JVC Pro-Series LCD´s LT-42X889/47X889/52X889, 1080p24, 120Hz, 12 Bit!
celle
#1 erstellt: 09. Apr 2008, 08:29
Im AVS-Forum wird schon fleißig über die kommende JVC-Top-Serie diskutiert. Erscheinen sollen sie im Sommer und leider nur im Fachhandel!
JVC’s NEW CLEAR MOTION DRIVE III ENGINE POWERS 2008 TOP-END PROCISION SERIES LCD TVs
New engine developed to meet the demands posed by ever-larger HD displays.
LAS VEGAS, January 6, 2008 – Underscoring its expertise in image processing technology, JVC today announced a new line of LCD televisions powered by a JVC-developed next-generation high definition engine, Clear Motion Drive III. The new full HD TVs are part of JVC’s recently launched Procision series, a product line that features the company’s most advanced technologies.
At the heart of the new JVC HD engine is the company’s new Genessa 32-bit processor – sixth generation technology and now with significantly higher processing capacity. The results are accurate, vividly colored images and superb motion image quality – critical performance parameters under any conditions, but especially so with high-resolution large-screen displays.
The new JVC Procision LCD TV series is comprised of three 1080p models – the 42-inch LT-42X899, the 47-inch LT-47X899 and the 52-inch LT-52X899. They will be available in late spring exclusively through JVC’s network of Procision dealers.
By developing a sophisticated new image processing algorithm and greatly increasing the bit accuracy of the image processing engine, JVC’s new Procision series LCDs meet the needs created by new-format high-quality sources, display panel evolution beyond 10 bits and the accelerating trend toward larger and larger screens. Several technologies were involved in the development of JVC’s new Clear Motion Drive III engine.
1.Real 36-bit (12 bit x 3) Image Processing – The engine’s digital image processing accuracy has been greatly increased. It handles 36-bit Deep Color input at 12 bit x 3 for R, G and B. This allows the engine to achieve a 68-billion color expression capability without image deterioration from digitization.
2.Real Bit Driver bit extension technology – JVC’s new bit extension technology takes 8-bit images and turns them into images with 12-bit precision. JVC’s latest generation Genessa signal processing then applies 12-bit processing throughout the entire circuit to reproduce smooth, natural signal gradations without sacrificing the original HD signal.
3.i-Clear Motion noise reduction – Conventional 3D noise reduction, which provides a fixed level of noise reduction regardless of noise volume, works well when the image contains no movement, but creates blurring on moving images, and so common practice has been to turn off 3D noise reduction for moving images to avoid this blurring. JVC’s 3D NR improved on this with noise detection and automatic adjustment to deliver the optimum amount of NR. JVC’s new i-Clear Motion NR provides 3D NR for moving images by applying the high-precision motion prediction techniques of the company’s double-speed 120Hz Clear Motion Drive technology. In addition, JVC’s new NR technology detects noise volume in each frequency band. These innovations together provide automatic optimum noise reduction.
4. Intelligent HD processing – Further improvements in JVC’s Genessa image processing includes Intelligent Gamma, which fine-tunes contrast in light and dark areas; Intelligent Clear, which ensures crisp, low-noise images; and Real Color Creation, which analyzes the color distribution of each image in real time and reproduces the images the viewer focuses on with more intensely real colors.
5. x.v.Color-enabled signal processing – JVC developed its own x.v.Color-enabled signal processing circuity to support the xvYCC international color space standard. This technology makes full use of the displays’ capabilities to produce perceptions of depth-of-field and texture.
In addition to the new Clear Motion Drive III engine, the JVC Procision LCD TV line features a host of other technologies. These include a 120 frames per second frame rate and full HD 24/30p. There are nine video aspect modes, an ATSC/QAM tuning system with a Quick Start-up mode and an illuminated universal remote with direct input access. Also new is a re-designed on-screen display.
Each set includes a full complement of interfaces: three HDMI (v1.3) inputs – two with CEC support, two component inputs, two S-Video inputs, SPDIF input, AV output, PC input, RS-232C interface and an IR (IR receiver) interface. A USB PhotoViewer allows viewing of JPEG photos stored on USB memory.
The sound package for the Procision LCDs includes a power output of 10 watts per channel, twin oblique cone speakers and JVC’s Max Audio sound technology for rich sound with the feel of powerful bass reproduction.
JVC’s new Procision LCD TVs will be available in early summer. Pricing will be announced at that time
celle
#2 erstellt: 09. Apr 2008, 08:40
Daten zusammengefasst:
- Clear Motion Drive 3
- Genessa 32Bit-Processor in 6. Generation
- 36 Bit Bildverarbeitung (3x12Bit) - 68 Milliard. Farben
- 12Bit Genessa-Bildaufbereitung für ruckelfreie Bilder ohne
Video-Look
- i-Clear Motion noise reduction - 3D-Rauschunterdrückung
- Genessa für exzellentes HD-Scaling und Deinterlacing
- x.v.Color und 36Bit-Unterstützung über HDMI 1.3
- 120/100Hz, 1080p24
- 3 x HDMI 1.3
- Optical-Ausgang
- USB (für JPEG-Foto´s z.B.)
- 2 x 10W Oblique Cone JVC-Lautsprecher für bessere
Sprachverständlichkeit und JVC’s Max Audio sound technology
für die Bassanhebung
rsaudio
#3 erstellt: 09. Apr 2008, 14:44
Hört sich nicht schlecht!
mk1981
#4 erstellt: 09. Apr 2008, 20:15
Würd gern ma wissen wann die in deutschland erscheinen,
hatte auch ma einen bericht über die neue procision serie gelesen alerdings nur auf ner amerkianischen website, in deutschland im net wohl noch nichts zu lesen.
Weiss jemand mehr??
r.s1981
#5 erstellt: 03. Jun 2008, 20:34
Wann kommen die denn? Und sollen die auch so dünn sein wie die aktuelle Serie?
celle
#6 erstellt: 04. Jun 2008, 07:19
IFA abwarten. Haben dann auch bestimmt eine andere EU-Bezeichnung.
celle
#7 erstellt: 12. Jun 2008, 12:47
r.s1981
#8 erstellt: 12. Jun 2008, 13:08
13,5cm dick!!!
Da hatte ich mir die Hälfte erhofft!
coopersx9
#9 erstellt: 28. Jun 2008, 10:43
wann kommen die teile denn nun raus? Habe gelesen das der realese mitte juni ist
mC_rOMeo
#10 erstellt: 29. Jun 2008, 18:24
Gibt es dann auch neue Slime LCD`s der größe 42" mit der neuen Technik und 100Hz?
23jvc
#11 erstellt: 03. Jul 2008, 10:45
Von JVC noch kein offizieller Release-Termin.
Neue günstige JVC 120Hz LCD´s!
celle am 29.01.2007  –  Letzte Antwort am 22.02.2007  –  12 Beiträge
LCD ==> JVC LT-32C50BU <==
nelbi am 19.03.2005  –  Letzte Antwort am 23.06.2010  –  7 Beiträge
HD Ready / LCD´s / JVC LT-37M60
E-ELEVEN am 11.11.2005  –  Letzte Antwort am 11.11.2005  –  3 Beiträge
Neuheit: JVC LT-42/46S90 sehr schlanke FHD-LCD´s mit HDMI 1.3 und 1080p24!
celle am 06.01.2008  –  Letzte Antwort am 05.03.2009  –  195 Beiträge
JVC LT-32HB1
tommy.smile am 08.10.2009  –  Letzte Antwort am 19.11.2009  –  2 Beiträge
JVC LT - X70 BU
a1b2 am 25.04.2006  –  Letzte Antwort am 09.06.2006  –  14 Beiträge
JVC LT-40S70BU
cessi am 08.04.2006  –  Letzte Antwort am 27.09.2006  –  16 Beiträge
JVC LT-42S90BU
petres2006 am 28.04.2008  –  Letzte Antwort am 28.08.2008  –  14 Beiträge
JVC LT-32A80ZU
marx_vie am 06.06.2008  –  Letzte Antwort am 05.10.2008  –  12 Beiträge
JVC LT-37ED6SU
manu92 am 26.08.2007  –  Letzte Antwort am 29.08.2007  –  8 Beiträge
  • Registrierte Mitglieder930.929 ( Heute: )
  • Neuestes MitgliedMagic_Teddy
  • Gesamtzahl an Themen1.564.183
  • Gesamtzahl an Beiträgen21.845.991
