| HIFI-FORUM » Stereo » Lautsprecher » Quadral Aurum Titan | |
Quadral Aurum Titan+A -A |
WOAMETALHEAD
erstellt: 12. Feb 2005, 22:40
Hello, I write in englisch because I m' from holland and my german isn't verry good Does anybody have any experience with teh Aurum Titan? I m thiking to upgrade to the aurum titan My current speakers is the aurum vulkan Is the upgrade worth the money? I haven't heard the titan yet cause not so many stores in holland have them in stock. Sounds the titan much better then the vulkan? And what kind of amp do I need to drive the titan? My amp at this moment is the Marantz pm-14mkIIki Is this amp stable enough to drive the michty Titan ? Regards The Wacken Open Air MetalHead !!! [Beitrag von WOAMETALHEAD am 12. Feb 2005, 22:46 bearbeitet] |
WOAMETALHEAD
erstellt: 14. Feb 2005, 20:54
nobody any experience with the aurum titan ??? |
strgaltdel
erstellt: 15. Feb 2005, 11:02
Hello Woametalhead, maybe your german is good enough to read this thread: http://www.hifi-foru...4445&back=&sort=&z=1the titan seems to be a little sensitive regarding room interaction. hoping I could help a little bit best regards Udo [Beitrag von strgaltdel am 15. Feb 2005, 11:03 bearbeitet] |
UweM
Moderator |
erstellt: 15. Feb 2005, 11:24
Hi, you can expect a similar sound in mids and highs, the main difference lies in the bass range. Titan reaches lower frequencies and can also produce higher volumes. As already mentioned this can cause problems with room interaction. If you already have some problems with resonances while using the Vulcan, these problems will become even worse with the Titan. There is only one way to judge: Listen to it in your own room! Your amp seems to be sufficient. Best regards, Uwe |
WOAMETALHEAD
erstellt: 15. Feb 2005, 16:50
Danke ! |
Where to buy Elac on the net ? gbogros am 12.03.2004 – Letzte Antwort am 22.03.2004 – 3 Beiträge |
Quadral aurum titan tranceliner am 04.06.2004 – Letzte Antwort am 04.06.2004 – 3 Beiträge |
CANTON VENTO 886 mit cambridge CXR120 Kevin1122 am 11.10.2016 – Letzte Antwort am 11.10.2016 – 6 Beiträge |
Quadral Aurum Titan VII onload am 16.05.2006 – Letzte Antwort am 22.05.2006 – 12 Beiträge |
Quadral Montan: "der Klang ist unklar" Touister am 02.03.2013 – Letzte Antwort am 03.03.2013 – 6 Beiträge |
dls 38cm josmuck am 01.03.2004 – Letzte Antwort am 01.03.2004 – 2 Beiträge |
Vulkan MKV woofer!Help! Soundofvoid am 20.01.2009 – Letzte Antwort am 20.01.2009 – 2 Beiträge |
Quadral Ascent 660 / 860 Koenie am 25.09.2005 – Letzte Antwort am 26.09.2005 – 5 Beiträge |
Isophon Europa II Tweeters Henrik_Sweden am 29.12.2020 – Letzte Antwort am 29.12.2020 – 3 Beiträge |
need advice:surround speaker placement ? eano am 13.04.2010 – Letzte Antwort am 13.04.2010 – 2 Beiträge |
2005
- Schneider Lautsprecher
- TSM kennt die jemand?
- Ecouton
- Ecouton
- Registrierte Mitglieder930.940 ( Heute: 6 )
- Neuestes MitgliedBifob
- Gesamtzahl an Themen1.564.219
- Gesamtzahl an Beiträgen21.847.201
