Biete Vor-/Endkombi Nuprime DAC-9/STA-9 in schwarz
taubeOhren
#1 erstellt: 04. Jul 2018, 16:11
Preis (Pflichtangabe!): VB 1299,-€ als Bundle (Einzeln DAC-9 699,- und STA-9 649,-)
Standort: Berlin
Zustand: Gebraucht
Artikelbeschreibung:
Biete Nuprime DAC-9 (Vorstufe/Dac) in schwarz. Techn./Opt. sehr gut.
Rechnung (5/17), OVP vorhanden sowie Nuprime STA-9 (Stereo-Endstufe) in schwarz. Techn./Opt. sehr gut.
Rechnung (9/17), OVP vorhanden.
DAC-9
Inputs:
1 x USB PCM / DSD Digital (PCM up to 384kHz & DSD up to DSD256 )
1 x Coaxial Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64)
1 x Optical Digital S/PDIF (PCM up to 192KHz supporting DoP format DSD64)
1 x Bluetooth or WiFi receiver module (optional).
1 x AES balance XLR
1 x Analog Stereo RCA (does not go through A2D conversion, analog input is selected by the preamp directly to analog outputs)
Outputs:
1 x pair of stereo RCA out (max output 4V)
1 x pair of stereo XLR balanced out (max output 8V)
1 x Optical S/DPIF out
USB Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz(64), 5.6MHz(128), 11.2MHz(256)
S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz, 352.8KHZ, 384KHz (Coaxial)
Bit Resolution: 16-32-bits
THD+N: 0.0015%
Dynamic range: >-113dB
Frequency Response: 10Hz to 80kHz
Dimensions: 235 mm W x 281 mm D x 55 mm H (including feet)
Weight: 2.3Kg
Worldwide AC voltage: (90VAC~130VAC // 210VAC~ 250VAC) With Voltage Select Switch
AC Fuse: Slow-blow, 1A, 250VA
STA-9
nputs:
RCA: Un-Balanced input x 1
XLR: Balanced input x 1
Outputs:
Stereo Speaker Out x 1 or
Mono Speaker Out x 1
Power: 2 X 120W / 1 X 290W an 8 & 4 Ohms
Peak Output Power: 2 X 280W / 1 X 320W an 8 & 4 Ohms
Input Impedance: 47k Ohms
Input sensitivity: 232.8mV, 1W an 8 Ohms; 1.4V to rated power
Gain: x 22
Signal to Noise Ratio: < -95dB at 1W, 10W, 100W
THD+N: 0.02% (Stereo) / 0.01% (Mono)
Frequency Response: 10Hz to 50kHz
Worldwide AC voltage: (115 VAC / 230 VAC) with Voltage Select Switch
AC Fuse: Slow-blow, 3A, 250VAC
Dimension: 235 mm W x 281 mm D x 55 mm H (including feet)
Weight: 4.75 kg
Die ist ein Privatverkauf - keine Garantie oder Rücknahme. Abholung oder versicherter Versand per DHL (zu Lasten des Käufers)
taubeOhren
20180615_162520
20180615_162547
20180629_152538
20180629_152632
20180629_153231
20180629_153558
taubeOhren
#2 erstellt: 14. Dez 2018, 07:55
Moin,
die Endstufe STA-9 ist verkauft. Bleibt also nur noch
DAC-9/Vorstufe
Inputs:
1 x AES balance XLR
Outputs:
THD+N: 0.0015%
Weight: 2.3Kg
Preis 509,-
taubeOhren
NuPrime DAC-9 DAC-Vorstufe mit PCM384 und DSD256
taubeOhren am 07.01.2019  –  Letzte Antwort am 28.01.2019  –  2 Beiträge
Denon 2106, Wharfedale CS 9 und DFS 9
frale am 17.10.2005  –  Letzte Antwort am 04.11.2005  –  16 Beiträge
Biete Infinity Kappa 9 in Rosenholz
manson am 08.01.2005  –  Letzte Antwort am 04.03.2005  –  62 Beiträge
B&W CDM 9 NT
TGA am 09.01.2005  –  Letzte Antwort am 14.01.2005  –  5 Beiträge
Metz 16:9 TV
Schmidrainer am 10.03.2006  –  Letzte Antwort am 19.03.2006  –  6 Beiträge
Yulong U100 USB DAC/Kopfhörerverstärker schwarz
Phln909 am 05.11.2012  –  Letzte Antwort am 08.11.2012  –  2 Beiträge
Ultrasone Edition 9 [verkauft]
Matzio am 17.10.2010  –  Letzte Antwort am 28.10.2010  –  2 Beiträge
Rollo Leinwand 16:9
wusel123 am 04.12.2023  –  Letzte Antwort am 15.02.2024  –  3 Beiträge
Biete SEG 16:9 Fernseher inkl. Stand
740er am 26.11.2006  –  Letzte Antwort am 29.11.2006  –  4 Beiträge
16:9 TV - Interesse ???
divehansen am 27.06.2005  –  Letzte Antwort am 28.06.2005  –  3 Beiträge
  • Registrierte Mitglieder928.864 ( Heute: 1 )
  • Neuestes MitgliedProgrammir_saKr
  • Gesamtzahl an Themen1.559.173
  • Gesamtzahl an Beiträgen21.719.346
