ITV HD Sender: H.222 ?
almero
#1 erstellt: 08. Mai 2008, 00:56
Hallo, (English follows)
seit 6. May ITV (UK) hat eine "Free-To-Air" test Sendung in HD:
Satellite: 28.5 E (Eurobird 1)
Frequency: 11428 MHz
Polarisation: Horizontal
Symbol Rate: 27500
Service ID: 10510
ABER die meisten receiver "sehen" es nicht, weil etwas falsch ist mit die Kodierung. KingOfSat listet es wie eine "H.222" stream. Es heist, diese Sendung ist nur geeignet für die neue "Freesat" receivern, obwhol sie "FTA" ist und kein CI karte braucht.
Weisst schon jemand ob es in Prinzip möglich ist, diese Sendung mit ein Loewe HD Sat receiver zu empfangen? Vielleicht nach einem Firmware Update?
and now in English:
Since May the 6th ITV has started a Free-To-Air broadcast in HD (parameters see above)
BUT, most existing HD receivers are unable to recognise the channel, because something is wrong in the stream information. At best, it is recognised as a radio channel.
KingOfSat lists the channel as being "H.222", whatever that may mean.
In British forums, I have found that the channel is part of the "Freesat" initiative, that aims at giving the British people free digital (SD and HD) satellite TV. They only need to buy the hardware and don't need a subscription or a CI card. So, officially, it's FTA, but they did something to the stream so it can't be picked up by standard receivers.
I have also found that the compression is actually H264, and if you can record the stream, it can be played without problems on a PC, for example with mediaplayer classic.
So it seems it should be relatively simple to make existing receivers suitable to recognise and show the channel.
The question is: can a Loewe TV with built-in HD Sat receiver be firmware-updated so it recognises the channel?
Does anyone have any information or thoughts about this?
alfie
#2 erstellt: 08. Mai 2008, 10:08
Hallo almero,
Ich habe es gerade ausprobiert, und habe keinen Empfang des Senders. Mein C52 findet auf diesem Transponder nur einen Sender namens "Brit Shorts". Eigentlich sollte dieses ominöse "h.222" aber auch "h.264" sein, so wie ich das gelesen habe.
Ich teste weiter, und falls ich etwas rauskriege, poste ich es hier.
h.264
#3 erstellt: 08. Mai 2008, 10:25
Der Standard H.222.0 beschreibt u.a. das MPEG-2 Transport-Stream-Format, also die Art und Weise, wie mehrere Audio-, Video- und Zusatzdatenströme (z.B. Videotext) in einen gemeinsamen Datenstrom "gemultiplext" werden. Dieses Format wird generell bei allen digitalen Fernsehausstrahlungen (DVB-T/-C/-S) verwendet, unabhängig davon, ob MPEG-2 oder H.264 als Video-Codec benutzt wird.
Wer es genauer nachlesen möchte, findet den H.222.0-Standardtext hier:
ITU-T Recommendation H.222.0
alfie
#4 erstellt: 08. Mai 2008, 10:27
Hi almero,
Tja, so wie es aussieht, wird´s wohl nix. Der Sender sendet mit falschen/ungültigen PID´s, mit denen wohl nur spezielle Receiver etwas anfangen können (Freesat).
Ich kenne keine Möglichkeit, die PID´s am Fernseher manuel einzugeben. Meine aber, daß es mit einem PC und passender Software (DVB-Viewer) klappen könnte.
Valan
#5 erstellt: 08. Mai 2008, 11:05
Moin,
Freesat wird noch nicht unterstützt, ist aber geplant. In wie weit die bestehenden Chassis durch Software-Update dafür fit gemacht werden können oder obs nur auf der nächsten Generation läuft steht noch nicht fest.
almero
#6 erstellt: 17. Mai 2008, 12:28
alfie123 schrieb:
Hi almero,
My IC40 offers the possibility to save the channel list to a USB stick. I then get 2 files:
proglist.plf and favlist.fav
proglist.pdf can be opened in an ascii editor (or in Excel; the file is TAB-delimited) and the PID's etc. can be modified.
Only problem is that the Loewe TV refuses to load a modified file, probably because the checksum in the beginning of the file becomes invalid.
Does anyone know if there exists an editor that allows to edit the proglist.plf file and generates a valid checksum so the file can be loaded by the TV?
ITV HD
w_pooh am 06.06.2008  –  Letzte Antwort am 06.06.2008  –  4 Beiträge
Loewe Spheros und HD- Sender
binuu am 07.03.2010  –  Letzte Antwort am 08.03.2010  –  5 Beiträge
Astra HD und andere Sender plötzlich weg
afferabe am 10.04.2009  –  Letzte Antwort am 11.04.2009  –  6 Beiträge
ANIXE HD ?
MathiasMausM am 21.03.2008  –  Letzte Antwort am 26.03.2008  –  16 Beiträge
RTL HD
abcfgh am 02.11.2009  –  Letzte Antwort am 03.12.2009  –  17 Beiträge
Premiere HD kommt nicht
sportkegler am 05.02.2009  –  Letzte Antwort am 12.02.2009  –  8 Beiträge
Xelos A37 HD+ 100 DR+ oder Spheros R37 Full HD
WuerthM am 08.10.2007  –  Letzte Antwort am 11.10.2007  –  10 Beiträge
Probleme mit HD
Fehsenfeld am 11.06.2012  –  Letzte Antwort am 14.06.2012  –  4 Beiträge
Spheros 32 HD Fragen
besgin am 06.05.2008  –  Letzte Antwort am 07.05.2008  –  3 Beiträge
Premiere HD über CI-Modul
kolli65 am 22.02.2008  –  Letzte Antwort am 22.02.2008  –  6 Beiträge
  • Registrierte Mitglieder930.997 ( Heute: 6 )
  • Neuestes Mitgliednisio
  • Gesamtzahl an Themen1.564.404
  • Gesamtzahl an Beiträgen21.852.942
