jbl 600 gti 16cm (high end)
sikibalon
#1 erstellt: 17. Jun 2005, 21:17
wie oben beschrieben zwei high end tiefmitteltöner sehr selten und sehr gute lautsprecher..mit schutzgitter
preis vhb 240€ oder tauch gegen gebot..
daten:
Frequency Response: 45Hz – 3.5kHz
Recommended Minimum High-Pass Crossover Frequency
for High Power Operation: 50Hz
Continuous Power Handling With 12dB Passive Network
High Passed at Recommended Minimum Frequency: 300 Watts
Continuous Power Handling When Used Without
High-Pass (Subwoofer Operation): 75 Watts
Minimum Recommended Amplifier Power: 20 Watts
Maximum Recommended Amplifier Power Rating: 300 Watts
Sensitivity (2.83 Volts / 1 Meter): 90dB
Impedance: 4 Ohms
Dimensions – Woofer/Midbass Transducers:
Overall Maximum Diameter
(Mounting Tab to Mounting Tab): 71/2" (191mm)
Height: 3 7/32" (81mm)
Mounting Depth: 27/8" (73mm)
Cutout Size: 57/8" (149mm)
Weight: 4 lbs. 9 oz. (2.1kg)
Free Air Resonance (Fs): 56Hz
Electrical Damping (Qes): 0.60
Mechanical Damping (Qms): 6.40
Total Damping (Qt): 0.55
Equivalent Volume of Compliance (Vas): 0.455 cu. ft. (12.9 liters)
Effective Cone Area (Sd): 21.7 sq. inches (0.014 m2)
Center to Peak Linear excursion (Xmax): 0.250 in (6.35mm)
Voice Coil DC Resistance (Re): 3.5 ohms
Voice Coil Inductance (Le): 0.24mH @ 1kHz
Voice Coil Diameter: 2 inches (50.8mm)
Voice Coil Length (Winding Length): 0.650 inches (16.5mm)
Air Gap Height: 0.250 inches (6.35mm)
BL Product: 6.4 T/M
Effective Moving Mass (Mm): 0.606 ounces (17.2 grams)
JBL W10 GTi 25cm Subwoofer High-End
xtc_motz am 01.11.2011  –  Letzte Antwort am 23.11.2011  –  6 Beiträge
JBL 1200 GTI
bassgott am 27.05.2007  –  Letzte Antwort am 11.06.2007  –  6 Beiträge
JBL GTi W12 + weiteres
sthpanzer am 14.06.2007  –  Letzte Antwort am 29.07.2007  –  7 Beiträge
JBL W12 GTI
Luni_19 am 11.12.2007  –  Letzte Antwort am 18.12.2007  –  3 Beiträge
[V] JBL 1200 GTI
skywalker_81 am 09.12.2008  –  Letzte Antwort am 29.01.2009  –  38 Beiträge
JBL GTI w10
hg_thiel am 03.11.2009  –  Letzte Antwort am 15.12.2009  –  8 Beiträge
JBL GTI 1800
t.l.100 am 02.03.2010  –  Letzte Antwort am 24.03.2010  –  4 Beiträge
JBL -p1220e vs. JBL-GTI-1200
tamdrag am 23.10.2004  –  Letzte Antwort am 23.10.2004  –  2 Beiträge
JBL GTI + Audio System Radion
t.l.100 am 07.02.2009  –  Letzte Antwort am 08.02.2009  –  3 Beiträge
Hertz ESK 130+JBL GTI
t.l.100 am 24.02.2009  –  Letzte Antwort am 28.02.2009  –  17 Beiträge
2005
  • Registrierte Mitglieder930.676 ( Heute: 7 )
  • Neuestes MitgliedRemklep
  • Gesamtzahl an Themen1.563.504
  • Gesamtzahl an Beiträgen21.827.346
