HIFI-FORUM » Reparatur & Wartung » Elektronik (Stereo&Surround) » Problem mit Pioneer VSX-D2011 | |
Problem mit Pioneer VSX-D2011+A -A |
Keksdreher
12:06
erstellt: 13. Jun 2010, |
Hallo zusammen, habe folgendes großes Problem mit meinem Pioneer-Receiver, er lässt sich nicht mehr einschalten und die Standbylampe blinkt nur noch, habe versucht einen Reset laut Handbuch zu machen, aber darauf reagiert das Gerät auch nicht mehr .... Was kann ich tun ? Bin für jede Hilfe dankbar.
tri-comp
20:27
I'm afraid you're not going to like this answer ...apart from it being in English ![]() This receiver is a very complicated and computer-controlled circuit. A LOT of things may cause the power-down you are experiencing. Most likely, of course it is a defective output amplifier ...but there are 7 of them! A power-supply fault is also a possibility along with faults in the protection circuit itself. What you need to do is to take the receiver to someone with a lot of experience in repairing highly complicated electronics. Once you find him, and he wants a service-manual to complete the work, feel free to PM me for info on how to get one. mfg, /tri-comp |
Keksdreher
18:50
erstellt: 14. Jun 2010, |
But is there some other possibility to Reset the Receiver ?? take out some fuse or smthg else ?! |
tri-comp
21:47
There is NOT another reset, but there is an explanation; at least I THINK the explanation of this 'Dead-State' is in the service-manual. I read through it for more information and it seems that when DC on some amp-output is detected once, the amplifier locks-up and refuses more key-inputs and continously blinks the Stand-By LED. The speaker-relay disconnects the speakers for safety to avoid speaker-failure as well. What you can do is to press simultaneously STEREO/DIRECT and TONE for more than 2 seconds a Diagnostic mode is entered. It will show sequentially in the display: PROTECT CHECK DC PROTECT CHECK OVERLOAD PROTECT CHECK FANSTOP PROTECT CHECK TEMP Each item should show 0 (Zero) but my guess is, that the first line will show a value. It indicates a defective amplifier with DC on the output. NOW, go back and read my recommendation in the first answer. mfg, /tri-comp |
Keksdreher
16:30
erstellt: 15. Jun 2010, |
Ok thanks for your answer, so my Dad is electrician Engineer and also myself is graduated in electrician, so maybe we can try to fix it by ourself, because the Receiver is out of guarantee, and some repair will cost up to 200€ and thats a lot of money for such an old Receiver. But where i can get some electrical drawings or smthg like that ?! |
Keksdreher
16:33
Ok i tried to push Stereo/Direct and Tone, but nothing happens ... |
tri-comp
22:05
Actually I possibly made an error. I read the service-manual again and I believe what Pioneer is trying to say is to push the TONE+ key along with the STEREO/DIRECT key for more than 2 seconds when the set is in stand-by mode. Try this at least. As I don't have the receiver on hand it's difficult to know if there is more than one TONEkey ![]() PM me with your e-mail address for info on how to get the servie-manual. mfg, /tri-comp |
Keksdreher
13:50
erstellt: 21. Jun 2010, |
Hey okay, so i was a few days not at home, and now i can turn on the receiver ?! but still no sound ... hmmm So i tried to enter the diagnostic-mode tone+ and stereo/direct. Display shows : Prot CHK DCDET 000 OVERLOAD 000 FANSTOP 000 TEMP 000 You can say anything about these messages ? hopefully ... |
audiophilanthrop
15:08
Eigenartig, angeblich alles in Butter - aber paßt dazu, daß er jetzt einschaltet. Könnte sein, daß ihm irgendwelche Betriebsspannungen abgehen. Alle Sicherungen sind OK? Unter welchen Umständen ist der Fehler eigentlich aufgetreten? Ich würde sagen, Mennjuell besorgen und fleißig mit dem Multimeter rumstochern, irgendwas wird schon faul sein... |
Keksdreher
15:31
Der Receiver schaltet ein und man hört deutlich das das Ausgangsrelais schaltet, dann läuft ungefähr alles 5-10 min problemlos. Dann verstummt alles, als wenn jemand mute drücken würde, aber man hört nicht das das Relais schaltet. Schalte ich den Receiver nun aus und warte eine zeitlang wiederholt sich das ganze ... Ich gehe soweit eigentlich von einem wärmeproblem aus ... Habe das Gerät schon aufgeschraubt und versucht mit Kältespray eine Fehlerquelle zu lokalisieren, leider bisher ergebnislos. Eine Werkstatt meinte sicher zu sein, das der Fehler iwo in der Digitalplatine sein muss, aber auch dort mit Kältespray kein Ergebnis ... Ca. Reparaturkosten 200€ aufwärts, und die sind mir das Gerät nicht wert, auch wenn ich damit sehr zufrieden bin/war ... Deswegen versuche ich zu retten was zu retten ist, denn irgendwie funktioniert er ja wohl Das Gerät verfügt bauseits über 2 interne Lüfter von denen zu keiner Zeit auch nur einer läuft was ich auch schon sehr merkwürdig finde ... Korrektur, nach 15 min warten, funktioniert er ca. 3 sekunden einwandfrei und "mutet" dann ... So ca. Stunde später läuft er ca. 4 min und "mutet" dann. [Beitrag von Keksdreher am 21. Jun 2010, 17:03 bearbeitet] |
audiophilanthrop
00:52
erstellt: 22. Jun 2010, |
Zur Eingrenzung: Hat er eine "Pure Direct"-Funktion, die den ganzen Digitalkrempel umgeht? Dann aktiviere die mal. Ansonsten suche mal nach allen Spannungsreglern (78xx/79xx) und was sich sonst so an kühlkörperbestückten Transistoren usw. findet, gerade im Netzteilbereich. Da gibt es gern schlechte Lötstellen, evtl. auch geschwächte Halbleiter. |
Keksdreher
16:18
erstellt: 23. Jun 2010, |
Also was du meinst wird wohl die Stereo/Direct funktion sein, aber auch in diesem Modus dasselbe Problem hatte ich auch schonmal versucht, deswegen finde ich es merkwürdig das die Werkstatt meint das es auf der Digitalprozessor Platine zum dem Problem kommt, wobei ich nicht weiss ob das Signal trotz dieser Funktion durch diese "gejagt" wird ... Nach den Transistoren etc. auch im Netzteilbereich werde ich morgen mal schauen ... heute ist erstmal Schland ![]() |
misfits
23:34
erstellt: 18. Sep 2010, |
Hast du mittlerweile die Lösung gefunden?Oder doch verkauft? Hab den kleinen Bruder hier und dasselbe Problem.Stand by blinkt nur noch.Mittels tasten kombi steht dan amp error und geht wieder aus.Vorher lies er sich normal einschalten nur halt kein ton dabei. Hab dann die "selbstdiagnose" durchführen lassen wobei bei DC der 255 erschien.also wenn der Wert 0 sein sollte ein wenig hoch^^. Danke für die Antwort. |
Keksdreher
14:18
erstellt: 19. Sep 2010, |
Hallo, nein mein Receiver lässt dich zwar wieder einschalten aber die Sache mit dem Ton funktioniert noch immer nicht. Also meiner zeigt bei der Selbstdiagnose alle Werte als OK an, aber dennoch schaltet er nach einigen minuten den Ton ab und dieser kommt auch nicht wieder, es sei denn man schaltet ihn wieder aus. Das mit der blinkenden Standbylampe, ja ich hatte ihn einfach ein paar Tage vom Netz getrennt danach liess er sich wieder einschalten, habe ich auch keine erklärung für. |
misfits
17:04
Hmm.Klingt irgendwie nach puffer batterie.Wenn die nach längerer Standzeit sich entladen scheint der Fehlerspeicher auch keine spannung mehr zu bekommen und ist wieder "leer".Bis halt das alte problem da.Hab das Service manual falls du es brauchst ;-) muss meinen wohl oder übel mal auseinader bauen. ![]() |
Keksdreher
17:24
Danke, habe das ServiceManual auch zur Hand, aber ich weiss beim besten willen nicht mehr wo ich ansetzen soll ... ![]() War wohl echt begeistert von dem Receiver, aber langsam bin ich mit meinem Latein am ende, werde ihn kurz oder lang wohl dem Schrott überlassen :´( |
Pioneer VSX-D2011 IR Sensor (Fernbedienung) kaputt? HiFi?JoHannes! am 03.02.2019 – Letzte Antwort am 11.02.2019 – 10 Beiträge |
Speicherkondensatortausch bei Pioneer VSX-D1011 / 2011 mopett1100 am 14.09.2012 – Letzte Antwort am 11.04.2023 – 15 Beiträge |
pioneer vsx d1011 mika15 am 16.02.2015 – Letzte Antwort am 18.02.2015 – 4 Beiträge |
Flachkabel Pioneer VSX-1016v stigma1 am 23.06.2009 – Letzte Antwort am 24.06.2009 – 2 Beiträge |
Pioneer VSX-d1011 misfits am 27.09.2010 – Letzte Antwort am 12.10.2010 – 5 Beiträge |
Pioneer VSX-329 Defekt? ;( BlackGale44 am 31.03.2015 – Letzte Antwort am 04.04.2015 – 2 Beiträge |
Pioneer VSX-D811S Defekt xtd_304 am 23.03.2013 – Letzte Antwort am 25.03.2013 – 4 Beiträge |
Pioneer VSX-916 defekt? dec.fx am 03.10.2012 – Letzte Antwort am 04.08.2018 – 18 Beiträge |
Pioneer VSX-824-K Def22Fire am 22.05.2016 – Letzte Antwort am 24.05.2016 – 3 Beiträge |
Fernbedienung Pioneer VSX-409 hanswolf am 28.05.2020 – Letzte Antwort am 31.05.2020 – 3 Beiträge |
- PV Anlage stört auf UKW
- Verstärker rauscht
- Registrierte Mitglieder928.975 ( Heute: 1 )
- Neuestes Mitgliedqrcob
- Gesamtzahl an Themen1.559.399
- Gesamtzahl an Beiträgen21.725.767
