Citypulse DA7.2x II TCXO [ DAC, Preamp, KHV All-In-One ]
Gelscht
Gelöscht
#1 erstellt: 29. Jan 2008, 20:31
CityPulse DA7.2x II TCXO Upgrade
NEW VERSION II! Citypulse has made an excellent DAC even better with tighter bass and warmer midrange!
Often compared to the well-known Benchmark DAC1, the Citypulse Audio DA7.2x Digital to Analog Converter (DAC) has gained an international following and reputation as the best-value D/A converter available. That's no surprise, given that the Citypulse 7.2x sells for less than a third of DAC1's thousand-dollar-plus price tag, yet delivers sound that rivals and, according to many, surpasses much more expensive DACs.
A versatile component, the Citypulse 7.2x has motorized volume, and optical, coaxial and analog auxiliary inputs, all selectable from the front panel or remote control. It accepts input from two digital and one analog source and can easily double as a preamp. Inside you'll find quality components from Wima, Evox and Rubycon. The PCM-1796 DAC chip from Texas Instruments is used for high-quality conversion at high bit rates while the digital input is a CS8416 IC from Crystal Semiconductor. Extremely well constructed with an extruded aluminum case with 6mm thick machined aluminum front panel, the compact size of the DA7.2x lends itself to easy placement.
This Citypulse DAC can be used to upgrade your existing CD player if it has a digital output or it can be connected to a DVD player for an improved output stage.
OPTION: TCXO Clock Upgrade for even deeper and better-controlled bass, better resolution, faster transients, more texture and a much larger soundstage. (And you get to keep the old clock, just in case you like it better)
Audiomagus is an authorized Citypulse Dealer
Stylishly designed and well-constructed (with matching remote control) the Citypulse 7.2x delivers:
* 24-Bit/192kHz performance
* User selectable from front panel buttons or remote control
o Volume
o Input (Optical. Coaxial or Auxiliary)
o Frequency (44.1 KHz or 88.2 KHZ)
o Mute
* Balanced XLR and Single-ended RCA analog outs
* Class A transistor output stage
* Headphone amp and front jack
o Perfect for a range of headphones, including mid- to low-impedance and high sensitivity
* Dual voltage operation 115/230V
* Burr Brown PCM1796 D/A Converter
* CS8416 192 kHz Digital Audio Receiver
* Remote control (This is no plastic gadget. It's made of a substantial pieces of CNC machined aluminum!)
* Volume control (motorized for remote; automatically turns down volume at start-up)
* Auxiliary RCA inputs (Selectable from front panel or remote control)
* TCXO Clock Upgrade
o Nominal Frequency: 33.868800Mhz
o Frequency Accuracy: <+/-1PPm
o Frequency Tolerance vs Temperature <+/- 1PPm
Specifications:
Digital coaxial input level 0.5vp-p
Input impedance 75Ω
Digital optical input level - 15 dBm
Digital encoder 24 bit / 192 KHz
D/A converter 24 bit / 192 KHz
Audio output 2.0v (1kHz, 0dB)
Xlr audio output 4.0v (1kHz, 0dB)
S/N 113dB
Dynamic range 116dB
THD 0019%
Frequency response
15Hz - 58kHz
Audio input 200mv (47kΩ)
Earphone impedance 32Ω - 600Ω
Power supply AC 110v or 220v(+/- 10%) 50/60Hz
Max power dissipation 60W
Dimension 9.8" x 11" x 2.4" (250mm x280mm x 62mm)
N.weight 10 lbs (4.5kg)
...habe den Citypulse nach den überragenden Stimmen bei audio magus in den USA bestellt, Kosten inkl. TCXO Upgrade, Versand, Zoll/MwsT ca. 360€.
Klingt auch hervorragend an K-701 und HD-650, jedoch bin ich nach mehrfachen Anläufen einfach kein Kopfhörer-Hörer.
Inkl. OVP, Fernbedienung, Toslink-Kabel, Rechung und Original Clock-Chip. (anderthalb Wochen jung).
PREIS: 330€ inkl.!
Gelscht
Gelöscht
#2 erstellt: 30. Jan 2008, 16:47
Sennheiser HD 650
Rechnung vom März 07, also nichtmal ein Jahr alt, Top-Zustand mit OVP, Zubehör und allen Unterlagen
Preis: 180€
Tapco S8
Aktiver Near/Midfieldmonitor mit 8" Tieftöner, Spitzenklang, 2x120W RMS. OVPs, Zubehör, Handbuch und Rechnung vorhanden.
Leichte Gebrauchsspuren, weniger tragisch.
Preis: 280€
passende Ständer (Klavierlack-Bodenplatte): 40€
AVM Evolution DAC1
Spitzen-Wandler mit AVM Evolution Vorstufe in einem Gerät.
Stereoplay 53-55 Pkt, Absolute Spitzenklasse I
Einwandfreie Funktion. mit XLR und Cinch Out.
Preis: 350€
Gelscht
Gelöscht
#3 erstellt: 30. Jan 2008, 16:53
...ich suche ein Paar Canton Ergo SC-L in Buche oder Schwarz, wenn jemand einen Sony TA-FA7ES Verstärker hat, bitte auch melden!
lite audio dac-am DAC und KHV - wie neu!
noexen am 14.12.2008  –  Letzte Antwort am 18.12.2008  –  5 Beiträge
Marantz HD-DAC1 (DAC, KHV, VV) *reserviert*
spawnsen am 20.12.2014  –  Letzte Antwort am 06.02.2015  –  2 Beiträge
MATRIX Mini-i // Klasse DAC/KHV
H3liX am 03.07.2015  –  Letzte Antwort am 21.07.2015  –  3 Beiträge
Audiolab 8200CDQ silber (DAC Preamp CD Player), neuwertig
Nielsen am 08.06.2014  –  Letzte Antwort am 24.06.2014  –  5 Beiträge
Musical Fidelity V-DAC II [verkauft]
aldi2106 am 09.11.2013  –  Letzte Antwort am 30.11.2013  –  2 Beiträge
DAC
ABI am 22.02.2010  –  Letzte Antwort am 28.02.2010  –  2 Beiträge
Parasound DAC 800
olli-tourguide am 02.10.2007  –  Letzte Antwort am 21.10.2007  –  2 Beiträge
MF V-DAC + V-PSU II (Preisupdate Nr.1)
raybanner am 04.10.2012  –  Letzte Antwort am 05.11.2012  –  6 Beiträge
HRT Music Streamer II USB DAC D/A Wandler
sakana am 02.07.2011  –  Letzte Antwort am 06.07.2011  –  2 Beiträge
Beresford TC-7520SE Caiman DAC
raz86 am 04.06.2012  –  Letzte Antwort am 17.06.2012  –  4 Beiträge
  • Registrierte Mitglieder930.676 ( Heute: 1 )
  • Neuestes Mitgliedsoyay
  • Gesamtzahl an Beiträgen21.827.027
