HIFI-FORUM » Surround & Heimkino » A/V-Receiver/-Verstärker » Marantz » Marantz SR 6006 Internetprobleme | |
Marantz SR 6006 Internetprobleme+A -A |
Smoetler
22:35
erstellt: 23. Jan 2017, |
Servus liebe Leute... Leider funktionieren bei mir seit heute die Netzwerkfunktionen nicht mehr (Airplay, Internetradio, usw.) ![]() ![]() ![]() Hab auch gleich geschaut ob es ev. eine neue Firmware/Update gibt, aber alles was mir zum Download zu Verfügung stand war ein "changelog"... was ist das genau und hilft euch das weiter ? ![]() Hier wäre der Inhalt der *.txt Datei: Changelog of SR6006 27.05.2014 Main:00.97 When the customer plays the source of "DTS-HD Master Audio/96k PBR (PeakBitRate) stream", the noise occurs or the sound is not output. The noise occurs in the play of DD+ stream of Netflix. 05.11.2012 Main:00.97 IR command addition to AV receiver. When AV receiver connects with Toshiba DBR-Z150 via HDMI, and BD playing is stopped and plays it again, the level of the sound pressure increases 6dB. No access to last.fm service. Problems when controlling by WEB GUI_II 30.04.2012 RS-232 command for speaker A+B not working. AirPlay doesn't operate, when a particular router is used. When turn on the "Pure-direct" by the RDS broadcast of FM, the display is flickering. 30.01.2012 Main:00.94 Improvement of DPMS update. Changed the default Internet radio station of PRESET CHANNEL3 from "1.fm Classical Musick" to "98.1 Klassik Radio FM". 07.11.2011 Main:00.94 Incorrect network behavior reported by Control4 programmer. Coding in XML document with wrong Symbols. Improvement of the error processing in DPMS. Correction of AMX VIALL command. Countermeasure of GUI defect in 1080i video. Countermeasure of DM860 NAND Read Disturb. Improvement of download time in DPMS. Countermeasure of the Podcast play defect in Internet radio. Countermeasure of problem concerning possibility of not operating correctly, when area of CNE increases and decreases. Countermeasure of play defect of m4a file in WMP12. 08.09.2011 Main 00.91 NET/USB might be not operated when ON and OFF in the power supply are repeated over 50 times. (Internet Radio, Media Server, USB direct play(iPod), Rhapsody, Napster, LastFM, Pandora, etc) When iPod is replaced, the product has the possibility of not outputting the video of NET/USB. The screen becomes a display of the black. There's a possibility that the screen shakes when the input signal of "480i/576i/1080i_50/60Hz_Film Source" is converted into the progressive signal. The problem of MFi (Made For iPod/iPhone) test has been improved. Requesting related to MFi was not filled. |
Smoetler
09:22
erstellt: 24. Jan 2017, |
Weiß keiner rät oder tat ? 😔 |
/cooper/
09:31
Vielleicht hilft Netzwerkkonfiguration zurücksetzen. (Reset) |
Smoetler
01:00
erstellt: 26. Jan 2017, |
Sry hab's erst soeben gelesen ![]() Aber ja, um euch auch noch kurz bescheid zu geben. Nach dem reset hat wieder alles funktioniert ![]() |
Marantz SR-6006 Fragen sr71 am 26.02.2012 – Letzte Antwort am 28.02.2012 – 3 Beiträge |
Marantz SR 6006 EQ Rob_Nick am 17.03.2012 – Letzte Antwort am 20.03.2012 – 3 Beiträge |
Marantz SR 6006 Hifive78 am 19.12.2012 – Letzte Antwort am 19.12.2012 – 2 Beiträge |
Marantz SR5006 und SR 6006 happy001 am 20.05.2011 – Letzte Antwort am 21.06.2016 – 505 Beiträge |
Schallplattenspieler am Marantz SR 6006 ExAzubi am 16.06.2012 – Letzte Antwort am 17.06.2012 – 3 Beiträge |
fragliche Leistungsangabe Marantz sr 5006 / 6006 astrafreak65 am 09.07.2011 – Letzte Antwort am 09.07.2011 – 4 Beiträge |
Marantz SR-6006 und Technisat Aussetzer bollok am 27.12.2011 – Letzte Antwort am 23.03.2012 – 4 Beiträge |
Marantz SR 5003/6006 und HDMI Signalqualität fba am 21.02.2012 – Letzte Antwort am 13.03.2012 – 9 Beiträge |
Marantz SR 6006 - Anzeige Einstellungen beim Fernsehen Akhorahil am 13.03.2012 – Letzte Antwort am 20.03.2012 – 13 Beiträge |
Marantz SR 6006 Internetradio geht aus Rob_Nick am 12.04.2012 – Letzte Antwort am 21.04.2012 – 18 Beiträge |
2017
Top Produkte in Marantz
Top 10 Threads in Marantz der letzten 7 Tage
- Marantz 2022/2023 Cinema 10/20/30/40 usw.
- Marantz 7008 schaltet sich ab
- Referenzpegel-Offset
- Firmware Update NR1506
- Zu leiser Ton schon beim Einrichten
- TV und NR1200 mit HDMI-Kabel verbunden (ARC), kein Ton
- HDMI Pass Through Probleme
- Marantz SR 5008 schaltet sich ab und blinkt
- Marantz SR 7008 mit Dolby Atmos
- Fernbedienung SR6004 Marantz
Top 10 Threads in Marantz der letzten 50 Tage
- Registrierte Mitglieder928.910 ( Heute: 9 )
- Neuestes MitgliedTux-Hugo
- Gesamtzahl an Themen1.559.251
- Gesamtzahl an Beiträgen21.721.441
