiträge |
High Resolution Player Vulpes_Zerda am 07.02.2020 – Letzte Antwort am 08.02.2020 – 2 Beiträge |
Cambridge Audio Amplifier??? flomo am 17.01.2004 – Letzte Antwort am 19.01.2004 – 5 Beiträge |
Denon 1909 Surround vs. Stereo Amplifier exid am 23.08.2010 – Letzte Antwort am 26.08.2010 – 5 Beiträge |
Suche Stereo Amplifier für neues HIFI-System Stockpferd am 19.09.2015 – Letzte Antwort am 19.09.2015 – 19 Beiträge |
- Subwoofer bis 500 Euro
- Wiim Mini Top oder Flop.
- Novex Smartline 600
- Registrierte Mitglieder930.676 ( Heute: 4 )
- Neuestes MitgliedTim.R1
- Gesamtzahl an Themen1.563.501
- Gesamtzahl an Beiträgen21.827.198
