Buffalo Link Theater PC-P3LWG/DVD Verkauft !!!
revenant1969
#1 erstellt: 22. Feb 2007, 17:16
Das Gerät dürfte dem einen oder anderen bekannt sein.
Garantie ist noch bis Ende November 2007
Wurde max. 10 Stunden benutzt.
Preis 199€ VB
Technische Daten:
Content Formats Disc Contents Formats (Media): DVD-Video, Video CD, Super Video CD, Audio CD (CD-DA)
File/Contents Formats (Media):
Digital Audio File Formats: MP3, WMA, Ogg, WAV (non-compiled)
Picture File Formats: JPEG, GIF, TIF, BMP, PNG
AVI File Formats: DivX (Ver. 3.11.4.5), RMP4, XviD+MP3/AC3
Video File Formats: MPEG-1, MPEG-2, WindowsMediaVideo9
Video Formats Digital Video Compression Formats:
MPEG-2 (DVD-Video, Super Video CD, *.MPG file) –
Max. Bit Rate: 15Mbps, Frame Rate: Max. 30fps
MPEG-1 (Video CD, *.DAT file) – Max. Bit Rate: 15Mbps, Frame Rate: Max. 30fps
MPEG-4 (*.AVI file, *.MP4 file) – Max. Bit Rate: 4Mbps (DivX), 5Mbps (RMP4), 8Mbps (XviD),
Windows Media Video (*.WMV file, *.ASF file) – Max. Bit Rate: 8Mbps,
Digital Audio Compression Formats:
Dolby Digital (AC-3) Multi-Channel (Digital Output Only, No Decoding Feature)
DTS Multi-Channel (Digital Output Only, No Decoding Feature)
MPEG-1 Audio Layer 1 2 Channel
MPEG-1 Audio Layer 2 Multi-Channel
MPEG-1 Audio Layer 3 2 Channel
MPEG-4 AAC (Low Complexty) 5.1 Channel
Windows Media Audio 9 (HD) 2 Channel
Digital Audio Non-Compression Formats:
Renear PCM 2 Channel, (S/P DIF) 16/20/24 bit, 44.1/48/96kHz
Audio Formats CD-DA, Renear PCM (*.WAV), Ogg Vorbis (*.OGG), MPEG-1 Audio Layer-3 (*.MP3),
Windows Media Audio (*.WMA), MPEG4-AAC (*.M4A)
Picture Formats JPEG (Baseline JPEG only), GIF, TIFF, BMP, PNG
File Extensions Video Files - dat, mpg, mpe, mpeg, m2v, m1v, vob, avi, divx, xvid, rmp4, mov, mp4, vro, m4v,
m2p, (in network mode) hnl, wmv
Audio Files - mp3, mp2, ogg, wav, aac, wma, pls, m4a, ac3, mp1, mpa, asf
Picture Files - jpg, gif, bmp, tif, png
File Extensions Video Files - dat, mpg, mpe, mpeg, m2v, m1v, vob, avi,divx, xvid, rmp4,mov, mp4, vro, m4v,
(via LinkStation) m2p,hnl, wmv
Audio Files - mp3, mp4, ogg, wav, aac, wma, ac3, m4a, aac, asf
Video Output Signals DA Converter – 12bit/54 MHz
Composite Video – 1.0Vp-p / 75 Ω
S Video – Y Output: 0.7Vp-p / 75 Ω; C Output: 0.3Vp-p / 75 Ω
Progressive/Scan – Y Output: 1.0Vp-p / 75 Ω; Pb Output: 0.7Vp-p / 75 Ω;
Pr Output: 0.7Vp-p / 75 Ω
50
Product Specifications continued
Audio Output Signals DA Converter – 24bit/192 MHz
Signal Noise >90 dB (1kHz)
Dynamic Range >80 dB (1kHz)
Mixed Noise >80 dB (1kHz)
Crack/Noise >-65 dB (1kHz)
Rear Panel Input/Output Video Output, S-Video Output, Component Video Output (Progressive Scan),
D4 Video Output,
Composite Audio Output, Composite Video Output, Digital Audio Output,
Digital Coaxial Audio
Output, Ethernet Port (100 Base-TX / 10Base-T), AC Adapter Input
SCART(External Adapter)
Network Interface (Wired)
Interface (10BASE-T) IEEE802.3, (10BASE-TX) IEEE802.3u
Supporting Protocol TCP/IP (HTTP) Setup Features, AppleTalk
Connector Type RJ-45 8 pin (NIC mode) x 1
Access Method CSMA/CD
Transfer Rate (Auto Sensing) 10 Mbps 100 Mbps
Network Interface (Wireless)
Standards IEEE802.11g/IEEE802.11b; ARIB STD-T66
Frequency 2,412 - 2,472 MHz (11channel)
Data Transfer Rate 6, 9, 12, 18, 24, 36, 48, 54 Mbps (IEEE802.11g); 1, 2, 5.5, 11 Mbps (IEEE802.11b)
Access Method Infrastracture Mode
Antenna Internal Diversity Antennas x 2
AOSS Technology AOSS button x 1 (on the front panel)
Security WEP 128 (104) / 64 (40) bit (Security can be set up by AOSS technology when you have a
Buffalo AOSS enabled router or access point.)
USB Interface
Interface USB 2.0/1.1
Controller VIA VT6212L
Data Transfer Speed 480 Mbps
Connector Type Series A x 1 (Front x 1)
DVD-ROM
Interface ATAPI
Bei Interesse PN
revenant1969
#2 erstellt: 24. Feb 2007, 08:47
Dann machen wir mal ein Preisupdate !
VB 150,-€
Das Teil ist unbenutzt, Klasse Netzwerk Mediaplayer nur ohne Netzwerk macht er keinen Sinn mehr.
amathi
#3 erstellt: 24. Feb 2007, 13:51
hi,
kannst du mal ein foto von vorne und hinten machen?
mfg adi
revenant1969
#4 erstellt: 24. Feb 2007, 15:00
Hm, ich habe keine Kamera um ein Bild zu machen. Schau doch einfach auf folgender Seite nach:
http://www.buffalo-technology.de/support/downloads-product.php
Dann als Produkt: PC-P3LWG/DVD dort ist auch die Bedienungsanleitung hinterlegt etc.
Es ist auf der Vorderseite sogar noch die Folie drauf !
amathi
#5 erstellt: 25. Feb 2007, 16:22
hi,
kann da nur den p4 finden, keinen p3.weißt du was bei den beiden der unterschied ist?
mfg adi
revenant1969
#6 erstellt: 25. Feb 2007, 18:40
Ne den P4 kenne ich net. Aber wenn du auf der Seite bist dann kannste den auswählen. Steht über dem P4. Wenn du den auswählst kommst du zu allen Downloads mit Bedienung und Produkt Flyer.
Ansonsten kannste dir denn auch in Natura anschauen, ich komme aus Haiger.
revenant1969
#7 erstellt: 27. Feb 2007, 17:11
So nun ein letztes mal 130,-€ FP
amathi
#8 erstellt: 01. Mrz 2007, 22:56
hi,
wie gut ließ er sich denn ins netzwerk integrieren?
mfg adi
revenant1969
#9 erstellt: 02. Mrz 2007, 17:09
Hm, wie darf ich die Frage verstehen ?
Na eigentlich IP Adresse rein und schon ist er im Netzwerk....
Was willst du denn genau wissen ? Vorteil bei dem Gerät ist, wenn man eine Link Station Festplatte hat, muß man keinen Rechner mehr laufen lassen sondern nur noch die Festplatte und kann dort Musik,Bilder etc. drauflegen und sich dann über das Gerät holen.
Oder aber man hat nen Rechner an, dann holt man sich die Daten über den Rechner.
Hier nochmal die Bildformate über YUV Ausgang bis 720p
Fernseherformate und -auflösungen
NTSC Vertical scan frequency 60Hz, 525 line
PAL Vertical scan frequency 50Hz, 625 line
DVD-Video 720 pixel x 480 line
Super VideoCD 480 pixel x 480 line
VideoCD 352 pixel x 240 line
MPEG2? 1920 pixel x 1080 line
MPEG2 720 pixel x 480 line
MPEG4 1280 pixel x 720 line
MPEG4 720 pixel x 480 line
WMV9 1280 pixel x 720 line
Wenn jemand Interesse an dem Kombi hat .... würde ich die Platte Link Station 120 GB dazu abgeben, Player + Platte zusammen dann 270,-€
[Beitrag von revenant1969 am 02. Mrz 2007, 17:28 bearbeitet]
Megatrons
#10 erstellt: 02. Mrz 2007, 20:09
hi,
Spielt er HDV(HDTV)Files ab (M2T)
Gruss
revenant1969
#11 erstellt: 02. Mrz 2007, 20:14
Tut mir leid ...keine Ahnung ...ich habe im ersten Post die ganzen Formate drin die er spielen kann.
[Beitrag von revenant1969 am 02. Mrz 2007, 20:16 bearbeitet]
amathi
#12 erstellt: 02. Mrz 2007, 22:06
hi,
meinte ob er probleme beim streamen gemacht hat z.b.
ich habe desöffteren schon gehört das netzwerk-player ab und zu(manche wie z.b. den kiss 600) sich schlecht ins netztwerk integrieren lassen.deine 120 gn festplatte ist mir leider ein wenig klein.
mfg adi
revenant1969
#13 erstellt: 03. Mrz 2007, 09:07
Ne bei dem kein Thema, nur wenn ich das Netzwerk dicht mache z.B. über den MCE Manager und 8 Kanälen Streame (Dbox 2) und will Musik hören ...dann wird es eng. Hängt aber mit dem Datenvolumen zusammen was dann gesamt übers Netzwerk geht.
verkauft
ingo74 am 03.12.2013  –  Letzte Antwort am 08.12.2013  –  2 Beiträge
Verkauft!
JokerofDarkness am 18.08.2011  –  Letzte Antwort am 24.08.2011  –  2 Beiträge
Verkauft!
neo-one am 27.02.2017  –  Letzte Antwort am 02.03.2017  –  2 Beiträge
verkauft........
hornet25 am 17.11.2012  –  Letzte Antwort am 01.12.2012  –  3 Beiträge
Onkyo DVD-Player (verkauft)
Luke66 am 01.11.2009  –  Letzte Antwort am 05.11.2009  –  2 Beiträge
Verkauft: Denon DVD 1940
syncronizer am 08.01.2013  –  Letzte Antwort am 24.01.2013  –  4 Beiträge
verkauft
koli am 30.06.2009  –  Letzte Antwort am 14.07.2009  –  13 Beiträge
Verkauft...
Neofight am 03.01.2007  –  Letzte Antwort am 04.01.2007  –  4 Beiträge
verkauft
ingo74 am 11.02.2012  –  Letzte Antwort am 19.02.2012  –  3 Beiträge
[verkauft]Harman Kardon DVD 22
Akalazze am 21.10.2008  –  Letzte Antwort am 27.10.2008  –  3 Beiträge
  • Registrierte Mitglieder930.676 ( Heute: 5 )
  • Neuestes MitgliedPeterMal
  • Gesamtzahl an Themen1.563.501
  • Gesamtzahl an Beiträgen21.827.236
