HIFI-FORUM » Reparatur & Wartung » Kopfhörer & Kopfhörer-Verstärker » best components to use | |
best components to use+A -A |
markyboy156
06:46
erstellt: 01. Apr 2021, |
hii want to buy the k5 pro amp ill be using a panasonic ub 820 4k player a playstation 5 xbox x latest version and two jbl 305 mk2 monitor speakers to conect as well plus what is the best cables to use with this setup i want to use a sub or even two subs i want to use 2 headphones if possible one gaming headset i want a 7.1 gaming headset desighned with the latest specs for heavy gun totting bass heavy games and films and for music as well i also want a audiophile headphones for top sound quality for music main use pop rock heavy metal r&b hip hop rave techno house classical orchestra in that order i want extremley good effect with drums electronic guitar guitar piano trumpet cymbals chello clarinet zillaphone and i want to use a turntable i have a audio technica 60 usb turntable a rega planar 1 and rega planar 3 turntable which would be best to use with this setup or can you recommend a nother turntable instead and also i want 2 subs that go extremly low in hz for blockbuster action movies i want bone shattering impact top notch sound effects i want music to sound incredible with very good bass effect what do you recommend and also can you recommend another amp to compliment that can be combined with k5 pro amp as well or can you recommend another amp/dac combi headphone system that would work better than the comination above please let me no thanks marcus need to no asap i want to buy the k5 pro amp ill be using a panasonic ub 820 4k player a playstation 5 xbox x latest version and two jbl 305 mk2 monitor speakers to conect as well plus what is the best cables to use with this setup i want to use a sub or even two subs i want to use 2 headphones if possible one gaming headset i want a 7.1 gaming headset desighned with the latest specs for heavy gun totting bass heavy games and films and for music as well i also want a audiophile headphones for top sound quality for music main use pop rock heavy metal r&b hip hop rave techno house classical orchestra in that order i want extremley good effect with drums electronic guitar guitar piano trumpet cymbals chello clarinet zillaphone and i want to use a turntable i have a audio technica 60 usb turntable a rega planar 1 and rega planar 3 turntable which would be best to use with this setup or can you recommend a nother turntable instead and also i want 2 subs that go extremly low in hz for blockbuster action movies i want bone shattering impact top notch sound effects i want music to sound incredible with very good bass effect what do you recommend and also can you recommend another amp to compliment that can be combined with k5 pro amp as well or can you recommend another amp/dac combi headphone system that would work better than the comination above please let me no thanks marcus need to no asap |
Rabia_sorda
21:25
Hello, Which language is your native language? The translation is difficult for me to understand. The attempt to write your text in your native language here could possibly lead to a success. |
2021
Top Produkte in Kopfhörer & Kopfhörer-Verstärker
Top 10 Threads in Kopfhörer & Kopfhörer-Verstärker der letzten 7 Tage
- Kopfhörer klingt plötzlich dumpf
- Kopfhörerbuchse defekt? Noch zu retten?
- Sennheiser HD 560 Ovation Kabel
- Rechts plötzlich kein Ton mehr - Beyerdynamic DT-990 Pro 250 Ohm
- Sennheiser Kopfhörer Kabelbruch reparieren, Kabel Farbkodierung
- Teufel Cage Kopfhörer / Headset wird nicht von Windows 10 erkannt
- P7 Wireless von Bowers & Wilkins kein Lebenszeichen
- Sony WH1000 XM2 - Reparatur sinvoll?
- Reparatur Kabel Bose QuietComfort Q20 In-Ear
- BEATS X schalten sich nicht ein
Top 10 Threads in Kopfhörer & Kopfhörer-Verstärker der letzten 50 Tage
- Registrierte Mitglieder928.983 ( Heute: 1 )
- Neuestes MitgliedAnna234
- Gesamtzahl an Themen1.559.416
- Gesamtzahl an Beiträgen21.726.136
