| HIFI-FORUM » Stereo » Elektronik » Analogtechnik/Plattenspieler » Dual 1219 hums | |
Dual 1219 hums+A -A |
tamagaba
erstellt: 14. Mai 2024, 15:39
8erberg
erstellt: 15. Mai 2024, 05:07
tamagaba
erstellt: 15. Mai 2024, 19:29
Thank you |
raindancer
erstellt: 15. Mai 2024, 20:37
tama, your data does not say anything to me. Can you provide a narrow band analysis (fft) of the signal? |
einstein-2
erstellt: 16. Mai 2024, 05:46
Hallo Bitte wenn möglich Beiträge auf Deutsch. |
tamagaba
erstellt: 16. Mai 2024, 10:19
Sorry, I can't speak Deutsch I will be short in English I mistake because the problem is MM phono preamp not the turntable Between two track was -35-40 dB noise level after MM phono. I was thinking about this effect of the LP player humming Same recording in directly to Tascam DR100 (without preamp and RIAA) show -55-57 dB This means that DR100 input amp unit much better than my tube MM phono stage. I have to contact with MM phono producer and clarify the reasons. PSU noise or other malfunction maybe pic a: with tube MM phono pic b: directly Tascam DR100 mk3 I will make recording from my Clearaudio test LP with MM phono and without - I can show you more concrete results I hope so I wrote clearly ![]() ![]() |
8erberg
erstellt: 16. Mai 2024, 13:15
Hello, If the DIN cable is still there, check that there is no cable break, it´s > 50 years old.... If in doubt, replace the cable from the muting switch (choose a coaxial cable with low capacity) and new RCA-plugs. Peter |
doc_sisiphus
erstellt: 16. Mai 2024, 16:00
Hallo, in beide Richtungen Übersetztungsprogramme helfen hier ganz gut weiter.... |
Dual 1254 automatic belt drive kikala5 am 13.04.2020 – Letzte Antwort am 14.04.2020 – 3 Beiträge |
DUAL 1219 Frank-Ulrich_Fuchs am 05.11.2018 – Letzte Antwort am 06.11.2018 – 13 Beiträge |
Dual 1219 martin am 25.04.2003 – Letzte Antwort am 14.05.2003 – 12 Beiträge |
dual 1219 sabafan66 am 14.08.2013 – Letzte Antwort am 19.08.2013 – 14 Beiträge |
Dual 1219 Tatanka_Yotanka am 17.10.2014 – Letzte Antwort am 20.10.2014 – 7 Beiträge |
Dual 1219 schmolke am 21.11.2021 – Letzte Antwort am 23.11.2021 – 6 Beiträge |
"Reparatur" eines Dual 1219 Basil9000 am 23.02.2004 – Letzte Antwort am 24.02.2004 – 6 Beiträge |
DUAL 1219 Wartung hasemaus am 07.09.2004 – Letzte Antwort am 07.09.2004 – 6 Beiträge |
DUAL 1219 Zu leise ?? bobosiebenschläfer1 am 19.01.2005 – Letzte Antwort am 19.01.2005 – 7 Beiträge |
DUAL 1219: welcher Tonabnehmer Henning81 am 15.02.2005 – Letzte Antwort am 28.02.2005 – 5 Beiträge |
2024
- Plattengewicht Ja oder Nein
- elliptisch, sphärisch, hä?
- Hilfe: Plattenteller eiert
- Registrierte Mitglieder930.501 ( Heute: 8 )
- Neuestes MitgliedMauber
- Gesamtzahl an Themen1.563.011
- Gesamtzahl an Beiträgen21.814.557
