Yamaha AV RX-V730 RDS + DVD S520 Schwarz
spartain
#1 erstellt: 30. Jun 2010, 09:07
Preis (Pflichtangabe!): € 200,-
Standort: Hamburg
Zustand: Gebraucht, aber sehr gepflegt! Nichtraucher und Mackenfrei
Artikelbeschreibung: Yamaha AV RX-V730 RDS und DVD-Player S520 in Schwarz!
MAIN, 20Hz-20kHz, 0.06% THD, 8Ω 75W + 75W
CENTER, 20 Hz-20kHz, 0.06% THD, 8Ω 75W + 75W
REAR, 20Hz-20kHz, 0.06% THD, 8Ω 75W + 75W
Minimum RMS Output Power per Channel
MAIN, 1kHz, 0.06% THD, 8Ω 80W + 80W
CENTER, 1kHz, 0.06% THD, 8Ω 80W + 80W
REAR, 1kHz, 0.06% THD, 8Ω 80W + 80W
Dynamic Power per Channel
MAIN, 8/6/4/2 Ω 90/120/150/190W
Dynamic Headroom
8 Ω 1.2dB
Damping Factor
MAIN L/R, 20Hz-20kHz, 8 Ω 80 or more
Input Sensitivity/Impedance
PHONO MM 2.5mV/47kΩ
CD, etc 150mV/47kΩ
Maximum Input Signal Level
PHONO MM, 1kHz, 0.05% THD, (Effect on) 100mV
CD, etc (Effect on) 2.2V
Output Level/Impedance
OUT (REC) 150mV/1.2kΩ
PRE OUT (MAIN, etc) 2.2V/1.2kΩ
SUBWOOFER (EFFECT OFF< MAIN SP:SMALL)
MONO 4.0V/1.2kΩ
Headphone Jack Raged Output/Impedance
CD, etc, (40mV, 8Ω 340mV/560Ω
Frequency Response (10Hz-100kHz)
CD, etc, MAIN L/R +0/-3.0dB
RIAA Equalization Deviation (20Hz-20kHz)
PHONO MM 0 +/- 0.5dB
Tone Control Characteristics
BASS:
Boost/Cut +/-10dB (50Hz)
Turnover Frequency 350Hz
TREBLE:
Boost/Cut +/-10dB (20kHz)
Turnover Frequency 3.5 kHz
Filter Characteristics
SUBWOOFER OUT: LPF fc=90Hz, 18dB/oct
MAIN, CENTER, REAR SP SMALL: HPF fc=90Hz, 12dB/oct
Total Harmonic Distortion (20Hz-20kHz)
CD, etc, to MAIN SP OUT L/R (1V) 0.06%
Signal-to-Noise Ratio (IHF-A-Network
CD, etc, Input Shorted (Effect off) 100dB
PHONO MM to OUT (REC) 86
Residual Noise (IHF-A-Network)
MAIN, SP OUT 150uV
Channel Separation (Vol. -30dB, Effect off)
CD, etc, Input 5.1kΩ Shorted, 1kHz 60dB
VIDEO SECTION
Video Signal Type NTSC
Composite Video Signal Level 1Vp-p/75Ω
S Video Signal Level
Y 1Vp-p/75Ω
C 0.286Vp-p/75Ω
Component Signal Level
Y 1Vp-p/75Ω
Cb/Cr 0.7V/75Ω
Video Maximum Input Level 1.5Vp-p
Video Signal-to-Noise Ratio 50dB
Monitor Output Frequency Response
Composite Video Signal 5Hz-10MHx, -3dB
S-Video Signal 5Hz-10MHz, -3dB
Component Signal DC-30MHz, -3dB
TUNER SECTION (FM)
Tuning Range 87.5 to 107.9MHz
50dB Quieting Sensitivity (IHF, 75Ω)
Mono (1kHz, 100% Mod) 2.0vU (17.3dBf)
Stereo (1kHz, 100% Mod) 25uV (39.2dBf)
Selectivity (400kHz) 70dB
Mono/Stereo (IHF) 76/70dB
Harmonic Distortion
Mono/Stereo (1kHz) 0.2./0.3%
Stereo Separation
1kHz 45dB
Frequency Response
20Hz-15kHz +0.5/-2.0dB
Output Level
FM 100% Mod. 1kHz 550mV
Antenna Input 75Ω unbalanced
TUNER SECTION (AM)
Tuning Range 530 to 1,710kHz
Usable Sensitivity 300uV/m
Output Level
AM 30% Mod. 1kHz 150mV
Signal-to-Noise Ratio 52dB
Antenna Loop Antenna
Dimensions (W x H x D) 17 1/8" x 6 7/16" x 15"
Weight 25 lbs
DVD-Player S520
(Yamaha- Seite):
DVD (48kHz Sampling) 2Hz-22kHz
DVD (96kHz Sampling) 2Hz-44kHz
CD, Video CD 2Hz-20kHz
Harmonic Distortion + Noise (1kHz) 0.0035%
Signal-to-Noise (1kHz) 100dB (Weighted)
Dynamic Range (1kHz) 97dB
Output Voltage (1kHz, 0db) 2.0V
D/A Converter 24 bit
VIDEO SECTION
Video Output 1V p-p (75Ω)
S-Video Output
Y Output 1Vp-p (75Ω)
C Output 0.286Vp-p (75Ω)
Component Video Output
Pb/Pr Output 0.7Vp-p (75Ω)
D/A Converter 10 bit
GENERAL
Dimensions (W x H x D) 17 1/8" x 3 5/8" x 12 3/8"
Weight 7.3 lbs
Beide Geräte funktionieren Einwandfrei!
[Beitrag von spartain am 30. Jun 2010, 09:09 bearbeitet]
Yamaha RX-V440 RDS !
frankie2004 am 17.05.2008  –  Letzte Antwort am 21.05.2008  –  6 Beiträge
Yamaha RX-V440 RDS (Schwarz)
Evil_Samurai am 17.08.2010  –  Letzte Antwort am 21.02.2011  –  6 Beiträge
Yamaha RX-V440 RDS
Matz71 am 28.11.2007  –  Letzte Antwort am 29.11.2007  –  3 Beiträge
Yamaha RX-485 RDS
olli1969 am 11.06.2007  –  Letzte Antwort am 27.06.2007  –  8 Beiträge
Yamaha RX-440 RDS
I.M.T. am 13.07.2008  –  Letzte Antwort am 25.07.2008  –  10 Beiträge
Yamaha RX-V 440 RDS
eLw00d am 26.11.2007  –  Letzte Antwort am 25.12.2007  –  4 Beiträge
Biete Yamaha RX-V540 RDS (Schwarz)
Heydt-Box am 19.01.2011  –  Letzte Antwort am 25.01.2011  –  2 Beiträge
Yamaha RX-V640 RDS Titan
boyke am 29.05.2008  –  Letzte Antwort am 08.06.2008  –  12 Beiträge
Yamaha RX-V440 RDS
Avenger_ am 28.01.2007  –  Letzte Antwort am 15.02.2007  –  10 Beiträge
Yamaha RX 496 RDS
light-Green_Apple am 09.04.2012  –  Letzte Antwort am 21.04.2012  –  2 Beiträge
  • Registrierte Mitglieder930.651 ( Heute: 2 )
  • Neuestes MitgliedX048969
  • Gesamtzahl an Themen1.563.423
  • Gesamtzahl an Beiträgen21.824.960
