Biete DA-Wandler:miniDAC(PCM1798) with headphone Amp
ufozhp
#1 erstellt: 02. Jan 2007, 20:52
Hello
I am selling one of my beloved miniDAC(in Duesseldorf). I bought it in October (2006). It is still in mint condition.( no scratch).
It is only 1.25KG which is ideal for laptop or mini CD player
You may find original price of this miniDAC is 250 Euro or 350 Dollar + shippment
http://cgi.ebay.de/S...Z14974QQcmdZViewItem
http://cgi.ebay.de/S...eZWD1VQQcmdZViewItem
Asking 160 Euro+shipment
4 Euro is insured shipping fee inside Germany
My feedback (forum)
http://www.head-fi.org/forums/showth...hlight=serotec
1. This Audio Device is designed and Developed by our engineers team over 4 years. This circuitary is based on PCM179X digital analog converter which has been improved, tuned and calibrated to make it performs at the best.
2. Sound Characteristics: Great Dynamic Range, Wide and Deep Soundstage, amazing details and sweet natural sound. Pair with high end headphones and audio components will let you enjoy the pleasure of high fidelity audio
3. The power supply is specially designed by using non-conventional technique, self developed T-Shaped RCR filtering network and also separate power supply section of each sections, to ensure power supply purity and naturalness of sound. Analog I/V conversion utilizing special developed I/V conversion module which comprise of audio grade JFET. The module is completely covered by metal case. With this module, sweet natural sound can be ensured with no listening fatigue.
4. Digital Signal Input go through into buffer which can effectively reduce jitter.
5. Power Supply utilizing custom made high performance EI transformer which is the basis of beautiful sound. After commutation, 3 pieces of ELNA Audio Grade Large Capacitors will do the filtering. After voltage stabilized will go through the filtering network which comprises of NICHICON MUSE Audio Grade Capacitors and high precision resistors. as much as 9 pieces of high speed capacitors were used into the digital circuit, such capacitors can only be found in a few European High End Audio Devices. Resistors comprises of DALE and KOA high precision resistor, some circuit uses the Western Electric High Class resistors.
6. The digital receiver of this item comprises of 74VHCU04 Hex Inverter and CS8414. Digital Analog converter is PCM1798, I/V conversion using self-developed JFET module, analog output stage using OPA604.
7. This item not only high performance DAC but also a high performance headphone amplifier too. The amp uses high current JRC4560D. the potentiometer is custom made in Taiwan. The DAC also has analog RCA output to connect to high end headphone amp or power amplifier for users who demand even higher performance.
8. Featuring dealy switch on capability and headphone protetion, to ensure safety of your headphones and speakers.
The figure shows as the follows:
PCM1798
THD:0.0005%
Dynamic Range: 120dB
Signal-to-noise ratio(S/N):110dB
Input Voltage: 220-240VAC
Input: Coaxial SPDIF Only
Frequency Response: 20-20kHz -0.08dB
Dimensions: 100x200x55mm
Weight: 1.3kg
http://i143.photobucket.com/albums/r130/serotec/120_154073.jpg
http://i143.photobucket.com/albums/r130/serotec/120_154074.jpg
http://i143.photobucket.com/albums/r130/serotec/120_130380.jpg
http://i143.photobucket.com/albums/r130/serotec/120_130381.jpg
http://i143.photobucket.com/albums/r130/serotec/120_130379.jpg
[Beitrag von ufozhp am 02. Jan 2007, 21:02 bearbeitet]
Biete CD160
stallion007 am 12.12.2008  –  Letzte Antwort am 30.12.2008  –  7 Beiträge
Biete: Cambridge Azur 840C
scrooge am 04.07.2011  –  Letzte Antwort am 19.07.2011  –  2 Beiträge
Biete Denon 3930 silber
DerMicha am 03.06.2008  –  Letzte Antwort am 04.06.2008  –  2 Beiträge
Biete Humax iCord 160GB
buzzzer am 10.03.2009  –  Letzte Antwort am 13.03.2009  –  3 Beiträge
Biete Siemens RH 777
stallion007 am 05.06.2009  –  Letzte Antwort am 28.03.2010  –  3 Beiträge
Biete: Slim Devices Transporter
topa am 20.12.2006  –  Letzte Antwort am 27.12.2006  –  2 Beiträge
Biete Scheu Laufwerk (geschlossen)
Tommes_Tommsen am 07.04.2013  –  Letzte Antwort am 28.06.2013  –  10 Beiträge
Biete TEAC UD-H01 DA Wandler -erledigt-
jakef am 10.08.2013  –  Letzte Antwort am 17.08.2013  –  2 Beiträge
Biete Sony DVP S335
740er am 14.08.2006  –  Letzte Antwort am 21.01.2007  –  25 Beiträge
Biete Marantz DV 4400
Bjoern2500 am 06.12.2006  –  Letzte Antwort am 11.12.2006  –  18 Beiträge
2007
  • Registrierte Mitglieder929.723 ( Heute: 7 )
  • Neuestes MitgliedMüRo2025
  • Gesamtzahl an Themen1.561.071
  • Gesamtzahl an Beiträgen21.766.553
Top Hersteller in Quellen / Abspielgeräte Widget schließen
