| HIFI-FORUM » Suche / Biete / Verschenke » Biete » Verstärker / Receiver » alter Reciever von Pioneer SX-434 | |
alter Reciever von Pioneer SX-434+A -A |
Stephan200TD
erstellt: 12. Mai 2008, 15:52
Preis: VHB 45 Euro + Versand Zustand: gebraucht...ein paar kleine Kratzer und eine Macke (auf dem 3. Foto)...und etwas staubig, stand ewig im TROCKENEN Keller. Das Gerät funktioniert, lediglich bei einer Lautstärkeänderung kratzt es manchmmal etwas. ![]() ![]() ![]() ![]() Grüße, Stephan [Beitrag von Stephan200TD am 12. Mai 2008, 16:08 bearbeitet] |
Stephan200TD
erstellt: 12. Mai 2008, 15:58
Hier noch ein paar Infos: http://www.classicaudio.com/value/pio/SX434.html http://www.fertinger...ew&id=149&Itemid=176 http://www.hifi-wiki.de/index.php/Pioneer_SX-434uelle: Pioneer Prospekt SX-434 15Wx 2 RMS stereo receiver with high-performance tuner and direct-coupled OCL power amplifier. There is a wide range of Pioneer stereo receivers to satisfy the needs and demands of virtually every audio fan. One of the latest, the SX-434, is specifically designed for those who insist an low distortion but who feel that paying for power they don't need is wasteful. The SX-434 has more than enough power, yet is priced to appeal to budget-consicious music lovers. Its FM section provides an excellent 1.9uV sensitivity (IHF), a capture ratio of 1.0dB (IHF), selectivity of 60dB (IHF), and superb stereo separation of more than 30dB over a 50 to 10,000Hz range. Advanced electronic circuitry throughout includes a low-noise FET and a frequencylinear 3-gang variable capacitor in the FM front end, exclusive IC and phase-linear ceramic filters in the FM IF section and more. The phono equalizer in the SX-434 is high-fidelity all the way, with RIAA equalization of less than ±1 dB deviation. The power amplifier circuitry is the purecomplementary direct-coupled OCL type with wide response and power bandwidth. The SX-434 produces 15W+1 5W continuous RMS power (both channels driven at 8 ohms) with harmonic distortion of less than 0.8% over 40 to 20,000Hz bandwidth. This is enough to drive two pairs of stereo speaker systems individually or simultaneously. Listen and compare. This new Pioneer receiver may just be the value you've been looking for. HIGH-PERFORMANCE FM FRONT END The Pioneer SX-434 features top-class FM capabilities. The low-noise FET and frequency-linear 3-gang variable capacitor in the FM front end contribute to the excellent sensitivity of 1.9uV (IHF), improved Image and spurious rejection characteristics and a high signal-to-noise ratio in performance. FM IF SECTION WITH IC AND CERAMIC FILTERS State-of-the-art techniques are also employed in the FM IF amplifier of the SX-434. Phase-linear ceramic filters and an advanced IC afford a high selectivity of 60dB (IHF) and a capture ratio of 1.0dB (IHF), figures you'd expect from a tuner or receiver in a higher price category. FM MUTING SWITCH Annoying inter-station noise can be cancelled during tuning by the handy FM Muting switch. EXCLUSIVE IC-EQUIPPED AM SECTION Maximum fidelity and noise-free listening can be enjoyed in the AM band with the IC-equipped AM section of exclusive Pioneer design. RMS CONTINUOUS POWER 15Wx2 The pure-complementary direct-coupled OCL design of the power amplifier section in the SX-434 assures wide frequency response, wide power band width and satistactorily low distortion. Continuous RMS power over the 40 to 20,000Hz frequency bandwidth (measured with both channels driven into 8-ohm loads) is a stable 15W+15W with less than 0.8% harmonic distortion. TWO-PAIR STEREO SPEAKER FACILITIES With its ample power provisions, the SX-434 drives up to two independent pairs of stereo speaker systems, one pair at a time or both together. Ideal for powering those remote speakers. PRECISE RIAA EOUALIZATION The two-stage direct-coupled NF (Negative Feedback) design of the phon-o equalizer in the SX-434 enables audio reproduction of records within ±1dB deviation from the RIAA characteristic curve. CLICK-STOP TONE CONTROLS The BASS and TREBLE tone controls are the click-stop type for convenience in adjustment. OTHER FEATURES The control capabilities of the SX-434 are ideal for the average hi-fi set-up: it handles a turntable, tape deck, microphone, AUX and has an output jack for stereo headphone. The provided LOUDNESS contour switch enhances freauencv resoonse at low-volume levels. SX-434 SPECIFICATIONS AMPLIFIER SECTION Continuous Power Output 40Hz to 20KHz 15 watts+15 watts (8 ohms), (Both channels driven): 15 watts+15 watts (4 ohms) 1KHz (Both channels driven): 16 watts+16 watts (8 ohms), 18 watts+18 watts (4 ohms) Harmonic Distortion: Less than 0.8% (continuous power output) Less than 0.1% (1 watt+l watt, power output) Intermodulation Distortion: Less than 0.8% (continuous power output) Less than 0.1% (1 watt+l watt, power output) Power Bandwidth:10Hz to 70KHz (H.D. 0.8%) (IHF, both channels driven) Output Speaker: A, B, A+B (4 to 16 ohms) Headphone:4 to 16 ohms Damping Factor: More than 25 (1KHz, 8 ohms) Residual Hum & Noise: Less than 0.5mV (8 ohms, pre & power amplifier) Input Sensitivity/Impedance PHONO: 2.5mV/50 Kohms PHONO Overload Level (rms/P-P): l00mV/280mV MIC: l0mV/90 Kohms AUX: 150mV/80 Kohms TAPE PB: 150mV/80 Kohms TAPE PB (DIN connector): 150mV/80 Kohms Output Level/Impedance TAPE REC:150mV TAPE REC (DIN connector): 30mV/80 Kohms Frequency Response PHONO (RIAA equalization): 30Hz to 15KHz±ldB AUX, TAPE PB:30Hz to 25KHz ± ldB Tone Control BASS:+9dB, -8dB (100Hz) TREBLE:+5dB, -7dB (10KHz) Loudness Contour:(volume control set at -40dB position) +10dB (100Hz), +5dB (10KHz) Hum & Noise (IHF, short-circuited A network): PHONO: More than 70dB MIC:More than 65dB TUNER, AUX, TAPE PB:More than 90dB 66 NMJ K* FM TUNER SECTION Usable Sensitivity (IHF):1.9µV Capture Ratio (IHF): 1.0dB Selectivity (IHF): 60dB Signal-to-Noise Ratio: 70dB Image Rejection: 60dB (98MHz) IF Rejection: 90dB (98MHz) Spurious Rejection: 75dB AM Suppression: 50dB Harmonic Distortion: Mono; less than 0.2%, Stereo; less than 0.4% Frequency Response:20Hz to 15KHz +0.2dB, -2.0dB, 50Hz to 10KHz +0.2dB, -0.5dB Stereo Separation:More than 40dB (1KHz), More than 30dB (50Hz to lOKHz) Sub Carrier Suppression:40dB Antenna Input: 300 ohms balanced and 75 ohms unbalanced Muting: ON-OFF AM TUNER SECTION Sensitivity:300 µV/m (IHF, ferrite antenna), 15µV (IHF, ext. antenna) Selectivity: 35dB Signal-to-Noise Ratio: 50dB Image Rejection: 40dB IF Rejection: 50dB SEMICONDUCTORS FET:1 ICs:3 Transistors:27 Diodes:13 MISCELLANEOUS Power Requirements:U.S.A. and Canada model; 120V 60Hz only or 220V 50Hz only or 110, 120, 130, 220, 240V (switchable FM de-emphasis) 50-60Hz Power Consumption: 75 watts (KCU), 110 watts Dimensions:Without package: 430(W) x 140(H) x 347(D) mm 16-15/16 (W) x 5-1/2 (H) x 13-21/32 (D) inches With package: 512 (W) x 223 (H) x 430 (D) mm 20-5/32 (W)x8-25/32 (H)x 16-15/16 (D)inches Weight: Without package: 8.1 kg/17 lb. 14 oz. With package: 9.1 kg/20Ib. 1 oz. Grüße, Stephan [Beitrag von Stephan200TD am 12. Mai 2008, 16:00 bearbeitet] |
schöner Klassiker: Pioneer SX 434 Receiver Stephan200TD am 02.03.2009 – Letzte Antwort am 11.03.2009 – 7 Beiträge |
Pioneer Receiver SX-737 und SX-535 the_reaper am 21.10.2013 – Letzte Antwort am 10.11.2013 – 4 Beiträge |
Pioneer SX-300W Kaster am 02.05.2007 – Letzte Antwort am 20.05.2007 – 6 Beiträge |
Pioneer SX-737 stux am 02.09.2007 – Letzte Antwort am 10.09.2007 – 3 Beiträge |
Receiver Pioneer SX-5570 hank_mo am 10.10.2007 – Letzte Antwort am 30.10.2007 – 3 Beiträge |
Pioneer SX-535 Kaster am 03.02.2009 – Letzte Antwort am 03.02.2009 – 2 Beiträge |
Pioneer SX- 750 abzugeben! De_Niro_Fan am 27.10.2011 – Letzte Antwort am 09.11.2011 – 3 Beiträge |
Pioneer Stereo-Receiver SX-339 bluesmanheide am 10.05.2007 – Letzte Antwort am 15.07.2008 – 3 Beiträge |
Pioneer SX-S30DAB in Schwarz - wie neu Hannichipsfrisch am 13.05.2017 – Letzte Antwort am 11.06.2017 – 2 Beiträge |
AV-Reciever: Pioneer VSX-D514 in Silber blackblade85 am 01.02.2008 – Letzte Antwort am 02.02.2008 – 5 Beiträge |
Top 10 Threads in Verstärker / Receiver der letzten 7 Tage
- Stage Line Sta 320 PA/Subwooferendstufe
- Pioneer A 605 R
- PRO-JECT 7 AMP - Der audiophile Purist mit Phono Vorstufe im Traumzustand
- High End Mono Endstufen Blöcke - ICEpower - Jeff Rowland 201 Klone
- Sovereign Director Signature Series, night-shadow, Bestzustand
- ASR Emitter I HD High End Vollverstärker inkl. Phono/Power Suppl
- Lyngdorf TDAI 2170 mit 4K HDMI und USB Board
- Pioneer A-A9-J Verstärker grau
- Yamaha RX-A6A AV-Receiver in der Farbe schwarz
- Röhrenamp Music Angel XD SE - KT88
Top 10 Threads in Verstärker / Receiver der letzten 50 Tage
- Pioneer A 605 R
- Registrierte Mitglieder930.991 ( Heute: 4 )
- Neuestes Mitgliedcinisi
- Gesamtzahl an Themen1.564.370
- Gesamtzahl an Beiträgen21.852.046
