| HIFI-FORUM » Suche / Biete / Verschenke » Biete » Selbstbau / DIY » AuraSound NS18-992-4A VERKAUFT | |
AuraSound NS18-992-4A VERKAUFT+A -A |
-Rayz-
erstellt: 11. Jan 2016, 12:24
Verkaufe zwei AuraSound NS18-992-4A Preis (Pflichtangabe!): 750€ pro Chassi Standort: 97638 Mellrichstadt Zustand: Gebraucht Artikelbeschreibung: Nominal Diameter _ _ _ _ _ _ _ _ _ _ _ _ _ _18 inches (477 mm) Nominal Impedance (Z) _ _ _ _ _ _ _ _ _ _ _4 Ohms Sensitivity, 1W/1m (E) _ _ _ _ _ _ _ _ _ _ _ 86 dB @ 100 Hz Power Capacity, RMS (Pe) _ _ _ _ _ _ _ _ _800 W Power Capacity, Peak _ _ _ _ _ _ _ _ _ _ _ 3200 W Frequency Range (-10dB) _ _ _ _ _ _ _ _ _ _Fo - 1_5 kHz Minimum Impedance _ _ _ _ _ _ _ _ _ _ _ _ 5 ohms Voice Coil Former Material _ _ _ _ _ _ _ _ _ Glass composite Voice Coil Wire Composition _ _ _ _ _ _ _ _ Aluminum Ribbon Voice Coil Diameter _ _ _ _ _ _ _ _ _ _ _ _ _99.2 mm Voice Coil Winding Length (h) _ _ _ _ _ _ _ _25.4 mm Voice Coil Number of Layers (n) _ _ _ _ _ _ _1 Magnetic Material _ _ _ _ _ _ _ _ _ _ _ _ _ _ Neodymium radial Stray Flux Shielding _ _ _ _ _ _ _ _ _ _ _ _ _ Inherent Magnetic Gap Depth (He) _ _ _ _ _ _ _ _ _ _ 50.8 mm Cone Material _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ Aluminum Surround Material _ _ _ _ _ _ _ _ _ _ _ _ _ _ Injecton molded rubber Polarity, Outward Motion _ _ _ _ _ _ _ _ _ _ Positive voltage on (+) terminal Weight _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ 51.0000 lbs. Thiele / Small Parameters Resonant Frequency (Fo) - Fs _ _ _ _ _ _ 20 Hertz Voice Coil DC Resistance - Re _ _ _ _ _ _3.1 ohms Total Q - Qts _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ 0.47 Mechanical Q - Qms _ _ _ _ _ _ _ _ _ _ _ 7.7 Electrical Q - Qes _ _ _ _ _ _ _ _ _ _ _ _ _0.50 Equivalent Volume of Air - Vas _ _ _ _ _ _322 L Radiating Piston Area - Sd _ _ _ _ _ _ _ _ 1164 cm 2 Electrical / Mechanical Parameters Flux Density x Length - BL _ _ _ _ _ _ _ _ _ _17 Tesla-meters Compliance - Cms _ _ _ _ _ _ _ _ _ _ _ _ _ _ 170 µm/N Total Mass - Mms _ _ _ _ _ _ _ _ _ _ _ _ _ _ 400 grams Frequency Response (1W, 1m) Maximum Excursion _ _ _ _ _ _ _ _ _ _ _ _ _ 75 mm peak to peak Xmax _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _50 mm peak to peak Mounting Information Overall Outside Diameter 18.75 Baffle Cutout Diameter 16.8 Depth 12.25 Bolt Circle Diameter17.5 # Mounting Holes8 ![]() ![]() Mit OVP. [Beitrag von -Rayz- am 11. Jan 2016, 12:24 bearbeitet] |
Aurasound NS12-513-4A FoLLgoTT am 13.07.2013 – Letzte Antwort am 24.07.2013 – 3 Beiträge |
Biete 2x Aurasound NS12-513 4a im Gehäuse an fine am 13.03.2019 – Letzte Antwort am 25.11.2021 – 2 Beiträge |
1 Paar Aurasound NS12-513-4A tiefton am 24.11.2009 – Letzte Antwort am 02.12.2009 – 2 Beiträge |
schon VERKAUFT! Eminence Beta 12CX 1 Paar Rotel_RA-980BX am 28.11.2012 – Letzte Antwort am 03.02.2013 – 2 Beiträge |
GBS 2612 12" Bass darb am 09.01.2009 – Letzte Antwort am 20.04.2009 – 15 Beiträge |
[V] Tang Band W3-1876s Minisubwoofer der Extraklasse Malice-Utopia am 18.06.2013 – Letzte Antwort am 03.07.2013 – 4 Beiträge |
Aurasound Cube 10 (2 Stück) & Hypex PSC 2.400 !!!VERKAUFT!!! R@uTe am 25.09.2013 – Letzte Antwort am 23.11.2013 – 9 Beiträge |
2 Vifa M22 W-09 bassgott am 14.09.2010 – Letzte Antwort am 31.01.2011 – 6 Beiträge |
Paar massive IMG Stage Line Oldtimer SP-10A/300PA - Preissenkung Ars_Vivendi am 20.04.2014 – Letzte Antwort am 03.05.2014 – 3 Beiträge |
Chassis zu verkaufen (Wavecor, Vifa, ZaphAudio, TangBand, Aurasound) hifi-alex am 25.11.2010 – Letzte Antwort am 20.01.2011 – 3 Beiträge |
2016
Top 10 Threads in Selbstbau / DIY der letzten 7 Tage
- Phonovorverstärker Volpe II mit Netzteil
- Lautsprecher Chassis für DONAR aus K+T mit Swans/HiVi, Audax, B+C
- 2x Tiefmitteltöner Vifa T-8110-581-1 4Ohm
- 2x A&D Audio R 1524
- 2x The Box 12-280/8-A *** verkauft ***
- JBL 2344A und 2426H
- Tang Band W5 1611 Sarah
- Ein Pärchen "AURUM" aus der K+T
- Goya Mini,Visaton FRS 8
- Hochtöner Monacor Monarch MHD 250/SL
Top 10 Threads in Selbstbau / DIY der letzten 50 Tage
- Registrierte Mitglieder930.682 ( Heute: 7 )
- Neuestes MitgliedRemklep
- Gesamtzahl an Themen1.563.504
- Gesamtzahl an Beiträgen21.827.352
