[V] Rockford Fosgate 801S (2-Kanal 800W RMS)
dforce
#1 erstellt: 30. Jun 2006, 09:08
Biete einen Rockford Fosgate 801S 2 Kanal Verstärker
Er ist technisch und optisch in gutem Zustand.
Nur die Madenschrauben sind teilweise bissl Murks!
Das ist das einzigste Bild das ich auf die schnelle gefunden habe.
Ich werde aber noch ein paar nachreichen!
Im Lieferumfang sind enthalten:
- Verstärker
- Abdeckkappen für die Kabel seitlich
- Remote Controll + Kabel
http://user.homeunix..._2005/5_P1010016.JPG
- MOSFET power, and proprietary technology bring out extraordinary detail in your music, driving your subs with precision and strength you just can't get from a lesser amp.
- 200 watts RMS x 2 at 4 ohms
- 400 watts RMS x 2 at 2 ohms
- 800 watts RMS x 1 bridged output at 4 ohms stereo or bridged mono output
- 4-ohm stable in bridged mode
- Tri-Way capable
- Signal to Noise Ratio: 100dB
- Bass Boost Frequency 45 Hz
- Low - Pass Frequency 50 Hz - 250 Hz (12 dB/octave)
- High - Pass Frequency 50 Hz - 250 Hz (12 dB/octave)
- THD at Rated RMS Power .05 %
- wiring and hardware not included with amplifier we recommend an 8-gauge amp wiring kit with a 60-amp fuse
- MOSFET power supply and output devices
- MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
- TOPAZ noise-killing differential inputs that eliminate 80% of ground loop noise
- Transana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
- NOMAD advanced protection circuitry for "intelligent" shutdown protection
wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz) speaker- and preamp-level inputs
Länge: 43,4cm
Breite: 25,0cm
Höhe: 6,1cm
PREIS VHB: 260,- EUR
dforce
#2 erstellt: 25. Jul 2006, 13:58
VERKAUFT !!
Rockford Fosgate Punch 801s
Dj-BBoy am 29.03.2008  –  Letzte Antwort am 03.04.2008  –  2 Beiträge
(V) Rockford Fosgate T15002 (((geschlossen)))
Ricricardo am 02.10.2012  –  Letzte Antwort am 03.11.2012  –  7 Beiträge
V: Rockford Fosgate 1501bd
shmajser am 17.02.2009  –  Letzte Antwort am 28.04.2009  –  15 Beiträge
[V] Rockford Fosgate Punch 500X
Dj_Ninja am 27.06.2005  –  Letzte Antwort am 30.06.2005  –  8 Beiträge
[V] Rockford Fosgate Punch 300X
Dj_Ninja am 26.11.2004  –  Letzte Antwort am 09.12.2004  –  14 Beiträge
Rockford Fosgate !!!!
MSC am 15.03.2006  –  Letzte Antwort am 17.03.2006  –  11 Beiträge
[V] Rockford Fosgate, Helix & Diverses
etaz2 am 01.09.2011  –  Letzte Antwort am 21.09.2011  –  3 Beiträge
Rockford Fosgate + Kove 2 Kanal Endstufen
Manuel_1988 am 12.11.2014  –  Letzte Antwort am 02.03.2016  –  23 Beiträge
Rockford Fosgate P4004 4-Kanal
neubicolt am 07.02.2006  –  Letzte Antwort am 13.02.2006  –  9 Beiträge
(V) Endstufe Rockford Fosgate T4004 (((geschlossen)))
Ricricardo am 05.09.2012  –  Letzte Antwort am 03.11.2012  –  10 Beiträge
2006
  • Registrierte Mitglieder928.835 ( Heute: 8 )
  • Neuestes Mitgliedpoggibonsi_100
  • Gesamtzahl an Themen1.559.104
  • Gesamtzahl an Beiträgen21.717.632
